صفحة 362 من 864 الأولىالأولى ... 262312352358 359 360 361 362363 364 365 366 372412462862 ... الأخيرةالأخيرة
النتائج 3,611 إلى 3,620 من 8635
  1. [3611]
    هذه ملفات أخرى أرجو المساعدة في الحصول عليها
    Clark, W. J., MacGrego, J. G., and Adams, P. F., "Inelastic Behaviour of Rein-forced Concrete Shear Wall Frame Structure," Proceedings of the Eighth Congres International Assoc, for Bridge and Struct. Engrg., Sept., 1968.
    MacGregor, J. G., Guha Majumdar, S. N. , and Nikhed, R. P., "Approximate Inelastic Analysis of Shear Wall Frame Structures," Journal of the Structural Division, ASCE, Vol. 98, No. ST11, Nov., 1972.
    Katsuhiko, E., and Sehnobrich, W. C., "Inelastic Behaviour of Concrete Frame-Wall Structures," Journal of the Structural Division, ASCE, Vol. 107, No. ST1, Jan., 1981.
    Grundy, P., and Wathen, G. R., "Frame Shear-Wall Interaction," Civil Engi-neering Transactions, Institution of Engineers, Australia, Vol. CE14, No. 1, Apr 1972, pp. 102-109.
    Kayal, S., "Nonlinear Analysis of Plane Frame-Wall Systems," thesis pre- sented to the Indian Institute of Technology, at Delhi, India, in 1978, in partial fulfillment of the requirement for the degree of Doctor of Philosophy.
    Balendra, T. 1984. “Free vibration of a shear wall-frame building on an elastic foundation.” J. Sound Vib.,964, 437–446.
    Basu, A. K., Nagpal, A. K., and Kaul, S. 1984. “Charts for seismic design of frame-wall systems.” J. Struct. Eng.,1101, 31–46.
    Basu, A. K., Nagpal, A. K., and Nagar, A. K. 1982. “Dynamic cha-racteristics of frame-wall systems.” ASCE J. Struct. Div., 1086,1201–1218.
    Heidebrecht, A. C., and Smith, S. B. 1973. “Approximate analysis of tall wall-frame structures.” ASCE J. Struct. Div.,992, 199–221.
    Heidebrecht, A. c. and Stafford Smith, B. “Approximate Analysis of Tall Wall-Frame Structures”, J. Struct. Div. Proc. ASCE 99, ST2. Februry 1973. 199-221.
    Nollet. M,-J. and Stafford Smith. B. “An Emprical Approach to the Evaluation of the Shear Rigidity of a Wall-Frame with Rigisity Jointed Link Beams”< Structural Engineering Series Report No. 88-5, Department of Civil Engineering and Applied Mechanics. McGill University, November 1988.
    T. Saito, J. Ogawa, J. Shibuya and J. Fu, “Analysis of Inelastic Behavior of Wall-Frame Structures”, Proceedings of the Japan Concrete Institute, Vol.13, No.2, pp.613-618, 1991 (in Japanese).
    ShiMin Huang and Lian Wei. 1997. The Computation Method for Erathquake-Excited Frame-Shear Wall Structures with Variable Rigidity along Height, Building Science, No.4, 16-20
    Sullivan T.J. Priestley M.N.J and Calvi G.M., (2005). “Development of an Innovative Seismic Design Procedure for Frame Wall Structures” Journal of Earthquake Engineering, 9, Special Issue 2 279-307
    Colombo A, Fardis MN, Molina J, Negro P, Panagiotakos TB, Tsionis G. Pseudo dynamic Response of Dual RC Structure with Different Designs. In: Proceedings of the 12th European Conference on Earthquake Engineering, Paper Reference 297.
    Taskin, B. (2001), “Non-linear stochastic analysis of 3D reinforced-concrete shear wall-frame structures under seismic excitation”, Ph.D. Thesis, Istanbul Technical University, Turkey.
    Taskin, B. and Hasgür, Z. (2003), “Determining the non-linear behavior of 3D, R-C shear wall-frame structures with a stochastic approach”, ARI-Bulletin of the Istanbul Technical University, 53(1), 102-109.
    Lopez, R.R. (1988), “A numerical model for non-linear response of R/C frame-wall structures”, Ph.D. Thesis, University of Llinois, Urbana Champaign, USA.
    Lee, L.-H., Chang, K.-K., and Chun, Y.-S. 2000. “Experimental formula for the fundamental period of RC buildings with shear-wall dominant systems.” Struct. Des. Tall Build., 9, 295–307.
  2. [3612]
    من فضلكم مساعدتى بكل ما يتعلق بالمعالجات الحرارية
    محمد السواكنى
  3. [3613]
    اقتباس المشاركة الأصلية كتبت بواسطة ihab jendeya مشاهدة المشاركة
    ممكن المساعدة في الحصول على هذا الكتاب للضرورة القصوى
    infrastructure planning handbook: Planning, engineering, and economics
    by goodman, alvin s. (author), hastak, makarand (author
    وهذة هي لينكات الكتاب من مواقع متعددة
    http://www.infibeam.com/books/info/a...071474943.html
    http://www.bestwebbuys.com/infrastru...?isrc=b-search
    http://www.flipkart.com/infrastructu...943-xmw3f92cw5
    http://www.amazon.com/infrastructure.../dp/0071474943
    يا جماعة الرجاء مساعدتي ولكم جزيل الشكر والعرفان خاص بالاستاذ انس
  4. [3614]
    -1-Improvement of soft soils using geogrid encased stone columns
    Joel Gniel1, a, and Abdelmalek Bouazza, a,
    aMonash University, Department of Civil Engineering, Building 60, Melbourne, Victoria 3800, Australia
    Received 16 May 2008;
    revised 4 November 2008;
    accepted 5 November 2008.
    Available online 19 January 2009.
    2-The behavior of a laminated reinforced granular column
    Cho-Sen Wu, a, and Yung-Shan Hong1, a,
    aDepartment of Civil Engineering, Tamkang University, Tamsui, Taipei 25137, Taiwan
    Received 6 August 2007;
    revised 5 December 2007;
    accepted 11 December 2007.
    Available online 28 January 2008.
    4-Response of multilayer geosynthetic-reinforced bed resting on soft soil with stone columns
    Kousik Deba, , , Sarvesh Chandrab, 1, and P.K. Basudharb, 2,
    aDepartment of Civil Engineering, Indian Institute of Technology Roorkee, Roorkee 247667, India
    bDepartment of Civil Engineering, Indian Institute of Technology Kanpur, Kanpur 208016, India
    Received 19 April 2007;
    revised 6 July 2007;
    accepted 15 August 2007.
    Available online 24 September 2007.
    6- 3D coupled mechanical and hydraulic modeling of a geosynthetic-reinforced deep mixed column-supported embankment
    Jie Huanga, , and Jie Hanb
    aOffice of Geotechnical Design South 1, Division of Engineering Services, California Department of Transportation, 100 South Main Street, 11th Floor, Los Angeles, CA 90012, USA
    bThe University of Kansas, CEAE Department, 1503 W 15th Street, Lawrence, KS 66045, USA
    Received 6 June 2008;
    revised 20 January 2009;
    accepted 27 January 2009.
    Available online 25 February 2009.
    9-Axial stress–strain relation of encapsulated granular column
    Cho-Sen Wua, , , Yung-Shan Honga, 1, and Hsien-Chin Linb
    bCECI Engineering Consultants Inc., Taipei 10637, Taiwan
    Received 23 May 2007;
    revised 7 January 2008;
    accepted 10 January 2008.
    Available online 4 March 2008.
  5. [3615]
    ارجو الحصول على الابحاث الاتية من science direct
    Improved soft clay characteristics due to stone column installation
    Z. Guetifa, M. Bouassidaa, , , and J.M. Debatsb
    aGeotechnical Engineering Research Team, 05/UR/11-06, National Engineering School of Tunis, BP 37 Le Belvédère 1002 Tunis, Tunisia
    bThe vibroflotation Group, 1445 Chemin des Lauves, 13100 Aix en Provence, France
    Received 12 July 2005;
    revised 20 September 2006;
    accepted 29 September 2006.
    Available online 18 January 2007.
    MY Mail is : mln20@hotmail.com
    شكرا للمساعدة
  6. [3616]
    شكرا للمساعدة
  7. [3617]
    الصورة الرمزية anass81
    Received: 503
    Given: 637
    اخي الكريم kikidodo72 أرجو منك أن تضع لي روابط المقالات التي تريدها , وسوف أحاول مساعدتك بإذن الله
  8. [3618]
    أرجو من المهندس أنس الاينسى الابحاث التي طلبتها لأني بحاجة ماسة لها
    شكراً
  9. [3619]
    Received: 503
    Given: 637
    اقتباس المشاركة الأصلية كتبت بواسطة ciemo87 مشاهدة المشاركة
    السلام عليكم الاخوة الكرام حفظكم الله واعانكم علي كل خير... الرجاء اذا امكن اريد الحصول علي الاوراق العلمية التالية:
    1-total least squares phased averaging and 3-d esprit for jointazimuth-elevation-carrier estimation
    strobach, p.
    Signal processing, ieee transactions on
    volume 49, issue 1, jan 2001 page(s):54 - 62
    digital object identifier 10.1109/78.890341
    2-azimuth/elevation direction finding using regular array geometries
    swindlehurst, a.l.; kailath, t.
    Aerospace and electronic systems, ieee transactions on
    volume 29, issue 1, jan 1993 page(s):145 - 156
    digital object identifier 10.1109/7.249120
    3-a comparison of tracking-beam arrays and switching-beam arraysoperating in a cdma mobile communication channel
    seungwon choi; donghee shim; sarkar, t.k.
    Antennas and propagation magazine, ieee
    volume 41, issue 6, dec 1999 page(s):10 - 56
    digital object identifier 10.1109/74.815315
    4-effect of mutual coupling on the performance of adaptive arrays
    gupta, i.; ksienski, a.
    Antennas and propagation, ieee transactions on
    volume 31, issue 5, sep 1983 page(s): 785 - 791
    بارك الله في مسعاكم ودمتم في حفظ الرحمن
    أعتذر عن التأخير , هذه هي المقالات المطلوبة في المرفقات
    لا تنساني من دعائك
  10. [3620]
    hello
    to all there
    can u help to me.
    i wanna thesis about the the exhaust flow in side a diesel particulate filter()
    or in paper about its tittle
