صفحة 127 من 864 الأولىالأولى ... 2777117123 124 125 126 127128 129 130 131 137177227627 ... الأخيرةالأخيرة
النتائج 1,261 إلى 1,270 من 8635
  1. [1261]
    اذا ممكن الاوراق التالية
    1) Corrosion resistance of sintered duplex stainless steels in the salt fog spray test
    Journal of Materials Processing Technology, Volumes 192-193, 1 October 2007, Pages 443-448
    L.A. Dobrzański, Z. Brytan, M. Actis Grande and M. Rosso
    2) Cohesive zone modeling of hydrogen-induced stress cracking in 25% Cr duplex stainless steel
    Scripta Materialia, Volume 57, Issue 7, October 2007, Pages 615-618
    Vigdis Olden, Christian Thaulow, Roy Johnsen and Erling Østby
    3) Characterization of microstructure, chemical composition, corrosion resistance and toughness of a multipass weld joint of superduplex stainless steel UNS S32750
    Materials Characterization, Volume 58, Issue 7, July 2007, Pages 610-616
    S.S.M. Tavares, J.M. Pardal, L.D. Lima, I.N. Bastos, A.M. Nascimento and J.A. de Souza
    4) Materials performance in SWRO desalination plant at KISR research and development program
    Desalination, Volume 135, Issues 1-3, 20 April 2001, Pages 99-110
    A. Al-Odwani, J. Carew, M. Al-Tabtabaei and A. Al-Hijji
    5) Erosion of construction materials in a reverse osmosis plant utilizing seawater in Kuwait
    Desalination, Volume 129, Issue 2, 10 July 2000, Pages 137-145
    A. Al-Odwani, M. Al-Tabtabaei, A. Al-Hashim, J. Carew and F. Al-Atram
    6) Performance of high chromium stainless steels and titanium alloys in Arabian Gulf seawater
    Desalination, Volume 120, Issues 1-2, 15 December 1998, Pages 73-81
    Ali Al Odwani, Mohammed Al-Tabtabaei and Ahmed Abdel-Nabi
    7) Optimization of material selection for evaporative desalination plants in order to achieve the highest cost-benefit ratio
    Desalination, Volume 124, Issues 1-3, 1 November 1999, Pages 99-103
    C. Sommariva, D. Pinciroli, E. Tolle and R. Adinolfi
    ولكم جزيل الشكر
  2. [1262]
    السلام عليكم اخي ان امكن هذه الأبحاث وجزاك الله كل خير
    1- Shear modulus and damping ratio of grouted sand
    Soil Dynamics and Earthquake Engineering, Volume 24, Issue 6, August 2004, Pages 461-471
    Estelle Delfosse-Ribay, Irini Djeran-Maigre, Richard Cabrillac and Daniel Gouvenot
    2- Shear modulus and damping ratio of grouted sand
    3- Load bearing behaviour of fully grouted anchors under shock loading
    Soil Dynamics and Earthquake Engineering, Volume 13, Issue 2, 1994, Pages 89-95
    Heinz Hagedorn
    4- Field studies on dynamic properties of reinforced earth[/font
    Soil Dynamics and Earthquake Engineering, Volume 10, Issue 8, November 1991, Pages 402-406
    S. Boominathan, K. Senathipathi and V. Jayaprakasam
    5- Shear strength of Portland cement grout
    Mahdi Moosavi, , a and William F. Bawdenb ,
    Cement and Concrete Composites
    Volume 25, Issue 7, October 2003, Pages 729-735
  3. [1263]
    عفوا الأبحاث التي تحت رقم 1020 قد تحصلت عليها ولله الحمد وقد درجت مني عم طريق الخطأ.
  4. [1264]
    اقتباس المشاركة الأصلية كتبت بواسطة mohajri مشاهدة المشاركة
    ولكم جزيل الشكر
    الأبحاث المطلوبه
  5. [1265]
    السلام عليكم اخي العزيز
    بعد اذنك اطلب هذه الأوراق البحثية ولك جزيل الشكر
    1- STRENGTH DEVELOPMENT IN CEMENT STABILIZED LOW PLASTICITY AND COARSE GRAINED SOILS: LABORATORY AND FIELD STUDY
    Suksun Horpibulsuk, Wanchai Katkan, Wanchai Sirilerdwattana and Runglawan Rachan, soils and foundations, Vol.46 No.3 (2006.6)
    2-CYCLIC RESISTANCE OF CLEAN SAND IMPROVED BY SILICATE-BASED PERMEATION GROUTING
    Yoshimichi Tsukamoto, Kenji Ishihara, Keitaro Umeda and Tadao Enomoto, soils and foundations, Vol.46 No.2 (2006.4
    3- EXPERIMENTAL DETERMINATION OF SOFTENING RELATIONS FOR CEMENT-TREATED SAND
    [Tsutomu Namikawa and Junichi Koseki, soils and foundations, Vol.46 No.4 (2006.8)
    4- UNDRAINED SHEAR STRENGTH OF CEMENT-TREATED SOILS
    [Kiyonobu Kasama, Kouki Zen and Kiyoharu Iwataki, soils and foundations, Vol.46 No.2 (2006.4]
  6. [1266]
    اقتباس المشاركة الأصلية كتبت بواسطة احمد عبدالكريم حسن مشاهدة المشاركة
    أسف لا أستطيع أيجاد هذه المجله
  7. [1267]
    السلام عليكم:
    احتاج الى بحثين منSienceDirect ولكم الاجر انشاء الله
    1.Energy and Building Volume 25,Issue 1,15 feb.,1997. pp.7-12
    Experimental thermal study of solar wall of composite type.
    L.Zalerski, M.Chantant, S. Lassue and B.Buthoit
    2. Solar Energy Volume 39, Isuse 5,1987, pp409-419
    Theoretical Study of composite Trombe-Michel Wall solar collector system
    Z.Zrikem and E.Bilgen
  8. [1268]
    Overhaul maintenance of large power-generating units: management by subprejects
    International Journal of Project Management, Volume 8, Issue 2, May 1990, Pages 116-121
    M. T. Tabucanon and N Dahanayaka
  9. [1269]
    اقتباس المشاركة الأصلية كتبت بواسطة احسان فاضل عباس مشاهدة المشاركة
    السلام عليكم:
    و عليكم السلام
  10. [1270]
    اقتباس المشاركة الأصلية كتبت بواسطة امجد66 مشاهدة المشاركة
    الشكر لله
    و السلام عليكم
