صفحة 293 من 864 الأولىالأولى ... 193243283289 290 291 292 293294 295 296 297 303343393793 ... الأخيرةالأخيرة
النتائج 2,921 إلى 2,930 من 8635
  1. [2921]
    ارجو المساعدة فى الحصول علىالأوراق العلمية التالية نظرا للحاجة الضرورية والشديدة لها
    Spears, M.L., K. Hagan, J.A. Bullin, and C.J. Michalik, "Converting to Mixed Amines on the Fly," To be presented at the 75th GPA Annual Convention on March 11-13, (1996).
    Savage, D. W., and E. W. Funk, "Selective Absorption of H2S and CO2 into Aqueous Solutions of Methyldiethanolamine," AIChE meeting, Houston, Texas, April 5-9, 1981.
    Daviet, G. R., R. Sundermann, S. T. Donnelly, J. A. Bullin, "Dome’s North Caroline Plant Conversion to MDEA," Proceedings of Gas Processors Association Convention, New Orleans, LA, p. 69, March, 1984.
    Ammons, H. L., and D. M. Sitton, "Operation Data From a Commercial MDEA Gas Treater," Gas Conditioning Conference, Norman, Oklahoma, March 2-4, 1981.
    Pennwalt Chemicals, "Methyldiethanolamine for Gas Sweetening," Publication S-282.
    Jou, F. Y., D. Lal, A. E. Mather, and F. D. Otto, "Solubility of Acid Gases in Methyldiethanolamine Solutions" paper presented at Canadian Gas Processors Association meeting, Calgary, March 12, 1981
  2. [2922]
    ارجو المساعده
    A genetic algorithm for the design of a fuzzy controller for active queue management
    G. Di Fatta F. Hoffmann G. Lo Re A. Urso
    This paper appears in: Systems, Man, and Cybernetics, Part C: Applications and Reviews, IEEE Transactions on
    </STRONG>
    Publication Date: Aug. 2003
    Volume: 33, Issue: 3
    On page(s): 313-324
    ISSN: 1094-6977
  3. [2923]
    ممكن هذا البيبر
    ممكن اخوتي مساعدتي بالحصول على هذا البيبر
    Fuzzy Logic Based Congestion Avoidance in TCP/AQM Networks
    ISBN 978-3-540-23478-4
    Pages: 575-584
    Springer Berlin / Heidelberg
    2005
  4. [2924]
    الصورة الرمزية م . ماجدة
    Post
    أرجوا منكم مساعدتى فى الحصول على هذه الورقة البحثية:
    Intelligent & integrated infrastructures in building – business overview ( I & I limited )
    وهذا هو عنوان الرابط :
    http://www.proplan.co.uk/reports.php
    مع العلم أننى قد حملت ملخص هذا البحث من هذا الموقع لكن لا أستطيع الحصول على البحث كاملاً ولا أعرف اذا كان هناك مواقع أخرى يمكن الحصول منها على هذا البحث
    أرجو المساعدة نظراً لأهمية هذا الموضوع برسالتى
    ولكم جزيل الشكر على مجهوداتكم العظيمة
  5. [2925]
    اقتباس المشاركة الأصلية كتبت بواسطة علي مجيد محمود مشاهدة المشاركة
    fuzzy Logic Based Congestion Avoidance In Tcp/aqm Networks
    Isbn 978-3-540-23478-4
    Pages: 575-584
    2005
    تفضل اخي البيبر
  6. [2926]
    السلام عليكم جميعا أخواني وبارك الله بجهودكم الخيرة وأذا ممكن نتعبكم بطلب الأبحاث التالية والشكر موصول مقدماً سواء توفرت أم لا
    A theoretical framework for determining the minimum number of bidders in construction bidding competitions
    Stephen C. Ngai; Derek S. Drew; H. P. Lo; Martin Skitmore
    Construction Management and Economics, Volume 20, Issue 6, 2002, Pages 473 – 482
    DETERMINATION OF OPTIMAL BIDDING PROFIT RATE BY FUZZY SET THEORY
    Zivojin Prascevic; Sonja Petrovic-Lazarevic
    Cybernetics and Systems: An International Journal, Volume 28, Issue 4, 1997, Pages 337 – 343 DOI: 10.1080/019697297126137
    G. Arslan, M. Tuncan, M.T. Birgonul, I. Dikmen, E-bidding proposal
    preparation system for construction projects, Building and Environment 41
    (10) (2006) 1406–1413
    J. Lambert, The fuzzy set membership problem using the hierarchy
    decision method, Fuzzy Sets and Systems 48 (1992) 323–330
    C. Boender, J. Graan, F. Lootsma, Multi-criteria decision analysis with
    fuzzy pairwise comparisons, Fuzzy Sets and Systems 29 (1989) 133–143
    T.Y. Hsieh, S.T. Lu, G.H. Tzeng, , Fuzzy MCDM approach for planning
    and design tender selection in public office buildings, International Journal
    of Project Management 22 (2004) 573–584 (Elsevier)
  7. [2927]
    بارك الله فيك اخي الكريم
    وجزاك الله الجنة
  8. [2928]
    Given: 11
    ممكن لو سمحتم الابحاث التالية
    -Guanidine derivative as a new corrosion inhibitor for copper in 3% NaCl solution
    Materials Chemistry and Physics, Volume 112, Issue 1, 15 November 2008, Pages 104-111
    K.F. Khaled
    2-Natural honey and black radish juice as tin corrosion inhibitors
    Corrosion Science, Volume 50, Issue 5, May 2008, Pages 1498-1504
    I. Radoj?i?, K. Berkovi?, S. Kova?, J. Vorkapi?-Fura?
    3-Variation of carbon steel corrosion rate with flow conditions in the presence of an inhibitive formulation
    Corrosion Science, Volume 50, Issue 5, May 2008, Pages 1245-1250
    Nakarin Srisuwan, Nathalie Ochoa, Nadine Pébère, Bernard Tribollet
    4-Poly(aniline-formaldehyde): A new and effective corrosion inhibitor for mild steel in hydrochloric acid
    Materials Chemistry and Physics, In Press, Corrected Proof, Available online 21 September 2008
    M.A. Quraishi, Sudhish Kumar Shukla
    5-Furfuryl alcohol as corrosion inhibitor for N80 steel in hydrochloric acid
    Corrosion Science, In Press, Corrected Proof, Available online 22 August 2008
    S. Vishwanatham, N. Haldar
    6-Corrosion inhibition of carbon steel in hydrochloric acid by furan derivatives
    Electrochimica Acta, Volume 53, Issue 20, 20 August 2008, Pages 6024-6032
    E. Machnikova, Kenton H. Whitmire, N. Hackerman
    7--(Piperidinomethyl)-3-[(pyridylidene)amino]isatin: A new and effective acid corrosion inhibitor for mild steel
    Materials Chemistry and Physics, In Press, Corrected Proof, Available online 13 August 2008
    M.A. Quraishi, Ishtiaque Ahamad, Ashish Kumar Singh, Sudhish Kumar Shukla, B. Lal, Vakil Singh
    8-Interfacial Behavior of Cysteine between Mild Steel and Sulfuric Acid as Corrosion Inhibitor
    Acta Physico-Chimica Sinica, Volume 24, Issue 8, August 2008, Pages 1387-1392
    Muzaffer ?zcan, Faruk Karada?, Ilyas Dehri
    9-Electrochemical and quantum chemical study of purines as corrosion inhibitors for mild steel in 1 M HCl solution
    Electrochimica Acta, Volume 53, Issue 20, 20 August 2008, Pages 5953-5960
    Ying Yan, Weihua Li, Lankun Cai, Baorong Hou
    10-
    27.
  9. [2929]
    Received: 12
    اريد هذه الورقة البحثية بعنوان:
    An intrusion detection tool for AODV-based ad hoc wireless networks
    وهذا هو رابطها :
    http://ieeexplore.ieee.org/search/wr...number=1377212
  10. [2930]
    اخي الكريم جزاك الله خير الجزاء ابحث وفي حاجة شديدة الي الكتب التالية او اي كتاب في هذا الموضوع ارجو سرعة الرد
    Handbook of Polymer Degradation
    Chemical Physics of Polymer Degradation and Stabilization
    Polymer Degradation: Principles and Practical Applications (Hanser Publishers)
    Polymer Durability: Degradation, Stabilization, and Lifetime Prediction (Advance in Chemistry Series)
    Progress in Polymer Degradation and Stability Research
    Degradable Polymers: Principles and Applications
    اهم واخطر كتاب مطلوب رجاء رجاء
    Polymer Photodegradation: Mechanisms and experimental methods by J.F. Rabek (1995 - or 2006)- Kindle Book
    my email is
    d_ahmed_elsayed(at)yahoo
    الرد علي في اي حال لاني في حاجة شديدة لهذة الكتب لاكمل رسالة الماجيستير
    Mobile phone # removed
    راجع مكتبة الكيمياء للحصول على بعض المراجع فى Degradation
    أضيفت حاليآ
