صفحة 359 من 864 الأولىالأولى ... 259309349355 356 357 358 359360 361 362 363 369409459859 ... الأخيرةالأخيرة
النتائج 3,581 إلى 3,590 من 8639
  1. [3581]
    الصورة الرمزية سعاد محمد امين
    L'énergie de demain - Techniques - environnement - économie
    Jean-Louis Bobin , Elise Huffer , Hervé Nifenecker , Collectif
    Broché
    Paru le
    : 28/04/2005
    Editeur
    : Edp Sciences
    Collection
    : grenoble sciences
    ISBN
    : 2-86883-771-9
    EAN
    : 9782868837714
    Nb. de pages
    : 632 pages
    Poids
    : 1,235 kg
    Dimensions
    : 17cm x 25cm x 3,1cm
  2. [3582]
    الصورة الرمزية anass81
    Received: 555
    Given: 651
  3. [3583]
    Received: 555
    Given: 651
    اقتباس المشاركة الأصلية كتبت بواسطة المصمم الكيميائى مشاهدة المشاركة
    h. J. Th. Bloemen and j. Burn, chemistry and analysis of volatile organic compounds in the environment, blackie academic & professional, 1993
    w. Ji, s.k. Sikdar and s.t. Hwang. Modeling of multiccomponent pervaporation for removal of volatile organic compounds from water. J. Membrane science , 93(1994) 1-19
    d.a. Dzombak, s.b. Roy and h.j. Fang. Air stripping design and costing computing programmer. J. Awwa 85 (1993) 53-72
    r. Billet and m. Schultes. Predicting mass transfer in packed columns. Chem eng. Technol. 6 (1993) 1-16
    v. Linek, j. Sinkule and v. Janda. Design of packed aeration towers to strip volatile organic contaminants from water. Water research 32, 4 (1998) 1264 – 1270
    m.c. Kavanaugh and r.r. Trussel. Design of packed aeration tower to strip volatile organic contaminants from water. J. Awwa 72 (1980) 684 -692
    c. Munz and p.v. Roberts. Air/water phase equilibria for volatile organic solutes. J. Awwa may issue (1987) 62-69
    k. Onda, h. Takeuchi and y. Okumoto. Mass transfer coefficients between gas and liquid phases in packed column. J. Chem. Eng. Jpn. 1 (1968) 56-62
    n. Nirmalakhandan, y.h. Lee and r.e. Speece. Designing a cost-air stripping process. J. Awwa, january issue (1987) 56-50
    integrated concepts in water recycling (2005) -s.j. Khan, a.i. Schäfer, m.h. Muston (eds) – isbn 1 74128 082 6
    chiang, p.-c., c.-h. Hung, j. C. Mar, and e. E. Chung, ‘‘henry’s constants and mass transfer coefficients of halogenated organic pollutants in an air stripping packed column,’’ water sci. And technol., 38, 287 1998..
    choori, u. N., j. F. Scamehorn, and j. H. O’haver, ‘‘removal of volatile organic compounds from surfactant solutions by flash vacuum stripping in a packed column,’’ ground water monit. Re- mediation, 18, 157 1998..
    dvorak, b. I., d. F. Lawler, j. R. Fair, and n. E. Handler, ‘‘evaluation of the onda correlations for mass transfer with large ran-dom packings,’’ en¨iron. Sci. Technol., 30, 945 1996..
    grant, d. J. W., and t. Higuchi, solubility beha¨ior of organic compounds, techniques of chemistry, vol. 21, w. H. Sanders, series ed.; wiley, new york 1990..
    howard, p. H., and w. M. Meylan, eds., handbook of physical properties of organic chemicals, crc, lewis publishers, boca raton, fl 1997..
    kavanaugh, m. C., and r. R. Trussell, ‘‘design of aeration towers to strip volatile contaminants from drinking water,’’ j. Awwa, 72, 684 1980..
    staudinger, j., w. R. Knocke, and c. W. Randall, ‘‘evaluating the onda mass transfer correlation for the design of packed-col-umn air stripping,’’ j. Amer. Water works assoc., 82, 73 1990..
    prado, m., and j. Fair ‘‘fundamental model for the prediction of sieve tray efficiency,’’ ind. Eng. Chem. Res., 29, 1031_1990..
    أرجو أن تضع لي روابط هذه المقالات حتى أستطيع مساعدتك
  4. [3584]
    Received: 555
    Given: 651
    اقتباس المشاركة الأصلية كتبت بواسطة aymanhega مشاهدة المشاركة
    الرجاء أخي الكريم المساعدة في الحصول على أوراق البحث التالية
    Physical modes of thin-film PV degradation
    Publication Date: 3-7 Jan. 2005
    On page(s): 437- 440
    ISSN: 0160-8371
    ISBN: 0-7803-8707-4
    INSPEC Accession Number: 8478917
    Current Version Published: 2005-08-08
    Characterization of degradation in thin-film photovoltaic module performance parameters
    Renewable Energy, Volume 28, Issue 9, July 2003, Pages 1455-1469
    E. L. Meyer and E. E. van Dyk
    و جزاكم الله خيرا و جعله في ميزان اعمالكم
    hلسلام عليكم
    هذا رابط للمقال الاول
    http://www.nrel.gov/pv/thin_film/doc...ion_karpov.pdf
    والمقال الثاني بالمرفقات
  5. [3585]
    Received: 555
    Given: 651
    اقتباس المشاركة الأصلية كتبت بواسطة الباحث الكبير مشاهدة المشاركة
    أريد هذه الورقة البحثية لو سمحتم، بعنوان A power control MAC protocol for ad hoc networks
    والرابط هو : http://portal.acm.org/citation.cfm?id=1160105
    تاريخ نشرها 2005، هناك ورقة بنفس الاسم في IEEE تاريخ نشرها 2002، أريد الورقة التي في هذا الرابط وشكرا لكم
    لا يتوفر لدي الا هذه , أرجو أن تفيدك
    http://pdos.csail.mit.edu/decouto/papers/jung02.pdf
  6. [3586]
    Received: 555
    Given: 651
    اقتباس المشاركة الأصلية كتبت بواسطة kondor مشاهدة المشاركة
    إخواني الأعزاء أحتاج إلى هذه الأبحاث إذا فيه مجال حد يساعدني
    1- r. C. Creppe, c. R. De souza, g. A. Simone, and p. J. A. Serni, “dynamic behavior of a linear induction motor” melecon 98,9th mediterranean electro technical conference, 1998, pages: 1047-1051, vol. 2
    2- g. Kang, and k. Nam, “field-oriented control scheme for linear induction motor with end effects”, iee proceedings-electric power applications, volume 152, issue 6, 4 nov. 2005, pages: 1565-1572.
    3- j. Atencia, m. Martinez, r. Garcia and j. Florez, “modeling of linear induction motors as linear drives”, ieee proceedings on power tech, vol. 4, 10-13 sep. 2001 pages: 5-7.
    4- m. A. Nasr khoidja, b. Ben salah and p. Brochet, “ fuzzy logic control for a single sided linear induction motor” , speedam 2006, ieee international symposium on power electronics, electrical drives, automation and motion. Pages: S37-1 to s37 -5.
    5- e. F. Da silva, e. B. Dos santos, p.c. M. Machado, and m. A.a. De oliveria, “vector control for linear induction motor”, ieee international conference on industrial technology, 2003 pages: 518-523 vol. 1.
    وأقبلوا جزيل الإحترام
    أرجو منك أن تضع لي روابط هذه المقالات
  7. [3587]
    Received: 555
    Given: 651
    اقتباس المشاركة الأصلية كتبت بواسطة islammasry مشاهدة المشاركة
    من فضلك أنا محتاج الأبحاث الآتية
    http://www3.interscience.wiley.com/s...w_selected.y=2
    http://www3.interscience.wiley.com/s...w_selected.y=4
    plz if you can get any of theses artiles send it to my mail
    is2003chem@yahoo.com
    thanks
    الروابط الثلاثة لم تعمل معي
  8. [3588]
    Received: 555
    Given: 651
    من فضلك انا محتاج الpapers الأتية:
    * Adsorption of a Low-Molecular-Weight Polyacrylic Acid on Silica, Alumina, and Kaolin
    http://www.sciencedirect.com/science...bb841ffc772de4
    * Molecular weight of polyacrylic and polymethacrylic acid
    http://www3.interscience.wiley.com/j...37846/abstract
    ايضاً , هذه الروابط لا تعمل
    The page you were looking for could not be found
  9. [3589]
    Received: 555
    Given: 651
    اقتباس المشاركة الأصلية كتبت بواسطة zer0freeze مشاهدة المشاركة
    أرجو المساعده في الحصول على هذه الورقه البحثية
    http://www.stormingmedia.us/04/0498/a049874.html
    أعتذر عن تلبية طلبك لان هذه المجلة غير متوفرة لدي
  10. [3590]
    Received: 555
    Given: 651
    اقتباس المشاركة الأصلية كتبت بواسطة jassim78 مشاهدة المشاركة
    ممكن اخي الابحاث التالية محتاجها ضروري واكون ممتن لك
    1-adsorption–desorption operations of multilayer desiccant packed bed for dehumidification applications
    renewable energy
    volume 34, issue 1, january 2009, pages 255-265
    2-energy and exergy analyses of omw solar drying process
    renewable energy
    volume 34, issue 3, march 2009, pages 660-666
    3-evaluation of thermal parameters and simulation of a solar-powered, solid-sorption chiller with a cpc collector
    renewable energy
    volume 34, issue 3, march 2009, pages 570-577
    4-monitoring and operational results of a hybrid solar-biomass heating system
    renewable energy
    volume 33, issue 8, august 2008, pages 1759-1767
    تفضل أخي الكريم , هذه هي المقالات بالمرفقات
