النتائج 1 إلى 10 من 68
    Thumbs up مجموعة كبيرة من المواضيع المهمة والمفيدة للعاملين بمجال التحكم الألي
    مراجع و كتب شنايدر الكاملة فى حلول التحكم الالى
    http://www2.schneider-electric.com/s...documents.page
    كتاب شنايدر فى التركيبات
    http://www.electrical-installation.s...ectric.com:80/
    http://www.electrical-installation.org/enwiki/Main_Page
    schneider products
    http://www2.schneider-electric.com/s...-services.page
    schneider Low Voltage Manual
    مرجع الجهد المنخفض من شنايدر ومكوناته
    كتاب اكثر من رائع
    Chapter 0: Introduction & legend
    Chapter 1: Control & protection of LV distribution network
    Chapter 2: Power monitoring & metering
    Chapter 3: Energy compensation
    Chapter 4: Motor control & protection
    Chapter 5: Relays, timers & power supplies
    Chapter 6: Soft starters
    Chapter 7: Variable speed drives
    Chapter 8: Human machine interface
    Chapter 9: Detection & data acquisition
    Chapter 10: Programmable logic controller (PLC)
    Chapter 11: Applications and general information
    http://www.schneider-electric.com.eg...w_voltage.page
    this industrial cables mangement of schnider
    http://www.schneider-electric.co.uk/...anagement.page
    Creating Human Machine Interfaces Using Visual Basic Jeff Weigant by
    http://www.amazon.com/Creating-Human...1430613&sr=8-1
    generators cycle controller alternators rectifiers avr uints
    http://www.governors-america.com/
    this for cycle controller (governers)
    http://www.leroy-somer.com
    for avr & rectifier & alternators
    three adjustments should accomplished to operate on the generator to ouput 50HZ
    three adjustments should accomplished to operate on the generator to make ouput signal have 50HZ
    first
    the connection of the winding coils should be fixed for required frequency
    second
    some adjustments in the AVR unit which stablize ouput 50hz or 60 hz
    third
    inside the cycle unit you should adjust the required frequency asthis unit stablize the gen speed as required frequency
    1500 rpm for 50 hz etc...
    AVR unit & winding coils connection diagram
    www.leroy-somer.com/documentation_pdf/4549_en.pdf
    www.leroy-somer.com/documentation_pdf/4243_en.pdf
    www.leroy-somer.com/documentation_pdf/3434_en.pdf
    cycle speed controller unit
    http://www.governors-america.com/esd5100_series.html
    www.governors-america.com/public_file/file/25/PTI1000_ESD5100_Series.pdf?1308862159
    they are examples
    books about control books
    http://www.kutub.info/library/book/3535
    http://www.kutub.info/library/category/13
    INVERTER (frequency controller converter)
    you can simply use an inverter for controllin the speed of motors 1 ph or 3 ph
    inveretr is advice used in change frequency which supplied to motor so due to changable frequency we can change also the speed of the motor
    v=120f/p (v= speed , f : frequency , p = num of poles)
    here are two types of inverter
    http://www.rhymebus.com.tw/en/module...p?cid=2&cid2=6
    http://www2.nord.com/documentation/d...anuals/manuals
    الجزء الاول والجزء الثاني من كتب التحكم الالي للمهندس وجيه جرجس
    http://www.mediafire.com/?f5qza07a1if7zww
    ختيار أجهزة الإنارة ذو درجة الحماية ip المناسبة في مناطق الحمامات والمناطق المبلولة حسب المواصفات
    www.arab-eng.org/vb/attachment.php?attachmentid=62879&d=1286123084
    complete fire alarm systems
    http://www.simplexgrinnell.com/ENUS/Pages/default.aspx
    moeller manual
    http://www.moeller.net/en/support/katalog.jsp
    من مواضيع undertacker2010 :
    1 Not allowed!
    التعديل الأخير تم بواسطة مهندس عادل @ ; 2011-12-13 الساعة 10:56 PM
    الصورة الرمزية undertacker2010
    ابدى رايك
    مكونات نظام سيمنس simatic s7-300 plc
    Exclamation برنامج بديل عن oslliscope عرض الاشارة عن طريق كارت الصوت على الكمبيوتر
    http://www.arab-eng.org/vb/showthread.php?t=11894
    Wink moeller wiring manual complete eng pdf
    Industrial Automation Product Overview All from a Single Source – Innovative Products for Electrical
    Thumbs up شرح برنامج ekts لمحاكاه دوائر التحكم الالى
    العنوان: شرح برنامج ekts لمحاكاه دوائر التحكم الالى
    عن الكتاب:
    مدونه صغيره تحتوى على شرح مبسط لبرنامج EKTS البسيط والجميل المستخدم فى محاكاه دوائر التحكم الالى..ومع مثالين توضيحين هما:
    1- تشغيل محرك ثلاثه فيز..
    2- تغير اتجاه حركه موتور..
    http://www.kutub.info/library/book/9039
    حجم الكتاب: 0.16 ميجا بايت
    عناصر دائر التحكم في المحركات الحثية ثلاثية الأطوار
    العنوان: عناصر دائر التحكم في المحركات الحثية ثلاثية الأطوار
    عن الكتاب:
    الكونتاكتر
    الأوفرلود
    القاطع الحراري
    ازرار الدفع
    الفيوزات
    http://www.kutub.info/library/book/8515
    http://www.kutub.info/downloads/8515...Q8mSES2Y%3D%0A
    حجم الكتاب: 0.72 ميجا بايت
    الدرس الأول فى plc
    العنوان: الدرس الأول فى plc
    عن الكتاب:
    8 دروس من الصفر وحتى الأحتراف فى plc
    تأليف: هيثم خيرى محمد
    http://www.kutub.info/library/book/7908
    1 Not allowed!
    Lightbulb الدرس الثانى فى plc
    العنوان: الدرس الثانى فى plc
    عن الكتاب:
    8 دروس فى plc من الصفر وحتى الأحتراف
    http://www.kutub.info/library/book/7909
