| التسجيل | الأسئلة الشائعة | قائمة الأعضاء | التقويم | مركز رفع الملفات | جعل المنتديات كمقروءة |
| هندسة الالكترونيات ................ بإشراف : م.الـحـربي |
LinkBack | أدوات الموضوع | تقييم الموضوع |
التكمله
Missing Pulse Detector (Basic)
Morse Code Practice Keyer, I Morse Code Practice Keyer, II Motor Accu Lader (Dutch language) Motorcycle Battery Charger Motorcycle Brake Light Flasher Motorcycle Low Voltage Warning No-Hassle 3rd Brakelight hookup Power Supply Converted from a PC - by Andy Batts Practical, 2-wire Intercom Pulse Timer, 555 Pulse Width modulator, 555 Pulse Width modulator, 4093 Radio Shack Special - Transmitters by Patrick Cambre Red Alert Alarm, #1 Red Alert Alarm, #2 Relays - Sound Activated, #1 Relays - Sound Activated, #2 Relays - Transistor Boosted Relays - Dark Activated Relays - Delayed Turn-on Relays - Automatic Turn-off Relays - Long Duration Relays - 12 Sec to 90 min Relays - Long Duration--1 to 100 min Relays - Long Duration--1 min to 20 hrs Relays - Self Latching RF Transmitter, light sensing RJ45 Cable Tester by Bruce Marcus Subcarrier Adapter Listen to those hidden FM transmissions ScanMate Your (Radio) scanner buddy-pcb available! Servo Modification - For contineous rotation Simplest R/C Circuit Simplest RF Transmitter Simple Transistor Audio PreAmplifier Single IC Audio Preamplifier Single Cell Sealed Lead Acid Charger - by Søren Solar Cell NiCad Charger Solid State Relay Telephone Transmitter (FM) Theremin Thermo Alarm Thermostat Third Brake Light Pulser Touch Activated Alarm System Touch Switch using Transistors Two-Tone Trainhorn Universal Flasher Circuit Variable Power Supply, 1 - 30V @ 1.5A Wailing Alarm Warble Alarm Whooper Alarm Water-level Sensing and Control Waterpump Safety Guard for Fish-pond Weller WLC100 Soldering Station Wireless Microphone Xmas Lights Tester Zap Adapter 1.5V Tracking Transmitter (with Video Clip) 2 Transistor 2 LED Flasher 4 Transistor Tracking Transmitter 4 Transistor Transmitter R8(1K) 3-03-2007 7.2V Field Charger (.pdf file) 8A Regulated Power Supply for 13.8V 9-V Stabilized Powersupply 9 to 9 pin (Female) Nullmodem Cable 12V to 9V with a LM317 30-Meter QRP Transmitter for Morse Code 555 DC-AC Inverter 555 Timer IC Tester 555 Go No/Go Tester More advanced Electronic Symbols Template
اللهم اعفُ عنه و عن والديه و عافهم في الدنيا و الاخره _____________________ ![]() اذا غضب الله على قوم رزقهم الجدل و منعهم العمل ::::::::::::::::::::::::: اعقل الناس ....اعذر الناس للناس :::::::::::::::::::::::::::::::: لا تََسقني كأسَ الحياةِ بذلةٍ ..... بَل فاسقني بالعزِ كأسَ الحنظلِ |
شروح
![]() 555 Timer/Oscillator 741 Op-Amp Capacitors 3-01-2007 Coils Crystal Oscillators (SOON) MosFet Test Piezo Education/Tutorial PLL Resistor Color Code Tutorial Relays, Relay Drivers, Solid-State SCR Tester Toroids Transistor Tutorial, 9 parts! Under Construction Triac Test UJT Test![]() Stefan's Electronic Projects - Projects and Repairs for Hobbyists, Experimenters, and Aviators. Testing the Sanyo Eneloop NiMH's - by Stefan Vorkoetter ![]() Circuits Archive - Older circuits. Most are working, some are not. Could be still useful. Tony's Data Sheets - Data Sheet for common Semiconductors. Data Sheets Archive - Link to tons of data sheets. Filter Solutions - PC windows based filter synthesis and analysis software. RP Electronics - Panel Meters, Analog/LCD. Radio Shack Partnumbers - Most common order numbers for my circuits. Resistor Value Calculator - By Danny Goodman, AE9F. Transistor 'SM' marking codes by Philips BV. TUP/TUN/DUS/DUG European transistor replacement system. PN100/200 - Data Sheets for the PN100 and PN200. LF13741 - Monolitic JFET Input OpAmp Data Sheet. MC14069UB - CMOS Hex Inverter Data Sheet. Toroids, RF/EMI Cores - Variety of commonly used toroids, colors, etc. Guelph Amateur Radio Club - GARC--Official Homepage. Jonathan's Electronics Message Forum - More help if you need it!
و لا تنسونا من صالح دعائكم
مشكور اخي على المرور
مشكورين اخواني الاعزاء على المرور
مشكور جدا اخي على هذه الدعوه
| أدوات الموضوع | |
| تقييم هذا الموضوع | |
br />
