مطلوب مهندسين شبكات وفنيين
صفحة 4 من 5 الأولىالأولى 1 2 3 45 الأخيرةالأخيرة
النتائج 31 إلى 40 من 48
  1. [31]
    Given: 3
    يوجد طرق عديدة تتوقف على طبيعة الاستخدام والشكل المعمارى ومثالا على ذلك
    Best-Hall Buildings
    Collinson supply and erects Best-Hall prefabricated tension fabric membrane buildings.
    BestHall buildings are manufactured in widths up from 12m to 100m clear span with unrestricted length/height.
    The modular steel frame has a heavy duty tensile PVC cover, available in a range of colours; the white roof fabric is translucent, permitting natural light into the interior and saving on electricity costs; roof ventilators are fitted as standard.
    Foundation requirements are minimal and erection is fast, resulting in reduced project costs.
    There are many door options – roller doors, sliding doors, custom design and personnel doors.
    BestHall hangars have been installed worldwide for industrial, commercial, military and civil purposes.
    Design Specification
    BestHall buildings are designed and manufactured in Finland to withstand the harsh climate extremes found in Scandinavia. Each building is designed in accordance with building regulations for the location with relation to wind and snow loads.
    Tension PVC Fabric membrane
    The PVC fabric membrane is manufactured by Ferrari SA in France using their patented Précontraint® technology.
    Throughout the entire manufacturing process the fabric membrane is subjected to a pre-stressing treatment of one metric tonne per metre and both sides of the woven polyester base cloth receive a thick coating of UV stabilised PVC; this combination provides a highly stable material in both the warp and weft directions.
    Précontraint® treatment provides the material with both a long life expectancy and exceptional dimensional stability.
    Longevity tests on this material were commissioned from a recognised German testing organisation TÜV, including the effects of tensioning, UV degradation, pollution and their effect on loss of tensile strength and therefore the material’s safety coefficient.
    After 18 years use TÜV have stated from the test to date that: “under normal conditions of use, a life expectancy of 25 years is confirmed”.
    Buildings having the original fabric membrane are still in use after 30 years; if necessary after many years the steel framework can easily be refurbished with a new PVC fabric membrane to resemble a brand new building.
    Old fabric membranes can be recycled at the end of their lifespan using the Ferrari Vinyloop™ process.
    Steel Frame
    The frame is made from steel trusses and longitudinal secondary rafters, manufactured from square hollow section to EN 10025 and welded to EN 25817 and EN 729 to give a substantial framework of indefinite expected life.
    The steel sections are shot blasted and epoxy painted with a Grey Eggshell finish, alternatively the framework can be hot dipped galvanised to EN ISO 1461 for specific applications.
    The shot blasted paint finish is normally specified as a completely smooth, burr free finish is guaranteed - this is beneficial for tensioning the fabric membrane cover over and ensures no wear points will develop over the life span of the membrane covering.
    The method of foundation fixing is determined by the size of the building and the ground conditions on site.
    Buildings up to 50m span can be anchored to existing asphalt or concrete surfaces; the Best-Hall ground anchor system uses steel rods pneumatically driven into asphalt at varying angles to depths of 1.2m; expansion or chemical anchors bolts are used on concrete.
    For buildings 50m to 100m span, a concrete ring beam around the entire perimeter of the building is recommended.
    Loadings are provided so that a suitable foundation may be designed for each site, accommodating soil strengths.
    Stanchion base plates are cast into the ring beam ready for the building to be fixed.
    The PVC fabric membrane has a skirt section at ground level, which is bonded to the existing surface with a bitumen-type product, to provide a reliable weatherproof seal.
    Erection and fixing is carried out by our highly skilled installation teams; Collinson are members of the National Britannia SAFE contractor scheme.
    Due to their pre-engineered design Besthall buildings can be erected quickly on site, eg. a building 1,500m² can be installed and ready for use in 2 weeks and a building 4000m² in around 5 weeks.
    However speedy construction belies the permanence of these structures: the long life of the materials and the strength of the anchorage combine to give extremely durable yet attractive buildings.
    Enhance your organisations competitive advantage by erecting a Best-Hall Tension Fabric membrane Building from Collinson.
  2. [32]
    هذا هو ال space truss الذي اتحدث عنه
    والله يعلم وانتم لا تعلمون
    أليس في جهنم مثوى للمتكبرين
    وأتقوا الله ويعلمكم الله
  3. [33]
    الصورة الرمزية miro1_6
    Received: 19
    اشكرك بشدة على المعلومات القيمة جزاك الله كل خير
    الف شكررررررررررررررررر
    شكرا سماسم لاهتمامك.....
  4. [34]
    كيف حالك مهندس هاني/ انا محمود محمد القلاوي - اشكرك جدا على المشاركات الجميلة وعلى فكرة لو وضعت لقب العائلة احسن بكثير من ( بدون لقب ) فاننا نفخر بعائلة القلاوي لرجوع نسبنا الى الاشراف والسلام يا عمي العزيز
    اقتباس المشاركة الأصلية كتبت بواسطة هانى حمدى عبدالعال مشاهدة المشاركة
    فى مثل تلك الحالات ذات المساحات الواسعة من الافضل استخدم نظام Space Frame على ان يتم تغطيته بالواح صاج معزولة سماكة من 5 سم الى 7.5 سم كما تفضل الاخوة وبدون الدخول فى تفاصيل التصميم فأن النظام يعتمد فى تركيبه على اعمدة وكمرات حديدية ( Built Up Sections ) , وثانيا اذا تم الانتهاء من التصور المعمارى للمشروع يمكن المساعدة فى تحديد اماكن الاعمدة الصحيحة والاستفادة من النظام فى الشكل المعمارى
  5. [35]
    اعتقد ان المفيد لهذا الامر هو نظام السقوف المعلقة وهو يشابه الجسور المعلقة tensiel steel
  6. [36]
    Given: 6
    انا لدي اكثر من 15 ملف اوتوكاد تفاصيل للنظام spaceframe ومستعدين للمساعدة اذا تبغوها
    وخصوصا للاخت المعمارية
    وانصح باستخدام هذه النظام لانه هو المستخدم كثيرا في هذا النوع من المشاريع
  7. [37]
    الصورة الرمزية mohy_y2003
    Received: 334
    Given: 433
    اقتباس المشاركة الأصلية كتبت بواسطة miro1_6 مشاهدة المشاركة
    اشكركم كثيرا للمساعدة حقيقة لم اكن اتوقع ذلك
    لم اصمم المبنى بعد لاننى ابحث عن التغطيه المناسبة انا غير مقيدة بفكرة معينه ولذلك اريد افضل تغطية واستغلال لمساحات المعرض
    سامحونى يا جماعة انا عارفة انى بتعبكم معايا بس فعلا احنا مش بندرس الحاجات دى فى القسم مع انها مفيدة جداااااااااااا وهى اساس المشروع كله
    الاخت miro1_6;285276/ السلام عليكم
    الافضل ان يتم التصميم المعماري وبعد ذلك يتم مناقشه طريقه التغطيه حسب المعماري المطلوب تغطيته -افضل من الكلام بصفه عامه
    م محيي الدين محمـــد
    الإمام محمد الغزالي
  8. [38]
    السلام عليكم ورحمة الله وبركاته ؛
    اسمحولى بالمشاركة فى موضوع المساحه المراد عمل تغطيه لها بدون استخدام اعمده داخليه,
    أفضل الانظمه الانشائيه لهذا الموضوع هو الspace frame ولكن هناك انظمه انشائيه كثيره اخرى يمكن بها تأدية نفس الوظيفه ؛ولكن هذا النظام يعتبر الانسب(هذا والله اعلى وأعلم)
    نرجوا رفع ابعاد الارض للمساعده بصوره أدق وافضل
  9. [39]
    الصورة الرمزية م. هشام عباس
    الاخوان ماقصروا معاااك
    ازيدك تصور واقعى مشاهد لكن الطريقة اظنها كما ذكر الاخوان
    فى ملاعب كرة القدم المغـطاه شبيه لما تبحثين عنه
    والله ورسوله اعلم ،،،،،،
  10. [40]
    لازم ابعاد الارض وتحديد اتجاه الشمال لاختيار النظام الانشائي المناسب والتحكم في الاضاءة وان شاء الله مشكلتك محلولة
