النتائج 1 إلى 10 من 16
    تبريد الهواء و تسخينه بدون اى مائع تبريد او حركة كمبريسور
    الحكايه ببساطه هى انبوبه تدخلها الهواء عند الظروف العاديه من جهه تخرجلك هواء ساخن عند درجة 70 درجة مئويه و هواء بارد عند -12 درجة مئويه من الجهة الاخرى ..... تعتمد الفكرة الاساسيه لهذة الانبوبه على احداث تيارات دواميه عن طريق وضع اشكال هندسيه مختلفة فى مسار تيار الهواء الداخل الى الانبوبة فيكون الهواء فى قاع الدوامه بارد و كثافته كبيرة و الهواء عند فوهتها ساخن و كثافتة اقل مما يعطى الشكل المخروطى للدوامه بالاضافه لاتجاهات خطوط السريان.
    وهذه بعض المعلومات عنه ولكنها باللغه الانجليزية:
    With nothing more than a few pieces of plumbing and a source of compressed air, you can build a remarkably simple device for attaining moderately low temperatures. It separates high-energy molecules from those of low energy. George O. Smith, an engineer of Rumson, N. I., discusses its theory and construction
    The 19th century British physicist James Clerk Maxwell made many deep contributions to physics, and among the most significant was his law of random distribution. Considering. the case of a closed box containing a gas, Maxwell started off by saying that the temperature of the gas was due to the motion of the individual gas molecules within the box. But since the box was standing still, it stood to reason that the summation of the velocity and direction of the individual gas molecules must come to zero.
    In essence Maxwell's law of random distribution says that for every gas molecule headed east at 20 miles per hour, there must be another headed west at the same speed. Furthermore, if the heat of the gas indicates that the average velocity of the molecules is 20 miles per hour, the number of molecules moving slower than this speed must be equaled by the number of molecules moving faster.
    After a serious analysis of the consequences of his law, Maxwell permitted himself a touch of humor. He suggested that there was a statistical probability that; at some time in the future, all the molecules in a box of gas or a glass of hot water might be moving in the same direction. This would cause the water to rise out of the glass. Next Maxwell suggested that a system of drawing both hot and cold water out of a single pipe might be devised if we could capture a small demon and train him to open and close a tiny valve. The demon would open the valve only when a fast molecule approached it, and close the valve against slow molecules. The water coming out of the valve would thus be hot. To produce a stream of cold water the demon would open the valve only for slow molecules.
    Maxwell's demon would circumvent the law of thermodynamics which says in essence: "You can't get something for nothing." That is to say, one cannot separate cold water from hot without doing work. Thus when physicists heard that the Germans had developed a device which could achieve low temperatures by utilizing Maxwell's demon, they were intrigued, though obviously skeptical. One physicist investigated the matter at first hand for the U. S. Navy. He discovered that the device was most ingenious, though not quite as miraculous as had been rumored
    when compressed air is admitted to the "leg" of the T, hot air comes out of one arm of the T and cold air out of the other arm! Obviously, however, work must be done to compress the air.
    وعلي هذا الرابط برنامج فلاشيشرح الموضوع
    http://www.vortec.com/vortex_tubes.php
    منقوووووول
    ____________
    الموضوع منقول من أحد المنتديات للاخ الكريم Amino و مهندسنا الفاضل شرى كول
    جزاك الله خير .........
    تبريد الهواء و تسخينه بدون اى مائع تبريد او حركة كمبريسور[/IMG]
    لأيمكن الأستغناء عن ضاغط الهواء (كومبريسر) لأجراء العملية .
    شكرأ .
    Received: 62
    الأخوة الأعزاء .
    تحية طيبة .
    كل عام وانتم بخير ومبارك عليكم عيد الأضحى .
    اود ان اوضح لكم هذا النظام الذي يسمى انبوب الدوامة . والذي كان يسمى انبوب رانك نسبة الى مخترعه الفرنسي جورج رانك عام 1931 .
    ثم قام بتطويره العالم الالماني هلش فأصبحت تسمى انبوب رانك-هلش ثم سمي بعد ذلك vortex tube انبوب الدوامه . بسبب حركة ضغط الهواء الدوامية .
    ولقد تناولت في موضوع سابق ( بدلة مقاومة للحريق لرجال الاطفاء ) حيث تستخدم فيه انبوب الدوامة
    لاجل التبريد .
    كما يسرني ان استجيب لأي سؤال في هذا المجال اذا طلب الأمر .
    تمنياتي لكم بالموفقية .
    البغدادي .
    Received: 62
    الأخوة الأعزاء .
    تحية طيبة .
    اليكم الرابط حيث كان سؤالأ .
    http://www.arab-eng.org/vb/t23002.html
    لقد بدأ لديكم واضحأ بانني قد أجبت على السؤال حيث كان سؤالأ .
    help me for vortex tube
    الأخ شكري نوري السلام عليكم ورحمة الله وبركاته:
    أنا طالب دراسات عليا وموضوعي هو بحث تجريبي على الأنابيب الدوامية وأنا أبحث عن مراجع قيمة في الموضوع واستطعت الحصول على عناوين مفيدة ولكن لم أستطع الحصول على المراجع لعدم توفرها مجاناً فهل بإمكانك مساعدتي في الامر؟
    اولا شكرا على المجهود الرائع
    ثانيا لماذا الانبوب الدوامى هذا لم يفعل فى تطبيقات ملموسه
    طريقة التبربد باستخدام انبوب الدوامه غير شائعه وغير عمليه لسبب بسيط وهي انخفاض معامل الاداء لهذه العمليه بالمقارنه بدورات التثليج الانضغاطيه اذ لايتعدى معامل ادائها ال0.15
    بالمقارنه بدورة التثليج الانضغاطيه التي يصل معامل الاداء فيها الى اكثر من 4 حسب ظروف تشغيل الدوره.
    Received: 62
    اقتباس المشاركة الأصلية كتبت بواسطة salmanha مشاهدة المشاركة
    البغدادي
    Received: 62
    انبوب الدوامة لها تطبيقات عديدة وشائعة في كافة ميادين العملية .
    ولايمكننا مقارنتها بالضاغط لأن كل واحد له تطبيقاته .
    والرابط التالي يبين تطبيقات انبوب الدوامة في النواحي العملية واستخداماته .
    http://www.itwvortec.com/vortex_tubes.php
    البغدادي .
