صفحة 53 من 864 الأولىالأولى ... 34349 50 51 52 5354 55 56 57 63103153553 ... الأخيرةالأخيرة
النتائج 521 إلى 530 من 8637
  1. [521]
    أنا آسف لإزعاجك وأرجو منك هذه الأبحاث
    1. L. Pavesi, and G. Guillot, (Eds.), Optical Interconnects: The Silicon Approach, Springer-Verlag Berlin Heidelberg, Springer Series in Optical Sciences, 2006.
    2. S.K. Dash, “Use of Parallel Processors in Numerical Weather Prediction and Climate Modeling.” 2nd Int. Workshop on parallel processing and Supercomputing Application in science and Engineering, ICTP 9-27 Sep., Trieste, ITALY, 1996.
    3. M. S. Warren, D.J. Bechker, M. P. Goda, J. K. Salmon, and T. Sterling, “Parallel Supercomputing with commodity computers, Proc. PDPTA,pp. 1372-1381, 1997. {hhtp”// loki-www.lanl.gov /papers/pdpta97/ }.
    4. S.J. Sistare, and C.J. Jackson, “Ultra-High Performance Communications with MPI and the Sun Fire TM Link Interconnect,” Sun Micro systems, Inc. tever.sistare@sun.com, 2002.
    5. D. H. Basly,D. Broadhurst, Y.Hiola X. S. Li, and B. Thompson, “High Performance Computing Meets Experimental Mathematics” 2002 IEEE.
    6. H. M. Elgazzaz, Domain and Function Decomposition in Multiprocessor System, Ph.D. Thesis, Dept. Computer Science and Engineering, Fac. Elect. Eng., Menoufia Univ., 2003.
    7. Nan M. Jokerest, Martin A. Brooke, Sang-Yesn Cho, Scott Wilkinson, and D. Scott Wills,"The Heterogenous Integration of Optical Interconnects into Integrated Microsystems", IEEE Journal of Selected Topics in Quantum Electronics, Vol. 9, No. 2, pp. 350-360, March/April 2003.
    8. Donald M. Chiarulli, Rami G. Melhem, and James P. Teza, "Optoelectronic Buses for High-performance Computing", Processing of the IEEE, Vol. 82, No. 11, pp. 1701-1710, November 1994.
    9. Sadakuni Shimada, and Takao Matsumoto,"Very-High-Speed Optical Signal Processing", Processing of the IEEE, Vol. 81, No. 11, pp. 1633-1646, November 1993.
    10. Alain Z. Shang, and Frank A. P. Tooler,"Digital Optical Interconnects for Networks and Computing Systems", Journal of Lightwave Technol., Vol. 18, No. 12, pp. 2086-2094, Dec. 2000.
  2. [522]
    please I need this book
    السلام عليكم ورحمة الله وبركات
    Advanced thermally assisted surface engineering processes
    BY RAMNARAYAN CHATTOPADHYAY
    و السلام عليكم ورحمة الله وبركات
  3. [523]
    please ineed this paper
    Titre du document / Document title
    Etude comparative de différents systèmes de pompage éolien. Application au cas de la Tunisie (Comparative study of different wind pumping systems. Application to the case of Tunisia)
    Auteur(s) / Author(s)
    MARZOUKI Jamel ; Affiliation(s) du ou des auteurs / Author(s) Affiliation(s)
    Ec. natl. supér. arts métiers (Paris), INCONNU
    Résumé / Abstract
    Etablissement d'un diagramme facilitant le choix d'une installation de pompage éolienne. Calcul du potentiel éolien et aquifère de nombreux sites tunisiens. Analyse du couplage entre aéromoteur à axe vertical et pompe. Expérimentations de validation de deux types de couplage: aéromoteur lent-pompe volumétrique et aéromoteur rapide-turbopompe. Comparaison technique et économique de ces deux modes de couplage Source / Source
    Travaux Universitaires
    1983, [Note(s) : [181] f.] (42 ref.) Travaux universitaires (Année de soutenance : sd) (Discipline : Génie méc.) Source : Français ; Mots-clés anglais / English Keywords
    Wind energy ; Wind mill ; Vertical axis ; Pumping ; Use ; Coupling ; Positive displacement pump ; Centrifugal pump ; Application ; France ; Tunisia ; Experimental study ; Pump ; Theoretical study ; Mots-clés français / French Keywords
    Energie éolienne ; Aéromoteur ; Axe vertical ; Pompage ; Utilisation ; Couplage ; Pompe volumétrique ; Pompe centrifuge ; Application ; France ; Tunisie ; Etude expérimentale ; Pompe ; Etude théorique ;
    230c04 ; 001d06c04 ; Localisation / Location
    Copyright 2006 INIST-CNRS. All rights reserved
    Toute reproduction ou diffusion même partielle, par quelque procédé ou sur tout support que ce soit, ne pourra être faite sans l'accord préalable écrit de l'INIST-CNRS.
    No part of these records may be reproduced of distributed, in any form or by any means, without the prior written permission of INIST-CNRS.
    Nº notice refdoc (ud2m) : 9534593
  4. [524]
  5. [525]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة malika_ahmed مشاهدة المشاركة
    essalamo alaikom
    please i need theses papers
    Fluid dynamics wind turbine design: Critical analysis, optimization and application of BEM theory
    Renewable Energy, In Press, Corrected Proof, Available online 20 February 2007,
    R. Lanzafame and M. Messina
    الاخت الكريمة malika ahmed
    هذا ما طلبتي (25 ورقة) ولم أجد ورقة قديمة
    الملفات مضغوطة وحجمها كبير, لذا أرجو منكي اخباري عند تنزيلها لكي اتمكن من مسحها من موقعي
    اتمنى لك التوفيق
    بالمناسبة الاوراق العلمية الفرنسية غير متوفرة
    http://www.4shared.com/file/16818712...papers994.html
  6. [526]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة hegazy2020 مشاهدة المشاركة
    وجدت أربعة منها, تفضل
    http://www.4shared.com/file/16819451...papers524.html
  7. [527]
    السلام عليكم ...
    من فضلك اخي الكريم هل يمكن ان توفر لي هدا البحث:
    On the bit error rate of lightwave systems with optical amplifiers
    Humblet, P.A. Azizoglu, M.
    الموجود في:
    http://ieeexplore.ieee.org/xpl/freea...97649&type=ref
    اسف ان كنت اثقلت عليك
  8. [528]
    1. An Interim Report 2003, “ The Future of Supercomputing,” computer science and Telecommunications Board (CSTB), The National Academies Press.
    2. M. K. Anderson, “ Public Computing on a Super Scale.,” http://www. wired.com/news/technology/o ,2004.
    3. J. Benner, “A Grid of Supercomputers,” http://www.wired.com/news/ technology/o, 2004.
    4. M. Shimasiki, “ Overview of Application of Supercomputing – Current Status and Future.,” IPSJ Magazine Abstract, Vol. 36, No. 2-004 JAPAN, 2003.
    5. G. Bell, and J. Gray, " High Performance Computing: Crays, Clusters, and Centers. What Next?", Communications of the ACM, No.1, Jan. 2002.
    6. J. Dongarra, T. Sterting , H. Simon, and E. Strohmaier, " High Performance Computing, Clusters, Constellations, MPPs, and Future Direction", Lawrence Berkeleg National Lab., erich @cs.utk.edu, June 2003.
    7. M. A. Kupinski, “Computing in Optics,” Computing in Sccience & Engineering, pp.13-22, Nov./Dec. 2003.
    8. J. H. Reif, and A. Yoshida," Optical Expanders with Applications in Optical Computing", July 20, 1999.
    9. S. Tokes, L. Orzo, C. Rekeczky, and T. Roska, “Dennis Gabor as the Initiator of Optical Computing”, Dennis Gabor Meorial Conf. and Symp., pp.1-14, June 2000.
    10. G. Allen et. Al., « Solving Einstens Equations on SuperComputres ,Computer, pp.52-58, Dec. 1999.
  9. [529]
    الصورة الرمزية saqure
    Post
    اقتباس المشاركة الأصلية كتبت بواسطة امل14 مشاهدة المشاركة
    السلام عليكم ...
    الموجود في:
    البحث المطلوب فى المرفقات
  10. [530]
    شكرا جزيلا و بارك الله فيك يا أخي الكريم
    وجزاك الله ألف خير
