صفحة 594 من 864 الأولىالأولى ... 94494544584590 591 592 593 594595 596 597 598 604644694 ... الأخيرةالأخيرة
النتائج 5,931 إلى 5,940 من 8639
  1. [5931]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة رضوان بن مشاهدة المشاركة
    شكرا جزيلا و جزاك الله خيرا
    1/
    Titre du document / Document title
    Experimental studies on R134a-DMAC hot water based vapour absorption refrigeration systems
    Auteur(s) / Author(s)
    MUTHU V. (1) ; SARAVANAN R. (1) ; RENGANARAYANAN S. (1) ; Affiliation(s) du ou des auteurs / Author(s) Affiliation(s)
    (1) Institute for Energy Studies, Anna University, Chennai 600 025, INDE
    Revue / Journal Title
    International journal of thermal sciences ISSN 1290-0729 Source / Source
    2008, vol. 47, no2, pp. 175-181 [7 page(s) (article)] (7 ref.)
    2/
    Absorption system based on the refrigerant R134a
    BORDE I. (1) ; JELINEK M. ; DALTROPHE N. C. ; Affiliation(s) du ou des auteurs / Author(s) Affiliation(s)
    (1) Ben-Gurion univ. Negev, mechanical eng. dep., Beer-Sheva 84105, ISLANDERevue / Journal Title
    International journal of refrigeration ISSN 0140-7007 CODEN IJRFDI Source / Source
    1995, vol. 18, no6, pp. 387-394 (12 ref.)
    3/
    Performance of diffusion absorption refrigeration cycle with organic working fluids
    A. Zohara, M. Jelineka, A. Levy, a, and I. Bordea
    International Journal of Refrigeration
    Volume 32, Issue 6, September 2009, Pages 1241-1246
    هذه البحوث التي طلبتها
    لك مني كل التقدير
    http://www.4shared.com/document/pVSV...ed_on_the.html
    http://www.4shared.com/document/TWYe...on_R134a-.html
    http://www.4shared.com/document/d085...ion_absor.html
  2. [5932]
    Received: 11
    جزاك الله ألف ألف ألف خير
    أنا شاكر جدا جدا جدا
    هل بالامكان برنامج REFPROP 8 and the interface with EES
    1/
    Solar pond operated R134a based vapour absorption heat transformer for process heat generation
    MURUGESAN S. N. (1) ; SARAVANAN R. (2) ; RENGANARAYANAN S. (2) ; MOHAMED K. P. (1) ; Affiliation(s) du ou des auteurs / Author(s) Affiliation(s)
    (1) Department of Mechanical Engineering, Cresent Engineering College, Vandalur, Chennai 600 048, INDE
    (2) Institute for Energy Studies, Anna University, Chennai 600 025, INDE
    International journal of ambient energy ISSN 0143-0750 CODEN IJAEDW Source / Source
    2001, vol. 22, no3, pp. 155-162 (18 ref.)
    2/
    Comparison of various working pairs for absorption refrigeration systems: application of R21 and R22 as refrigerants
    S Kumara, M Prévostb and R Bugarelb
    aSchool of Energy, Environment and Natural Resources, Madurai Kamaraj University, Madurai 625 021, India
    bLaboratoire d'Energétique des Procédés, Ecole Nationale Supérieure d'Ingénieurs de Génie Chimique, Chemin de la loge, 31078 Toulouse Cedex, France
    Volume 14, Issue 5, September 1991, Pages 304-310
    3/
    pTx Measurements for Some Working Fluids for an Absorption Heat Transformer: 1,1,1,2-Tetrafluoroethane (R134a) + Dimethylether Diethylene Glycol (DMEDEG) and Dimethylether Triethylene Glycol (DMETrEG)
    Raouf Zehioua, Christophe Coquelet, Abdeslam-Hassen Meniai and Dominique Richon*
    Laboratoire de l’Ingnierie des Procds de l’Environnement (LIPE), Dpartement de Chimie Industrielle, Universit Mentouri Constantine, Route Ain El Bey, Constantine 25017, Algrie, and Mines ParisTech, CEP/TEP-Centre Energtique et Procds, 35 Rue Saint Honor, 77305 Fontainebleau, France
    J. Chem. Eng. Data, 2010, 55 (8), pp 2769–2775
    DOI: 10.1021/je9009915
    Publication Date (Web): February 12, 2010
    Copyright © 2010 American Chemical Society
    استطعت ان اجد واحده.. اما الاخريات فارجو الاهتمام بطريقة الكتابه لانه عليك ان تعرف انني لا افهم تخصصك كما تفهمه انت.. فانا حين اقرا ما تكتبه لا افهم اين العنوان واين المؤلف واين الجورنال ..وخاصة ان قسم منها بالفرنسي
    ارجو الاهتمام بذلك كي تعيننا على التواصل
    تقبل مني كل التقدير
    http://www.4shared.com/document/FHG4..._working_.html
  3. [5933]
    طلب مساعدة
    اخي العزيز ارجو من الله ان يوفقك في حياتك ويستر عليك بستره ويرزقك من حيث تحتسب ومن حيث لاتحتسب
    اخي ارجو منك البحوث التالية:
    1. R. H. WOOD and L. G. SIMMS, A tentative design method for the composite action of heavily loaded brick panel walls supported on reinforced concrete beams,
    Current research paper CP26/69, Building Research Station, U.K. (1969).
    2. S. ROSENHAUPT, Experimental studies of masonry walls on beams ,J. Struct. Div. ASCE, 88, 137 (1962).
    3. S. ROSENHAUPr and Y. SOKAL, Masonry walls on continuous beams, J. Struct. Div. ASCE, 91, 155 (1965).
    4. P. BURHOUSE, Composite action between brick panel walls and their supporting beams, 1CEProceedings, 43, 175 (1969).
    5. S. ROSE~AUPT, Stresses in point supported composite walls, ACI Proceedings, 61, 795(1964).
    6. A. COULL, Composite action of walls supported on beams, Build. Sci., 1, 259 (1966).
  4. [5934]
    اخي العزيز ارجو منك هذا الفصل وجدته في موقع scirus
    Chapter6: FE Modelling of Masonry Shear Walls 155 CHAPTER 6 FINITE... [PDF-7MB]
    Apr 2007
    ...criterion for masonry can be found...1996). A discrepancy between the values...analysis of URM walls reported...Modelling of Masonry Shear Walls 164 The...criterion for masonry can be found...contains a composite yield surface of tension...
    [http://library-resources.cqu.edu.au/...dt-QCQU/up...]
  5. [5935]
    جزاك الله خير اخى رفاق الصحراء على المجهود
  6. [5936]
    متشكرة جدا على مجهودك وتعبك ولك جزيل الشكر
  7. [5937]
    Received: 11
    اقتباس المشاركة الأصلية كتبت بواسطة مسلم البصري مشاهدة المشاركة
    Apr 2007
    السلام عليكم... اخي الفاضل.. هذا هو الفصل واسال الله ان ينفعك به ولكن ارجو ان تبحث جيدا قبل ان ترسل لي العنوان فربما تجده انت بسهوله كي تعطيني الوقت لخدمة الاخرين وللاشياء الصعبه
    تقبل مني كل التقدير
    http://www.4shared.com/document/a8Hl...ING_OF_MA.html
  8. [5938]
    Received: 11
    اخي الكريم.. لم اجد الا هذه الجورنال الى الان لان الوقت ضيق جدا
    ربما اجد الباقيات فيما بعد
    اذا احتجت المزيد فانا جاهز ان شاء الله تعالى لكن ارجو توضيح اسم المجله
    تقبل تقديري
    http://www.4shared.com/document/rjeH...alls_supp.html
  9. [5939]
    شكر وتقدير
    اخي العزيز اشكرك جزيل الشكر وأسال من الله العلي القدير ان يوفقك في الدنيا والاخرة
    شكر يارفاق الصحراء
  10. [5940]
    أخي العزيز رفاق الصحراء ارجو منك ان لاتنسى البحوث الباقية لحاجتي الملحة لها
    بالتوفيق يااخي العزيز
