صفحة 105 من 864 الأولىالأولى ... 55595101 102 103 104 105106 107 108 109 115155205605 ... الأخيرةالأخيرة
النتائج 1,041 إلى 1,050 من 8635
  1. [1041]
    الأخ الفاضل:
    جعل الله هذا في ميزان حسناتك,إن لم أكن أشق عليك فإننى احتاج الى بعض المقالات العلميه واتمنى ان اجدها لديك :
    1- In situ analysis and modeling of crack initiation and propagation within model fretting contacts using polymer materials
    M.C. Dubourg, A. Chateauminois and B. Villechaise
    Tribology Intrnational, Vol 36, Issue 2, February 2003, Pages 109-119
    2-Numerical study of polymer surface wear caused by sliding contact
    H. Q. Zhang, K. Sadeghipour and G. Baran
    Wear, Volume 224, Issue 1, January 1999, Pages 141-152
    3-Mechanics of fretting fatigue crack formation
    Matthew P. Szolwinski and Thomas N. Farris
    Wear, Volume 198, Issues 1-2, October 1996, Pages 93-107
    4- Effect of Crack-fiber interactions on crack growth rate in fiber-reinforced brittle matrix composite under cyclic loading: model experiment
    K. Goto, Y. Kagawa, K. Nojima and H. Iba
    Material Science and Engineering A, Volume 212, Issue 1, 15 July 1996, Pages 69-74
    5-Computer simulation of wear and rolling contact fatigue
    F. J. Franklin, I. Widiyarta and A. Kapoor
    Wear, Volume 251, Issues 1-12, October 2001, Pages 949-955
    ولكم جزيل الشكر
  2. [1042]
    الاخوة الاعضاء مشكورين على المساعدة واذا فية إمكانية اريد الاوراق التالية
    A study on the failure of pump casings made of ductile Ni-resist cast irons used in desalination plants
    Engineering Failure Analysis, Volume 14, Issue 7, October 2007, Pages 1294-1300
    Y.A. Alzafin, A.-H.I. Mourad, M. Abou Zour and O.A. Abuzeid
    Materials technology for seawater pumps
    World Pumps, Volume 2007, Issue 490, July 2007, Pages 38-39
    Takafumi Maehara
    Duplex — A new generation of stainless steels for desalination plants
    Desalination, Volume 205, Issues 1-3, 5 February 2007, Pages 104-113
    Jan Olsson and Malin Snis
    On-line corrosion resistance tests in sea water on metals for MED plants
    Desalination, Volume 183, Issues 1-3, 1 November 2005, Pages 187-194
    G. Gusmano, G. Montesperelli, G. Forte, E. Olzi and A. Benedetti
    Erosion — corrosion of duplex stainless steel under Kuwait marine condition
    Desalination, Volume 183, Issues 1-3, 1 November 2005, Pages 227-234
    Essam Hussain and A. Husain
  3. [1043]
    السلام عليكم شكرا لمجهودك الرائع لافادتنا بكل ما نحتاج اليه وجزاك الله خير الجزاء هل لي ان اطمع بالحصول علىTitle: Interphase mass transfer in cocurrent vertical two-phase channel flows with non-Newtonian liquids Resource Relation: International Communications in Heat and Mass Transfer ; VOL. 24 ; ISSUE: 1 ; PBD: Jan-Feb 1997
  4. [1044]
    عضو تحرير المجلة
    الصورة الرمزية aalmasri
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة مريم النعيمي مشاهدة المشاركة
    وعليكم السلام ورحمة الله
    نسأل الله ان يعيننا على خدمتكم
    هذا ما طلبتي
    • نوع الملف: pdf 001.pdf‏ (379.4 كيلوبايت, 17 مشاهدات)
  5. [1045]
    عضو تحرير المجلة
    Received: 9
    أخي smi
    لا يكن في صدرك علي شي...لكن طلباتك كثيرة -ما شاء الله-
    لذا اريد منك تجزئتها على مواضيع. في كل موضوع عشرة من الاوراق...حتى اذا انتهيت من تحميلها لك, اطلب العشرة التي تليها.
    اريد تسهيل الامور لي ولك وترتيبها حتى لا انسى بعض ما تطلب
    دمت بخير
  6. [1046]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة elbary مشاهدة المشاركة
    الأخ الفاضل:
    ولكم جزيل الشكر
    لا يوجد اي مشقة اخي elbary
    هذا ما طلبت في المرفقات باستثناء الورقة الرابعة لم اجدها
    • نوع الملف: pdf 002.pdf‏ (1.08 ميجابايت, 10 مشاهدات)
    • نوع الملف: pdf 003.pdf‏ (1.48 ميجابايت, 9 مشاهدات)
    • نوع الملف: zip 001.zip‏ (437.2 كيلوبايت, 8 مشاهدات)
  7. [1047]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة mohajri مشاهدة المشاركة
    Takafumi Maehara
    تفضل هذا ما طلبت
    • نوع الملف: pdf 001.pdf‏ (1.97 ميجابايت, 24 مشاهدات)
    • نوع الملف: zip 004.zip‏ (1.77 ميجابايت, 24 مشاهدات)
    • نوع الملف: zip 005.zip‏ (1.95 ميجابايت, 26 مشاهدات)
  8. [1048]
    الصورة الرمزية smi
    OK SIR GAJAKOOM ALLAH KHIRAN
    THIS THE FIRST GROUP
    Moshini, R. A. & Davidson, C. H.: Determinants of Performance in the Traditional
    Building Process. Construction Management and Economics 10 (1992), pp. 343-359.
    Walker, D.: An Investigation into Construction Time Performance. Construction
    Management and Economics (1995) 13, pp. 263-274
    Langford, D. A. et al.: Does Quality Assurance Deliver Higher Productivity? Construction
    Management and Economics (2000) 18, pp. 775-782.
    Lansey, P.: Analysing Construction Organizations. Construction Management and
    Economics (1994) 12, pp. 337-348.
    Liu, A. & Walker, A.: Evaluation of Project Outcomes. Construction Management and Economics 16:2 (1998), pp. 209-219
    Hatush, Z. & Skitmore, M.: Evaluating Contractor Pre-Qualification Data:
    Selection Criteria and Project Success Factors. Construction Management and Economics 15:2 (1997), pp. 129-147.
    Herbsman, Z. & Ellis, R.: Research on Factors Influencing Construction Productivity. Construction Management and Economics, 1990:8, pp. 49-61
    Garnett, N. & Pickrell, S.: Benchmarking for Construction: Theory and Practice. Construction Management and Economics 18:1 (2000), pp. 55-68
    Fraser, C.: A Non-Results-Based Effectiveness Index for Construction Site
    Managers.
    Construction Management and Economics 17:6 (1999), pp. 789-798.
    Fraser, C.: The Influence of Personal Characteristics on Effectiveness of Construction
    Site Managers. Construction Management and Economics 18:1 (2000), pp. 29-36
    Egbu, C.: Skills, Knowledge and Competencies for Managing Construction Refurbishment Works. Construction Management and Economics 17:1 (1999), pp.29-43
    Winch, G. et al.: Towards Total Project Quality: A Gap Analysis Approach.
    Construction
    Management and Economics 16 (1998), pp. 193-207.
    Winch, G. & Carr, B.: Benchmarking On-Site Productivity in France and the UK: A CALIBRE approach. Construction Management and Economics, 19:6 (2001), pp. 577-590.
    Yasamis, F. et al.: Assessing Contractor Quality Performance. Construction Management
    and Economics 20:3 (2002), pp. 211-223
  9. [1049]
    عضو تحرير المجلة
    Received: 9
    اقتباس المشاركة الأصلية كتبت بواسطة smi مشاهدة المشاركة
    Managers.
    Construction
    هذه اثنتا عشر ورقة
    http://mihd.net/637qx5
  10. [1050]
    Given: 11
    مكن اخي العزيز من موقع SCIENCE DIRECTواكون ممتنا لك
    1-Heavy metal leaching from mine tailings as affected by organic amendments
    Bioresource Technology, Volume 98, Issue 15, November 2007, Pages 2935-2941
    Paul Schwab, D. Zhu and M.K. Banks
    2-Two stage leaching of activated spent HDS catalyst and solvent extraction of aluminium using organo-phosphinic extractant, Cyanex 272
    Journal of Hazardous Materials, Volume 148, Issues 1-2, 5 September 2007, Pages 287-295
    Kyung Ho Park, Debasish Mohapatra and Chul-Woo Nam
    3-Aluminium leaching using chelating agents as compositions of food
    Food and Chemical Toxicology, Volume 45, Issue 9, September 2007, Pages 1688-1693
    Rim Karbouj
