صفحة 858 من 864 الأولىالأولى ... 358758808848854 855 856 857 858859 860 861 862 ... الأخيرةالأخيرة
النتائج 8,571 إلى 8,580 من 8637
  1. [8571]
    Received: 11
    Given: 5
    إن الدنيا بعدك ليست تكفينا ...
  2. [8572]
    Received: 11
    Given: 5
    الرجاء الحصول على الأبحاث التالية
    Building Information Modeling (BIM) for existing buildings — Literature review and future needs
    Identifying and assessing critical risk factors for BIM projects: Empirical study
    Productive modeling for development of as-built BIM of existing indoor structures
    A BIM-based construction quality management model and its applications
    BIM extension for the sustainability appraisal of conceptual steel design
    BIM and ontology-based approach for building cost estimation
    Analysis and Design of Reinforced Concrete Bridge Column Based on BIM
    Integrating BIM and GIS to improve the visual monitoring of construction supply chain management
    و لكم جزيل الشكر
  3. [8573]
    السلام عليكم..طلب مقالة هام جدا..جزاكم الله خيرا..
    Dijkstra's Algorithm Model Over MPLS / GMPLS - IEEE Xplore
    Parra, O.J.S. ; Fac. de Ing., Univ. Distrital Francisco Jose de Caldas, Bogota, Colombia ; Manta, C. ; Rubio, G.L.
    مع تحياتي
  4. [8574]
    :plz i need this paper
    An integration of fuzzy association rules and WordNet for document clustering
    An Approach for Arabic Text Categorization Using Association Rule Mining
  5. [8575]
    السلام عليكم ورحمة الله
    من فضلكم اريد هذا البحث:
    http://ieeexplore.ieee.org/xpl/login...mber%3D6027318
    شكرا جزيلا
  6. [8576]
    please I need a paper or research about how to
    , Compute the theoretical parameters and compare to the real measurements, including R L C
    skin effect and phase velocity
    Consider the 330 kv system.
    please i need it as soon as possible
    thanks in advance
  7. [8577]
    الصورة الرمزية Ali_eisa_AlDloami
    Received: 8
    Given: 8
    سلام عليكم
    جزاك الله خير ممكن هذه الورقة البحثية
    http://www.sciencedirect.com/science...63822312001857
  8. [8578]
    Given: 3
    السلام عليكم ...ممكن هذه البحوث المنشورة في معهد الخرسانة الامريكي مع جزيل الشكر...
    Mau, S. T., and Hsu, C. T., Formulla for shear strength of deep beams,ACI
    JournalV.86,NO.5,SEPT.-OCT., 1989 ,PP.516-523 ,
    Clark, A.P., Diagonal tension in reinforced concrete beams
    ACI JORANAL, Proceedings, V.48, NO. 10, OCT.1951, PP.145-156
  9. [8579]
    السلام عليكم هل بالامكان اية ابحاث او اطاريح عن تقنية معالجة مياه المجاري بالنباتات المائية(phytoremediation) لان بحث الماجستير تبعي يخص هذا الموضوع مع جزيل الشكر مقدما
  10. [8580]
    أريد هذه المقالة من فضلكم.........شكرا.
