صفحة 277 من 864 الأولىالأولى ... 177227267273 274 275 276 277278 279 280 281 287327377777 ... الأخيرةالأخيرة
النتائج 2,761 إلى 2,770 من 8639
  1. [2761]
    اسف على الرسالة السابقة فقد كانت غير منظمة وهذه هي الابحاث التي اريدها وارجو من الله ان تجدوها لي مع شكري لكم ودعائي لكم
    1. http://www.nasa.gov/centers/glenn/pdf/84790main_fs03grc.pdf
    2. NOISE-CON 87; Proceedings of the National Conference on Noise Control Engineering, State College, PA, June 8-10,
    1987 (A88-39701 16-71). Poughkeepsie,NY, Noise Control Foundation, 1987, p. 129-134.
    3. http://www.aerospaceweb.org/question/propulsion/q0033.shtml
    4. Bies, David A. and Hansen, Colin H., Engineering Noise Control Theory and Practice,(New York: E & FN SPON, 1998), pages 470-472.
    5. Tokhi, M. O. and Leitch, R. R., Active Noise Control, (Oxford: Clarendon Press;NewYork: Oxford University Press, 1992), pages 1-6.
    6. http://www.grc.nasa.gov/WWW/RT2002/5000/5530delaat.html.
    7. Harris, David A. (ed.), Noise Control Manual: Guidelines for Problem Solving in the Industrial / Commercial Acoustical Environment, (New York, Van Nostrand Reinhold, 1991), pages 10-13.
    8. Witton, J.J. and E. Noordally, "Porous Media Burners for Clean Engines", CombustionProcesses in Propulsion (Gabriel D. Roy, Ed.), Academic Press/Elsevier, 2005, pp. 139-144
    9. Ellzey, J.L., A.J. Barra, and G. Diepvens, "Simulations of a Porous Burner for a Gas Turbine", Combustion Processes in Propulsion (Gabriel D. Roy, Ed.), Academic Press/Elsevier, 2005,pp. 145-156
    10. Singh, S. and R.E. Peck, "An Innovative Method for Reducing Gaseous Emissions from Power Turbine Combustors", Advances in Chemical Propulsion (Gabriel D. Roy Ed.) CRC Press,
    2002, pp. 463-476
    11. Kinsler, L. E., Frey, A. R., Coppens, A. B., and Sanders, J. V., Fundamentals of Acoustics, (New York: John Wiley & Sons, 1999),. 4th edition.
    12. Selamet, A., Dickey, N. S., and Novak, J. M., “The Herschel-Quincke Tube: A Theoretical, Computational and Experimental Investigation”, Journal of Acoustical Society of America, Vol. 96, No. 5, pages 3177-3185, Nov., 1994.
    13- NASA Glen Research Center, “Making Future Commercial Aircraft Quieter”, 1999,
    http://www.grc.nasa.gov/WWW/PAO/PAIS/fs03grc.htm (2001).
    14- R. A. Mangiarotty, “The Reduction of Aircraft Engine Fan-Compressor Noise Using Acoustic Linings,” Journal of Sound and Vibration 18 (4) (1971): 565-576.
    15- M. Rim and Y. J. Kim, “Narrowband Noise Attenuation Characteristics of In-Duct Acoustic Screens,” Journal of Science and Vibration 234 (5) (2000): 737-759.
    16- R. H. Thomas, R. A. Burdisso. C. R. Fuller, and W. F. O’Brien, “Active Control of Fan Noise From a Turbofan Engine,” AIAA 93-0597 (1993).
    17- J. P. Smith and R. A. Burdisso, “Active Control of Inlet Noise From a Turbofan Engine Using Inlet Wavenumber Sensors,” CEAS/AIAA 99-1808 (1999).
    18- R. A. Burdisso, C. R. Fuller, and J. P. Smith, “Experiments of the Active Control of a Turbofan Inlet Noise using Compact, Lightweight Inlet Control and Error Transducers,” CEAS/AiAA 95-028, (1995): 177-185.
    19- J. F. W. Herschel, “On the Absorption of Light by Colored Media, viewed in connection with the Undulatory Theory,” Philosophical Magazine and Journal of Science. 3 (1833): 401-412.
    20- G. Quincke, “Ueber interferenzapparate für schallwellen,” Ann. Phys. Chem. 128 (1866): 177-192.
    21- G. W. Stewart, “The Theory of the Herschel-Quincke Tube,” Physical Review 31.4 (1928): 696-698.
    22- Selamet, P. M. Radavich, and N. S. Dickey, “Mult-Dimensional Effects On Silencer Performance,” Noise Control 94 (1994): 261-266.
    23- A. Selamet, N. S. Dickey, and J. M. Novak, “The Herschel-Quincke tube: a theoretical, computational,and experimental investigation,” J. Acoust. Soc. Am. 96 (5) (1994): 3177-3185.
    24- A. Selamet and P. M. Radavich, “Effect of Expansion Chamber on the Resonance Frequency of Side Branches and Herschel-Quincke Tubes,” ASME NCA 22 (1996): 127-132.
    25- A. Selamet and V. Easwaran, “Modified Herschel-Quincke tube: Attenuation and resonance for n-duct configurations,” Acoust. Soc. Am. 102.1 (1997): 164-169.
    26- C. R. Fuller and D. A. Bies, “The effects of flow on the performance of a reactive acoustic attenuator,” J. Sound Vib, 62 (1979): 73-92.
    27- A. J. Torregrosa, A. Broatch, and R. Payri, “A study of the influence of mean flow on the acoustic performance of Herschel-Quincke tubes,” J. Acoust. Soc. Am. 107 (4) (2000): 1874-1879.
    28- Z. Zhichi, L. Song, T. Rui, G. Rui, D. Genhua, and L. Peizi, Application of Quincke tubes to flow ducts as a sound attenuation device,” Noise Control Eng. J., 46 (6) (1998): 245-255.
    29- L. A. Brady, R. A. Burdisso, and J. P. Smith, “Investigation of the Herschel-Quincke Concept for the Suppression of Higher-order Modes in a Duct,” Proceedings of Internoise, 99 (1999): 545-550.
    30- R. F. Hallez, J. P. Smith, and R. A. Burdisso, “Control of Higher-Order Modes in Ducts using Arrays of Herschel-Quincke Waveguides,” ASME Control of Vibration and Noise (2000): 1-8.
    31- R. D. Stunk, “Silencer for Hydraulic Piston Pump Pressure Pulsations,” SAE Technical Paper Series, 911759, International Off-Highway & Powerplant Congress & Exposition (1991).
    32- C. C. Chen and M. C. Hastings, “Half-wavelength tuning cables for passive noise control in automotive power steering systems,” Act. Control Vib. Noise, ASME Proc. DE-75 (1994): 355-361.
    33- R. A. Burdisso and J. P. Smith, “Control of Inlet Noise from Turbofan Engines Using Herschel-Quincke Waveguides,” AIAA. 2000-1994.
    34- R F. Hallez, “Investigation of the Herschel-Quincke Tube Concept as a Noise Control Device for Turbofan Engines,’ Maters of Science Thesis, Virginia Tech, 2001.
    35- Tyler J. M. and Sofrin, T. G., “Axial Flow Compressor Noise Studies,” SAE Transaction no. 70, 309-332, (1962).
    36- Kantola, R.A., and Gliebe, P.R., “Effects of Vane/Blade Ratio and Spacing on Fan Noise,” AIAA Paper no. 81-2033, Oct. (1981).
    37- Dittmar, J. H. and Woodward, R. P., “An Evaluation of some Alternative
    Approaches for Reducing Fan Tone Noise,” NASA Technical Memorandum
    105356, February (1992).
    38- Mangiarotty, R. A., “The Reduction of Aircraft Engine Fan-Compressor Noise Using Acoustic Linings,” Journal of Sound and Vibration, 18 (4), 565-576, (1971).
    39- Thomas, R.H., R. A. Burdisso, C. R. Fuller and W. F. O’Brien, “Active Control of Fan Noise From a Turbofan Engine,” AIAA paper no. 93-0597, January (1993).
    40- Smith, J. P. and Burdisso, R. A., “Active Control of Inlet Noise From a Turbofan Engine Using Inlet Wavenumber Sensors,” CEAS/AIAA-99-1808, Seattle, WA, May (1999).
    41- Burdisso, R. A., Fuller, C. R. and Smith, J. P., “Experiments on the Active Control of a Turbofan Inlet Noise using Compact, Lightweight Inlet Control and Error Transducers,” CEAS/AIAA-95-028, pp. 177-185, (1995).
    42- Herschel, J. F. W. ,“On the absorption of light by coloured media, viewed in connexion with the undulatory theory,” Philosophical Magazine and Journal of Science, 3, 401-412, (1833).
  2. [2762]
    أحتاج هذه المقالات من فضلكم:
    Setting up shop: The business of open-source software .1
    Linux in the workplace .2
    The business case for Linux .3
    Linux and Open - Source Success .4
    مرتبينَ حسبَ أهميتهم بالنسبة إليَّ. وهم بالمناسبة كلهم من عددٍ واحدٍ من المجلة (IEEE).
    وشكراً مقدماً يا أصدقاء،
    مأمون.
  3. [2763]
    السلام عليكم من فضلكم ابحث عن هده المقالات :
    T. A. BIRKS, J. C. KNIGHT, P. ST.J. RUSSELL: Endlessly single-mode photonic crystal fiber, Opt. Lett. 22, 961-963, 1997
    http://ol.osa.org/abstract.cfm?id=36213
    Macro-bending loss properties of photonic crystal fibre
    http://ieeexplore.ieee.org/xpl/freea...rnumber=911957
    M. D. NIELSEN, N. A. MORTENSEN, M. ALBERTSEN, J. R. FOLKENBERG, A. BJARKLEV, AND D. BONACINNI: Predicting macrobending loss for large-mode area photonic crystal fibers, Opt. Express 19, 1775-1779, 2004
    http://www.opticsexpress.org/abstrac...OPEX-12-8-1775
    وشكرا جزيلا
  4. [2764]
    هل استطيع الحصول على هاتان الورقتان :
    http://ieeexplore.ieee.org/xpl/freea...rnumber=163756
    http://ieeexplore.ieee.org/xpl/freea...rnumber=400337
    بارك الّله في جهودكم
  5. [2765]
    الصورة الرمزية المسك
    السلام عليكم من فضلكم ابحث عن هده المقالة
    A new method for the determination of the thickness, the optical constants and the relaxation time of weakly absorbing semiconducting thin filmsInfrared Physics, Volume 26, Issue 6, November 1986, Pages 385-393D. B. Kushev, N. N. Zheleva, Y. Demakopoulou and, D. Siapkas-وشكرا جزيلا
  6. [2766]
    الصورة الرمزية drisseto
    Received: 9
    اسمحوا لي على الانقطاع اللاارادي و اليكم هاته المكتبة الرائعة جدا جدا حتى تحملوا ما تريدون.
    أرجوا ممن حمل ما يريد أن يكتب بأنه حمل الملفات و شكرا للاخوة.
    المكتبة في المرفقات. أرجوا التحميل بعقلانية و مساعدة الاخوة.
  7. [2767]
    السلام عليكم اخي العزيز هل ممكن الحصول على هذا الكتاب و لك جزيل الشكر والتقدير على جهودك
    .NET Security and Cryptography (Integrated .NET Series from Object Innovations)
  8. [2768]
    ساعدوني في هذه البحوث
    السلام عليكم محتاج هذه البحوث
    Friedel, L. 1979. Improved friction pressure drop correlations for horizontal and vertical
    two-phase pipe flow. Europ. Two-phase Flow Group Meeting, Ispra, Paper E2.
    Cavallini, A. 2002. Condensation Heat Transfer and Energy Efficiency of Working
    Fluids in Mechanical Refrigeration. Bulletin of the IIR, Vol. 82, no. 6, pp. 4-21.
    Cavallini, A.; Censi, G.; Del Col, D. ; Doretti, L. ; Longo, G.A. and Rossetto, L. 2002.
    In tube condensation of halogenated refrigerants. ASHRAE Transactions, Vol.
    108, No. 1, #4507.
  9. [2769]
    two phase flow and heat transfer
    كل هذه البحوث موجودة على موقع
    www.sincedirect.com
    ولكن لم اقدر على تحميلها
    A. Cavallini, D. Del Col, G.A. Longo, L. Rossetto
    Condensation heat transfer with refrigerants, in: Proceedings
    of Two-Phase Flow Modelling and Experimentation
    Conference, ETS, Pisa, vol. 1, 1999, pp. 71–88.
    108, No. 1, #4507.
    Chisolm, D., 1983. Two-Phase flow in Pipelines and Heat Exchangers, Longman Inc.,
    New York.
  10. [2770]
    احتاج هذه البحوث
    New York.
    A. Cavallini, D. Del Col, G.A. Longo, L. Rossetto,
    108, No. 1, #4507.
    Cavallini, A.; Censi, G.; Del Col, D. ; Doretti, L. ; Longo, G.A. ; Rossetto, L. 2001.
    Experimental investigation on condensation heat transfer and pressure drop of
    new HFC refrigerants (R134a, R125, R32, R410A, R236ea) in a horizontal
    smooth tube. Int. J. of Refrigeration, Vol. 24, pp. 73-87.
