دورة إدارة المشاريع الاحترافية PMP
آخر المواضيع الجديدة
النتائج 1 إلى 8 من 8
اسباب تطاير (تبخر) الزيت من محرك السيارة
Volatility and the NOACK Test " Why do I have to keep adding oil to my engine? " Volatization, the
  1. #1
    يوسف الهمالي Don't Avatar
    تاريخ التسجيل
    Jan 2004
    صفحة الملتقى الرسمية على الفيس بوك .. مجموعة المهندسين العرب .. follow us on twitter...
    Volatization, the methods used to test it and why AMSOIL decided customers would care.
    When speaking about their vehicles, motorists may comment that their auto "uses a little oil now and then." Although many are positive that the vehicle is "using" this oil, upon further questioning they often cannot explain how or why or where exactly the oil disappeared. Is it leaking? Certainly some vehicles leak an amount of oil out of seals, gaskets and joints. But others that "use" oil have no leaks at all. So where does this oil go? The oil goes through a process known as volatization, and it can end up costing motorists more than just the price of a few quarts of oil.
    Why Oil Volatizes
    After crude oil has been pumped from the ground, it is sent to a refinery where it is distilled into its usable components. Distillation separates the crude into fractions based on their individual boiling ranges. The crude is heated
    A Fractioning Tower separates the usable portions of crude oil to obtain common end products. until each fraction boils off as a vapor, and then is condensed and subjected to further processing. This boiling is essentially the same circumstance occurring during volatization in an engine, with lighter molecules vaporizing and heavier molecules remaining. In refining, this process can effectively increase the amount of similar molecular structures in each fraction, and therefore improve the stability and quality of each product refined. However, even the final petroleum-based product still consists of a wide range of hydrocarbon structures. These are sometimes referred to as a "chemical soup."
    This "chemical soup" found in standard petroleum mineral oils contributes to many of their shortcomings when compared with synthetic oils. Because these molecules prevent uniformity, the oil has a tendency to deteriorate more rapidly. If lighter fractions are present in the oil, they can boil off (or volatize) which leads to oil consumption, oil thickening and a loss of performance.
    Money to Burn?
    Even though many motorists do not realize it, when they notice that their vehicle is "using" oil they are often witnessing the effects of volatization.
    Most simply buy extra oil to replace what they assume the motor has "used" and check regularly to see if the level is low. But is adding more mineral oil necessarily the best solution to the problem? What they may in fact be doing by adding more petroleum-based mineral oil is burning up their money.
    For example, if an automobile needs five quarts of mineral oil sold at $2 a quart to operate during a 3,000- mile drain interval, and the mineral oil used in the vehicle volatizes and is replaced at a rate of one quart every 1,000 miles, the automobile actually goes through 7 quarts of mineral oil during the drain interval and the motorist spends an extra $4 per oil change interval on "topping off" the levels. Considering that the average vehicle puts on 15,000 miles a year, $20 in extra oil is used to keep the oil levels sufficient.
    But extra oil is not the only expense motorists face when dealing with volatization. As motor oil goes through the process of volatizing, the chemically lighter (or more volatile) portions are always the first to "boil off" in the oil. This leaves the heavier, less pumpable portions behind. This heavier oil cannot be relied upon to flow easily and quickly to all of the engine components. The end result is decreased fuel efficiency, premature component wear and deposit formation within the engine. The expense to the motorist can be quite substantial.
    The Synthetic Solution
    Synthetic motor oils have a natural advantage over petroleum-based oils when it comes to volatility. This is because synthetic oils are designed to have uniform chemical structures. This eliminates the extra chemicals and hydrocarbon structures (or "chemical soup") found in oils based only in mineral stock. Because they contain less lighter chemical portions to boil off, synthetic products lose less of their lubricating abilities to volatization.
    AMSOIL Synthetic Motor Oils maintain their viscosity and provide ongoing cold start protection, fuel efficiency and reduced oil consumption.
    An AMSOIL First
    Surprisingly, volatility was not always considered when comparing motor oils. Few oil companies published test results measuring an oil's volatility until the 1980s, when AMSOIL became the first in the United States to publish NOACK Volatility Test results.
    The NOACK Volatility test apparatus. The grey box holds the oil
    sample and heats it to 150ºC. Dry air is passed over the
    sample to carry away the vapors which have boiled off.
    In the NOACK Volatility Test the oil is heated to 150° C for a specified period. Lighter oil fractions will "boil off," leading to oil consumption, oil thickening and a loss of performance. The percentage lost, by weight, due to this "boil-off" is reported.
    The test has different passing requirements depending on the weight of the oil being tested. For example, 10W-30 oil in the United States may lose up to 22 percent, by weight, and still be "passable." However, with 20 percent gone, the oil suffers significant performance deficits in characteristics such as pumpability and lubricity.
    Effective July 1, 2001, a new specification, known as GF-3, allows a maximum of 15 percent loss. European standards, which have been stricter for years, already limit high quality oils to a maximum of 13 percent loss. AMSOIL 10W-30 loses only 6.76 percent to volatility.
    AMSOIL reports these results because they enable informed consumers to understand the value offered by synthetic motor oils. Low oil volatility means reduced oil consumption rates, maximum fuel efficiency and higher levels of performance for longer periods of time.
    من مواضيع يوسف الهمالي :
  2. #2
    Qal&ia Don't Avatar
    تاريخ التسجيل
    Sep 2006
    مرحبا
    نستطيع ان نجمل اسباب تطاير الزيت من المحرك في ما يلي:
    1. تهريب من احدى الحافظات
    2.ارتفاع حرارة المحرك
    3.ذوبان في الحلقات ( الرنجات)
    من مواضيع Qal&ia :
  3. #3
    تاريخ التسجيل
    Jan 2004
    هذا من الناحية الميكانيكية ولكن هناك تطاير للزيت من المحرك غير مباشر وهو بيت القصيد المتمثل في نوع الزيوت الاساسية والأضافات المستخدمة وجودة الزيت ونوعية الزيت معدني ام اصطناعي
  4. #4
    تاريخ التسجيل
    Jan 2004
    هذا من الناحية الميكانيكية ولكن هناك تطاير للزيت من المحرك غير مباشر وهو بيت القصيد المتمثل في نوع تركيبةالزيوت الاساسية والأضافات المستخدمة وجودة الزيت ونوعية الزيت معدني ام اصطناعي
  5. #5
    عضو فعال الصورة الرمزية عـلـي
    تاريخ التسجيل
    Jun 2009
    بسراحه موضوع مميز ونادر فلا يوجد حد تكلم عن اسباب تبخير الماكينه وانا من من بحث عن موضوع التبخير ولم اجد اسباب التبخير لان لدي شاحنه من نوع مرسيدس ال بي ويخرج منها بخار من ماكن صب الزيت عندمات تكون ساخنه والامر الاغب انه لا يخرج دخان ابيض او ازرق من العادم وذهبت الى كذا ميكانيكي وقالو لي غير مبخرة الزيت
    وهي توجد في اعلى المكينه بالنص المكينه ولا اعرف اذا كان لها اسم اخر وغيرته ولم يتوقف التبخير
    وقالو لي غير الزيت وغيرته الى زيت كاسترول واتوقع انه عالي الجوده ولم يتوقف لتبخير ارجو منكم الاهتمام بالموضوع لان هذا المنتدى الوحيد الذي يتكلم بهاذا الموضوع ولكي تعم الفائده للجميع
    وجزاكم الله خير
    من مواضيع عـلـي :
  6. #6
  7. #7
    طارق حسن محمد Don't Avatar
    تاريخ التسجيل
    Nov 2009
    شكرآ لك اخي يوسف وجازاك الله كل خير
    من مواضيع طارق حسن محمد :
  8. #8
    POLOTSHY Don't Avatar
    تاريخ التسجيل
    Feb 2010
    لدي سيارة كيا سيفيا موديل 1996 ينقص الزيت دون وجود تهريب او دخان نهائيا ولا اعرف السبب علما انني استعمل زيت جولف ما السبب
المواضيع المتشابهه
  1. اسباب انحراف السيارة
    بواسطة رفعت سلطان في المنتدى هندسة السيارات
    مشاركات: 40
    آخر مشاركة: 16-03-2013, 05:59 PM
  2. اسباب احتراق محرك كهربائي
    بواسطة نويجع في المنتدى قسم الألات الكهربائية
    مشاركات: 31
    آخر مشاركة: 30-12-2012, 09:55 PM
  3. اسباب لارتفاع حرارة محرك السيارة
    بواسطة م.محمود جمال في المنتدى هندسة السيارات
    مشاركات: 25
    آخر مشاركة: 01-06-2011, 08:39 PM
  4. ما هي اسباب اهتزاز السيارة
    بواسطة sadi436 في المنتدى هندسة السيارات
    مشاركات: 7
    آخر مشاركة: 25-11-2010, 09:24 PM
ضوابط المشاركة
  • لا تستطيع إضافة مواضيع جديدة
  • لا تستطيع الرد على المواضيع
  • لا تستطيع إرفاق ملفات
  • لا تستطيع تعديل مشاركاتك
عن ملتقى المهندسين العرب
    يُعتبر ملتقى المهندسين العرب من أوائل وأكبر المواقع الهندسية حيث تم تأسيسه منذ عام 2001م ويهدف إلى نشر المعرفة الهندسية وتقديم كل ما له فائدة للمهندسين والمهتمين من خلال أقسامة العلمية والهندسية المتعددة بالإضافة إلى وجود أقسام عامة تستقطب الكثير لمختلف النقاشات الهادفة.
مواقع صديقة
تابعنا على
Twitter Facebook
The owner and operator of the site is not responsible for the availability of, or any content provided.
Topics that are written in the site reflect the opinion of the author.
Search Engine Optimization by vBSEO
