صفحة 686 من 864 الأولىالأولى ... 186586636676682 683 684 685 686687 688 689 690 696736786 ... الأخيرةالأخيرة
النتائج 6,851 إلى 6,860 من 8639
  1. [6851]
    الصورة الرمزية Gardina
    مساء الخير
    السلام عليكم ... ارجو التفضل بمساعدتي وولكم مني جزيل الشكر والتقدير
    Thesis Details
    subject
    Valve timing, charge dilution and cycle-to-cycle stability of work output of a spark ignition engine
    link
    http://ethos.bl.uk/OrderDetails.do?d...l.ethos.417943
    Author: Lai, Wing Cheung William. Awarding Institution: University of Nottingham Current Institution: University of Nottingham Awarded: 2005
    Qualification name:Thesis (Ph.D.)--University of Nottingham, 2005
    EThOS Persistent ID:
    uk.bl.ethos.417943
    subject
    Characterisation of emissions and combustion stability of a port fuelled spark ignition engine
    link
    http://ethos.bl.uk/OrderDetails.do?d...l.ethos.514811
    Author: Brown, Nicholas M Awarding Institution: University of Nottingham Current Institution: University of Nottingham Awarded: 2009
    uk.bl.ethos.514811
    subject
    An investigation into the effects of variable valve actuation on combustion and emissions in an SI engine.
    link
    http://ethos.bl.uk/OrderDetails.do?d...l.ethos.312736
    Author: Ghauri, Ahmar. Awarding Institution: University College London (University of London) Current Institution: University College London (University of London) Awarded: 1999
    Qualification name:
    PhD thesis
    EThOS Persistent ID:uk.bl.ethos.312736
    subject
    Matching of Internal Combustion Engine Characteristics for Continuously Variable Transmissions
    link
    http://ethos.bl.uk/OrderDetails.do?d...l.ethos.443334
    Author: Bonnet, Baptiste Awarding Institution: Cranfield University Current Institution: Cranfield University Awarded: 2007
    Advisor: Vaughan, N. D. (supervisor)
    Qualification name:PhD
    EThOS Persistent ID:uk.bl.ethos.443334
    ولــــــــــــــــــكم فــــــــــائــــــــق الـــشـــــــكـــــــر و الـــــتقــــــديــــــــــــر
  2. [6852]
    اذا امكن كتاب applied fluid mechanics by chow
    حلول كتاب fluid mechanics by streeter
  3. [6853]
    الصورة الرمزية هاني سليمان
    Received: 16
    اقتباس المشاركة الأصلية كتبت بواسطة gardina مشاهدة المشاركة
    thesis details
    subject
    valve timing, charge dilution and cycle-to-cycle stability of work output of a spark ignition engine
    link
    http://ethos.bl.uk/orderdetails.do?d...l.ethos.417943
    author: lai, wing cheung william. awarding institution: university of nottingham current institution: university of nottingham awarded: 2005
    qualification name:thesis (ph.d.)--university of nottingham, 2005
    ethos persistent id:
    uk.bl.ethos.417943
    subject
    characterisation of emissions and combustion stability of a port fuelled spark ignition engine
    link
    http://ethos.bl.uk/orderdetails.do?d...l.ethos.514811
    author: brown, nicholas m awarding institution: university of nottingham current institution: university of nottingham awarded: 2009
    uk.bl.ethos.514811
    subject
    an investigation into the effects of variable valve actuation on combustion and emissions in an si engine.
    link
    http://ethos.bl.uk/orderdetails.do?d...l.ethos.312736
    author: ghauri, ahmar. awarding institution: university college london (university of london) current institution: university college london (university of london) awarded: 1999
    qualification name:
    Phd thesis
    ethos persistent id:uk.bl.ethos.312736
    subject
    matching of internal combustion engine characteristics for continuously variable transmissions
    link
    http://ethos.bl.uk/orderdetails.do?d...l.ethos.443334
    author: bonnet, baptiste awarding institution: cranfield university current institution: cranfield university awarded: 2007
    advisor: vaughan, n. D. (supervisor)
    qualification name:phd
    ethos persistent id:uk.bl.ethos.443334
    اخي الكريم..
    ليس لدي اكسس الي المكتبة البريطانية
    لا تقول لي شكرا.. بل ادعوا الله لي بان يوفقني و يرحم والدي
  4. [6854]
    Received: 16
    اقتباس المشاركة الأصلية كتبت بواسطة tareg-123 مشاهدة المشاركة
    ارجو هذه الاوراق مشكورا
    The Research of Double-Driven Electric Vehicle Stability Control System
    http://ieeexplore.ieee.org/search/fr...d%3DSearch+All
    Motor torque based vehicle stability control for four-wheel-drive electric vehicle
    A Simulation of Vehicle Lateral Stability Based on Fuzzy PID Control
    Estimation of road grade and vehicle mass via model predictive control
    Intelligent control method of vehicle's starting on slope road
    Constructing Equations of Motion for a Vehicle Rigid Body Model
    http://papers.sae.org/2008-01-2751
    http://www.4shared.com/document/6ucGULpt/05289613.html
    http://www.4shared.com/document/aStieQPy/05203408.html
    http://www.4shared.com/document/pA_H_aqh/05203117.html
    http://www.4shared.com/document/gZRLf8W4/01507359.html
    http://www.4shared.com/document/QcVs5m8f/01384478.html
    http://www.4shared.com/document/DSDKJOqa/01342022.html
  5. [6855]
    Received: 16
  6. [6856]
    Received: 16
    اقتباس المشاركة الأصلية كتبت بواسطة eng-hym مشاهدة المشاركة
    ابحاث فقط..
    اسف جدا
  7. [6857]
  8. [6858]
    اقتباس المشاركة الأصلية كتبت بواسطة هاني سليمان مشاهدة المشاركة
    اخي الكريم..
    شكرا جزيلا عالجهود المبذولة ... وفقك الله ويسر امرك
  9. [6859]
    تحية طيبة
    ارجو التفضل بالمساعدة ولكم جزيل الشكر
    Combustion Engines Development
    Mixture Formation, Combustion, Emissions and Simulation
    With contributions by numerous specialists
    Merker, Günter P.; Schwarz, Christian; Teichmann, Rüdiger (Eds.)
    Hardcover, ISBN 978-3-642-02951-6
    link
    http://www.springer.com/engineering/...-3-642-02951-6
    Decreasing of Fuel Consumption and Emissions
    Sensing, Control and Reduction of Emissions
    Series: Green Energy and Technology
    Palocz-Andresen, Michael
    Hardcover, ISBN 978-3-642-11975-0
    Due: October 14, 2011
    link
    http://www.springer.com/engineering/...-3-642-11975-0
    Detection and Diagnosis of Stiction in Control Loops
    State of the Art and Advanced Methods
    Series: Advances in Industrial Control
    Jelali, Mohieddine; Huang, Biao (Eds.)
    Hardcover, ISBN 978-1-84882-774-5
    link
    http://www.springer.com/engineering/...-1-84882-774-5
    Process Control Performance Assessment
    From Theory to Implementation
    Ordys, Andrzej; Uduehi, Damien; Johnson, Michael A. (Eds.)
    Hardcover, ISBN 978-1-84628-623-0
    link
    http://www.springer.com/engineering/...-1-84996-630-6
    شــــــكـــــــرا جــــــــزيــــــــلا .... وفــــقـــكـــــــم اللــــــــــــــــــــــــــــــــه
  10. [6860]
    Received: 16
    combustion engines development
    mixture formation, combustion, emissions and simulation
    with contributions by numerous specialists
    merker, günter p.; schwarz, christian; teichmann, rüdiger (eds.)
    hardcover, isbn 978-3-642-02951-6
    link
    decreasing of fuel consumption and emissions
    sensing, control and reduction of emissions
    series: green energy and technology
    palocz-andresen, michael
    hardcover, isbn 978-3-642-11975-0
    due: October 14, 2011
    link
    detection and diagnosis of stiction in control loops
    state of the art and advanced methods
    series: advances in industrial control
    jelali, mohieddine; huang, biao (eds.)
    hardcover, isbn 978-1-84882-774-5
    link
    process control performance assessment
    from theory to implementation
    ordys, andrzej; uduehi, damien; johnson, michael a. (eds.)
    hardcover, isbn 978-1-84628-623-0
    link
    هذه كتب و ليس ابحاث..
