العودة   ملتقى المهندسين العرب - أول ملتقى هندسي عربي > الملتقى الهندسي > الهندسة الصناعية
الهندسة الصناعية بإشراف : محمد فوزى ، صناعي1
تعريف الجودة
LinkBack أدوات الموضوع التقييم: تقييم الموضوع: 4 تصويتات, المعدل 4.75.
قديم 12-06-2008, 12:27 AM   رقم المشاركة : [31 (permalink)]
عضو تحرير المجلة
الصورة الرمزية محمد حسن نصر
محمد حسن نصر
steps to get iso certificate
  • Educate Yourself
The first thing you should do is educate yourself on what ISO 9001:2000 Quality Management Standards (QMS) means, what certification entails, and how ISO certification will help your business. The best source of information is probably by purchasing a manual from your national standards association, or taking one of the many courses available through accredited certification bodies.
  • Preliminary Audit
You can perform your own preliminary audit using audit checklists available online as a guideline, or by preparing your own audit checklist based on the manual and training you received in step 1. Use this as a chance to evaluate how things are done now, versus what you would have to change in order to get certified. A lot of companies should already have in place laboratory manuals, health and safety procedures, staff training and orientation, production process manuals, quality control and other processes that need to be documented for ISO. You can use these same manuals.
  • Hire a Consultant
At this point, it might be prudent to hire a consultant, even for a one-day evaluation of your company, to make sure you’re on the right track. The consultant will perform his/her own audit and interview various members of the company to get an idea of what your company does and how things are done. You can then make an educated choice whether to let them continue with the certification process and prepare your documents for you, or whether you might be able to go it alone.
  • Establish Staff Roles
You need to establish the roles of various managers and staff in terms of who will be performing audits, who will maintain certain documents and who will conduct management reviews and implement improvements. All auditors should receive auditor training. In a large company, it might be cost-effective to have an accredited instructor come to you. Smaller companies can take advantage of the frequently offered public courses.
  • Prepare Process Diagrams
Most consultants will recommend you take this organizational approach to planning your application. The act of preparing process diagrams helps you visualize all the inputs and outputs of each product your company produces. This will aid in setting up controls and documentation for each step of each process.
  • Prepare Documentation
Take advantage of existing documentation in your company, as mentioned in step 2. You will likely find that some documents require updating or minor revisions. Implement these changes and then proceed to preparing your ISO 9001:2000 QMS Manual. In the manual, you outline how each of the QMS requirements are being met, by referring to the existing (or newly prepared) documents for daily tasks such as ordering, customer relations, production, R&D, quality control and more. This is the most time consuming step of becoming ISO certified.
  • Staff Training
Once the QMS manual is prepared and you have all documentation in place, it’s time to train the remainder of staff on the ISO process and what it entails. Passing the audit requires compliance at all levels. Ensure management recognizes their role in setting examples and motivating staff.
  • Pre-Certification Audit
Performing another internal audit ensures there will be no surprises when the external (third party) auditor comes. You could consider bringing back the consultant that you hired in step 3, to make sure you have understood and addressed all of his/her concerns. By now, you should find only minor non-compliance issues, if any. Address these now, and, if necessary, perform a second internal audit.
  • Certification Audit
Once you are satisfied you are complying with all the QMS requirements, you are ready for your third party audit by an accredited certification body. If you have followed the guidelines and everything is in place, you should hopefully pass your audit with flying colors!
Tips:
1. Don't make things more complicated than they need to be. Use existing documentation/manuals and keep the QMS Manual as simple as possible.
2. Talk to as many consultants as you can at the beginning, and take an auditor training course to make sure you don't overlook anything and are very familiar with what the auditors are looking for.
What You Need:
  • QMS Essentials Handbook
  • QMS Requirements booklet
  • QMS Fundamentals and Vocabulary booklet
  • A sample QMS auditor checklist
محمد حسن نصر غير موجود حالياً   رد مع اقتباس
قديم 17-07-2008, 12:25 AM   رقم المشاركة : [32 (permalink)]
الصورة الرمزية أنلييزر
أنلييزر يستحق التميز
بارك الله فيك بارك الله فيك
فى انتظار المزيد
أنلييزر غير موجود حالياً   رد مع اقتباس
قديم 26-07-2008, 11:47 AM   رقم المشاركة : [33 (permalink)]
الصورة الرمزية احمد صدقى
احمد صدقى يستحق التميز
الف شكر على هذه الملف الجميل
احمد صدقى غير موجود حالياً   رد مع اقتباس
قديم 26-07-2008, 08:51 PM   رقم المشاركة : [34 (permalink)]
الصورة الرمزية محمد مرتضى تمام
محمد مرتضى تمام يستحق التميز
مجهود مشكور
محمد مرتضى تمام غير موجود حالياً   رد مع اقتباس
قديم 19-08-2008, 11:15 AM   رقم المشاركة : [35 (permalink)]
الصورة الرمزية إبراهيم الفيتوري
إبراهيم الفيتوري يستحق التميز
السلام عليكم أختي بنت فلسطين
لدى تعريف للجودة وبعض التفاصيل الهامة عن الموضوع من ضمن الملفات الخاصة بى على power point
ولكن أريد المساعدة فى الطريقة التى أعرض بها هذا الملف على الموقع لتعم الفائدة
أرجو المساعدة
أخوكم م.إبراهيم الفيتوري
إبراهيم الفيتوري غير موجود حالياً   رد مع اقتباس
قديم 19-08-2008, 11:39 AM   رقم المشاركة : [36 (permalink)]
أخوانى الأعزاء على هذا المنتدي الرائع أتمنى أن تدلونى على الطريقة التى أستطيع بها الإفادة بما لدي من معلومات عن الجودة سواء كانت ملفات مضغوطة أو ملفات Pdf
كي يستفيد منه الجميع فى هذا المجال حيث أننى حديث المشاركة بالمنتدي
أخوكم م .إبراهيم الفيتوري
قديم 19-08-2008, 01:22 PM   رقم المشاركة : [37 (permalink)]
الأخت بنت فلسطين إليك هذا الرابط والذي يحتوي علي التعريف بالجودة ملف POWER POINT
أتمني أن يستفيد منه الجميع بهذا المنتدي الرائع
http://www.ziddu.com/download/1964046/.zip.html
لا تنسونا من دعائكم الصالح
أخوكم م.إبراهيم الفيتورى
قديم 20-08-2008, 11:10 AM   رقم المشاركة : [38 (permalink)]
السلام عليكم إخوانى الأعزاء
ألرابط المبين أدناه تحتوي على التعريف بالجودة على POWER POINT
أتمني أن ينتفع به الجميع على هذا المنتدي الرائع
http://www.ziddu.com/download/1972463/13.zip.html
قديم 29-08-2008, 11:17 PM   رقم المشاركة : [39 (permalink)]
زائر
الصورة الرمزية شبكة المهندس المصر
شبكة المهندس المصر
مشكوووووووووووووووووور
شبكة المهندس المصر غير موجود حالياً   رد مع اقتباس
قديم 30-08-2008, 04:27 PM   رقم المشاركة : [40 (permalink)]
الصورة الرمزية عارف10
عارف10 يستحق التميز
مشكور اخي واقول لو ان كل الناس او كل المواطنين فهموا كلمة الجودة ومدا اهميتها لكان الحال غير الحال
عارف10 غير موجود حالياً   رد مع اقتباس
الجودة, تعريف
الساعة الآن 11:00 PM.
سبق لك تقييم هذا الموضوع:
