صفحة 213 من 864 الأولىالأولى ... 113163203209 210 211 212 213214 215 216 217 223263313713 ... الأخيرةالأخيرة
النتائج 2,121 إلى 2,130 من 8635
  1. [2121]
    انني اطلب لو بالامكان ورقة او بحث او اطروحة او تقريرحول(ANALYSIS OF COMPOSITE BEAM UNDER HIGH TEMPERATURE)و خصوصا اذا كان التحليل بواسطة برنامج ANSYS
    ارجو مساعدتي ضمن الامكان لحاجتي الماسة و اعلامي في حالة امكانية ذلك او العكس و تقبلوا مني جميعا جزيل الشكر و التقدير لمجهودكم الرائع
  2. [2122]
    Received: 16
    احتاج هذه الـ paper
    Skid to turn control of the APKWS missile using trajectorylinearization technique
    Mickle, M.C.; Zhu, J.J.
    American Control Conference, 2001. Proceedings of the 2001
    Volume 5, Issue , 2001 Page(s):3346 - 3351 vol.5
    Digital Object Identifier 10.1109/ACC.2001.946145
    Summary:This paper presents the design and simulation results of an autopilot for the US Army's APKWS missile. The concept is to add on a guidance section to the existing Hydra 70 unguided rocket airframe. The guidance section is to be mounted onto existing hardware using a deroll bearing which permits the motor to roll freely while the guidance section is roll stabilized. The Hydra 70 has unusual dynamic and aerodynamic characteristics, which include a very large intentional induced roll moment which is heavily influenced by down wash effects on the rear spin inducing fins from large aerodynamic angles and the displacement of the control canards. Moreover, angle of attack tracking with control canards makes the problem nonminimum phase. The autopilot consists of a nonlinear inverse subsection which places the missile on the nominal commanded trajectory, and a linear time varying trajectory regulating controller. The regulating controller is formulated using a new parallel differential eigenvalue stability concept. An advantage of the proposed design method is that the controller gains are computed symbolically such that a full flight envelope autopilot can be designed without resorting to pointwise gain scheduling. Simulation results are shown to demonstrate the effectiveness of the trajectory linearization control technique
    لا اله الا الله محمد رسول الله
    تفضل , هنا تقرأ القرآن
  3. [2123]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة تمارا عبواليونان مشاهدة المشاركة
    وعليكم السلام ورحمة الله
    اخيتي تمارا عبواليونان
    استخدمي محرك البحث العلمي scirus.com وان شاء الله تجدي ما تريدين
    دمتي بخير
  4. [2124]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة م المصري مشاهدة المشاركة
    احتاج هذه الـ paper
    أهلا بمشرفنا العزيز م المصري :)
    هذه هي الورقة
    http://mihd.net/o6gzpi
    دمت بخير
  5. [2125]
    Received: 16
    اقتباس المشاركة الأصلية كتبت بواسطة aalmasri مشاهدة المشاركة
    هذه هي الورقة
    دمت بخير
    لا اعرف كيف اشكرك اخي الفاضل ....... شكرا شكرا
    و احلي ما في هذا القسم .... خدمة العملاء السريعه
    تحياتي و الف شكر
  6. [2126]
  7. [2127]
    عضو تحرير المجلة
    Received: 9
  8. [2128]
    Received: 12
    شكرا جزيلا لك يا عزيزي aalmasri، وتمنياتي لك بالتفوق و التقدم و النجاح دائما
  9. [2129]
    Received: 12
    Thumbs up من ساعدني لأتعلم حرفا صرت له عبدا ...
  10. [2130]
    الصورة الرمزية drisseto
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة الباحث الكبير مشاهدة المشاركة
    تفضل أخي مقالاتك.
