صفحة 84 من 864 الأولىالأولى ... 347480 81 82 83 8485 86 87 88 94134184584 ... الأخيرةالأخيرة
النتائج 831 إلى 840 من 8635
  1. [831]
    الصورة الرمزية smi
    Schedule, Cost, and Profit Control with PERT: A Comprehensive Guide for Program Management
    By Robert Wallace Miller
    Summary
    By Robert Wallace MillerPublished 1963
    McGraw-Hill227 pagesOriginal from the University of MichiganDigitized Aug 17, 2006
  2. [832]
    الصورة الرمزية smi
    can you plz help me to get the next
    State-of-the-Art Review of Construction Performance Models and Factors
    Tanaya Korde,1 Mingen Li,2 and Alan D. Russell3
    1MASc Student and Graduate Research Assistant, Department of Civil Engineering, University of British Columbia, Vancouver, Canada, tpk08*************
    2PhD Student and Graduate Research Assistant, Department of Civil Engineering, University of British Columbia, Vancouver, Canada, limingen@civil.ubc.ca
    3Professor and Computer Integrated Design & Construction Chairholder, Department of Civil Engineering, University of British Columbia, Vancouver, Canada, adr@civil.ubc.ca
  3. [833]
    الصورة الرمزية smi
  4. [834]
    الصورة الرمزية smi
    Title: Key performance indicators for measuring construction success Author(s): Albert P.C. Chan, Ada P.L. Chan Journal: Benchmarking: An International Journal ISSN: 1463-5771 Year: 2004 Volume: 11 Issue: 2 Page: 203 - 221 DOI: 10.1108/14635770410532624 Publisher: Emerald Group Publishing Limited
  5. [835]
    ارجو الحصول على هذه الابحاث
    Dear Brother i need the following papers (gazakom Allah Khaira)
    1- Sayers, A.T., 1988. Flow interference between four equispaced cylinders when subjected to a cross flow. Journal of Wind Engineering
    and Industrial Aerodynamics 31, 9–28.
    2- Sayers, A.T., 1990. Vertex shedding from groups of three and four equispaced cylinders situated in a cross flow. Journal of Wind
    Engineering and Industrial Aerodynamics 34, 213–221.
    3- Lam, K., Lo, S.C., 1992. A visualization study of cross-flow around four cylinders in a square configuration. Journal of Fluids and
    Structures 6, 109–131.
    4- Lam, K., So, R.M.C., Li, J.Y., 2001. Flow around four cylinders in a square configuration using surface vorticity method. Proceedings
    of the Second International Conference on Vortex Methods, Turkey, pp. 115–122.
    5- Price, S.J., Paidoussis, M.P., 1984. The aerodynamic forces acting on groups of two and three circular cylinders when subjected to a
    cross flow. Journal of Wind Engineering and Industrial Aerodynamics 17, 329–347.
    6- Lam, K., Fang, X., 1995. The effect of interference of four equispaced cylinders in cross flow on pressure and force coefficients. Journal
    of Fluids and Structures 9, 195–214.
    7- Ng, C.W., Ko, N.W.M., 1995. Flow interaction behind two circular cylinders of equal diameter—a numerical study. Journal of Wind
    Engineering and Industrial Aerodynamics 54/55, 277–287.
    8- Zdravkovich, M.M., 1968. Smoke observation of the wake of a group of three cylinders in various arrangements. Journal of Fluid
    Mechanics 32, 339–351.
    9- Zdravkovich, M.M., 1977. Review-review of flow interference between two circular cylinders in various arrangements. ASME Journal
    of Fluids Engineering 99, 618–633.
    10- Zdravkovich, M.M., 1987. The effects of interference between circular cylinders in cross flow. Journal of Fluids and Structures 1,
    239–261.
    11- Bearman, P.W., Wadcock, A.J., 1973. The interaction between a pair of circular cylinders normal to a stream. Journal of Fluid
    Mechanics 61, 499–511.
    12- Dielen, B., Ruscheweyh, H., 1995. Mechanism of interference galloping of two identical circular cylinders in cross flow. Journal of
    Wind Engineering and Industrial Aerodynamics 54/55, 289–300.
    13-Fitzpatrick, J.A., Donaldson, I.S., Mcknight, W., 1988. Strouhal numbers for flows in deep tube array models. Journal of Fluids and
    Structures 2, 145–160.
    14- Gu, Z.F., 1996. On interference between two circular cylinders at supercritical Reynolds number. Journal of Wind Engineering and
    Industrial Aerodynamics 62, 175–190.
    15-Gu, Z.F., Sun, T.F., 1999. On interference behind two circular cylinders in staggered arrangement at high subcritical Reynolds
    numbers. Journal of Wind Engineering and Industrial Aerodynamics 80, 287–309.
    16-Guillaume, D.W., Larue, J.C., 1999. Investigation of the flopping regime with two-, three- and four-cylinder arrays. Experiments in
    Fluids 27, 145–156.
    17- Kareem, A., Kijewski, T., Lu, P.C., 1998. Investigation of interference effects for a group of finite cylinders. Journal of Wind
    Engineering and Industrial Aerodynamics 77&78, 503–520.
    18-Lam, K., Cheung, W.C., 1988. Phenomena of vortex shedding and flow interference of three cylinders in different equilateral
    arrangements. Journal of Fluid Mechanics 196, 1–26.
    19-Guillaume, D.W., LaRue, J.C., 1999. Investigation of the flopping regime with two-, three- and four-cylinder arrays. Experiments in
    Fluids 27, 145–156.
    20-Igarashi, T., 1981. Characteristics of the flow around two circular cylinders arranged in tandem (1st Report). Bulletin of the JSME 24,
    323–331.
    21-Sin, V.K., So, R.M.C., 1987. Local force measurement on finite-span cylinders in a cross-flow. ASME Journal of Fluids Engineering
    109, 136–143.
    22-So, R.M.C., Savkar, S.D., 1981. Buffeting forces on rigid circular cylinders in cross flows. Journal of Fluids Mechanics 105, 397–425.
    23-So, R.M.C., Liu, Y., Chan, S.T., Lam, K., 2001. Numerical studies of a freely vibrating cylinder in a cross-flow. Journal of Fluids and
    Structures 15, 845–866.
    24-Sumner, D., Wong, S.S.T., Price, S.J., Paidoussis, M.P., 1999. Fluid behaviour of side-by-side circular cylinders in steady cross-flow.
    Journal of Fluids and Structures 13, 309–338.
    25-Szepessy, S., Bearman, P.W., 1992. Aspect ratio and end plate effects on vortex shedding from a circular cylinder. Journal of Fluid
    Mechanics 234, 191–217.
    26-Tadrist, H., Martin, R., Tadrist, L., 1990. Experimental investigation of fluctuating forces exerted on a cylindrical tube (Reynolds
    numbers from 3000 to 30 000). Physics of Fluids A 2 (12), 2176–2182.
    27-Tutar, M., Hold, A.E., 2001. Computational modeling of flow around a circular cylinder in subcritical flow regime with various
    turbulence models. International Journal for Numerical Methods in Fluids 35, 763–784.
    28-West, G.S., Apelt, C.J., 1982. The effects of tunnel blockage and aspect ratio on the mean flow past a circular cylinder with Reynolds
    numbers between 104 and 105. Journal of Fluid Mechanics 114, 361–377.
    29- West, G.S., Apelt, C.J., 1993. Measurements of fluctuating pressures and forces on a circular cylinder in the Reynolds number range
    104 to 2.5x105. Journal of Fluids and Structures 7, 227–244.
    30-West, G.S., Apelt, C.J., 1997. Fluctuating lift and drag forces on finite length of a circular cylinder in the subcritical Reynolds number
    range. Journal of Fluids and Structures 11, 135–158.
  6. [836]
    السلام عليكم ورحمة الله
    الأخ الفاضل
    aalmasri
    أسأل الله تعالى أن يبارك بجهودك لما تقدمه لنا من عون كما أسأل الله أن يجعل كل ماتقدمه من فائده لاخوانك في ميزان حسناتك
    نفع الله بكم ووفقكم لما يحب ويرضى
  7. [837]
    الصورة الرمزية asas121
    شكرا لهذا الجهد الرائع جعلة اللة فى ميزان حسناتك
    ممكن هذا
    A metrological analysis of a (Direct Digital Control) DDC-based air conditioning system
    Energy and Buildings, Volume 29, Issue 2, 1999, Pages 155-166
    A. Capuano, M. Dell'Isola, N. Massarotti and L. Vanoli
    Abstract | Full Text + Links | PDF (428 K) |
    To Purchase and Download the Full Article, Click PDF
    Dynamic and real-time simulation of BMS and air-conditioning system as a ‘living’ environment for learning/training
    Automation in Construction, Volume 10, Issue 4, May 2001, Pages 487-505
    Shengwei Wang and Ling Zheng
    Abstract | Full Text + Links | PDF (1378 K) |
    Comparison and application of DDC algorithms for a heat exchanger
    Automatica, Volume 12, Issue 5, September 1976, Pages 393-402
    H. Unbehauen, Chr. Schmid and F. Bo¨ttiger
    Abstract | Abstract + References | PDF (847 K)
  8. [838]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 8
    اقتباس المشاركة الأصلية كتبت بواسطة smi مشاهدة المشاركة
    Summary
    هذا كتاب وليس بحثا...يمكنك طلبه في موضوع طلبات الكتب اخي smi
  9. [839]
    عضو تحرير المجلة
    Received: 8
    للاسف غير متوفرة
  10. [840]
    عضو تحرير المجلة
    Received: 8
    للاسف ايضا غير متوفرة
