صفحة 273 من 864 الأولىالأولى ... 173223263269 270 271 272 273274 275 276 277 283323373773 ... الأخيرةالأخيرة
النتائج 2,721 إلى 2,730 من 8635
  1. [2721]
    الصورة الرمزية asas121
    ولى رجاء اخرممكن احد ان يدلينى عن هذة الورقه
    Cascia, M.A. 2000. Implementation of a near-optimal global set point control method in a DDC controller.
    ASHRAE Transactions 106(1):249–63.
  2. [2722]
    Buonicore J. A., (1980). Air pollution control, Chem.
    Eng., 87 (12), 81-100.
    Chhabra P. R., Sridhar T., Uhlherr T. H. P. and Potter E.
    O., (1980). Predicring transport cpefficient of liquid
    -A unified approch. AIChE. J., 26 (3), 522-525.
    Hwa M. Y., Hsieh C. C., Wu C. T. and Chang W. L. R.,
    (2000). Real-world vehicle emissions and VOCs
    profile in the Taipei tunnel located at Taiwan Taipei
    area, Atmosph. Environ., 36, 1993-2002.
    Mahajani V. V., (1985). Figuring packed-tower diameter
    calculation and shortcut deskbook, McGraw Hill CO.,
    New York, 30-33.
    McNutly K. and Chopey P. N., (1994). Effective design
    for absorbtion and strippey. Chem. Eng., 101 (20),
    43-49.
    Palmgren F., (2001). Benzene emission from the actual
    car fleet in relation to petrol composition in Denmark.
    Atmos. Environ., 35, 535-542.[/quote]
  3. [2723]
    اذا ممكن هذا البحث
    1. Effects of sigma phase precipitation on seawater pitting of duplex stainless steel
    Desalination, Volume 207, Issues 1-3, 10 March 2007, Pages 268-275
    2. Influence of alternating, direct and superimposed alternating and direct current on the corrosion of mild steel in marine environments
    Desalination, Volume 216, Issues 1-3, 5 October 2007, Pages 103-115
    3. Stress corrosion cracking (caustic embrittlement) of super heater tubes
    Desalination, Volume 222, Issues 1-3, 1 March 2008, Pages 682-688
    4. Fabrication of polymer film heat transfer elements for energy efficient multi-effect distillation
    Desalination, Volume 222, Issues 1-3, 1 March 2008, Pages 696-710
    5. Reduce costs for storage and distribution of desalted water — use duplex stainless steel
    Desalination, Volume 223, Issues 1-3, 1 March 2008, Pages 476-486
  4. [2724]
    اخي الكريم:
    ارجومنك مساعدتي في الحصول على البحث التالي:
    Magnesium, Magnesite, and Dolomite - Global Strategic Business Report
    المصدر:
    Global Industry Analysts, Inc., Jan 2006, Pages: 415
    http://www.researchandmarkets.com/reports/338729
  5. [2725]
    أرجو إرشادي في كيفية الحصول على مراجع الإيزو
  6. [2726]
    عذراً لقد نسيت أن أذكر اسم المرجع الإيزو الذي أنا بحاجة ماسة إليه:
    ISO 5167 (1991) Measurement of fluid flow by means of pressure differential devices. International Standards Organization
    http://www.scopus.com/scopus/redirec...234ec769fbe167
    DIN 1952 (1982) Durchflußmessung mit Blenden, Du¨sen and
    Venturirohren in voll durchstro¨mten Rohren mit Kreisquerschnitt
  7. [2727]
    Please i need the portion that deal with Sodium Silicate or (Alkaly silicate) in the following Book
    D. Barby et al.: The Modern Inorganic Chemicals Industry, Royal Soc. Chemistry, London 1977.
    also if some one can upload this book, i think it is useful
    thanks
  8. [2728]
    الرجاء من الاخوة القائمين على هذا الملتقى مساعدتي بتوفير اطروحة الماجستير التالي ذكرها لصعوبة حصولي عليها بعد محاولاتي الكثيرة
    علما ان لهذه الاطروحة علاقة مباشرة و ممكن ان استفاد منها كثيرا في توجيهي و دعمي كمصدر في بحث الماجستير الذي اقوم به
    واكون ممنونة كثيرا اذا استطعتم توفيره لي
    جزاكم الله خيرا
    الاطروحة بعنوان
    [FONT='Times New Roman','serif']Zhang, J. (2001). “Experimental Assessment of Process-Based Planning and Control in Residential Construction.” Master’s Degree Dissertation, Department of Civil Engineering, North Carolina State University, NC 27695.[/FONT]
    [FONT='Times New Roman','serif']ارجو من الاخوان الاهتمام و الرد في اقرب وقت ممكن مع الشكر و التقدير[/FONT]
  9. [2729]
    رد وشكر
    شكرك جزيل الشكر اخي الكريم وبارك الله فيك
  10. [2730]
    الصورة الرمزية محمد زيدان القيسي
    أرجو مساعدة الاخوة في الحصول على الملف التالي:
    3D to 2D transformation solution of transient eddy currentelectromagnetic fields in an actuator
    Li, E.; McEwan, P.M.
    Magnetics, IEEE Transactions on
    Volume 29, Issue 2, Mar 1993 Page(s):1733 - 1736
    Digital Object Identifier 10.1109/20.250740
