صفحة 50 من 864 الأولىالأولى ... 4046 47 48 49 5051 52 53 54 60100150550 ... الأخيرةالأخيرة
النتائج 491 إلى 500 من 8639
  1. [491]
    hello:
    i need this paper
    Water Science and Technology Vol 35 No 11-12 pp 107–112 © IWA Publishing 1997
    UV ability to inactivate microorganisms combined with factors affecting radiation
    A. M. Shaban, G. E. El-Taweel and G. H. Ali
    Water Pollution Research Department, National Research Centre Dokki, Cairo Egypt
  2. [492]
    الصورة الرمزية faiqmohmed
    Received: 15
    Given: 7
    اخي الكريم
    اطمع ان تساعدني بالبحوث التالية مع فائق التقدير
    Boussabaine, A H (1996) The use of artificial neural networks in construction management: a review. Construction Management and Economics, 14(5), 427-36.
    Boussabaine, A H and Kaka, A P (1998) A neural networks approach for cost-flow forecasting. Construction Management and Economics, 16(4), 471-9.
    Boussabaine, A H, Thomas, R and Elhag, T M S (1999) Modelling cost-flow forecasting for water pipeline projects using neural networks. Engineering, Construction and Architectural Management, 6(3), 213-24.
    Emsley, M W, Lowe, D J, Duff, A R, Harding, A and Hickson, A (2002) Data modelling and the application of a neural network approach to the prediction of total construction costs. Construction Management and Economics, 20(6), 465-72.
    Li, H (1996) Neural network models for intelligent support of mark-up estimation. Engineering, Construction and Architectural Management, 3(1), 2),-69-81.
    Parvar, J, Lowe, D, Margaret Emsley and Duff, A R (2000) Neural networks as a decision support system for the decision to bid process. In: Akintoye, A (Ed.), 16th Annual ARCOM Conference, 6-8 September 2000, Glasgow Caledonian University. Association of Researchers in Construction Management, Vol. 1, 209-17.
    Wanous, M, Boussabaine, A H and Lewis, J (2003) A neural network bid/no bid model: the case for contractors in Syria. Construction Management and Economics, 21(7), 737-44
  3. [493]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة FATAMA مشاهدة المشاركة
    hello:
    i need this paper
    تفضلي البحث في المرفقات
    • نوع الملف: pdf 001.pdf‏ (365.7 كيلوبايت, 10 مشاهدات)
  4. [494]
    تحية طيبة لكم :- نأمل الحصول على طريقة تحليلية وهى EPA METHOD number 3050 or 3050A
  5. [495]
    الحمد لله مازالت الدنيا بخير
    مادام العبد فى عون اخيه
  6. [496]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة hegazy2020 مشاهدة المشاركة
    السلام عليكم وحمة الله و بركاته
    أشكركم على المجهود المبذول وربنا يبارك لكم
    أرجو المساعدة في الحصول على الكتب والأبحاث التالية
    [1] Tri. T. Ha and Rena M. Loesch, "Crosstalk Analyses of Asynchronous Optical Chip Interconnects with Direct Detection." J. Lightwave Technol., vol. 12, No*11, pp. 1932-1938, Nov.*1994.
    [2] Ahmed Lovri and A. K. Kodi "Parallel Optical Interconnection Network for Address Transaction in Large Scale Cache Coherent Symmetric Multiprocessors", “, IEEE J. Selected Topics in Quantum Electronics, Vol. 9, No. 2, PP. 667-676, Mar. / April 2003.
    [3] A. Cassinelli, M. Naruse, and M. Ishikawa, " Multistage Network With Globally Controlled Switching Stages and Its Implementation using Optical Multi-Interconnection Modules." J. Lightwave Technol., Vol. 22, No.*2, pp. 315-328, Feb.*2004.
    [4] K. Iga, F. Koyama, and S. Kinoshita, " Surface - Emitting Semiconductor Lasers ", IEEE J. Quantum Electron, Vol. 24, No. 9, pp. 1845-1855, Sept. 1988.
    [5] A. Tropper, and S. Hoogland, "VCSELs Achieve High Power and Spectral Versatility", SPIE's OE magazine, pp. 21-23, Mar. 2004.
    [6] L. A. Coldren, B. J. Thibeault, "Vertical Cavity Surface-Emitting Lasers" ,Ch. 6, pp. 200-266,ln Optical Fiber Telecommunications IIIB, Ed. 1. P. Kaminowand, T. L. Koch, AP, USA, 1997.
    [7] F. Z. El. Halafawy, A. A. Mohamed, M. G. El-kholy, and M. S. Tabbour, "High Speed Laser Diodes Under Thermal Operating Conditions In Advanced Communication System ", Proc. 4th ICEENG, Conf., 2004, 23-25 Nov. 2004, pp. 266-279 [CAS(1-14)] , Cairo, EGYPT,2004.
    [8] S. F. Yu, W. N. Wang, P. Shum, and E. H. Li, " Theoretical Analysis of Modulation Response and 'Second Order Harmonic Distortion in Vertical Cavity Surface-Emitting Lasers",IEEE J. Quantum Electron., Vol. 32, No. 12, pp. 2139-2147,1996.
    [9] N. Bewtra, D. A. Suda, G. L. Tan, F. Chatenoud, and J.M. Xu," Modeling of quantum-well Lasers with Electro-OptoThermal Interaction ", IEEE J.Selected Topics in Quantum Electron., Vol. I, No. 2, pp. 331-340,1995.
    [10] P. V. Mena, J. J. Monkuni, S. M. Kang, A. V. Harton. and K. W. Wyatt, " A Simple Rate-Equation-Based Thermal VCSEL Model", J. Lightwave Technol. Vol. 17, No.5, pp. 865-872. May 1999.
    وجدت ستة منها
    تفضل
    http://www.4shared.com/file/16694975...papers542.html
  7. [497]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة faiqmohmed مشاهدة المشاركة
    اخي الكريم
    أخي الكريم
    هذا ما وجدت
    http://www.4shared.com/file/16695908...papers979.html
  8. [498]
    بعد إذنك أخي الكريم احتاج هده البحوث في اقرب فرصة ممكنة
    1.Sensitivity of optically preamplified DPSK receivers withFabry-Perot filters
    http://ieeexplore.ieee.org/xpl/freea...85595&type=ref
    Tunable optical filters for dense WDM networks.2
    http://ieeexplore.ieee.org/xpl/freea...rnumber=735877
    fiber grating spectra .3
    http://ieeexplore.ieee.org/xpl/freea...rnumber=618322
    4.Elimination of the fibre chromatic dispersion penalty on 1550 nmmillimetre-wave optical transmission
    ولك مني جزيل الشكر
  9. [499]
    أشكركم على المجهود المبذول وأرجو منكم البحوث التالية :
    [1] H. J. Choo and Ti_Shiang Wang, " An Optical Interconnection Network for Terabit IP Routers", J. Light wave Technol., …. Vol. 18, No. 12, pp. 2095-2112, Dec. 2000.
    [2] G. Kim, X. Han, and R.T. Chen, " An 8-Gb/supercomputing Optical Backplane Bus Based on Micro channel Interconnects: Design, Measurements", J. Light wave Technol., …. Vol. 18, No. 11, pp. 1477- 1486, Nov. 2000.
    [3] R. R. Patel et. al., " Multiwavelength Parallel Optical Processing", IEEE J. Selected Topics in Quantum Electronics, Vol.9, No 2,pp. 657-666, Mar. / April 2003.
    [4] D. Huang, T. sze, A. Landin, R. Lylel, and H. L. Dairdsan, “ Optical Interconnects: Out of the Box Forever “, IEEE J. Selected Topics in Quantum Electronics, Vol. 9, No. 2, PP. 614-623, Mar. / April 2003.
    [5] Rajiv Ramaswami. "Optical Fiber Communication: From Transmission to Network", IEEE Commun. Magazine, 50th anniversary commemorative issue, pp. 138-147 May 2002.
    [6] T. Pfeiffer, J. Kissing. J. Elbers. B. Deppisch, M. Witte, H. Schmuck, and E. Voges, "Coarse WDM/CDM/TDM Concept for Optical Packet Transmission in Metropolitan and Access Networks Supporting 400 Channels at 2.5 Gb/s Peak Rate." IEEE/OSA J. Lightwave Technol., Vol. LT-18, pp. 1928-1938, Dec. 2000.
    [7] C. Siva Ram Siva Murthy, G. Mohan, "WDM Optical Networks: Concepts, Design, and Algorithms", Dec. 2001.
    [8] B. Mukherjee, "Optical Communication Networks", New York: McGraw-Hill, 1997.
    [9] L. P. Barry, P. Guignard, J. Debeau, R Boittin, and M. Bernard, "A High-Speed Optical Star Network Using TDMA and All-Optical Demultiplexing Techniques," IEEE J. on Selected Areas in Commun. Vol. 14, No. 5, pp. 1030-1038, June 1996.
  10. [500]
    أشكركمجدا جدا جدا على المجهود المبذول وربنا يبارك لكم
    [1] G. Kim, X. Han, and R.T. Chen, " An 8-Gb/supercomputing Optical Backplane Bus Based on Micro channel Interconnects: Design, Measurements", J. Light wave Technol., …. Vol. 18, No. 11, pp. 1477- 1486, Nov. 2000.
    [2] D. Huang, T. sze, A. Landin, R. Lylel, and H. L. Dairdsan, “ Optical Interconnects: Out of the Box Forever “, IEEE J. Selected Topics in Quantum Electronics, Vol. 9, No. 2, PP. 614-623, Mar. / April 2003.
    [3] Rajiv Ramaswami. "Optical Fiber Communication: From Transmission to Network", IEEE Commun. Magazine, 50th anniversary commemorative issue, pp. 138-147 May 2002.
    [4] T. Pfeiffer, J. Kissing. J. Elbers. B. Deppisch, M. Witte, H. Schmuck, and E. Voges, "Coarse WDM/CDM/TDM Concept for Optical Packet Transmission in Metropolitan and Access Networks Supporting 400 Channels at 2.5 Gb/s Peak Rate." IEEE/OSA J. Lightwave Technol., Vol. LT-18, pp. 1928-1938, Dec. 2000.
    [5] C. Siva Ram Siva Murthy, G. Mohan, "WDM Optical Networks: Concepts, Design, and Algorithms", Dec. 2001.
    [6] B. Mukherjee, "Optical Communication Networks", New York: McGraw-Hill, 1997.
    [7] L. P. Barry, P. Guignard, J. Debeau, R Boittin, and M. Bernard, "A High-Speed Optical Star Network Using TDMA and All-Optical Demultiplexing Techniques," IEEE J. on Selected Areas in Commun. Vol. 14, No. 5, pp. 1030-1038, June 1996.
    [8] K. Bala, T. E. Stem, D. Simchi-Levi, and K. Bala, "Routing in a Linear Lightwave Network," IEEE Trans. Network, Vol. 3, No. 4, Aug. 1995.
    [9] A. D. Gelman and D. L. Schilling, "A Fiber Optic CDMA Network for Real-Time Communication," in Proc. IEEE Conf. Comp. (IWOCOM '88), New Orleans, LA, pp. 62-69, Mar. 1988.
    [10] M. llyas, H. T. Mouftan, "The Handbook of Optical Communication Networks," CRC Press Feb. 2003.
    [11] J. A. Salehi, "Emerging Optical Code-Division Multiple Assess Communications Systems," IEEE Network, pp. 31-39, Mar. 1989.
