Automotive repair shops that use the ALLDATA system have a clear differentiation from other repair facilities. AllDATA-equipped shops can provide their customers with the most accurate repair estimates and proof of diagnostic and repair procedures. ALLDATA also includes factory-correct maintenance schedules that itemize additionally needed services. Moreover, ALLDATA helps shops build consumer confidence and loyalty.
Professional repair shops need current, factory-correct information to meet the complex repair demands of today's automotive industry. ALLDATA shops have fast access to the industry's best information for vehicles from 1982 to present, including TSBs, maintenance schedules, manufacturer recall information, OEM solutions and factory diagrams. ALLDATA DVD, the leading computer-based diagnostic, repair and estimating information system, can help you boost shop performance and build customer loyalty as you efficiently repair more makes, while reducing comebacks. Reinforce your expertise with current factory-correct automotive information. The most comprehensive information for 1982 to present vehicles, diagrams and diagnostic flow charts. Parts and labour information. Maintenance schedules. Manufacturer TSBs and recalls. Integrated estimating software. OEM wiring diagrams with connector, ground, power distribution and splice information. A2Z Component Search - the fastest route available to component information.
ALLDATA offers you its unique A2Z component search feature. When you enter the full or partial component name, the system automatically displays the information route. Information is only a click away.
Automotive Service Information Structure
Information is structured around the needs of an automotive service business: maintenance; diagnosis & repair; parts and labour; technical support.
Automotive Oriented Lookup Hierarchy (Component Indexing)
Component Indexing arranges the entire ALLDATA database into a single, consistent information format - organized the way a master technician thinks and works. From the vehicle to the component level, all relevant information types are consistently listed together. You get fast, easy access, reduced search time and more efficient diagnostics.
Year, Make, Model & Engine Specific
Information presented applies to specific year, make, model and engine (YMME) combination. Unrelated information about other years, makes, models or engines is not displayed.
TurboView Navigation
ALLDATA’s exclusive TurboView navigational tool automatically tracks the information that you look up as you use the system. A click of the mouse instantly displays a list of the component and subsystem information that you most recently looked up and makes it readily available to you.
Advanced Hyperlinking
ALLDATA’s editorial staff creates hyperlinks so that you can easily and quickly move to related articles. With hyperlinks, you can move between all related repair articles from a single screen.
Split Screen Text & Image Viewing (Image+Text Display)
ALLDATA saves shops time with its adjustable split screens for simultaneous viewing of repair procedure text, plus images. The Image+Text Display eliminates the need to move between multiple screens. The zoom feature allows close-up viewing of diagrams and illustrations.
Comprehensive Vehicle Manufacturer Coverage
You get factory diagrams (including wiring, ground, connector and exploded diagrams), service precautions, repair illustrations, factory diagnostics procedures, and connector locations.
Advanced Technical Service Bulletin Features
TSBs give you access to the most up-to-date factory fixes available. Unlike other information systems, ALLDATA TSBs are linked all the way to the component level. If a TSB applies to the information being viewed, it is easily spotted by the user and accessible with a mouse click.
Simultaneous Parts and Labour Lookup (Image Hot Spots)
Image Hot Spots provide the fastest, easiest way to identify the exact parts you need. Just click on the highlighted parts within exploded diagrams and the system automatically displays their OEM part numbers, prices and associated labour times.
Integrated Parts and Labour
Parts and Labour are fully integrated with the other ALLDATA vehicle information. No need to change the DVD!
ALLDATA Customer Reception Tools
Use ALLDATA's shop operations or any description of operation article to help your customers' gain valuable knowledge and a general understanding of what may be needed to fix their vehicle.
Integration - Open System Ready
ALLDATA supports iSHOP, the industry integration standard. Open System Ready enables software manufacturers such as shop management software (SMS) companies to integrate with ALLDATA’s repair information. For more information on iSHOP, go to [].
Custom Annotations
Annotations provide a great way for shops to create their own helpful hints regarding specific repairs. Technicians can pin customized notes to any specific repair article or image. These annotations remain in place, even after database updates, for all shop technicians to view on future repairs.
Tune-Up and Maintenance Specifications
ALLDATA provides a centralized tune-up database location for quick access to routine service data such as ignition timing, idle speed, firing order, fuel pressure and air/fuel mixture information.
for more information please go to
All Data main program:
[refer to "AllData 8.5.txt" for install info]
General Motors DVD1A:
General Motors DVD1B:
General Motors DVD2A:
General Motors DVD2B:
Chrysler DVD1A:
Chrysler DVD1B:
Ford DVD1A:
Ford DVD1B:
The subject is copied from another forum uploaded their by user a1, all links are new links
