| ملتقى البرامج العامة و الانترنت ................ بإشراف : Mu7ammad |
LinkBack | أدوات الموضوع | تقييم الموضوع |
Hiren's BootCD 8.5 أقوى سيديات الصيانة ... للمهندسيين
Hiren's BootCD 8.5 أقوى سيديات الصيانة الوصف: يعتبر من أقوى سيديات الصيانة ويحوي على البرامج التي ستحتاجها مستقبلاً في حدوث مشكلة في الويندوز. الميزات الرئيسية والبرامج التي يحتويها السيدي : Hiren's BootCD 8.5 - All in one Dos Bootable CD which has all these utilities. Partition Tools: - Partition Magic Pro 8.05 - Best software to partition hard drive - Acronis Disk Director Suite 9.0.554 - Popular disk management functions in a single suite - Paragon Partition Manager 7.0.1274 - Universal tool for partitions - Partition Commander 9.01 - The safe way to partition your hard drive,with undo feature - Ranish Partition Manager 2.44 - a boot manager and hard disk partitioner. - The Partition Resizer v1.3.4 - move and resize your partitions in one step and more. - Smart Fdisk 2.05 - a simple harddisk partition manager - SPecial Fdisk 2000 - SPFDISK a partition tool. - eXtended Fdisk 0.9.3 - XFDISK allows easy partition creation and edition - GDisk 1.1.1 - Complete replacement for the DOS FDISK utility and more. Disk Clone Tools: - ImageCenter 5.6 (Drive Image 2002) - Best software to clone hard drive - Norton Ghost 8.3 - Similar to Drive Image (with usb/scsi support) - Acronis True Image 8.1.945 - Create an exact disk image for complete system backup and disk cloning. - Partition Saver 3.20 - A tool to backup/restore partitions. - COPYR.DMA Build013 - A Tool for making copies of hard disks with bad sectors Antivirus Tools: - F-Prot Antivirus 3.16f - Very good virus scanner (with ntfs support and easy to use menu) - McAfee Antivirus 4.40 - a virus scanner (with ntfs support and easy to use menu) Recovery Tools: - Active Partition Recovery 3.0 - To Recover a Deleted partition. - Active Uneraser 3.0 - To recover deleted files and folders on FAT and NTFS systems. - Ontrack Easy Recovery Pro 6.10 - To Recover data that has been deleted/virus attack - Winternals Disk Commander 1.1 - more than just a standard deleted-file recovery utility - TestDisk 6.5b - Tool to check and undelete partition. - Lost & Found 1.06 - a good old data recovery software. - DiyDataRecovery Diskpatch 2.1.100 - An excellent data recovery software. - Prosoft Media Tools 5.0 v1.1.2.64 - Another excellent data recovery software with many other options. - PhotoRec 6.5b - File and pictures recovery Tool. Testing Tools: - System Speed Test 4.78 - it tests CPU, harddrive, ect. - PC-Check 6.0 - Easy to use hardware tests - Ontrack Data Advisor 5.0 - Powerful diagnostic tool for assessing the condition of your computer - The Troubleshooter 7.02 - all kind of hardware testing tool - PC Doctor 3.0 - a benchmarking and information tool - Test Cpu/Video/Disk 5.6 - a tool to test cpu, video, and disk - Test Hard Disk Drive 1.0 - a tool to test Hard Disk Drive RAM (Memory) Testing Tools: - DocMemory 3.1b - RAM Test utility - GoldMemory 5.07 - RAM Test utility - Memtest86+ 1.65 - PC Memory Test Hard Disk Tools: - Hard Disk Diagnostic Utilities - Seagate Seatools Desktop Edition 3.02 - Western Digital Data Lifeguard Tools - Western Digital Diagnostics (DLGDIAG) 5.04f - Maxtor PowerMax 4.23 - Maxtor amset utility 4.0 - Maxtor(or any Hdd) Low Level Formatter 1.1 - Fujitsu HDD Diagnostic Tool 6.61 - Fujitsu IDE Low Level Format 1.0 - Samsung HDD Utility(HUTIL) 2.02 - Samsung Disk Diagnose (SHDIAG) 1.28 - IBM/Hitachi Drive Fitness Test 4.08 - IBM/Hitachi Feature Tool 2.03 - Gateway GwScan 3.15 - ExcelStor's ESTest 3.80 - MHDD 4.6 - WDClear 1.30 - Toshiba Hard Disk Diagnostic 2.00b - HDD Regenerator 1.51 - to recover a bad hard drive - Ontrack Disk Manager 9.57 - Disk Test/Format/Maintenance tool. - Norton Disk Doctor 2002 - a tool to repair a damaged disk, or to diagnose your hard drive. - Norton Disk Editor 2002 - a powerful disk editing, manual data recovery tool. - Active Kill Disk 1.1 - Securely overwrites and destroys all data on physical drive. - HDAT2 4.5.2 - main function is testing and repair (regenerates) bad sectors for devices - SmartUDM 2.00 - Hard Disk Drive S.M.A.R.T. Viewer. - Victoria 3.33 - a freeware program for low-level HDD diagnostics System Information Tools: - Aida16 2.14 - a system information tool, extracts details of all components of the PC - PCI and AGP info Tool (0410) - The PCI System information & Exploration tool. - System Analyser version 5.3o - View extensive information about your hardware - Navrįtil Software System Information 0.59.9 - High-end professional system information tool - Astra 5.21 - Advanced System info Tool and Reporting Assistant - HwInfo 5.0.3 - a powerful system information utility - PC-Config 9.33 - Complete hardware detection of your computer - SysChk 2.46- Find out exactly what is under the hood of your PC - CPU Identification utility v1.12 - Detailed information on CPU - CTIA CPU Information - another CPU information tool MBR (Master Boot Record) Tools: - MBR Work 1.07b - a utility to perform some common and uncommon MBR functions - MBR Tool 2.2.100 - backup, verify, restore, edit, refresh, remove, display, re-write... - DiskMan4 - all in one tool for cmos, bios, bootrecord and more - BootFix Utility - Run this utility if you get 'Invalid system disk' - MBR SAVE / RESTORE 2.1 - BootSave and BootRest tools to save / restore MBR - Boot Partition 2.60 - add Partition in the Windows NT/2000/XP Multi-boot loader - Partition Table Doctor 3.0 - a tool to repair/modify mbr, bootsector, partition table - Smart Boot Manager 3.7.1 - a multi boot manager - Bootmagic 8.0 - This tool is for multi boot operating systems - MBRWizard 2.0b - Directly update and modify the MBR (Master Boot Record) BIOS / CMOS Tools: - CMOS 0.93 - CMOS Save / Restore Tool - BIOS Cracker 4.8 - BIOS password remover (cmospwd) - BIOS Cracker 1.4 - BIOS password remover (cmospwc) - BIOS Utility 1.35.0 - BIOS Informations, password, beep codes and more. - !BIOS 3.20 - a powerfull utility for bios and cmos - DISKMAN4 - a powerful all in one utility - UniFlash 1.40 - bios flash utility - Kill CMOS - a tiny utility to wipe cmos MultiMedia Tools: - Picture Viewer 1.94 - Picture viewer for dos, supports more then 40 filetypes. - QuickView Pro 2.57 - movie viewer for dos, supports many format including divx. - MpxPlay 1.54 - a small Music Player for dos Password Tools: - Active Password Changer 3.0 - To Reset User Password on windows NT/2000/XP/2003 (FAT/NTFS) - Offline NT/2K/XP Password Changer - utility to reset windows nt/2000/xp administrator/user password. - Registry Viewer 4.2 - Registry Viewer/Editor for Win9x/Me/NT/2K/XP - Registry Reanimator v1.02 - check and restore structure of the damaged registry files of NT/2K/XP - NTPWD - utility to reset windows nt/2000/xp administrator/user password. - ATAPWD 1.2 - Hard Disk Password Utility NTFS Ext2FS, Ext3FS (FileSystems) Tools : - NTFS Dos Pro 5.0 - To access ntfs partitions from Dos - NTFS 4 Dos 1.4 - To access ntfs partitions from Dos - Paragon Mount Everything 3.0 - To access NTFS, Ext2FS, Ext3FS partitions from dos - NTFS Dos 3.02 - To access ntfs partitions from Dos - EditBINI 1.01 - to Edit boot.ini on NTFS Partition Dos File Managers: - Volkov Commander 4.99 - Dos File Manager with LongFileName/ntfs support (Similar to Norton Commander) - Dos Command Center 5.1 - Classic dos-based file manager. - File Wizard 1.35 - a file manager - colored files, drag and drop copy, move, delete etc. - File Maven 3.5 - an advanced Dos file manager with high speed PC-to-PC file transfers via serial or parallel cable - FastLynx 2.0 - Dos file manager with Pc to Pc file transfer capability - LapLink 5.0 - the smart way to transfer files and directories between PCs. - Dos Navigator 5.9.0 - Dos File Manager, Norton Commander clone but has much more features. - Mini Windows 98 - Can run from Ram Drive, with ntfs support, Added 7-Zip which supports .7z .zip .cab .rar .arj .gzip, .bzip2 .z .tar .cpio .rpm and .deb, Disk Defragmenter, Notepad / RichText Editor, Image Viewer, .avi .mpg .divx .xvid Movie Player, etc... Other Tools: - Ghost Walker 2003.793 - utility that changes the security ID (SID) for Windows NT, 2000 and XP - DosCDroast beta 2 - Dos CD Burning Tools - Universal TCP/IP Network 5.8 - MSDOS Network Client to connect via TCP/IP to a Microsoft based network. The network can either be a peer-to-peer or a server based network, it contains 85 different network card drivers Dos Tools: - USB CD-Rom Driver 1 - Standard usb_cd.sys driver for cd drive - Universal USB Driver 2 - Panasonic v2.20 ASPI Manager for USB mass storage - SCSI Support - SCSI Drivers for Dos - 1394 Firewire Support - 1394 Firewire Drivers for Dos - Interlnk support at COM1 To access another computer from COM port - Interlnk support at LPT1 - To access another computer from LPT port Windows Tools: - SpaceMonger 1.4 - keeping track of the free space on your computer - Drive Temperature 1.0 - Hard Disk Drive temperature meter - Disk Speed1.0 - Hard Disk Drive Speed Testing Tool - MemTest 1.0 - a Memory Testing Tool - PageDfrg 2.32 - System file Defragmenter For NT/2k/XP - WhitSoft File Splitter 4.5a - a Small File Split-Join Tool - Ghost Image Explorer 8.3 - to add/remove/extract files from Ghost image file - DriveImage Explorer 5.0 - to add/remove/extract files from Drive image file - Drive SnapShot 1.37 - creates an exact Disk Image of your system into a file while windows is running. - Active Undelete 5.1.010 - a tool to recover deleted files - Restoration 2.5.14 - a tool to recover deleted files - GetDataBack for FAT 2.31 - Data recovery software for FAT file systems - GetDataBack for NTFS 2.31 - Data recovery software for NTFS file systems - Startup Control Panel 2.8 - a tool to edit startup programs - Startup Monitor 1.02 - it notifies you when any program registers itself to run at system startup - IB Process Manager 1.04 - a little process manager for 9x/2k, shows dll info etc. - Pocket KillBox 2.0 - can be used to get rid of files that stubbornly refuse to allow you to delete them - HijackThis 1.99 - a general homepage hijackers detector and remover and more - RootkitRevealer 1.7 - Rootkit Revealer is an advanced patent-pending root kit detection utility. - Silent Runners Revision 48 - A free script that helps detect spyware, malware and adware in the startup process - Autoruns 8.53 - Displays All the entries from startup folder, Run, RunOnce, and other Registry keys, Explorer shell extensions,toolbars, browser helper objects, Winlogon notifications, auto-start services, Scheduled Tasks, Winsock, LSA Providers, Remove Drivers and much more which helps to remove nasty spyware/adware and viruses. - CurrPort 1.07 - displays the list of all currently opened TCP and UDP ports on your computer - Unknown Devices 1.2 - helps you find what those unknown devices in Device Manager really are - PCI 32 Sniffer 1.1 (0410) - device information tool (similar to unknown devices) - NewSID 4.10 - utility that changes the security ID (SID) for Windows NT, 2000 and XP - Double Driver 1.0 - Driver Backup and Restore tool - CPU-Z 1.37 -It gathers information on some of the main devices of your system - CWShredder 2.19 - Popular CoolWebSearch Trojan Remover tool - Winsock 2 Fix for 9x - to fix corrupted Winsock2 information by poorly written Internet programs - XP TCP/IP Repair 1.0 - Repair your Windows XP Winsock and TCP/IP registry errors - CCleaner 1.33.382 - Crap Cleaner is a freeware system optimization and privacy tool - EzPcFix 1.0.0.16 - Helpful tool when trying to remove viruses, spyware, and malware - ******* Advisor Password Remover 1.0 - It Removes ******* Advisor Password from Internet Explorer - Spybot - Search & Destroy 1.4 (0410) - Application to scan for spyware, adware, hijackers and other malicious software. - SpywareBlaster 3.5.1 (0410) - Prevent the installation of spyware and other potentially unwanted software. - Ad-Aware SE Personal 1.06 (0410) - find and remove spyware, adware, dialers etc. (a must have tool) موقع الشركة الحجم: 65.6 MB التحميل: http://www.oxyshare.com/get/40742816....v8.5.rar.html http://rapidshare.de/files/35609198/hbcd.v8.5.rar ملاحظة: بعد فك الملف ببرنامج WinRAR أحرق الملف ببرنامج Nero منقـــــــــــــــــول ... والله ولى التوفيق ...
![]() .... فهــــــــــــرس ملتقــــــــــى البرامـــــــــج .... ... مكتبة برامج الـ Pocket PC ... ... أن شــــاء الله ... معكم يومياً كل مســــاء ... ... العين تقراء السطور ... والعقل يقراء ما بين السطور ... |
دة موقع رفع جميل جدا
ويسمح بالتحميل ببرامج الداونلود وسريع جدا www.mihd.net ياريت ترفعها على الموقع دة افضل من المواقع التانية بكتيير وكمان يا ريت تضغطها قبل ما ترفعها |
اعزائي اقدم لكم الرابط الجديد هنا وجدته وانا ابحث عن السي دي المذكور
مع تحيات الخيّال وعلى كلاً انا هلا نزلته بس يكمل البرنامج تنزيل راح ارفعه كرابط ومضغوط موجود الداونلود في اخر الصفحه بعد ان تفتحها http://www.9down.com/downloads.php?fileid=410 التعديل الأخير تم بواسطة nidal_rifai ; 29-01-2007 الساعة 01:30 PM. سبب آخر: اضافة كلمات |
كل هذه الادوات في سي دي واحد فقط نزل السي دي وتمتع مع تحيات الخيّال
الرابط هو http://www.9down.com/downloads.php?fileid=410 All in one Dos Bootable CD which has all these utilities. ---------------------------------------------------------------------------- Partition Tools ---------------------------------------------------------------------------- Partition Magic Pro 8.05 Best software to partition hard drive Acronis Disk Director Suite 9.0.554 Popular disk management functions in a single suite Paragon Partition Manager 7.0.1274 Universal tool for partitions Partition Commander 9.01 The safe way to partition your hard drive,with undo feature Ranish Partition Manager 2.44 a boot manager and hard disk partitioner. The Partition Resizer v1.3.4 move and resize your partitions in one step and more. Smart Fdisk 2.05 a simple harddisk partition manager SPecial Fdisk 2000 SPFDISK a partition tool. eXtended Fdisk 0.9.3 XFDISK allows easy partition creation and edition GDisk 1.1.1 Complete replacement for the DOS FDISK utility and more. ---------------------------------------------------------------------------- Disk Clone Tools ---------------------------------------------------------------------------- ImageCenter 5.6 (Drive Image 2002) Best software to clone hard drive Norton Ghost 8.3 Similar to Drive Image (with usb/scsi support) Acronis True Image 8.1.945 Create an exact disk image for complete system backup and disk cloning. Partition Saving 3.20 A tool to backup/restore partitions. (SavePart.exe) COPYR.DMA Build013 A Tool for making copies of hard disks with bad sectors ---------------------------------------------------------------------------- Antivirus Tools ---------------------------------------------------------------------------- F-Prot Antivirus 3.16f (0410) Very good virus scanner (with ntfs support and easy to use menu) McAfee Antivirus 4.40 (0410) a virus scanner (with ntfs support and easy to use menu) ---------------------------------------------------------------------------- Recovery Tools ---------------------------------------------------------------------------- Active Partition Recovery 3.0 To Recover a Deleted partition. Active Uneraser 3.0 To recover deleted files and folders on FAT and NTFS systems. Ontrack Easy Recovery Pro 6.10 To Recover data that has been deleted/virus attack Winternals Disk Commander 1.1 more than just a standard deleted-file recovery utility TestDisk 6.5b Tool to check and undelete partition. Lost & Found 1.06 a good old data recovery software. DiyDataRecovery Diskpatch 2.1.100 An excellent data recovery software. Prosoft Media Tools 5.0 v1.1.2.64 Another excellent data recovery software with many other options. PhotoRec 6.5b File and pictures recovery Tool. ---------------------------------------------------------------------------- Testing Tools ---------------------------------------------------------------------------- System Speed Test 4.78 it tests CPU, harddrive, ect. PC-Check 6.0 Easy to use hardware tests Ontrack Data Advisor 5.0 Powerful diagnostic tool for assessing the condition of your computer The Troubleshooter 7.02 all kind of hardware testing tool PC Doctor 3.0 a benchmarking and information tool Test Cpu/Video/Disk 5.6 a tool to test cpu, video, and disk Test Hard Disk Drive 1.0 a tool to test Hard Disk Drive ---------------------------------------------------------------------------- RAM (Memory) Testing Tools ---------------------------------------------------------------------------- DocMemory 3.1b RAM Test utility GoldMemory 5.07 RAM Test utility Memtest86+ 1.65 PC Memory Test ---------------------------------------------------------------------------- Hard Disk Tools ---------------------------------------------------------------------------- Hard Disk Diagnostic Utilities Seagate Seatools Desktop Edition 3.02 Western Digital Data Lifeguard Tools Western Digital Diagnostics (DLGDIAG) 5.04f Maxtor PowerMax 4.23 Maxtor amset utility 4.0 Maxtor(or any Hdd) Low Level Formatter 1.1 Fujitsu HDD Diagnostic Tool 6.61 Fujitsu IDE Low Level Format 1.0 Samsung HDD Utility(HUTIL) 2.02 Samsung Disk Diagnose (SHDIAG) 1.28 IBM/Hitachi Drive Fitness Test 4.08 IBM/Hitachi Feature Tool 2.03 Gateway GwScan 3.15 ExcelStor's ESTest 3.80 MHDD 4.6 WDClear 1.30 Toshiba Hard Disk Diagnostic 2.00b HDD Regenerator 1.51 to recover a bad hard drive Ontrack Disk Manager 9.57 Disk Test/Format/Maintenance tool. Norton Disk Doctor 2002 a tool to repair a damaged disk, or to diagnose your hard drive. Norton Disk Editor 2002 a powerful disk editing, manual data recovery tool. Active Kill Disk 1.1 Securely overwrites and destroys all data on physical drive. HDAT2 4.5.2 main function is testing and repair (regenerates) bad sectors for detected devices SmartUDM 2.00 Hard Disk Drive S.M.A.R.T. Viewer. Victoria 3.33 a freeware program for low-level HDD diagnostics ---------------------------------------------------------------------------- System Information Tools ---------------------------------------------------------------------------- Aida16 2.14 a system information tool, extracts details of all components of the PC PCI and AGP info Tool (0410) The PCI System information & Exploration tool. System Analyser version 5.3o View extensive information about your hardware Navratil Software System Information 0.59.9 High-end professional system information tool Astra 5.21 Advanced System info Tool and Reporting Assistant HwInfo 5.0.3 a powerful system information utility PC-Config 9.33 Complete hardware detection of your computer SysChk 2.46 Find out exactly what is under the hood of your PC CPU Identification utility v1.12 Detailed information on CPU (CHKCPU.EXE) CTIA CPU Information another CPU information tool ---------------------------------------------------------------------------- MBR (Master Boot Record) Tools ---------------------------------------------------------------------------- MBRWork 1.07b a utility to perform some common and uncommon MBR functions MBR Tool 2.2.100 backup, verify, restore, edit, refresh, remove, display, re-write... DiskMan4 all in one tool for cmos, bios, bootrecord and more BootFix Utility Run this utility if you get 'Invalid system disk' MBR SAVE / RESTORE 2.1 BootSave and BootRest tools to save / restore MBR Boot Partition 2.60 add Partition in the Windows NT/2000/XP Multi-boot loader Partition Table Doctor 3.0 a tool to repair/modify mbr, bootsector, partition table Smart Boot Manager 3.7.1 a multi boot manager Bootmagic 8.0 This tool is for multi boot operating systems MBRWizard 2.0b Directly update and modify the MBR (Master Boot Record) ---------------------------------------------------------------------------- BIOS / CMOS Tools ---------------------------------------------------------------------------- CMOS 0.93 CMOS Save / Restore Tool BIOS Cracker 4.8 BIOS password remover (cmospwd) BIOS Cracker 1.4 BIOS password remover (cmospwc) BIOS Utility 1.35.0 BIOS Informations, password, beep codes and more. !BIOS 3.20 a powerfull utility for bios and cmos DISKMAN4 a powerful all in one utility UniFlash 1.40 bios flash utility Kill CMOS a tiny utility to wipe cmos ---------------------------------------------------------------------------- MultiMedia Tools ---------------------------------------------------------------------------- Picture Viewer 1.94 Picture viewer for dos, supports more then 40 filetypes. QuickView Pro 2.57 movie viewer for dos, supports many format including divx. MpxPlay 1.54 a small Music Player for dos ---------------------------------------------------------------------------- Password Tools ---------------------------------------------------------------------------- Active Password Changer 3.0 To Reset User Password on windows NT/2000/XP/2003 (FAT/NTFS) Offline NT/2K/XP Password Changer utility to reset windows nt/2000/xp administrator/user password. Registry Viewer 4.2 Registry Viewer/Editor for Win9x/Me/NT/2K/XP Registry Reanimator v1.02 check and restore structure of the damaged registry files of NT/2K/XP NTPWD utility to reset windows nt/2000/xp administrator/user password. ATAPWD 1.2 Hard Disk Password Utility ---------------------------------------------------------------------------- NTFS Ext2FS, Ext3FS (FileSystems) Tools ---------------------------------------------------------------------------- NTFS Dos Pro 5.0 To access ntfs partitions from Dos NTFS 4 Dos 1.4 To access ntfs partitions from Dos Paragon Mount Everything 3.0 To access NTFS, Ext2FS, Ext3FS partitions from dos NTFS Dos 3.02 To access ntfs partitions from Dos EditBINI 1.01 to Edit boot.ini on NTFS Partition ---------------------------------------------------------------------------- Dos File Managers ---------------------------------------------------------------------------- Volkov Commander 4.99 Dos File Manager with LongFileName/ntfs support (Similar to Norton Commander) Dos Command Center 5.1 Classic dos-based file manager. File Wizard 1.35 a file manager - colored files, drag and drop copy, move, delete etc. File Maven 3.5 an advanced Dos file manager with high speed PC-to-PC file transfers via serial or parallel cable FastLynx 2.0 Dos file manager with Pc to Pc file transfer capability LapLink 5.0 the smart way to transfer files and directories between PCs. Dos Navigator 5.9.0 Dos File Manager, Norton Commander clone but has much more features Mini Windows 98 Can run from Ram Drive, with ntfs support, Added 7-Zip which supports .7z .zip .cab .rar .arj .gzip, .bzip2 .z .tar .cpio .rpm and .deb Disk Defragmenter, Notepad / RichText Editor, Image Viewer, .avi .mpg .divx .xvid Movie Player, etc... ---------------------------------------------------------------------------- Other Tools ---------------------------------------------------------------------------- Ghost Walker 2003.793 utility that changes the security ID (SID) for Windows NT, 2000 and XP DosCDroast beta 2 Dos CD Burning Tools Universal TCP/IP Network 5.8 MSDOS Network Client to connect via TCP/IP to a Microsoft based network. The network can either be a peer-to-peer or a server based network, it contains 85 different network card drivers ---------------------------------------------------------------------------- Dos Tools ---------------------------------------------------------------------------- USB CD-Rom Driver 1 Standard usb_cd.sys driver for cd drive Universal USB Driver 2 Panasonic v2.20 ASPI Manager for USB mass storage SCSI Support SCSI Drivers for Dos 1394 Firewire Support 1394 Firewire Drivers for Dos Interlnk support at COM1 To access another computer from COM port Interlnk support at LPT1 To access another computer from LPT port ---------------------------------------------------------------------------- and too many great dos tools very good collection of dos utilities ---------------------------------------------------------------------------- extract.exe pkzip.exe pkunzip.exe unrar.exe rar.exe ace.exe lha.exe gzip.exe uharcd.exe mouse.com attrib.com deltree.exe xcopy.exe diskcopy.com imgExtrc.exe undelete.com edit.com fdisk.exe fdisk2.exe fdisk3.exe lf.exe delpart.exe wipe.com zap.com format.com move.exe more.com find.exe hex.exe debug.exe split.exe mem.exe mi.com sys.com smartdrv.exe xmsdsk.exe killer.exe share.exe scandisk.exe scanreg.exe guest.exe doskey.exe duse.exe biosdtct.exe setver.exe ntersvr.exe interlnk.exe loadlin.exe lfndos.exe doslfn.com ---------------------------------------------------------------------------- Windows Tools ---------------------------------------------------------------------------- SpaceMonger 1.4 keeping track of the free space on your computer Drive Temperature 1.0 Hard Disk Drive temperature meter Disk Speed 1.0 Hard Disk Drive Speed Testing Tool MemTest 1.0 a Memory Testing Tool PageDfrg 2.32 System file Defragmenter For NT/2k/XP WhitSoft File Splitter 4.5a a Small File Split-Join Tool Ghost Image Explorer 8.3 to add/remove/extract files from Ghost image file DriveImage Explorer 5.0 to add/remove/extract files from Drive image file Drive SnapShot 1.37 creates an exact Disk Image of your system into a file while windows is running. Active Undelete 5.1.010 a tool to recover deleted files Restoration 2.5.14 a tool to recover deleted files GetDataBack for FAT 2.31 Data recovery software for FAT file systems GetDataBack for NTFS 2.31 Data recovery software for NTFS file systems Startup Control Panel 2.8 a tool to edit startup programs Startup Monitor 1.02 it notifies you when any program registers itself to run at system startup IB Process Manager 1.04 a little process manager for 9x/2k, shows dll info etc. Pocket KillBox 2.0 can be used to get rid of files that stubbornly refuse to allow you to delete them HijackThis 1.99 a general homepage hijackers detector and remover and more RootkitRevealer 1.7 Rootkit Revealer is an advanced patent-pending root kit detection utility. Silent Runners Revision 48 A free script that helps detect spyware, malware and adware in the startup process Autoruns 8.53 Displays All the entries from startup folder, Run, RunOnce, and other Registry keys, Explorer shell extensions,toolbars, browser helper objects, Winlogon notifications, auto-start services, Scheduled Tasks, Winsock, LSA Providers, Remove Drivers and much more which helps to remove nasty spyware/adware and viruses. CurrPort 1.07 displays the list of all currently opened TCP and UDP ports on your computer Unknown Devices 1.2 (0410) helps you find what those unknown devices in Device Manager really are PCI 32 Sniffer 1.1 (0410) device information tool (similar to unknown devices) NewSID 4.10 utility that changes the security ID (SID) for Windows NT, 2000 and XP Double Driver 1.0 Driver Backup and Restore tool CPU-Z 1.37 It gathers information on some of the main devices of your system CWShredder 2.19 Popular CoolWebSearch Trojan Remover tool Winsock 2 Fix for 9x to fix corrupted Winsock2 information by poorly written Internet programs XP TCP/IP Repair 1.0 Repair your Windows XP Winsock and TCP/IP registry errors CCleaner 1.33.382 Crap Cleaner is a freeware system optimization and privacy tool EzPcFix 1.0.0.16 Helpful tool when trying to remove viruses, spyware, and malware ******* Advisor Password Remover 1.0 It Removes ******* Advisor Password from Internet Explorer Spybot - Search & Destroy 1.4 (0410) Application to scan for spyware, adware, hijackers and other malicious software. SpywareBlaster 3.5.1 (0410) Prevent the installation of spyware and other potentially unwanted software. Ad-Aware SE Personal 1.06 (0410) find and remove spyware, adware, dialers etc. (a must have tool) ---------------------------------------------------------------------------- Download Mirror |
| مواقع النشر (المفضلة) |
| أدوات الموضوع | |
| تقييم هذا الموضوع | |
