LinkBack | أدوات الموضوع | تقييم الموضوع |
Mathworks Matlab R2007b DVD l 3.3 GB
![]() environment for algorithm development, data visualization, data analysis, and numeric computation. Using MATLAB, you can solve technical computing problems faster than with traditional programming languages, such as C, C++, and Fortran. You can use MATLAB in a wide range of applications, including signal and image processing, communications, control design, test and measurement, financial modeling and analysis, and computational biology. Add-on toolboxes (collections of special-purpose MATLAB functions, available separately) extend the MATLAB environment to solve particular classes of problems in these application areas. MATLAB provides a number of features for documenting and sharing your work. You can integrate your MATLAB code with other languages and applications, and distribute your MATLAB algorithms and applications. R2007b includes Simulink 7, new features in MATLAB, two new products released since R2007a, and updates and bug fixes to 82 other products. Subscribers to MathWorks Software Maintenance Service can download R2007b product updates. R2007b introduces a major new feature: C code generation from Embedded MATLAB functions directly at the MATLAB command line, using Real-Time Workshop. In addition, Embedded MATLAB Function blocks in Simulink support algorithms in multiple M-files. Download http://www.filefactory.com/file/fbf541/ http://www.filefactory.com/file/ed299f/ http://www.filefactory.com/file/e5dd5c/ http://www.filefactory.com/file/b92347/ http://www.filefactory.com/file/1a87ca/ http://www.filefactory.com/file/fe7de3/ http://www.filefactory.com/file/ce0049/ http://www.filefactory.com/file/67d134/ http://www.filefactory.com/file/b22d68/ http://www.filefactory.com/file/1af064/ http://www.filefactory.com/file/ccd308/ http://www.filefactory.com/file/6d1173/ http://www.filefactory.com/file/7abc9e/ http://www.filefactory.com/file/151772/ http://www.filefactory.com/file/63112a/ http://www.filefactory.com/file/5ee1f0/ http://www.filefactory.com/file/e3833e/ http://www.filefactory.com/file/848c52/ http://www.filefactory.com/file/0a7eb2/ http://www.filefactory.com/file/77fc0f/ http://www.filefactory.com/file/5ca278/ http://www.filefactory.com/file/a14e1b/ http://www.filefactory.com/file/c42648/ http://www.filefactory.com/file/6c087b/ http://www.filefactory.com/file/f0af78/ http://www.filefactory.com/file/afca60/ http://www.filefactory.com/file/106300/ http://www.filefactory.com/file/a45527/ http://www.filefactory.com/file/014aa2/ http://www.filefactory.com/file/e0196f/ http://www.filefactory.com/file/835ef9/ http://www.filefactory.com/file/6d25bc/ http://www.filefactory.com/file/d3dcc6/ http://www.filefactory.com/file/a34033/ 3.3 GB |
الف شكر ليك اخي بصراحة انا مسدقتش نفسي لما شفت الروابط لاني بجد دخت على بال ما وصلت للبرنامج الرهيب ده .. بجد مليون كلمة شكر انت تستاهلها حبيب قلبي
النفسُ تبكي على الدنيا وقد علمت *** أن السعادة فيها ترك ما فيهــــــا
لا دارٌ للمرءِ بعد الموت يسكُنـــهـا***إلا التي كانَ قبل الموتِ بانيـــــها فإن بناها بخير طاب مسكنُــــــــه *** وإن بناها بشر خاب بانيـــــــــها |
ESSALEM OUALIKOM
je veut remercier tous les gent qui ont vrément des savon et et je vousremecier aussi pour ce traville important et pour toutes les autre choses que vous fait pour le devellopement des sciences merci infiniment abientot essalem oualikom. |
essalem oualikom
azoole falaouen, natch slimani abdoun aligre aksere a chanchakragh falmadjhodath anoone hirime beche ahlaymeme kaae ewrikini yatkossen ellogiciel matlab beche adanesse natchninne ahantanagre oue hantanef ouadjthent saha lakhthemte anoune athamlilith . essalem oualikom |
| مواقع النشر (المفضلة) |
| أدوات الموضوع | |
| تقييم هذا الموضوع | |
