As Engineer If You Are Freesh You Have To Work With Contracting Company To Get Experiance , So Iam Advising You Dont Work With Consultant Or Government .
2- As Contractot Engineer You Are Responsible To Deliver The Project According To (time , Cost Safty And Budget
In Other Words You Should Make Or Follow The Planning And See The Manpower And Equipment Which Is Required
Then Make Moblization For The Site , Chech All Permissins From Related Authorities
Check The B . M And Plot Limit
Depth Od Excavation And Dewatering According To Soil Investigation Report
Make Your Submitals To The Consultant And Client In Advane ( Like But Not Limited Concrete Disgne Mixe < Block Steel , Tiles , Water Proof .... (
Keep Records For Every Corespndance
Mahmoud Bader
