صفحة 118 من 864 الأولىالأولى ... 1868108114 115 116 117 118119 120 121 122 128168218618 ... الأخيرةالأخيرة
النتائج 1,171 إلى 1,180 من 8635
  1. [1171]
    اشكرك جدا على تعاونك المثمر معنا وجعله الله في ميزان حسناتك وبعد اذنك اطلب هذه الأوراق ان توفرت :
    [FONT='Times New Roman','serif']1- Active Isolation of Machine Foundations by In-Filled Trench Barriers[/FONT]
    [FONT='Times New Roman','serif']J. Geotech. Engrg., Volume 122, Issue 4, pp. 288-294 (April 1996)[/FONT]
    T. M. Al-Hussaini AND S. Ahmad
    2- Investigation on Active Isolation of Machine Foundations by Open Trenches
    J. Geotech. Engrg., Volume 122, Issue 6, pp. 454-461 (June 1996)
    S. Ahmad , T. M. Al-Hussaini AND K. L. Fishman
    3- Simplified Model for Vertical Vibrations of Surface Foundations
    J. Geotech. and Geoenvir. Engrg., Volume 132, Issue 5, pp. 651-655 (May 2006)
    Shi-Shuenn Chen1 and Jun-Yang Shi
    4- Predicting Soil and Structure Vibrations from Impact Machines
    J. Geotech. and Geoenvir. Engrg., Volume 128, Issue 7, pp. 602-612 (July 2002)
    Mark R. Svinkin
    5- Vibration of Foundations on Incompressible Soils with No Elastic Region
    J. Geotech. Engrg., Volume 120, Issue 9, pp. 1570-1592 (September 1994)
    [FONT='Calibri','sans-serif']Ronaldo I. Borja[/FONT][FONT='Calibri','sans-serif'],1 and Wen-Hwa Wu,2[/FONT]
  2. [1172]
    ألف شكر على استجابتك السريعة
  3. [1173]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة asas121 مشاهدة المشاركة
    السلام عليكم أخى المصرى
    اطلب منك ان تساعدنى لأجد هذة الأوراق هى كثيرة بس هى كتير مهمة بالنسبة لة ولك الف شكر
    Huang, S., and Nelson, R. M., Rule Development and Adjustment Strategies of a Fuzzy Logic Controller for an
    HVAC system, Part One—Analysis and Part Two—Experiment, ASHRAE Transactions, 1994, Part I, pp.
    841–856.
    Zimmerman, A. J., Fundamentals of Direct Digital Control, Heating/Piping/Air Conditioning, no. 5, 1996,
    pp. 49–59.
    Harvey, Charles and Peter Wise, “New BMS and DCS Provide Reliable
    and Responsive Power Plant Automation,” Instrumentation & Control
    Systems, Vol. 72 No. 11, November 1999, pp. 59-61.
    URL: http://www.darmstadt.gmd.de/ambiente/
    Braun, J.E. 1999. Automated Fault Detection and Diagnostics for the HVAC&R Industry. HVAC&R
    Research, Vol. 5, No. 2, pp. 85–86.
    Cikanek, H.A. 1986. Space Shuttle Main Engine Failure Detection. IEEE Transactions on Automatic
    Control, Vol. 6, pp. 13–18.
    Fasolo, P.S. and Seborg, D.E. 1995. Monitoring and Fault Detection for an HVAC Control System.
    International Journal of Heating, Ventilation, and Air-Conditioning and Refrigeration Research,
    Vol. 99, Part 1, pp. 3–13.
    Issermann, R. 1984. Process Fault Detection Based on Modeling and Estimation Methods — A Survey.
    Automatica, Vol. 20, No. 4, pp. 387–404.
    Hartman, T. B., Direct Digital Controls for HVAC Systems, McGraw-Hill, New York, 1993.
    Zaheer-Udin (M.) - Optimal control of a single-zone environmental space. Building and Environment, 1992, vol. 27, n°1.
    Keeney (K.) and Braun (J.E.) - A simplified method for determining optimal cooling control strategies for thermal storage in building mass. HVAC&R Research, vol. 2 n°1. 1996.
    Virk GS, Ghazali AB, Azzi D, Fuzzy Logic Control of Building Management Systems, UKACC International Conference on Control 96, University of Exeter, UK, Conference Publication No 427, Vol 1, pp 580-585, 1996.
    Undenvood, C. P., “Robust Control ofHVAC Plant I:
    Modeling” Proceeding of CIBSE, Vol. 21, No. 1,2000
    Underwood, C. P., “HVAC Control Systems:
    Modeling, Analysis and Design” E & FN SPON Publication, 1999
    ******************************Ke YP, Mumma SA. Optimized supply air temperature (SAT) in variable-air-volume (VAV) systems. Energy—Int
    J 1997;22(6):601–14.
    Bynum, H.D. 1991. “Plan and Specification Documentation of a Direct Digital
    Control/Building Management System.” ASHRAE Transactions 97 (1): 773-779
    Haines, R.W. 1985. “Reducing Energy Cost Through Intelligent Operation of HVAC
    Systems.” ASHRAE Transactions 91 (2B): 791-793.
    Chan KT, Yu FW. Applying condensing-temperature control in air-cooled reciprocating water
    chillers for energy efficiency. Appl Energ 2002;72:565–81.
    Chan KT, Yu FW. Part-load efficiency of air-cooled multiple-chiller plant. Build Serv Eng Res
    Technol 2002;23(1):31–41.
    Chan KT, Yu FW. Optimum set-point of condensing temperature for air-cooled chillers. Int J
    HVAC&R Res 2004;10(2):113–27.
    I found only these
  4. [1174]
    ورقة علمية
    السلام عليكم ورحمة الله وبركاته،،،،،
    أقدم الشكر الجزيل لكل القائمين علي هذا الموقع الكبير سائلين الله أن يوفقكم دوما لما فيه خير أمتنا العربية والاسلامية
    عندي طلب لم اجده في محركات البحث وهو
    Corrections to "A General Theory of Phase Noise in Electrical Oscillators"
    Hajimiri, A.; Lee, T.H.
    Solid-State Circuits, IEEE Journal of
    Volume 33, Issue 6, Jun 1998 Page(s): 928 - 928
    وبارك الله فيكم
  5. [1175]
    السلام عليكم أخى aalmasri كل عام وأنتم بخير نتمنى أن يكون غيابك عنا فى الفترة السابقة غيابا محمودا، والعود أحمد
    كالعادة فإنى أود أن أزيد أعبائك بطلبى لتلك المقالات العلمية:-
    Scratching of polymers—Modeling abrasive wear
    Sujeet K. Sinha, W.L.M. Chong and Seh-Chun Lim
    Wear, Volume 262, Issues 9-10, 10 April 2007, Pages 1038-1047
    Effects of normal load on single-pass scratching of polymer surfaces
    Sujeet K. Sinha and Desmon B.J. Lim
    Wear, Volume 260, Issues 7-8, 7 April 2006, Pages 751-765
    Dry sliding wear characteristics of some industrial polymers against steel counterface
    H. Unal, U. Sen and A. Mimaroglu
    Tribology International, Volume 37, Issue 9, September 2004, Pages 727-732
    Friction and wear behaviour of unfilled engineering thermoplastics
    H. Unal and A. Mimaroglu
    Materials & Design, Volume 24, Issue 3, May 2003, Pages 183-187
    وجزاكم الله خيرا
  6. [1176]
    السلام عليك
    اخ المصري شكرا لتواصلك معنا ومجهودك الرائع لمساعدتنا
    ارجو الحصول ع
    not on the mechanism of interficial mass transfer of absorption
    processes
    international journal of heat and mass transfer
    Volume 48, Issue 16, July 2005, Pages 3454-3460
  7. [1177]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة مريم النعيمي مشاهدة المشاركة
    السلام عليك
    ارجو الحصول ع
    processes
    أختي مريم النعيمي
    وعليكم السلام ورحمة الله
    انما نستمر بفضل الله ثم بدعائكم...
    هذا هو البحث
    • نوع الملف: pdf 001.pdf‏ (233.0 كيلوبايت, 14 مشاهدات)
  8. [1178]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة s_online مشاهدة المشاركة
    وبارك الله فيكم
    أخي s_online
    موقع ieee معطل اليوم ولا أدري ما السبب...لذا سأحاول تحصيل البحث لك غدا ان شاء المولى عز وجل.
    دمت بخير
  9. [1179]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة elbary مشاهدة المشاركة
    وجزاكم الله خيرا
    وعليكم السلام أخي elbary
    كل عام وانت بألف خير...غيابي كان اجازة سريعة...غير ان الاجازة الطويلة للاردن قادمة قريبا ان شاء الله...لذا من كان له طلب فليعجل به...
    هذا ما طلبت
    http://mihd.net/miqsnu
  10. [1180]
    اذا ممكن الاوراق التالية
    1) Corrosion failures of AISI type 304 stainless steel in a fertiliser plant
    Engineering Failure Analysis, Volume 10, Issue 3, June 2003, Pages 329-339
    H. Shaikh, R. V. Subba Rao, R. P. George, T. Anita and H. S. Khatak
    2) Precise determination of surface micro-galvanic behavior
    Desalination, Volume 139, Issues 1-3, 20 September 2001, Pages 333-340
    Adel Husain
    3) Electrochemical noise analysis of localized corrosion of duplex stainless steel aged at 475 °C
    Materials Chemistry and Physics, Volume 91, Issues 2-3, 15 June 2005, Pages 355-360
    Chan-Jin Park and Hyuk-Sang Kwon
    4) Selection of materials for Taweelah “B” MSF desalination plant project (6 × 10–12.7 migd)
    Desalination, Volume 97, Issues 1-3, August 1994, Pages 3-16
    Adil Al Radif, R. Borsani and Haneef Sultan
    5) Evaporators made of solid duplex stainless steel. A new approach to reduced costs
    Desalination, Volume 97, Issues 1-3, August 1994, Pages 67-76
    Jan O. Olsson and Hans L. Groth
    6) Vapour-side corrosion of copper base condenser tubes of the MSF desalination plants of Abu Dhabi
    Desalination, Volume 97, Issues 1-3, August 1994, Pages 109-119
    E. A. Al Sum, Shawky Aziz, Adil Al Radif, M. Samir and O. Heikal
    ولكم جزيل الشكر
