صفحة 156 من 864 الأولىالأولى ... 56106146152 153 154 155 156157 158 159 160 166206256656 ... الأخيرةالأخيرة
النتائج 1,551 إلى 1,560 من 8635
  1. [1551]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 8
    اقتباس المشاركة الأصلية كتبت بواسطة smi مشاهدة المشاركة
    Issues in Subcontracting Practice
    J. Constr. Engrg. and Mgmt., Volume 131, Issue 8, pp. 866-876 (August 2005)
    David Arditi,1 M.ASCE and Ranon Chotibhongs2
    The influence of partnering and
    procurement on subcontractor involvement and innovation
    Author(s): Per Erik Eriksson, Michael Dickinson, Malik M.A. Khalfan
    Journal: Facilities
    ISSN: 0263-2772
    Year: 2007 Volume: 25 Issue: 5/6 Page: 203 - 214
    DOI: 10.1108/02632770710742174
    Publisher: Emerald Group Publishing Limited
    The Contractor-Subcontractor Relationship: The Subcontractor’s View
    by Jimmie Hinze, and Andrew Tracey
    Journal of Construction Engineering and Management, Vol. 120, No. 2, June 1994, pp. 274-287 , (doi 10.1061/(ASCE)0733-9364(1994)120:2(274))
    Discussion of “The Contractor-Subcontractor Relationship: The Subcontractor's View” J. Constr. Engrg. and Mgmt., Volume 121, Issue 3, pp. 332-333 (September/October 1995) C. E. Haltenhoff,1 Fellow, ASCE
    Pre-construction project partnering: from adversarial to collaborative relationships
    Authors: Humphreys P.; Matthews J.; Kumaraswamy M.
    Source: Supply Chain Management: An International Journal, Volume 8, Number 2, 2003 , pp. 166-178(13)
    Golden Rule of Contractor-Subcontractor Relations
    by Joseph R. Proctor, Jr., Life Member, ASCE, (Constr. Consultant, 936 Evergreen Rd., Lake Oswego, OR 97034) Practice Periodical on Structural Design and Construction, Vol. 1, No. 1, February 1996, pp. 12-14 , (doi 10.1061/(ASCE)1084-0680(1996)1:1(12))
    Evaluating sub-contractors performance using EFNIM
    Automation in Construction, Volume 16, Issue 4, July 2007, Pages 525-530
    Chien-Ho Ko, Min-Yuan Cheng and Tsung-Kuei Wu
    هذا ما وجدت...دعواتك
  2. [1552]
    الصورة الرمزية smi
    gajak allah kol elkhair
  3. [1553]
    الأخ الفاضل
    من فضلك أريد هذا البحث ضرورى لو ممكن ولو مش فى الامكان ياريت تعرفنى وجزاكم الله كل خير على هذه الخدمة المتميزة و جعلها فى ميزان حسناتك
    SAE 2007-01-0615
    http://www.sae.org/technical/papers/2007-01-0615
    An Experimental and Numerical Investigation of the Combustion Characteristics of a Dual Fuel Engine With a Swirl Chamber
  4. [1554]
    who help me to find this
    Suemitsu, M. Ghribi, P. Viarouge et H.Le-Huy, 'Current regulation of a permanent-magnet synchronous motor using the TMS320C30 DSP', in Proc. IECON'92 Conf. Nov 1992, pp. 1412-1416.
    N. Matsui et H. Ohashi, 'DSP-based adaptive control of a brushless motor', US-IEEE 1988,pp.375-380
    M. Lajoie-Mazenc et al. 'Study and implementation of hysteresis controlled inverter on permanent magnet svnchronous machine',
    IEEE Trans. on ind. appli. , vol. 1A-21, No. 2,pp. 408-413, MarcMApd 1985.
    D. G. Luenburger,'An introduction to observers', IEEE Traiis.
    OnAutomatic Control, Vol AC-16, 1971, pp. 596-602
    F. Piriou, Abdel Razak, R. Perret et H. Le-huy, "Torque caractenctics of brushless DCmotors with imposed current waveform", LAS-IEEE, pp. 176- 18 1, 1986
    M. Ghribi, "Etude des stratégies de commande de la PMSM dans le système depositionnement", thèse de doctorat (Ph-D), Université Laval, 1994
    Teodeorescu R.: Getting started with dSPACE System. Aalborg University, Institute of EnergyTechnology, Department of Electrical Energy Conversion. Aalborg, Denmark, 2000
    M. R. Zolghadri, J. Guiraud, J. Davoine, and D. Roye, “A DSP
    based direct torque controller for permanent magnet synchronous motor drives,” in Conf. Rec. IEEE 29th Annual Power Electronics Specialists Conference (PESC’98), vol. 2, May 17–22, 1998, pp. 2055–2061
    جراكم الله خيرا
  5. [1555]
    جراكم الله خيرا
  6. [1556]
    لو سمحتم كنا نريد هذا البحث من موقع science direct
    http://www.sciencedirect.com/science...84520507af416c
    ولكم جزيل الشكر
  7. [1557]
    عضو تحرير المجلة
    Received: 8
    اقتباس المشاركة الأصلية كتبت بواسطة GJJMR مشاهدة المشاركة
    ولكم جزيل الشكر
    تفضل......دعواتك
    • نوع الملف: pdf lol.pdf‏ (284.5 كيلوبايت, 16 مشاهدات)
  8. [1558]
    الصورة الرمزية drisseto
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة رزقي محمد أسامة مشاهدة المشاركة
    جراكم الله خيرا
    اليك اخي ما طلبت من المقالات.
  9. [1559]
    Thumbs up
    الأخ الفاضل
    من فضلك أريد هذا البحث ضرورى لو ممكن ولو مش فى الامكان ياريت أيضا تعرفنى وجزاكم الله كل خير على هذه الخدمة المتميزة و جعلها فى ميزان حسناتك
    SAE 2007-01-0615
  10. [1560]
    اريد بحث عن ( دراسات الجدوى البيئية للمشاريع الهندسية) جزاكم الله كل خير
