I have a 60 x 160 mm prestressed reinforced concrete beam. The distance between the concrete and the centre of compression and tensions steel is 16 mm. One 7 mm prestressing bar is located 100 mm from the top edge of the beam. The question is how to find the location of the neutral axis and hence the second moment of area.
Kind Regards
