صفحة 151 من 864 الأولىالأولى ... 51101141147 148 149 150 151152 153 154 155 161201251651 ... الأخيرةالأخيرة
النتائج 1,501 إلى 1,510 من 8635
  1. [1501]
    بارك الله فيكم و لكن هل هنالك بحوث علي automatic contrast enhancement
  2. [1502]
    Given: 11
    لو سمحت ممكن من موقع science direct
    1-Selective extraction of zinc(II) over iron(II) from spent hydrochloric acid pickling effluents by liquid–liquid extraction
    Journal of Hazardous Materials, In Press, Corrected Proof, Available online 13 May 2007
    Marcelo Borges Mansur, Sônia Denise Ferreira Rocha, Fernando Silva Magalhães and Jeaneth dos Santos Benedetto
    2-Extraction and recovery of Ga(III) from waste material using Cyanex 923
    Hydrometallurgy, Volume 87, Issues 1-2, June 2007, Pages 18-26
    Bina Gupta, Niti Mudhar, Zareena Begum I and Indu Singh
    3-Extraction and separation of Pd(II), Pt(IV), Fe(III), Zn(II), Cu(II) and Ag(I) from hydrochloric acid solutions with selected cyanamides as novel extractants
    Journal of Hazardous Materials, Volume 149, Issue 2, 22 October 2007, Pages 465-470
    E.A. Mowafy and H.F. Aly
    4-Fluid temperature and velocity effect on fouling
    Applied Thermal Engineering, Volume 27, Issue 16, November 2007, Pages 2732-2744
    David J. Kukulka and Mohan Devgun
    5-Design and multi-objective optimization of heat exchangers for refrigerators
    Applied Energy, Volume 84, Issue 12, December 2007, Pages 1226-1239
    A.K. Gholap and J.A. Khan
    6-Study of annealing temperature effect on stress-corrosion cracking of aluminum brass heat-exchangers tubes by microdiffraction experiments
    Engineering Failure Analysis, Volume 15, Issues 1-2, January-March 2008, Pages 54-61
    Annalisa Pola, Marcello Gelfi, Laura Eleonora Depero and Roberto Roberti
  3. [1503]
    Given: 11
  4. [1504]
    الاخ الكريم
    عندي الطلب الاتيش
    Strategies for Achieving Excellence in Construction Safety Perfprmance
    by EDWARD J .Jaselskis
    journal of construction engineering and managemant
    march 1996
    page 61
    مع جزيل الشكر
    اخوكم علي البغدادي
  5. [1505]
    السلام عليكم أخي
    أود هده الأوراق جزاكم الله خيرا
    [1]N. Matsui et H. Ohashi, 'DSP-based adaptive control of a brushless motor', US-IEEE 1988,
    pp.375-380.
    [2]M. Lajoie-Mazenc et al. 'Study and implementation of hysteresis controlled inverter on
    permanent magnet svnchronous machine', IEEE Trans. on ind. appli. , vol. 1A-21, No. 2,
    pp. 408-413, MarcMApd 1985.
    [3]D. G. Luenburger,'An introduction to observers', IEEE Traiis. On Automatic Control, Vol.
    AC-16, 1971, pp. 596-602.
    [4] F. Piriou, Abdel Razak, R. Perret et H. Le-huy, "Torque caractenctics of brushless DC
    motors with imposed current waveform", LAS-IEEE, pp. 176- 18 1, 1986.
    [5] M. Ghribi, "Etude des stratégies de commande de la PMSM dans le système de
    positionnement", thèse de doctorat (Ph-D), Université Laval, 1994.
    [6] Teodeorescu R.: Getting started with dSPACE System. Aalborg University, Institute of Energy
    Technology, Department of Electrical Energy Conversion. Aalborg, Denmark, 2000.
    [7] M. R. Zolghadri, J. Guiraud, J. Davoine, and D. Roye, “A DSP
    based direct torque controller for permanent magnet synchronous motor
    drives,” in Conf. Rec. IEEE 29th Annual Power Electronics Specialists
    Conference (PESC’98), vol. 2, May 17–22, 1998, pp. 2055–2061.
  6. [1506]
    طلب بحث
    بالبداية احي المشرفين الكرام على تحملنا و جهودهم الكريمة لخدمة جميع المهندسين
    انا طالب ماجستير و ارجو من المهندسين الكرام افادتي بالبحث التالي او مواضع قريب منها
    Effects of the Temperature Rise on the Surface Roughness (Ra) on
    the Peices
    او تاثير ارتفاع الدرجة الحرارة على نعومة السطحية للمعادن (الاجزاء)المختلفة من المواد
    مع التقدير و الاحترام
    المهندس زوان دلشاد
  7. [1507]
    طلب بحث
    the Peices
    المهندس زوان دلشاد
  8. [1508]
    الصورة الرمزية drisseto
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة jassim78 مشاهدة المشاركة
    السلام عليكم و بركاته
    تفضل اخي المقالات التي طلبتها.
    و المقالة الاتيةحجمها7 MB
    رفعتها على الرابط التالي:
    http://mihd.net/ijaubw
    و المقالة :
    على الرابط الاتي :
    http://mihd.net/72lfyr
    و المقالة الاخرى على الرابط التالي :
    http://mihd.net/fpyqjn
    ارجوا أن تنتفع بها و اذا كان هناك طلبات اخرى فانا في الخدمة.
  9. [1509]
    طلب بحث عاجل جدا
    اولا اشكر الاخوة و الاخوات المشرفين و المشرفات لجهودهم (هن) الطيبة في خدمة المهندسين
    انا طالب ماجستير و احتاج لبحث او اوراق علمية يتضمن هذا الموضوع (Effect of Temperature rise on the Surface Roughness (Ra) of Machined parts)و انا كلش شاكر لاي احد يساعدني
    مع التقدير
    المهندس زوان دلشاد
    العراق\كردستان\اربيل
  10. [1510]
    طلب بحث عاجل جدا
    مع التقدير
    المهندس زوان دلشاد
