صفحة 58 من 864 الأولىالأولى ... 84854 55 56 57 5859 60 61 62 68108158558 ... الأخيرةالأخيرة
النتائج 571 إلى 580 من 8635
  1. [571]
    merci pour les dernieres articles que vous m'avez envoyez je cherche aussi le journal " Earthquake engineering " pour les année suivante 2000- jusqu'a 2007 je vous remerci d'avance .
  2. [572]
    الف شكر أخي العزيز
  3. [573]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة ابو بكر الجبوري مشاهدة المشاركة
    السلام عليكم ارجو مساعدتكم في الحصول على المقالات التاليه وتقبلوا مني احلى التحايا واخلص الدعوات
    1. El- Nasr, M., and El- Haggar, S., Performance of a Wickless Heat Pipe Solar Collector, J. Energy Sources, v. 15, n. 3, pp.513- 522, 1993.
    2. Sivaraman, B. and Mohan, N., Experimental analysis of heat pipe solar collector with different L/d(i) ratio of heat pipe, J. Scientific and Industrial research, v. 64, n. 9, pp. 698- 701, 2005.
    3. Shah, L. and Furbo, S., Modeling shadows on evacuated tubular collectors with cylindrical absorbers, ASME J. Solar Energy Engineering, v. 127, n. 3, pp. 333- 342, 2005.
    4. Devarakonda, A.; Xiong, D. and Beach, D., Intermediate Temperature Water Heat Pipe Tests, NASA Report, NASA/TM- 213581- 200 5.
    5. Shiraishi, M.; Kim, Y., Murakami, M. and Terdtoon, P., A correlation for the heat transfer rate in an inclined two- phase closed thermosyphon, in: Proceedings of the 5th int. heat pipe symposium, Melbourne, 1996.
    6. Terdtoon, P.; Ritthidej, S. and Shiraishi, M., Effect of aspect ratio and Bond number on heat transfer characteristics of an inclined two- phase closed thermosyphon at normal operating conditions, in: Proceedings of the 5th int. heat pipe symposium, Melbourne, 1996.
    7. Shalaby, M.; Araid, F.; Sultan, G. and Awad, M., Heat transfer performance of a two- phase closed thermosyphon, in: Proc. of the 6th int. heat pipe symposium, Chiang Mia, pp. 269- 278, 2000.
    8 .Chun, W., Kang, Y.H., Kwak, H.Y., Lee, Y.S., 1999. An experimental study of the utilization of heat pipes for solar water heaters. Applied Thermal Engineering 19, 807–817
    لم أجد الا الاخيرة
    • نوع الملف: pdf 001.pdf‏ (408.1 كيلوبايت, 6 مشاهدات)
  4. [574]
    نأمل من الاخوة الكرام ايجاد طريقة التحليل الكيميائى التالية:-
    EPA Method Number 3050 or 3050A
    ولكم منى جزيل الشكر والامتنان
  5. [575]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة عامرمحمد مشاهدة المشاركة
    السلام عليكم و رحمته و بركاتة
    بعد الاطلاع على الرابط توجد البحوث التالية
    1 http://scirus.com/srsapp/sciruslink?src=web&url=http%3A%2F%2Fwww.rilem.net% 2Ffiche.php%3Fcat%3Dconference%26reference%3Dpro03 2-156
    2 http://scirus.com/srsapp/sciruslink?src=sd&url=http%3A%2F%2Fwww.sciencedire ct.com%2Fscience%3F_ob%3DGatewayURL%26_origin%3DSc ienceSearch%26_method%3DcitationSearch%26_piikey%3 DS0143974X05000787%26_version%3D1%26_returnURL%3Dh ttp%253A%252F%252Fwww.scirus.com%252Fsrsapp%252Fse arch%253Fq%253DEXTERNAL%252BAND%252BPRESTRESS%2526 t%253Dall%2526drill%253Dyes%2526p%253D0%26md5%3D1b ce3f6b43df9814acd53b4a6412c5df
    3 http://scirus.com/srsapp/sciruslink?src=pat&url=http%3A%2F%2Fv3.espacenet.c om%2Ftextdoc%3FDB%3DEPODOC%26IDX%3DEP1076742%26F%3 D0
    4 http://scirus.com/srsapp/sciruslink?src=sd&url=http%3A%2F%2Fwww.sciencedire ct.com%2Fscience%3F_ob%3DGatewayURL%26_origin%3DSc ienceSearch%26_method%3DcitationSearch%26_piikey%3 DS0143974X05001598%26_version%3D1%26_returnURL%3Dh ttp%253A%252F%252Fwww.scirus.com%252Fsrsapp%252Fse arch%253Fq%253DEXTERNAL%252BAND%252BPRESTRESS%2526 t%253Dall%2526drill%253Dyes%2526p%253D0%26md5%3D81 00664cc5f7da0e6222a70622955d27
    5 http://scirus.com/srsapp/sciruslink?src=sd&url=http%3A%2F%2Fwww.sciencedire ct.com%2Fscience%3F_ob%3DGatewayURL%26_origin%3DSc ienceSearch%26_method%3DcitationSearch%26_piikey%3 DS0958946505000600%26_version%3D1%26_returnURL%3Dh ttp%253A%252F%252Fwww.scirus.com%252Fsrsapp%252Fse arch%253Fq%253DEXTERNAL%252BAND%252BPRESTRESS%2526 t%253Dall%2526drill%253Dyes%2526p%253D0%26md5%3D1c 4eb160cc13105af287f5c7d5c41e0e
    6 http://scirus.com/srsapp/sciruslink?src=sd&url=http%3A%2F%2Fwww.sciencedire ct.com%2Fscience%3F_ob%3DGatewayURL%26_origin%3DSc ienceSearch%26_method%3DcitationSearch%26_piikey%3 DS0143974X06000186%26_version%3D1%26_returnURL%3Dh ttp%253A%252F%252Fwww.scirus.com%252Fsrsapp%252Fse arch%253Fq%253DEXTERNAL%252BAND%252Bprestressed%25 2BAND%252Bconcrete%252BAND%252Bbeam%252BAND%252Bex perimental%2526t%253Dall%2526drill%253Dyes%2526p%2 53D0%26md5%3Df2a10b3ae8cd7a7b4201e809def58d08
    7 http://scirus.com/srsapp/sciruslink?src=sd&url=http%3A%2F%2Fwww.sciencedire ct.com%2Fscience%3F_ob%3DGatewayURL%26_origin%3DSc ienceSearch%26_method%3DcitationSearch%26_piikey%3 DS0141029606001313%26_version%3D1%26_returnURL%3Dh ttp%253A%252F%252Fwww.scirus.com%252Fsrsapp%252Fse arch%253Fq%253DEXTERNAL%252BAND%252Bprestressed%25 2BAND%252Bconcrete%252BAND%252Bbeam%252BAND%252Bex perimental%2526t%253Dall%2526drill%253Dyes%2526p%2 53D0%26md5%3D7c17bbf15eaf8211d27c0563ee6aa2ea
    8 http://scirus.com/srsapp/sciruslink?src=sd&url=http%3A%2F%2Fwww.sciencedire ct.com%2Fscience%3F_ob%3DGatewayURL%26_origin%3DSc ienceSearch%26_method%3DcitationSearch%26_piikey%3 DS0141029605003408%26_version%3D1%26_returnURL%3Dh ttp%253A%252F%252Fwww.scirus.com%252Fsrsapp%252Fse arch%253Fq%253DEXTERNAL%252BAND%252Bprestressed%25 2BAND%252Bconcrete%252BAND%252Bbeam%252BAND%252Bex perimental%2526t%253Dall%2526drill%253Dyes%2526p%2 53D0%26md5%3D602ba76838e7353bcc97fb7b05ef79f6
    9 http://scirus.com/srsapp/sciruslink?src=sd&url=http%3A%2F%2Fwww.sciencedire ct.com%2Fscience%3F_ob%3DGatewayURL%26_origin%3DSc ienceSearch%26_method%3DcitationSearch%26_piikey%3 DS0143974X04001385%26_version%3D1%26_returnURL%3Dh ttp%253A%252F%252Fwww.scirus.com%252Fsrsapp%252Fse arch%253Fq%253DEXTERNAL%252BAND%252Bprestressed%25 2BAND%252Bconcrete%252BAND%252Bbeam%252BAND%252Bex perimental%2526t%253Dall%2526drill%253Dyes%2526p%2 53D0%26md5%3D8b1578c0e0e271740f7af54e1ec72aa6
    10 http://scirus.com/srsapp/sciruslink?src=web&url=http%3A%2F%2Fwww.civag.unim elb.edu.au%2Fejse%2FArchives%2FFulltext%2F200201%2 F07%2F20020107.doc
    11 http://scirus.com/srsapp/sciruslink?src=sd&url=http%3A%2F%2Fwww.sciencedire ct.com%2Fscience%3F_ob%3DGatewayURL%26_origin%3DSc ienceSearch%26_method%3DcitationSearch%26_piikey%3 DS0141029605003391%26_version%3D1%26_returnURL%3Dh ttp%253A%252F%252Fwww.scirus.com%252Fsrsapp%252Fse arch%253Fq%253DEXTERNAL%252BAND%252Bprestressed%25 2BAND%252Bconcrete%252BAND%252Bbeam%252BAND%252Bex perimental%2526t%253Dall%2526drill%253Dyes%2526p%2 53D0%26md5%3D9c7c4a7f35bd39d471c455b052f6a788
    12 http://scirus.com/srsapp/sciruslink?src=ndl&url=http%3A%2F%2Fwww4.gu.edu.au %3A8080%2Fadt-root%2Fpublic%2Fadt-QGU20030102.094646
    اكون شاكرا لكم ان تساعدوني في الحصول عليها و انقاذي
    بارك الله فيكم وجعله في ميزان اعمالكم و جزاكم الله خيرا
    عامر
    أخي الكريم
    تفضل هذا ما طلبت
    http://www.4shared.com/file/17129063...papers591.html
  6. [576]
    الاخوة الكرام نأمل منكم الحصول على هذه المعلومة :- EPA Method Number 3050 or 3050A
    وهى طريقة تتحدث عن فصل العناصر الثقيلة من التربة كيميائيا وتصدر هذه الطريقة من وكالة حماية البيئة الامريكية US EPA
  7. [577]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة djamel-al مشاهدة المشاركة
    أخي العزيز أرجو منك الكتابة باللغة الانجليزية أو العربية حيث انني لا اتقن اللغة الفرنسية
    المجلة متوفرة من 1999 حتى 2007
    أي عدد تريد منها؟
  8. [578]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة شوفا مشاهدة المشاركة
    سبحان الله الرد الاسهل عندك غير متوفر انتا علوز اجبلك البحث
    على العموم شكرا
    حياك الله واهلا بك
  9. [579]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة قادربوه مشاهدة المشاركة
    هل هي موجودة في احدى المجلات العالمية؟
  10. [580]
    جزاك الله عني كل خير اكون ممنون منك لو حاولت الحصول لي على باقي البحوث لاني احتاجها بشده في بحثي لرسالة الدكتوراه وبحثت عنها كثيرا بدون فائده علما اني من العراق ولا يخفى عليكم ظروفنا في العراق ولكم مني كل الشكر والتقدير
