صفحة 521 من 864 الأولىالأولى ... 21421471511517 518 519 520 521522 523 524 525 531571621 ... الأخيرةالأخيرة
النتائج 5,201 إلى 5,210 من 8635
  1. [5201]
    الصورة الرمزية AboJim
    اقتباس المشاركة الأصلية كتبت بواسطة ghghost مشاهدة المشاركة
    ممكن تحميل هذا الملف
    http://www.techniques-ingenieur.fr/b...ionnement.html
    http://ifile.it/qml9pjk/Ghost.zip
    من يريد أبحاث يطلبها في هذا المنتدى و سيتم الرد على طلبه
    http://university.arabsbook.com/forums/99
  2. [5202]
    اقتباس المشاركة الأصلية كتبت بواسطة shadowz911 مشاهدة المشاركة
    Dear,
    Thank you for this great effort,
    Can I have the following papers ?
    Laminar film flow down a wavy incline
    International Journal of Multiphase Flow, Volume 23, Issue 1, February 1997, Pages 69-79
    V. Bontozoglou, G. Papapolymerou
    Shear flow over cylindrical rods attached to a substrate
    Journal of Fluids and Structures, In Press, Corrected Proof, Available online 1 April 2010
    C. Pozrikidis
    An engineering model of a developed turbulent flow in a Couette device
    Chemical Engineering and Processing: Process Intensification, Volume 49, Issue 2, February 2010, Pages 219-224
    Dmitry Eskin
    Exact solution of two phase stratified flow through the pipes for non-Newtonian Herschel–Bulkley fluids
    International Communications in Heat and Mass Transfer, Volume 36, Issue 7, August 2009, Pages 768-775
    M. Firouzi, S.H. Hashemabadi
    A different approach to exact solutions in non-Newtonian second-grade of creeping fluid
    Applied Mathematics and Computation, Volume 191, Issue 2, 15 August 2007, Pages 484-489
    Muhammad Ali, Mahmood-ul-Hassan
    Exact solutions for the unsteady axial flow of Non-Newtonian fluids through a circular cylinder
    Communications in Nonlinear Science and Numerical Simulation, In Press, Accepted Manuscript, Available online 21 March 2010
    Imran Siddique, Zamra Sajid
    A note on the second problem of Stokes for Newtonian fluids
    International Journal of Non-Linear Mechanics, Volume 43, Issue 5, June 2008, Pages 451-457
    Corina Fetecau, D. Vieru, Constantin Fetecau
    Local non-similarity solutions for the flow of a non-Newtonian fluid over a wedge
    International Journal of Non-Linear Mechanics, Volume 36, Issue 6, September 2001, Pages 961-976
    Mehrdad Massoudi
    Exact solutions for the flow of a generalized Oldroyd-B fluid induced by a constantly accelerating plate between two side walls perpendicular to the plate
    Journal of Non-Newtonian Fluid Mechanics, Volume 156, Issue 3, February 2009, Pages 189-201
    Constantin Fetecau, Corina Fetecau, M. Kamran, D. Vieru
    New exact solutions corresponding to the second problem of Stokes for second grade fluids
    Nonlinear Analysis: Real World Applications, Volume 11, Issue 1, February 2010, Pages 584-591
    M. Nazar, Corina Fetecau, D. Vieru, C. Fetecau
    The flow of non-Newtonian fluids down inclines
    Journal of Non-Newtonian Fluid Mechanics, Volume 136, Issue 1, 15 June 2006, Pages 64-75
    I.D. Šutalo, A. Bui, M. Rudman
    Thanks in advance
    http://ifile.it/zbtmsuj/Shadow.zip
  3. [5203]
    اقتباس المشاركة الأصلية كتبت بواسطة عبدالله محمد صالح مشاهدة المشاركة
    انا مبسوط جدا من خدمتك ديه و من انك بتساعد الناس
    انا فعلا مقدر مجهودك ده الف شكر
    و بعد اذنك انا كنت عايز ال papers ديه عشان هاتفدني جدا في مشروع التخرج
    http://ieeexplore.ieee.org/Xplore/lo...hDecision=-203
    http://www.sciencedirect.com/science...ecc92a3caef09b
    http://portal.acm.org/citation.cfm?i...TOKEN=11490938
    متشكر جدا
    http://ifile.it/cjw7r6z/Abdulla.zip
  4. [5204]
  5. [5205]
    اقتباس المشاركة الأصلية كتبت بواسطة en.salam مشاهدة المشاركة
    السلام عليكم ورحمة الله, اخواني ممكن البحوث التالية حفظكم الله
    1. Heat transfer: A liquid flowing through a porous prism
    T.E.W. Schumann
    http://www.sciencedirect.com/science...46a7afd13596f1
    2. Economic design of a rock bed storage device for storing solar thermal energy
    C. Choudhury,M. Chauhan and H. P. Garg
    http://www.sciencedirect.com/science...f10d21a78c338b
    3. Time and spatial heat transfer performance around an isothermally heated sphere placed in
    a uniform, downwardly directed flow (in relation to the enhancement of latent heat storage
    rate in a spherical capsule)
    H. Koizumi
    http://www.sciencedirect.com/science...e9a3ce06b20d74
    4. Thermal characteristics of paraffin in a spherical capsule during freezing and melting processes
    Keumnam Cho and S. H. Choi
    http://www.sciencedirect.com/science...add1db3a84572e
    5. Experimental investigation on a combined sensible and latent heat storage system integrated
    with constant/varying (solar)heat sources
    N. Nallusamy, S. Sampath and R. Velraj
    http://www.sciencedirect.com/science...bf59a3a0702b6d
    6. Visualization study of the shrinkage void distribution in thermal energy storage capsules
    of different geometry
    Shripad T. Revankar and Travis Croy
    http://www.sciencedirect.com/science...1b9ead8f112e49
    7. Turbulent buoyant flows into a two dimensional storage tank
    L. Cai, W.E. Stewart Jr and C.W. Sohn
    http://www.sciencedirect.com/science...2ff3a666337b06
    8. Performance assessment of some ice TES systems
    David MacPhee and Ibrahim Dincer
    http://www.sciencedirect.com/science...81f205380a405d
    9. A numerical comparison of control strategies applied to an existing ice storage system
    Vincent Lemort
    http://www.sciencedirect.com/science...ddf55b5315b07a
    10. Heat transfer characteristics of cool-thermal storage systems
    Hee Wook Ryu, Seong Ahn Hong, Byung Chul Shin and Sang Done Kim
    http://www.sciencedirect.com/science...0d4d29cf624d09
    11. Natural convection melting of a frozen porous medium
    S. Chellaiah and R. Viskanta
    http://www.sciencedirect.com/science...91c7dcc6ebe0c6
    12. Laminar forced convection heat transfer in microcapsulated phase change material suspensions
    Manish Goel, S.K. Roy and S. Sengupta
    http://www.sciencedirect.com/science...5410d323778e37
    13. Effects of buoyancy-driven convection on melting within spherical containers
    J. M. Khodadadi and Y. Zhang
    http://www.sciencedirect.com/science...31689158b0faf5
    14. Computer simulation of moving-interface, convective, phase-change processes
    S. E. Hibbert, N. C. Markatos and V. R. Voller
    http://www.sciencedirect.com/science...df9aae65fed16b
    15. The problem of time-dependent natural convection melting with conduction in the solid
    Zhang Zongqin and Adrian Bejan
    http://www.sciencedirect.com/science...4869eab81af03f
    16. Review on sustainable thermal energy storage technologies, Part I: heat storage materials and techniques
    S. M. Hasnain
    http://www.sciencedirect.com/science...457dc4280b36b0
    17. Solar water heaters with phase change material thermal energy storage medium: A review
    Anant Shukla, D. Buddhi, and R.L. Sawhney
    http://www.sciencedirect.com/science...88d1ec4a11d9a8
    18. A review of solar thermal technologies
    Mirunalini Thirugnanasambandam, S. Iniyan and Ranko Goic
    http://www.sciencedirect.com/science...7b2c6c787c62f5
    http://ifile.it/a897lgj/Salam.zip
  6. [5206]
    الصورة الرمزية en.salam
    بارك الله فيك اخي ابوجم وغفر لك ولوالديك
    مني لك كل الشكر والتقدير
  7. [5207]
    ارجو التكرم توفير الورقة التالية ولكم جزيل الشكر
    1- Nanogranular packing of C–S–H at substochiometric conditions Matthieu Vandamme, Franz-Josef Ulm, and Philip Fonollosa, Cement and Concrete Research, Volume 40, Issue 1, January 2010, Pages 14-26
    2- ACI 216-07
  8. [5208]
  9. [5209]
    بارك الله فيك AboJim على الاهتمام
    وهذه هي الروابط
    http://ieeexplore.ieee.org/search/fr...d%3DSearch+All
  10. [5210]
