صفحة 215 من 864 الأولىالأولى ... 115165205211 212 213 214 215216 217 218 219 225265315715 ... الأخيرةالأخيرة
النتائج 2,141 إلى 2,150 من 8635
  1. [2141]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 8
    اقتباس المشاركة الأصلية كتبت بواسطة المصمم الكيميائى مشاهدة المشاركة
    السلام عليكم ورحمة الله
    امل ان اتمكن من الحصول على الأوراق التالية
    Emad Ali, Robust control of industrial multi-stage flash desalination plants, Desalination, Volume 114, Issue 3, 30 December 1997, Pages 289-302
    Emad Ali,, Model reduction and robust control of multi-stage flash (MSF) desalination plants, Desalination, Volume 121, Issue 1, 29 January 1999, Pages 65-85
    M. A. Darwish , Energy consumption by multi-stage flash and reverse osmosis desalters
    Applied Thermal Engineering, Volume 20, Issue 5, 1 April 2000, Pages 399-416
    Hisham T. El-Dessouky, Multi-stage flash desalination: present and future outlook
    Chemical Engineering Journal, Volume 73, Issue 2, May 1999, Pages 173-190
    Hisham El-Dessouky , A fixed point iterative algorithm for solving equations modeling the multi-stage flash desalination process
    Computer Methods in Applied Mechanics and Engineering, Volume 141, Issues 1-2, 15 February 1997, Pages 95-115
    Hisham El-Dessouky, Steady-state analysis of multi-stage flash desalination process
    Desalination, Volume 103, Issue 3, December 1995, Pages 271-287
    Abdulla Ismail, Control of multi-stage flash desalination plants: A survey
    Desalination, Volume 116, Issues 2-3, 18 September 1998, Pages 145-155
    Abdulla Ismail ,Fuzzy model reference learning control of multi-stage flash desalination plants, Desalination, Volume 116, Issues 2-3, 18 September 1998, Pages 157-164
    Viral M. Maniar , Advanced controls for multi-stage flash (MSF) desalination plant optimization, Journal of Process Control, Volume 6, Issue 1, February 1996, Pages 49-66
    P. J. Thomas, Steady state and dynamic simulation of multi-stage flash desalination plants: A case study, Computers & Chemical Engineering, Volume 22, Issue 10, 20 September 1998, Pages 1515-1529
    ولكم جزيل الشكر والعرفان
    تفضل اخي الكريم
    http://mihd.net/kv3z7p
  2. [2142]
    الاخ العزيز drisseto اشكرك ابتداءا على وضعك لهذا الرابط الذي يحوي كثير من المجلات المهمة والمفيدة ولكن للاسف لم افلح في الوصول اليها حيث انه يطلب pass word and user name كلما ادخل على واحدة من هذه المجلات بعد ان استخدم الرابط في الدخول بنجاح
    ارجو المساعده والتوجيه والايضاح قدر المستطاع مع خالص شكري ودعائي لكم بالتوفيق والسداد
  3. [2143]
    الصورة الرمزية drisseto
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة حميد بلاسم ماهود مشاهدة المشاركة
    تفضلوا اخوتي مكتبات اخرى و هي ايضا جيدة :
    Lawr**ence Te**ch :
    http://ez**pro**xy.lt*u.ed*u:80**80/me**nu
    kb0**00254**145
    Univ gate**way :
    https://mu**tex.gm**u.e*du/me**nu
    bmu**noz
    luci**a900
    Rol*lins Coll*ege - Win*ter Pa*rk, Flo*rida :
    https://login.ez**proxy.rolli**ns.edu:24**43/login
    zl*ee / ck*rq6*999
    أرجوا محو *
  4. [2144]
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة رزقي محمد أسامة مشاهدة المشاركة
    هل استطيع الحصول على هذه الاوراق:
    D. Swierczynski and M. P. Kazmierkowski,
    “Direct Torque Control of Permanent Magnet Synchronous Motor (PMSM) Using Space Vector modulation (DTC-SVM)-Simulation and Experimental Results,”
    The 28th IEEE Annual Conf. of the Industrial Electronics
    Society, 5-8 Nov. 2002, pp751-755.
    L. Zhong, M. F. Rahman, W. Y. Hu, and K. W. Lim,
    “Analysis of direct torque control in permanent magnet synchronous motor drives,”
    IEEE Trans. Power Electron., vol. 12, no. 3, pp. 528–536, May 1997.
    M. R. Zolghadri, J. Guiraud, J. Davoine, and D. Roye,
    “A DSP based direct torque controller for permanent magnet synchronous motor drives,” in Conf. Rec. IEEE 29th Annual Power Electronics Specialists Conference (PESC’98), vol. 2, May 17–22, 1998, pp. 2055–2061.
    J. Habibi and S. Vaez-Zadeh,
    “Efficiency-optimizing direct torque control of permanent magnet synchronous machines,”
    in Conf. Rec. IEEE 36th Annual Power Electronics Specialists Conference (PESC’05), Recife, Brazil, June 12–16, 2005, pp. 759–764.
    L. Li, X. Wang, and H. Sun,
    “A variable-voltage direct torque control based on DSP in pm synchronous motor drive,” in Conf. Proc. IEEE Region 10 Conference on Computers, Communications, Control and Power Engineering (TENCON’02), vol. 3, Oct. 28–31, 2002, pp. 2065–2068.
    M. R. Zolghadri and D. Roye
    “A fully digital sensorless direct torque control system for synchronous machine,”
    Elect. Mach. Power Syst., vol. 26, pp. 709–721, 1998.
    M.R.
    والله الموفق
    اليك أخي ما طلبت.
    رابط اخر :
    http://mihd.net/zisg74
  5. [2145]
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة الباحث الكبير مشاهدة المشاركة
    اليك ما طلبت.
  6. [2146]
    ادعو الله أن يوفق الجميع لما فيه الخير ومنفعه للأسلام والمسلمين
    اتمنى ان اجد هذه الأوراق وأعتذر لعلمى انها كثيره ولكنى أطمع فى كرم أعضاء الملتقى
    (1) H. Hoekstra et al., 'New formulation of the beam propagation method based on the slowly varying envelope approximation', Opt. Comm., 97, pp. 301-303, 1993.
    (2)M.K. Smit, 'New focusing and dispersive component based on an optical phased-array.', Electron. Lett, 24 (7), pp. 385-386, 1988 .
    (3)M.K. Smit and C. van Dam, "PHASAR-Based WDM-Devices: Principles, Design and Applications", IEEE J. of Sel. Topics in QE, 2 (2), pp. 236-250, 1996.
    (4)H. Takahashi et al., 'Arrayed waveguide grating for wavelength division multi/demultiplexer with nanometer resolution', Electron. Lett., 26 (2), pp. 87-88, 1990.
    (5)C. Dragone, "An N x N Optical Multiplexer Using a Planar Arrangement of 2 Star Couplers," /E€€ Photonics Tech. Lett.. 1991, vol. 3, no. 9, pp. 81 2-1 5.
    (6)C. Dragone, C.A. Edwards, and R.C. Kistler, “Integrated optics N × N multiplexer on silicon,” IEEE Photon. Technol. Lett., 3, 896–899, 1991.
    (7)H. Takahashi, Y. Hibino, and I. Nishi, “Polarization-insensitive arrayed-waveguide grating wavelength multiplexer on silicon,” Opt. Lett., 17, 499–501, 1992.
    (8)Y. Yoshikuni, “Semiconductor arrayed waveguide gratings for photonic integrated devices,” IEEE J. Selected Top. Quantum Electron, 8, 1102–1114, 2002.
    (9)H. Takahashi, K. Oda, H. Toba, and Y. Inoue, “Transmission characteristics of arrayed waveguide N  _wavelength multiplexer,” J. Lightwave Technol., 13, 447–455, 1995.
    (10)K. Okamoto and A. Sugita, “Flat spectral response arrayed-waveguide grating multiplexer with parabolic waveguide horns,” Electron. Lett., 32, 1661–1662, 1996.
    (11)Y. Hida, Y. Hibino, T. Kitoh, Y. Inoue, M. Itoh, T. Shibata, A. Sugita, and A. Himeno, “400-channel arrayed-waveguide grating with 25 GHz spacing using 1.5%-Δ waveguides on 6-inch Si wafer,” Electron. Lett., 37, 576–577, 2001.
    (12)A. Sugita, A. Kaneko, K. Okamoto, M. Itoh, A. Himeno, and Y. Ohmori, “Very low insertion loss arrayed waveguide grating with vertically tapered waveguides,” IEEE Photon. Technol. Lett., 12, 1180–1182, 2000.
    (13)Y. Inoue, A. Kaneko, F. Hanawa, H. Takahashi, K. Hattori, and S. Sumida, “Athermal silica-based arrayed waveguide grating multiplexer,” Electron. Lett., 33, 1945–1946, 1997.
    وجزاكم الله كل خير
  7. [2147]
    الاخ العزيزaalmasri
    ارجو المساعدة في الحصول على الرقة
    Zhang CZ, Zhou MC, Yu M
    Ad hoc network routing and security
    INTERNATIONAL JOURNAL OF COMMUNICATION SYSTEMS 20 (8): 909-925 AUG 2007 0
    مع خالص الشكر والتحية وكذلك العرض
    Kargl F, Klenk A, Schlott S, et al.
    Advanced detection of selfish or malicious nodes in ad hoc networks
    LECTURE NOTES IN COMPUTER SCIENCE 3313: 152-165 2005
    Venkatraman L, Agrawal DP
    Strategies for enhancing routing security in protocols for mobile ad hoc networks
    JOURNAL OF PARALLEL AND DISTRIBUTED COMPUTING 63 (2): 214-227 FEB 2003
  8. [2148]
    أحي الكريم أعجز عن الشكر و لكن تأكد أنني لن أعجز عن الدعاء لكم جميعا
    فجزاكم الله كل خير و جعل كل ما تعملون في ميزان حسناتكم آمين
  9. [2149]
    عضو تحرير المجلة
    Received: 8
    اقتباس المشاركة الأصلية كتبت بواسطة الاءنبيل مشاهدة المشاركة
    وجزاكم الله كل خير
    هذا ما طلبتي اختي الكريمة باستثناء الورقة الاولى لم تتوفر
    http://mihd.net/d798ag
  10. [2150]
    عضو تحرير المجلة
    Received: 8
    اقتباس المشاركة الأصلية كتبت بواسطة نهاد مجدي مشاهدة المشاركة
    الاخ العزيزaalmasri
    اهلا بك اخي نهاد
    هذه الاولى والثالثة
    http://mihd.net/tbhswr
