صفحة 122 من 864 الأولىالأولى ... 2272112118 119 120 121 122123 124 125 126 132172222622 ... الأخيرةالأخيرة
النتائج 1,211 إلى 1,220 من 8635
  1. [1211]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة حميد بلاسم ماهود مشاهدة المشاركة
    الاخ المشرف المحترم اعتذ لعدم الوضوح ف طلبي الاخير وارجو الحصول على البحوث التالية ان امكن :
    [FONT='Times New Roman','serif']Park, W., Klausner, J., and Mei, R., “Unsteady forces on spherical bubbles,” Experiments in Fluids, Vol. 19, 1995,[/FONT]
    [FONT='Times New Roman','serif']pp. 167–172.[/FONT]
    [FONT='Times New Roman','serif']J.L. Xu, T.K. Chen, X.J. Chen, Critical flow in convergent divergent[/FONT]
    [FONT='Times New Roman','serif']nozzles with cavity nucleation model, Exp. Thermal[/FONT]
    [FONT='Times New Roman','serif']Fluid Sci. 14 (2) (1997) 166–173.[/FONT]
    [FONT='Times New Roman','serif'] V.N. Blinkov, O.C. Jones, B.I. Nigmatulin, Nucleation and[/FONT]
    [FONT='Times New Roman','serif']flashing in nozzles-2 comparison with experiments using a five [/FONT]
    [FONT='Times New Roman','serif']equation model for vapor void development, Int. J. Multiphase[/FONT]
    [FONT='Times New Roman','serif']Flow 19 (6) (1993) 965–986.[/FONT]
    [FONT='Times New Roman','serif']T.S. Shin, O.C. Jones, Nucleation and flashing in nozzles-1 a [/FONT]
    [FONT='Times New Roman','serif']distributed nucleation model, Int. J. Multiphase Flow 19 (6)[/FONT]
    [FONT='Times New Roman','serif'](1993) 943–964.[/FONT]
    [FONT='Times New Roman','serif']Dekang Chen, Sui Lin, Under pressure of vaporization of[/FONT]
    [FONT='Times New Roman','serif']refrigerant R134A through a diabatic capillary tube, Int. J.[/FONT]
    [FONT='Times New Roman','serif']Refrig. 24 (2001) 261–271.[/FONT]
    [FONT='Times New Roman','serif']O. Zeitoun, M. Shoukri, V. Chatoorgoon, Interfacial heat[/FONT]
    [FONT='Times New Roman','serif']transfer between stream bubbles and subcooled water in[/FONT]
    [FONT='Times New Roman','serif']vertical upward flow, Trans. ASME, J. Heat Transfer 117[/FONT]
    [FONT='Times New Roman','serif'](1995) 402–407.[/FONT]
    [FONT='Times New Roman','serif']M. Song, A. Steiff, P.-M. Weinspach, Parametric analysis of direct[/FONT]
    [FONT='Times New Roman','serif']contact evaporation process in a bubble column, Internat. J. Heat Mass[/FONT]
    [FONT='Times New Roman','serif']Transfer 41 (1998) 1749–1758.[/FONT]
    [FONT='Times New Roman','serif']M.G. Wohak, H. Beer, Numerical simulation of direct-contact evaporation[/FONT]
    [FONT='Times New Roman','serif']of a drop rising in a hot, less volatile immiscible liquid of higher[/FONT]
    [FONT='Times New Roman','serif']density—Possibilities and limits of the SOLA-VOF/CSF algorithm,[/FONT]
    [FONT='Times New Roman','serif']Numer. Heat Transfer A 33 (1998) 561–582.[/FONT][FONT='Times New Roman','serif'][/FONT]
    هذا ما توفر
    • نوع الملف: pdf 002.pdf‏ (866.9 كيلوبايت, 3 مشاهدات)
    • نوع الملف: pdf 001.pdf‏ (250.5 كيلوبايت, 3 مشاهدات)
  2. [1212]
    الصورة الرمزية asas121
    ممكن هذ الأوراق
    [1]
    Controls and Diagnostics for Air Distribution Systems
    Journal of Solar Energy Engineering -- August 2003 -- Volume 125, Issue 3, pp. 310-317
    [2] Willskys AS. A survey of design methods for fault detection in dynamic systems. Automatica 1976;12:601–11.
    [3] Basseville M. Detecting changes in signals and systems—A survey. Automatica 1998;24(3):309–26.
    [4] Frank PM. Fault diagnosis in dynamic systems using analytical and knowledge-based redundancy—A survey and
    some new results. Automatica 1990;26(3):456–74.
    [5] Isermann R. Supervision, fault detection and fault-diagnosis methods—An introduction. Control Eng Practice
    1997;5(5):639–92.
    [6]B. Arguello-Serrano, M. Velez-Reyes, Nonlinear control of a heating, ventilating, and air conditioning system with thermal
    oad estimation, IEEE Transactions on Control Systems Technology 7 (1999) 56e63
  3. [1213]
    ممكن هذ الأوراق
    [1]
    1997;5(5):639–92.
  4. [1214]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة asas121 مشاهدة المشاركة
    ممكن هذ الأوراق
    [1]
    1997;5(5):639–92.
    للاسف غير متوفرة
  5. [1215]
    السلام عليكم اخي العزيز
    بعد اذنك اطلب هذه الأوراق البحثية ولك جزيل الشكر
    1- STRENGTH DEVELOPMENT IN CEMENT STABILIZED LOW PLASTICITY AND COARSE GRAINED SOILS: LABORATORY AND FIELD STUDY
    [FONT='Calibri','sans-serif']Suksun Horpibulsuk, Wanchai Katkan, Wanchai Sirilerdwattana and Runglawan Rachan, soils and foundations, Vol.46 No.3 (2006.6)[/FONT]
    [FONT='Calibri','sans-serif'][/FONT]
    2-CYCLIC RESISTANCE OF CLEAN SAND IMPROVED BY SILICATE-BASED PERMEATION GROUTING
    [FONT='Calibri','sans-serif']Yoshimichi Tsukamoto, Kenji Ishihara, Keitaro Umeda and Tadao Enomoto, soils and foundations, [FONT='Calibri','sans-serif']Vol.46 No.2 (2006.4)[/FONT][/FONT]
    [FONT='Calibri','sans-serif'][FONT='Calibri','sans-serif'][/FONT][/FONT]
    3- EXPERIMENTAL DETERMINATION OF SOFTENING RELATIONS FOR CEMENT-TREATED SAND
    [FONT='Calibri','sans-serif']Tsutomu Namikawa and Junichi Koseki, soils and foundations, Vol.46 No.4 (2006.8)[/FONT]
    4- UNDRAINED SHEAR STRENGTH OF CEMENT-TREATED SOILS
    [FONT='Calibri','sans-serif']Kiyonobu Kasama, Kouki Zen and Kiyoharu Iwataki, soils and foundations, [FONT='Calibri','sans-serif']Vol.46 No.2 (2006.4)[/FONT][/FONT]
    [/FONT][/FONT][/FONT][/FONT][FONT='Calibri','sans-serif'][/FONT]
  6. [1216]
    الاخوة جميعا السلام عليكم
    ارجوا اذا كان بالامكان مساعدتي في الحصول على التالي:
    من موقع sciencedirect
    Application of CFD in ship engineering design practice and ship hydrodynamics
    Journal of Hydrodynamics, Ser. B, Volume 18, Issue 3, Supplement 1, July 2006, Pages 315-322
    Zhi-rong ZHANG, Hui LIU, Song-ping ZHU and Feng ZHAO
    وكذلك رجاءا
    Laminar and turbulent flow about ship models
    Journal of the Franklin Institute, Volume 213, Issue 2, February 1932, Pages 195-209
    Wendell P. Roop
    وجزيتم خيرا
  7. [1217]
    الله يجزاك خير يا اخ aalmasri
    والله يوفق في الدنيا والاخرة
  8. [1218]
    اخي ال Al Masri اريد مساعدتك بالحصول على بحوث او اطاريح تخص موضوع السكن العشوائي في كل من الاردن ومصر وسوريا واكون ممتن لذلك وجزاك الله الف خير
  9. [1219]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة البطنان مشاهدة المشاركة
    أخي الكريم
    استخدم موقع البحث العلمي scirus.com لايجاد بحوث في هذا المجال
  10. [1220]
    سيدي العزيز نريد منك اوراقا علمية تفيدني في تخصص الميكانيك فرع سيارات
    حيث بدا التفكير بمشروعي واريد بعد مشيئة الله وتوفيقه ان اضرب ضربة ما حصلتش.............
