صفحة 458 من 864 الأولىالأولى ... 358408448454 455 456 457 458459 460 461 462 468508558 ... الأخيرةالأخيرة
النتائج 4,571 إلى 4,580 من 8639
  1. [4571]
  2. [4572]
    أرجو امدادى بالأوراق العلميه الأتيه
    8-
    Calculation of Three-Dimensional Viscous Flow in Hydrodynamic Torque Converters
    H. Schulz, R. Greim, and W. Volgmann
    J. Turbomach. 118, 578 (1996)
    9-
    Measurement and Analysis of Static Pressure Field in a Torque Converter Turbine
    R. R. By and B. Lakshminarayana
    J. Fluids Eng. 117, 473 (1995)
    10-
    Measurement and Analysis of Static Pressure Field in a Torque Converter Pump
    J. Fluids Eng. 117, 109 (1995)
    11-
    Estimation of Turbine Torque of Automatic Transmissions Using Nonlinear Observers
    Kyongsu Yi, Byung-Kwan Shin, and Kyo-II Lee
    J. Dyn. Sys., Meas., Control 122, 276 (2000)
    ولكم جزيل الشكر:o:o:o:o:o:o:o:o:o:o
  3. [4573]
    please I need these papers
    Modeling of the optimum tilt of a solar chimney for maximum air flow
    Solar Energy, Volume 82, Issue 1, January 2008, Pages 80-94
    E.P. Sakonidou, T.D. Karapantsios, A.I. Balouktsis, D. Chassapis
    A single dimensionless variable for solar chimney power plant modeling
    Solar Energy, Volume 83, Issue 12, December 2009, Pages 2136-2143
    Atit Koonsrisuk, Tawit Chitsomboon
    Thermodynamic study of a simplified model of the solar chimney power plant
    Solar Energy, Volume 83, Issue 1, January 2009, Pages 94-107
    Richard Petela
    Partial geometric similarity for solar chimney power plant modeling
    Solar Energy, Volume 83, Issue 9, September 2009, Pages 1611-1618
    Accuracy of theoretical models in the prediction of solar chimney performance
    Solar Energy, Volume 83, Issue 10, October 2009, Pages 1764-1771
    Performance analysis of the power conversion unit of a solar chimney power plant
    Solar Energy, Volume 82, Issue 11, November 2008, Pages 999-1008
    T.P. Fluri, T.W. Von Backström
    Critical evaluation of solar chimney power plant performance
    Solar Energy, Volume 80, Issue 5, May 2006, Pages 535-544
    J.P. Pretorius, D.G. Kröger
    Evaluation of operational control strategies applicable to solar chimney power plants
    Solar Energy, Volume 84, Issue 2, February 2010, Pages 277-288
    Marco Aurélio dos Santos Bernardes, Theodor W. von Backström
    Dynamic similarity in solar chimney modeling
    Solar Energy, Volume 81, Issue 12, December 2007, Pages 1439-1446
    Analysis of some available heat transfer coefficients applicable to solar chimney power plant collectors
    Solar Energy, Volume 83, Issue 2, February 2009, Pages 264-275
    Marco Aurélio dos Santos Bernardes, Theodor W. Von Backström, Detlev G. Kröger
    Experimental investigations on solar chimney for room ventilation
    Solar Energy, Volume 80, Issue 8, August 2006, Pages 927-935
    Jyotirmay Mathur, N.K. Bansal, Sanjay Mathur, Meenakshi Jain, Anupma
    Solar chimney power plants for high latitudes
    Solar Energy, Volume 79, Issue 5, November 2005, Pages 449-458
    E. Bilgen, J. Rheault
    Maximum fluid power condition in solar chimney power plants – An analytical approach
    Solar Energy, Volume 80, Issue 11, November 2006, Pages 1417-1423
    Theodor W. von Backström, Thomas P. Fluri
  4. [4574]
    الصورة الرمزية AboJim
    اقتباس المشاركة الأصلية كتبت بواسطة sami_2010 مشاهدة المشاركة
    ارجو التكرم بامدادي بالكتاب الاتي
    electronic processes in non-crystalline materials: By n. F. Mott and e. A. Davis,
    ليس متوفر الكترونيا على ما أظن
  5. [4575]
    اقتباس المشاركة الأصلية كتبت بواسطة ahmadabbas مشاهدة المشاركة
    8-
    9-
    10-
    11-
    http://ifile.it/hs054ck/Abbas.rar
  6. [4576]
    Cost analysis of solar chimney power plants
    Solar Energy, Volume 83, Issue 2, February 2009, Pages 246-256
    T.P. Fluri, J.P. Pretorius, C. Van Dyk, T.W. Von Backström, D.G. Kröger, G.P.A.G. Van Zijl
    Comparison of modelling approaches and layouts for solar chimney turbines
    Solar Energy, Volume 82, Issue 3, March 2008, Pages 239-246
    T.P. Fluri, T.W. von Backström
    Elementary theory of stationary vortex columns for solar chimney power plants
    Solar Energy, Volume 83, Issue 4, April 2009, Pages 462-476
    N. Ninic, S. Nizetic
    Technical feasibility assessment of a solar chimney for food drying
    Solar Energy, Volume 82, Issue 3, March 2008, Pages 198-205
    André G. Ferreira, Cristiana B. Maia, Márcio F.B. Cortez, Ramón M. Valle
    Constructal solar chimney configuration
    International Journal of Heat and Mass Transfer, Volume 53, Issues 1-3, 15 January 2010, Pages 327-333
    A. Koonsrisuk, S. Lorente, A. Bejan
    Numerical analysis of flow and heat transfer characteristics in solar chimney power plants with energy storage layer
    Energy Conversion and Management, Volume 49, Issue 10, October 2008, Pages 2872-2879
    Tingzhen Ming, Wei Liu, Yuan Pan, Guoliang Xu
    Experimental study of temperature field in a solar chimney power setup
    Applied Thermal Engineering, Volume 27, Issues 11-12, August 2007, Pages 2044-2050
    Xinping Zhou, Jiakuan Yang, Bo Xiao, Guoxiang Hou
    Available energy of the air in solar chimneys and the possibility of its ground-level concentration
    Solar Energy, Volume 80, Issue 7, July 2006, Pages 804-811
    N. Ninic
    Numerical investigation of a plume from a power generating solar chimney in an atmospheric cross flow
    Atmospheric Research, Volume 91, Issue 1, January 2009, Pages 26-35
    Xinping Zhou, Jiakuan Yang, Reccab M. Ochieng, Xiangmei Li, Bo Xiao
    Experimental study for natural ventilation on a solar chimney
    Renewable Energy, Volume 34, Issue 12, December 2009, Pages 2928-2934
    J. Arce, M.J. Jiménez, J.D. Guzmán, M.R. Heras, G. Alvarez, J. Xamán
    Analysis of chimney height for solar chimney power plant
    Applied Thermal Engineering, Volume 29, Issue 1, January 2009, Pages 178-185
    Xinping Zhou, Jiakuan Yang, Bo Xiao, Guoxiang Hou, Fang Xing
    An analytical and numerical study of solar chimney use for room natural ventilation
    Energy and Buildings, Volume 40, Issue 5, 2008, Pages 865-873
    Ramadan Bassiouny, Nader S.A. Koura
    Modeling of window-sized solar chimneys for ventilation
    Building and Environment, Volume 40, Issue 10, October 2005, Pages 1302-1308
    N.K. Bansal, Jyotirmay Mathur, Sanjay Mathur, Meenakshi Jain
    Summer-performance of inclined roof solar chimney for natural ventilation
    Energy and Buildings, Volume 38, Issue 10, October 2006, Pages 1156-1163
    Jyotirmay Mathur, Sanjay Mathur, Anupma
    An experimental investigation of a solar chimney model with uniform wall heat flux
    Building and Environment, Volume 38, Issue 7, July 2003, Pages 893-906
    Z. D. Chen, P. Bandopadhayay, J. Halldorsson, C. Byrjalsen, P. Heiselberg, Y. Li
    Performance analysis of a solar chimney power plant in the southwestern region of Algeria
    Renewable and Sustainable Energy Reviews, Volume 14, Issue 1, January 2010, Pages 470-477
    Salah Larbi, Amor Bouhdjar, Toufik Chergui
    Investigation on the application of solar chimney for multi-storey buildings
    Renewable Energy, Volume 34, Issue 12, December 2009, Pages 2545-2561
    Sompop Punyasompun, Jongjit Hirunlabh, Joseph Khedari, Belkacem Zeghmati
    Counter-rotating turbines for solar chimney power plants
    Renewable Energy, Volume 31, Issue 12, October 2006, Pages 1873-1891
    F. Denantes, E. Bilgen
    Numerical simulation of the solar chimney power plant systems coupled with turbine
    Renewable Energy, Volume 33, Issue 5, May 2008, Pages 897-905
    Ming Tingzhen, Liu Wei, Xu Guoling, Xiong Yanbin, Guan Xuhu, Pan Yuan
    Air flow and thermal efficiency characteristics in solar chimneys and Trombe Walls
    Energy and Buildings, Volume 39, Issue 2, February 2007, Pages 128-135
    S. A.M. Burek, A. Habeb
    Heat transfer by convection, conduction and radiation in solar chimney systems for ventilation of dwellings
    International Journal of Heat and Fluid Flow, Volume 30, Issue 1, February 2009, Pages 150-157
    H.F. Nouanégué, E. Bilgen
    Effect of solar chimney inclination angle on space flow pattern and ventilation rate
    Energy and Buildings, Volume 41, Issue 2, February 2009, Pages 190-196
    Ramadan Bassiouny, Nader S.A. Korah
    Application of passive cooling systems in the hot and humid climate: The case study of solar chimney and wetted roof in Thailand
    Building and Environment, Volume 42, Issue 9, September 2007, Pages 3341-3351
    Sudaporn Chungloo, Bundit Limmeechokchai
    A simplified analytical approach for evaluation of the optimal ratio of pressure drop across the turbine in solar chimney power plants
    Applied Energy, Volume 87, Issue 2, February 2010, Pages 587-591
    S. Nizetic, B. Klarin
  7. [4577]
    اقتباس المشاركة الأصلية كتبت بواسطة poura مشاهدة المشاركة
    Richard Petela
    N. Ninic
    please poura next time number your articles
    it is for your own sake so that I do not miss any article
    here are ur requests
    http://ifile.it/ctbpf5e/poura.rar
  8. [4578]
    1)Simulation of a pilot solar chimney thermal power generating equipment
    Renewable Energy, Volume 32, Issue 10, August 2007, Pages 1637-1644
    2)Comparison of classical solar chimney power system and combined solar chimney system for power generation andseawater desalination
    Desalination, Volume 250, Issue 1, 1 January 2010, Pages 249-256
    Xinping Zhou, Bo Xiao, Wanchao Liu, Xianjun Guo, Jiakuan Yang, Jian Fan
    3)Study of the natural convection phenomena inside a wall solar chimney with one wall adiabatic and one wall under a heat flux
    Applied Thermal Engineering, Volume 27, Issue 13, September 2007, Pages 2266-2275
    Evangellos Bacharoudis, Michalis Gr. Vrachopoulos, Maria K. Koukou, Dionysios Margaris, Andronikos E. Filios, Stamatis A. Mavrommatis
    4)Analysis and feasibility of implementing solar chimney power plants in the Mediterranean region
    Energy, Volume 33, Issue 11, November 2008, Pages 1680-1690
    S. Nizetic, N. Ninic, B. Klarin
    5)Structural stability of concrete wind turbines and solar chimney towers exposed to dynamic wind action
    Journal of Wind Engineering and Industrial Aerodynamics, Volume 95, Issues 9-11, October 2007, Pages 1079-1096
    Reinhard Harte, Gideon P.A.G. Van Zijl
    6)The potential of solar chimney for application in rural areas of developing countries
    Fuel, Volume 85, Issues 17-18, December 2006, Pages 2561-2566
    Frederick N. Onyango, Reccab M. Ochieng
    7)The solar cyclone: A solar chimney for harvesting atmospheric water
    Energy, Volume 33, Issue 2, February 2008, Pages 331-339
    B.A. Kashiwa, Corey B. Kashiwa
    8)Solar chimneys: simulation and experiment
    Energy and Buildings, Volume 32, Issue 1, June 2000, Pages 71-79
    Clito Afonso, Armando Oliveira
    9)Solar chimney power generation project—The case for Botswana
    Renewable and Sustainable Energy Reviews, Volume 12, Issue 7, September 2008, Pages 2005-2012
    Clever Ketlogetswe, Jerzy K. Fiszdon, Omphemetse O. Seabe
    10)Dynamic physical model for a solar chimney
    Solar Energy, Volume 81, Issue 5, May 2007, Pages 614-622
    J. Martı´-Herrero, M.R. Heras-Celemin
    11)Thermal and technical analyses of solar chimneys
    Solar Energy, Volume 75, Issue 6, December 2003, Pages 511-524
    M. A. dos S. Bernardes, A. Voß, G. Weinrebe
    12)Solar chimney turbine characteristics
    Solar Energy, Volume 76, Issues 1-3, January-March 2004, Pages 235-241
    T. W. von Backström, A. J. Gannon
    13)Performance of a solar chimney
    Solar Energy, Volume 74, Issue 1, January 2003, Pages 1-17
    K. S. Ong, C. C. Chow
    14)Ventilation of dwellings using solar chimneys in North African climate
    Solar & Wind Technology, Volume 4, Issue 3, 1987, Pages 313-317
    Z Zrikem, E Bilgen
    15)Theoretical evaluation of the influence of geometric parameters and materials on the behavior of the airflow in a solar chimney
    Computers & Fluids, Volume 38, Issue 3, March 2009, Pages 625-636
    Cristiana B. Maia, André G. Ferreira, Ramón M. Valle, Márcio F.B. Cortez
    16)A mathematical model of a solar chimney
    Renewable Energy, Volume 28, Issue 7, June 2003, Pages 1047-1060
    K. S. Ong
    17) Solar Chimneys
    Encyclopedia of Physical Science and Technology, 2004, Pages 99-109
    Jörg Schlaich, Wolfgang Schiel
    04/01960 Solar chimney turbine characteristics : von Backström, T. W. and Gannon, A. J. Solar Energy, 2004, 76, (1–3), 235–241
    Fuel and Energy Abstracts, Volume 45, Issue 4, July 2004, Page 271
    thanks
  9. [4579]
    Comparison of classical solar chimney power system and combined solar chimney system for power generation and seawater desalination
    Z Zrikem, E Bilgen
    K. S. Ong
    Solar Chimneys
    thanks
    pleeeeeeeeeeeeeeeeeeeeeeeeaaaaaaaaaaaaaaaaaaaaase
    dont be sad if I miss some articles
    here are the remaining articles of ur latest post
    http://ifile.it/dtvir3l/poura2.rar
  10. [4580]
    I am sorry AboJim
    I have disturbed you
    I will be careful next time
    and thanks for your effort
