النتائج 1 إلى 10 من 32
    Received: 22
    Given: 7
    Cool CSi SAFE Version 12.3.2
    Version: 12.3.2
    Supported Operating Systems: Windows XP, Windows Vista and Seven7
    SAFE is the ultimate tool for designing concrete floor and foundation systems. From framing layout all the way through to detail drawing production, SAFE integrates every aspect of the engineering design process in one easy and intuitive environment. SAFE provides unmatched benefits to the engineer with its truly unique combination of power, comprehensive capabilities, and ease-of-use.
    Laying out models is quick and efficient with the sophisticated drawing tools, or use one of the import options to bring in data from CAD, spreadsheet, or database programs. Slabs or foundations can be of any shape, and can include edges shaped with circular and spline curves.
    Post-tensioning may be included in both slabs and beams to balance a percentage of the self-weight. Suspended slabs can include flat, two-way, waffle, and ribbed framing systems. Models can have columns, braces, walls, and ramps connected from the floors above and below. Walls can be modeled as either straight or curved.
    Mats and foundations can include nonlinear uplift from the soil springs, and a nonlinear cracked analysis is available for slabs. Generating pattern surface loads is easily done by SAFE with an automated option. Design strips can be generated by SAFE or drawn in a completely arbitrary manner by the user, with complete control provided for locating and sizing the calculated reinforcement. Finite element design without strips is also available and useful for slabs with complex geometries.
    Comprehensive and customizable reports are available for all analysis and design results. Detailed plans, sections, elevations, schedules, and tables may be generated, viewed, and printed from within SAFE or exported to CAD packages.
    SAFE provides an immensely capable yet easy-to-use program for structural designers, provideing the only tool necessary for the modeling, analysis, design, and detailing of concrete slab systems and foundations.
    MODELING
    • Object Based Graphical Interface
    • Model Explorer for Easy Access to Program Features
    • Model Templates for Typical Slabs and Foundations
    • Arbitrary Geometry and Loadings, including Variations in Thickness
    • Automated Mesh Generation
    • Slab, Beam, Column/Brace, and Wall/Ramp Objects
    • Slab/Foundation Area Objects with Thick Plate
    • Automated Soil Spring Supports
    • Editing with Move, Mirror, Nudge, and Replicate
    • Accurate Dimensioning with Guidelines
    • Intelligent Snaps and Architectural Dimensions
    • Quick Draw Options for Object Creation
    • Selective Data Input On-Screen with Right-Button Click
    • Area, Line, and Point Loading
    • Post-Tensioning with Automated Load Balancing (PT)
    • Powerful Grouping and Selection Options
    • User Controlled General Design Strips
    • Enhanced Graphical Display for Easy Model Checking
    ANALYSIS
    • Slabs and Foundations Modeled with Area Objects
    • Beams Drawn as Lines – Automatically Meshed into Elements
    • Orthotropic Bending with Thick Plate Behavior
    • Beams with Flexural, Shear, and Torsional Deformations
    • Column and Wall Stiffness Above and Below Slab
    • Thickness Variations, Drop Panels, and Openings
    • Nonlinear Cracked Analysis
    • Nonlinear Long-Term Creep and Shrinkage
    • Nonlinear No-Tension Soil Model
    • Slab Discontinuities Due to Construction Joints or Elevation Changes
    • Automatic Meshing with Constraings at Mismatched Slab Meshes
    • Variations in Soil Modulus of Subgrade Reaction
    • Multiple Load Cases and Combinations
    DESIGN
    • Slab and Beam Concrete Design for American, Australian, British, Canadian, Chinese, European, Hong Kong, Indian, New Zealand and Singapore Codes
    • Both Strip Based and Finite Element Based Design
    • Punching Shears Checks and Shear Stud Design
    • Post-Tensioning Strength and Serviceability Design (PT)
    • Twisting Moments Included
    • Automatic T-Beam Effects
    • Design Based on General Design Strips
    DETAILING
    • Automatic Generation of Default Views and Drawings
    • Plans, Elevations, Sections, Rebar Tables, Schedules, and Bill of Quantities
    • Customizable Drawing Sheets with Multiple Views
    • Edit Reinforcement, Text, and Annotations
    • Synchronization After Model Changes
    • Export Drawings to DXF or AutoCAD DWG
    • Plot Full Size Drawings
    DISPLAY
    • 3D Graphical Displays
    • Deformed Shapes
    • Loading Diagrams
    • Animation of Deformed Shapes
    • Slab Displacement, Moment, Shear, and Bearing Pressure Contours
    • User Controlled Stress Averaging for Contours
    • Beam Moment, Shear, and Torsion Diagrams
    • Post-Tensioning Stress Diagrams (PT)
    • Tabular Display of Model Input & Output
    • Reaction Force Diagrams Eng-Syria.NET
    • Integrated Strip Moment and Shear Diagrams
    • Graphical Display of Required Reinforcing for Slabs and Beams
    • Rendered View with Lighting, Textures, and Shadows
    • Rendered View of Rebar Cages
    SAFE v12.3.2 FULL DOWNLOAD
    Received: 22
    Given: 7
    تحميل الكراك
    http://www.4shared.com/rar/3cDiRQEA/crack_safe.html
    الصورة الرمزية mazzagangy
    Received: 44
    Given: 7
    شكرا لك
    لا إله إلا أنت سبحانك إني كنت من الظالمين
    الصورة الرمزية aymanallam
    Received: 90
    Given: 14
    جزاك الله خيراً
    Eng. Ayman Allam
    الصورة الرمزية م/ لؤي
    Received: 8
    Given: 8
    ما شاء الله
    هيك كتير يا باشمهندس etabs+safe في يوم واحد و مرة وحدة؟
    ما شاء الله عنك الله يعطيك العافية و شكرا على السبق و التميز
    Received: 22
    Given: 7
    تحياتي مهندس لؤي وأشكرك على المرور
    الصورة الرمزية bboumediene
    Given: 14
    جزاك الله خيرا
    الصورة الرمزية remstereo
    Received: 9
    Given: 15
    الف شكر على البرنامج لكن الرخصة مش شغالة وذلك يظهر فى الصورة الموجودة فى المرفقات
    CSi SAFE Version 12.3.2 الملفات المرفقة
    • نوع الملف: rar safe.rar‏ (81.6 كيلوبايت, 385 مشاهدات)
    Given: 14
    ياريت كل اللي حمل البرنامج يرد علينا اذا كان شغال ولا لاء
    Received: 9
    Given: 15
    الكراك ده شغال 100/100
    http://hotfile.com/dl/144600664/7429960/crack.rar.html
    http://depositfiles.com/files/6inltijsr
    password
    joker™_civilea.com
