صفحة 598 من 864 الأولىالأولى ... 98498548588594 595 596 597 598599 600 601 602 608648698 ... الأخيرةالأخيرة
النتائج 5,971 إلى 5,980 من 8635
  1. [5971]
    اسم الكتاب
    Effect of Tire Pressure on Flexible Pavement
  2. [5972]
    الصورة الرمزية نجمة السماء
    ممكن مساعدتي بالحصول على البحث التالي شاكرة لكم المساعدة:
    Sciencedirect من مجلة
    Year round performance studies on a built-in storage type solar water heater at Jodhpur, India
    References and further reading may be available for this article. To view references and further reading you must purchase this article.
    H.P. Garga
    aCentral Arid Zone Research Institute, Jodhpur, India
    Received 3 July 1974;
    revised 16 December 1974.
    Available online 7 August 2003
  3. [5973]
    السلام عليكم محتاج الى هذه البحوث
    السلام عليكم اخواني مهندسي الخير
    احتاج الى البحوث المدرجة ادناه ولكم جزيل الشكر والتقدير
    1. على مجلة science direct
    Flexural behavior of polyester polymer concrete
    volume 17 , 1ssue 2
    C. Vipulanandana and N. Dharmarajana
    A Department of Civil Engineering University of Houston Houston, Texas 77004, USA
    Received 10 October 1986; accepted 15 December 1986. Available online 12 February 2003
    2. على مجلة springlink
    Water Resistance of Polyester Polymer Concrete
    Mechanics of Composite Materials
    Volume 39, Number 2, 99-110, DOI: 10.1023/A:1023407910034
    R. D. Maksimov, L. A. Jirgens, E. Z. Plume and J. O. Jansons
    3-Mechanical properties of polyester polymer-concrete
    R. D. Maksimov, L. Jirgens, J. Jansons and E. Plume
    Volume 35, Number 2, 99-110, DOI: 10.1007/BF02257239
    Comparative Studies on the Mechanical Properties of a Thermoset Polymer in Tension and Compression
    Volume 41, Number 5, 425-436, DOI: 10.1007/s11029-005-0068-y
    R. D. Maksimov, E. Z. Plume and J. O. Jansons
    Chapter 45. Durability of polyester polymer concrete under varying temperature and moisture
    S. Galan , M. Robles , and R. Aguilar
    Citation Information
    Excellence in Concrete Construction through Innovation
    Proceedings of the conference held at the Kingston University, United Kingdom, 9 - 10 September 2008
    Edited by Hsein Y. Kew and Mukesh C. Limbachiya
    Taylor & Francis 2009
    Print ISBN: 978-0-415-47592-1
    eBook ISBN: 978-0-203-88344-0
    DOI: 10.1201/9780203883440.ch45
    ورحم الله والديكم وجزاكم الله الف خير
  4. [5974]
    محتاج هذه البحوث رجاءا
    1. على مجلة الـ Sciencedirect
    1- Flexural behavior of polyester polymer concrete
    volume 17 , 1ssue 2
    2. على مجلة الـ springlink
    2-Water Resistance of Polyester Polymer Concrete
    4- Comparative Studies on the Mechanical Properties of a Thermoset Polymer in Tension and Compression
    5- Chapter 45. Durability of polyester polymer concrete under varying temperature and moisture
  5. [5975]
    volume 17 , 1ssue 2
  6. [5976]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة مسلم البصري مشاهدة المشاركة
    أخي العزيز شكرا جزيلا لك
    ارجو منك البحوث التالية كلها بنفس الرابط لو تفظلت بها علي:
    1-Closure to "Stress-Strain Curves for Brick Masonry in Biaxial Compression" by Krishna Naraine and Sachchidanand Sinha (June, 1992, Vol. 118, No. 6)
    J. Struct. Engrg. 120, 1049 (1994)
    2-Discussion of "Stress-Strain Curves for Brick Masonry in Biaxial Compression" by Krishna Naraine and Sachchidanand Sinha (June, 1992, Vol. 118, No. 6)
    Manicka Dhanasekar and Adrian Page
    J. Struct. Engrg. 120, 1048 (1994)
    3-Stress-Strain Curves for Brick Masonry in Biaxial Compression
    J. Struct. Engrg. 118, 1451 (1992)
    الرابط هو:http://ascelibrary.aip.org/vsearch/s...on&maxdisp=25&[search].x=0&[search].y=0&frommonth=&fromday=&fromyear=&tomonth=&today= &toyear=&fromvolume=&fromissue=&tovolume=&toissue= &page=1&origquery=&vdk_query=&chapter=0&docdisp =0
    http://www.4shared.com/document/xHX_...for_Brick.html
    http://www.4shared.com/document/pKbR...FOR_BRICK.html
  7. [5977]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة abc-ahmed مشاهدة المشاركة
    volume 17 , 1ssue 2
    السلام عليكم€..
    هذا الجورنال الاول واما الباقيات فسارفعها لا حقا ان شاء الله تعالى
    لك مني كل التقدير... ارجو ملاحظة عدم التكرار هذا في المشاركات كي لا تشتت عملي
    http://www.4shared.com/document/j9WY...polyester.html
  8. [5978]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة نجمة السماء مشاهدة المشاركة
    H.P. Garga
    هذا ما طلبتيه
    لك مني كل التقدير
    http://www.4shared.com/document/W18f...e_studies.html
  9. [5979]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة admamer123 مشاهدة المشاركة
    اسعد الله اوقاتكم...........انني اريد research papers لمادة data communications and networking
    الرجاء لمن لديه اعلامي..........
    الاخ الكريم.. السلام عليكم
    عليك ان تبحث بنفسك في المواقع المذكوره سلفا وانا مهمتي ان انزل البحوث التي تطلبها
    لانه لا يوجد الوقت للبحث للجميع فنحن مثل طلبه وعلينا من الواجبات الكثير
    تقب لتقديري
  10. [5980]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة احمد بلتاجى مشاهدة المشاركة
    اريد الحصول على
    thickness design – asphalt pavement for highways and streets
    ninth edition, the asphalt institute, manual series no.1 (ms-1),1991.
    الاخ احمد.. السلام عليكم
    ارجو توضيح ماذا تريد؟ هل هو كتاب ام بحث وفي اي موقع
    تقبل تحياتي
