Hide Folders™ XP 2.5.build 3.321
Here are some key features of "Hide Folders XP":
· Effective protection methods allow you to hide folders out from users and applications in Microsoft Windows 2000 and Windows XP
· Nobody but you will access your hidden folders.
· 3 protection methods available: Hide, Lock, Hide & Lock
· NTFS, FAT32 and FAT volumes are supported.
· Unlimited number of folders may be protected at the same time.
· No file system structure modifications will occur.
· Effective password protection when running program.
· Effective password protection when uninstalling program.
· Removing Hide Folders XP folder from the system will not uncover hidden folders.
· Files from hidden folders will not be lost even if someone tries to remove an upper-level folder.
· Clear recent documents option. Hide Folders XP clears records of recently accessed documents if these documents reside in the hidden folders.
· Clear Recycle Bin items originally located in hidden folders.
· Secure Hide Folders XP by removing itself from the list of mostly used programs (Windows XP start menu).
· Secure Hide Folders XP by removing itself from Add/Remove software Control Panel applet.
· Hide Folders XP will not hide your Windows, Windows System folders and Windows partition root folders - so careless using of Hide Folders XP would not bring the system down.
· True stealth mode - you cannot detect the program with Windows Task Manager.
· Safe mode support - The folders can be hidden even if your computer is running in safe mode.
· Hot keys to manage basic Hide Folders XP functions.
· Command line support.
· Support of folders named with national language symbols .
· Hide Folders XP is multilingual software, its user interface supports different languages and can be easily translated to new languages.
· Intuitive and extrimely easy-to-use user interface.
Original Site
.... والله ولى التوفيق ...
