صفحة 41 من 864 الأولىالأولى ... 3137 38 39 40 4142 43 44 45 5191141541 ... الأخيرةالأخيرة
النتائج 401 إلى 410 من 8635
  1. [401]
    hi
    hi thank you for the papers
    i need this paper
    Miniaturized dual-mode bandpass filter using inductively loaded cross-slotted patch resonator
    Auteur(s) / Author(s)
    LEI ZHU (1) ; BOON CHAI TAN (1) ; SIANG JUAY QUEK (1) ;
    Affiliation(s) du ou des auteurs / Author(s) Affiliation(s)
    (1) School of Electrical and Electronic Engineering, Nanyang Technological University, Singapore 639798, SINGAPOUR
    Résumé / Abstract
    An inductively loaded cross-slotted patch resonator is presented to build up a miniaturized dual-mode bandpass filter. By terminating the cross-slot on the square patch with the T-shape slot stubs, the resonant frequency is exhibited to be largely lowered due to an additional inductive loading, implying a capacity in size-miniaturization. In parallel, the rectangular slit is introduced at the four sides of the cross-slotted patch to facilitate the tightened parallel coupling between the feeders and resonator. A dual-mode filter with the patch size of A/4 squared is then designed and predicted results are evidently supported by measurement.
    Revue / Journal Title
    IEEE microwave and wireless components letters (IEEE microw. wirel. compon. lett.) ISSN 1531-1309 Institute of Electrical and Electronics Engineers microwave and wireless components letters
    Source / Source
    2005, vol. 15, no1, pp. 22-24 [3 page(s) (article)] (10 ref.)
    Langue / Language
    Anglais
    Editeur / Publisher
    Institute of Electrical and Electronics Engineers, New York, NY, ETATS-UNIS (2001) (Revue)
    Mots-clés anglais / English Keywords
    Slotted resonator ; Microwave resonator ; Microwave filter ; Inductive load ; Resonance frequency ; T shape ; Band pass filter ; Mode filter ; Miniaturization ;
    Mots-clés français / French Keywords
    Résonateur fente ; Résonateur hyperfréquence ; Filtre hyperfréquence ; Charge inductive ; Fréquence résonance ; Forme en T ; Filtre passe bande ; Filtre mode ; Miniaturisation ;
    001d03g02b ;
    Mots-clés espagnols / Spanish Keywords
    Resonador hiperfrecuencia ; Filtro hiperfrecuencia ; Carga inductiva ; Frecuencia resonancia ; Forma de una T ; Filtro paso banda ; Filtro modo ; Miniaturización ;
    Mots-clés d'auteur / Author Keywords
    Cross-slotted patch resonator ; dual-mode filter ; size miniaturization ;
    Localisation / Location
    INIST-CNRS, Cote INIST : 22393, 35400012659166.0080
  2. [402]
    الــــــــــســلام عــلـيـكم و رحـمـة الـاـه تــعــالــــى و بــركـــاتــه
    جـــــــــــــزاك الــاــه كــل خــيــر يـــا أخـــي aalmasriعــلــى هــذه الأعــــانـــات الـــتي تـتـــفــضـــل بـــهـــا
    وجــعــلــهــا الــاــه فــي مــيــزان حــســنــــاتـــك
  3. [403]
    hi
    HI INEED THIS PAPER
    Dual mode cross slotted filter realized with double-sided Tl2Ba2CaCu2O8 films grown by MOCVD
    A Cassinese et al 2001 Supercond. Sci. Technol. 14 406-412 doi:10.1088/0953-2048/14/6/315
    PDF (410 KB) | References | Articles citing this article
    A Cassinese1, A Andreone1, E Di Gennaro1, G Pica1, R Vaglio1, G Malandrino2, L M S Perdicaro2, I L Fragalà2 and C Granata3
    1 INFM and Dipartimento di Scienze Fisiche, Università di Napoli Federico II, Napoli, Italy
    2 Dipartimento di Scienze Chimiche and I.N.S.T.M., Università di Catania, Catania, Italy
    3 Istituto di Cibernetica del CNR di Arco Felice, Napoli, Italy
    Abstract. We report on the realization of dual mode microwave filters based on Tl2Ba2Ca1Cu2O8 (Tl-2212) double-sided superconducting films. The Tl-2212 samples have been grown ex situ on 10×10 mm2 LaAlO3 (100) substrates by a combined approach of metal-organic chemical vapour deposition (MOCVD) and thallium vapour diffusion. Their morphological, compositional and structural natures have been investigated by scanning electron microscopy, energy dispersive x-ray analyses and x-ray diffraction characterization. Both sides of the films are smooth, homogeneous in thickness and composition and show epitaxially-grown Tl-2212 phases. Typical values of Tc = 100 K and Jc = 0.05 MA cm-2 at 77 K have been inductively measured for both sides. Microwave measurements have been performed at 20 GHz by using a dielectric resonator.
    Two planar superconducting single-stage dual mode filters operating in the C-band with 1% and 10% fractional bandwidth have been realized. The basic element of the device is a square patch resonator diagonally crossed by unequal slots providing both a size reduction and a simple and controllable way to couple the two degenerate modes. Device response has been studied at different temperatures, performing power and intermodulation measurements. In view of practical applications, the results are compared with those obtained by a filter based on high-quality YBCO films.
    Print publication: Issue 6 (June 2001)
    Received 13 February 2001, in final form 26 March 2001
    FROM IOP ELECTRONIC JOURNALS
  4. [404]
    ممكن يا اخي اذا تقدر ان تطلع لي هذه المقالات و لكن يا ريت تكون مجانيه B. Friedlander,"Lattice filters for adaptive processing", Proc. IEEE, Vol.70, pp 829-867, Aug., 1982.
    . J. Kakhoul,"Linear Prediction: A tutorial review", Proc. IEEE, Vol. 63, pp 561-580, April 1975.
  5. [405]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة شوفا مشاهدة المشاركة
    اخوانى الكرام
    برجاء مساعدتى فى الحصول على البحث التالى اوابحات ممثله فى المؤتمر
    Durability of Building Materials and Components: Proceedings of the Seventh International ... By Christer Sjõstrõm ....held in May 1996.
    بعنوان:
    enviromental effects on bond in reinforced concrete structures) by K.Nghabai ..............page 605
    للأسف لم أجدها
  6. [406]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة راغدة1 مشاهدة المشاركة
    i need this paper
    في المرفقات
  7. [407]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة أحمد67 مشاهدة المشاركة
    حياك الله, وان شاء الله نخدمك في يوم من الايام
  8. [408]
    عضو تحرير المجلة
    Received: 9
    HI INEED THIS PAPER
    في المرفقات
  9. [409]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة محمدالكاتب مشاهدة المشاركة
    تفضل, ومجانية كما أردت :)
    http://www.4shared.com/file/15754129...papers869.html
  10. [410]
    السلام عليكم وحمة الله و بركاته
    أرجو المساعدة في الحصول على الكتب والأبحاث التالية
    [1] L. Pavesi, and G. Guillot, (Eds.), Optical Interconnects: The Silicon Approach, Springer-Verlag Berlin Heidelberg, Springer Series in Optical Sciences, 2006.
    [2] T. D. Bennett, M. B. Farrelly, I. Pasta, D. Pulikal , “Rapid Thermal Bonding of Optical Fiber Interconnect,” J. Applied physics, Vol. 7, 034903,2005.
    [3] Ali M. Shams-Zadeh-Amiri, Wei Li, Hans Wenzel, and Xun Li, “Amplified-Spontaneous-Emission Spectrum of the Radiation Field in Surface-Emitting DFB Lasers ,” J. Lightwave Technology, Vol. 24, No. 4, pp. 1828-1832,April 2006.
