صفحة 724 من 864 الأولىالأولى ... 224624674714720 721 722 723 724725 726 727 728 734774824 ... الأخيرةالأخيرة
النتائج 7,231 إلى 7,240 من 8639
  1. [7231]
    dear all
    I hope you are fine
    i need this paper please
    Silver-Rutile Schottky Diode Fabricated on Oxidized Titanium Foil 2011 IOP Conf. Ser.: Mater. Sci. Eng. 17 012016
    and the link is
    http://iopscience.iop.org/1757-899X/17/1/012016/pdf/
    i will be realy thankful
    regards
  2. [7232]
    لو سمحتم توفير الأبحاث التالية للضرورة
    Advances in Environmental Research, Volume 7, Issue 4, June 2003, Pages 835-845
    Junko Tanaka, Masatoshi Matsumura
    Nitrogen removal from wastewater with high ammonia nitrogen concentration via shorter nitrification and denitrification
    Water Science and Technology, Volume 36, Issue 10, 1997, Pages 73-78
    Joanna Surmacz-Górska, Andrzej Cichon, Korneliusz Miksch
    Kinetics of sequential nitrification and denitrification processes
    Enzyme and Microbial Technology, Volume 27, Issues 1-2, July 2000, Pages 37-42
    Ali R. Dinçer, Fikret Kargı
    Controlling factors for simultaneous nitrification and denitrification in a two-stage intermittent aeration process treating domestic sewage
    Water Research, Volume 33, Issue 4, March 1999, Pages 961-970
    Hong W. Zhao, Donald S. Mavinic, William K. Oldham, Frederic A. Koch
    Preliminary trials of in situ ammonia stripping from source segregated domestic food waste digestate using biogas: Effect of temperature and flow rate
    Bioresource Technology, Volume 101, Issue 24, December 2010, Pages 9486-9492
    M. Ángeles De la Rubia, Mark Walker, Sonia Heaven, Charles J. Banks, Rafael Borja
    Air stripping of ammonia from pig slurry: characterisation and feasibility as a pre- or post-treatment to mesophilic anaerobic digestion
    Waste Management, Volume 23, Issue 3, 2003, Pages 261-272
    August Bonmatí, Xavier Flotats
    Simultaneous removal of ammonia, P and COD from anaerobically digested piggery wastewater using an integrated process of chemical precipitation and air stripping
    Journal of Hazardous Materials, Volume 178, Issues 1-3, 15 June 2010, Pages 326-332
    Xuejun Quan, Changying Ye, Yanqi Xiong, Jinxin Xiang, Fuping Wang
    Nitrogen potential recovery and concentration of ammonia from swine manure using electrodialysis coupled with air stripping
    Journal of Environmental Management, In Press, Corrected Proof, Available online 11 June 2011
    D. Ippersiel, M. Mondor, F. Lamarche, F. Tremblay, J. Dubreuil, L. Masse
    وشكرا لكم
  3. [7233]
    المرجو مساعدتي في الحصول على هذه الورقة:
    Linear stratified approach for 3D modelling and calibration using full geometric constraints
    http://www.computer.org/portal/web/c...W.2009.5206593
    جزاكم الله خيرا
  4. [7234]
    الأخ الكريم aalmasri، عندي طلب الورقة العلمية التالية :
    R. P. Stein and V. M. K. Sastri, A heat transfer analysis
    of heat exchangers with laminar tube-side and turbulent
    shell-side flows-a new heat exchanger Graetz problem.
    A.F.Ch.E. Symp. Ser. 68, S&-89 (1972).
    F. Scofano Neto and R. M. Cotta, Lumped-differential
    analysis of concurrent flow double-pipe heat exchanger.
    Gun. J. Chem. Engng (in press).
    R. M. Cotta and M. N. ozisik, Thermally developing
    concurrent ffow circular double pipe heat exchanger
    analysis, 8th Int. Heat transfer Coeff. San Francisco,
    pp. 2805-2810 (1986).
    K. Mastanaiah and V. M. K. Sastri, Surface temperature
    distributions in double-pipe heat exchangers. Cut?. J.
    Chepn. Engng 52, x38-840 (1974).
    R. P. Stein, Heat transfer coefficient in liquid metal concurrent
    flow double pipe heat exchangers, Chum. En,qng
    Prog. Svmp. Ser. 59,64-75 (1965).
    R. P. Stein, The Graetz problem in concurrent flow
    double pipe heat exchangers, Chem. Engng Prog. Symp.
    Ser. 59, 78-87 (1965).
    W. N. Gill, E. M. Porta and R. J. Nunge, Heat transfer
    in thermal entrance region of concurrent flow heat
    exchangers with fully developed laminar flow, lnt. J.
    Heat Mass Transfer 11, 1408-1412 (1968).
    C.W. Bert, M. Malik, Differential quadrature method in computational
    mechanics: a review, Appl. Mech. Rev. 49 (1) (1996) 1–28.
    Y. Wang, Y.B. Zhao, G.W. Wei, A note on the numerical solution of high-order
    differential equations, J. Comput. Appl. Math. 159 (2003) 387–398.
    R. Bellman, J. Casti, Differential quadrature and long-term integration, J. Math.
    Anal. Appl. 34 (1971) 235–238.
    أتمنى أن تستطيع الحصول عليها في أقرب وقت ، فأنا في أمس الحاجة إليها
    وشكراً
  5. [7235]
    السلام عليكم و رحمة الله
    الرجاء المساعدة في الحصول علي الاوراق الموجودة في الملف المرفق
    و لكم جزيل الشكر
  6. [7236]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة GHADBANE Ahmed مشاهدة المشاركة
    وشكراً
    pls freind.. can u write the website or the journal of those papers or at least copy the links of them
    im waiting u
  7. [7237]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة محمد سعيد جبر مشاهدة المشاركة
    Application of ozone treatment for ammonia removal in spent brine
    وشكرا لكم
    one of them was not bought
    http://ifile.it/wqlzg3x/Air%20stripp...0digestion.pdf
    http://ifile.it/7cxvtm9/Application%...nt%20brine.pdf
    http://ifile.it/l8ij39r/Controlling%...20domestic.pdf
    http://ifile.it/arksg6d/Kinetics%20o...0processes.pdf
    http://ifile.it/2e5lo6b/Nitrogen%20p...0stripping.pdf
    http://ifile.it/fkz1u9i/Preliminary%...ffect%20of.pdf
    http://ifile.it/a2yxpzt/Simultaneous...ocess%20of.pdf
  8. [7238]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة adnane1230 مشاهدة المشاركة
    جزاكم الله خيرا
    http://ifile.it/0oxnywu
  9. [7239]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة heartlessdevil مشاهدة المشاركة
    و لكم جزيل الشكر
    Im sorry, I have no access to this journal
  10. [7240]
