العودة   ملتقى المهندسين العرب > الملتقى الهندسي > الهندسة الكيميائية
الهندسة الكيميائية ................ بإشراف : أبو عزام
قديم 09-09-2006, 08:56 AM
الصورة الرمزية tymz
جهاز الامتصاص الذري(atomic Absorbtion)
انا بصدد انشاء مختبر خاص بالاجهزة البترولية . ارجوا المساعدة باهم الاجهزة وايضا معلومات عن جهاز الامتصاص الذري.
شكرا للجميع...
رد مع اقتباس
قديم 11-09-2006, 10:24 AM   رقم المشاركة : [2 (permalink)]
الصورة الرمزية mtak
mtak يستحق التميز
Preparing Your Laboratory for
Atomic Absorption
Spectrometers-------------------------------------------------------------------------------------------------------
1. SUITABLE WORKING
AREA
The environment in which any
instrument is housed is an
important consideration. The
room temperature should be
between 15 and 35 °C (59-95 °F)
with a maximum rate of change of
3 °C (5 °F) per hour. The relative
humidity should be between 20
and 80%, noncondensing.
A relatively dust-free environment
is necessary. This is especially
important when working with
ultra-trace techniques, such as
graphite furnace sampling. Other
important considerations are to
locate the instrument in an area
free of corrosive fumes and
vibration and in an area that does
not receive direct sunlight.
Atomic absorption spectrometer
systems are normally installed on
laboratory work benches or tables.
The benchtop or area in which the
atomic absorption instrument is to
be installed should be large
enough to accommodate the
instrument and all accessories.
(Dimensions of those items are
given in Section 10.) The
instrument should not be placed
permanently against a wall, as the
instrument must be accessible
from the back for servicing
purposes. An accessible space of
at least 60 cm (24 in.) should be
available behind the instrument. If
this is not possible, the table or
bench on which the instrument is
mounted should be on wheels so
that it can be easily moved.
A means of electrically grounding
the instrument and all accessories
must be available.
2. EXHAUST VENT
A venting system is required to
remove the combustion fumes and
vapors from the flame or graphite
furnace for atomic absorption
instruments. Exhaust venting is
important for a number of reasons:
• It will protect laboratory
personnel from toxic vapors
which may be produced by
some samples.
• It will tend to remove the effects
of room drafts and the laboratory
atmosphere on flame stability.
• It will help to protect the
instrument from corrosive
vapors which may originate
from the samples.
• It will remove dissipated heat
which is produced by the flame
or furnace.
mtak غير متواجد حالياً   رد مع اقتباس
قديم 11-09-2006, 12:10 PM   رقم المشاركة : [3 (permalink)]
الصورة الرمزية tymz
tymz يستحق التميز
شكرا اخي العضو (mtak) ارجو تحديد اكثر عن الغازات المستعملة؟وطريقة تحضير العينات المدخلة بالجهاز؟
tymz غير متواجد حالياً   رد مع اقتباس
قديم 11-09-2006, 05:50 PM   رقم المشاركة : [4 (permalink)]
الصورة الرمزية mtak
mtak يستحق التميز
اكسيد نيتروز
و
استيلين
بالضافة الى كمبريسور لانتاج هواء
قديم 16-09-2006, 09:43 AM   رقم المشاركة : [5 (permalink)]
الصورة الرمزية mtak
mtak يستحق التميز
تفضل يا اخى هذا الملف
ارجو ان يفيدك
قديم 16-09-2006, 09:48 AM   رقم المشاركة : [6 (permalink)]
الصورة الرمزية mtak
mtak يستحق التميز
عذرا اخى
لم استطع بعث الملف
تفضل هذا الرابط به كل ما تريد
http://ewr.cee.vt.edu/environmental/...mer/aa/aa.html
قديم 17-09-2006, 08:08 AM   رقم المشاركة : [7 (permalink)]
الصورة الرمزية tymz
tymz يستحق التميز
شكرا ياخي كثيرررررررررررررررراااااااا
قديم 17-09-2006, 10:42 AM   رقم المشاركة : [8 (permalink)]
الصورة الرمزية mtak
mtak يستحق التميز
u r welcome any time
على فكرة انا كيميائى فى شركة خاصة بنقل البترول الخام
اى شىء تريدة تحت امرك
قديم 02-10-2007, 01:22 PM   رقم المشاركة : [9 (permalink)]
عضو تحرير المجلة
الصورة الرمزية نبيل عواد الغباري
نبيل عواد الغباري يستحق التميز
الاخ العزيز
جهاز الامتصاص الذري يقوم بفحص المواد الثقيلة المتواجدة في المواد البترولية وغالبا ما يتم حرق هذة المواد اولا ثم اذابة المواد المتبقية في الاحماض للحصول على محلول مائي يتم اجراء التحاليل علية واهم هذة التحاليل هي ايجاد الفاناديوم والصوديوم والنيكل والرصاص وبعض المعادن الاخرى وتعتمد الحاجة لمثل هذا الجهاز في المختبرات البترولية على مدى الطلب او الحاجة لاستخدامه حيث ان التكلفة لهذا الجهاز تعتبر عالية نظرا لسعره المرتفع عالميا وكذلك الحاجة الى المواد العيارة اللازمة لمعايرة الجهاز اضافة الى قطع الغيار واللوازم . لذلك اذا كان بالامكان تحديد المهام التي تسعى اليها لهذا المختبر فيمكن ان اساعدك بالاجهزة اللازمه ومواصفاتها لانشاء مختبر جيد .
نبيل عواد الغباري غير متواجد حالياً   رد مع اقتباس
قديم 20-02-2008, 11:08 AM   رقم المشاركة : [10 (permalink)]
الصورة الرمزية ارماجيدون
ارماجيدون يستحق التميز
يمكن مشاركتي كانت متأخرة لكن ان لم تؤمن المطلوب أرجو منك اعلامي فأنا اقدم رسالة ماجستير لتحديد العناصر المعدنية في الزيوت النباتية على جهاز Gfaaa , Faas
ارماجيدون غير متواجد حالياً   رد مع اقتباس
قديم 26-06-2008, 11:55 PM   رقم المشاركة : [11 (permalink)]
الصورة الرمزية فردوس الاسلام
فردوس الاسلام يستحق التميز
بوركتم
والله دائما تاتينا بالمفيد والمميز
جزاكم الله الفردوس الاعلى من الجنة على الطرح الدي استفدت منه
فردوس الاسلام غير متواجد حالياً   رد مع اقتباس
قديم 29-06-2008, 03:13 PM   رقم المشاركة : [12 (permalink)]
الصورة الرمزية علي محمد المهندس
علي محمد المهندس يستحق التميز
مشكور يا اخي الكريم
علي محمد المهندس غير متواجد حالياً   رد مع اقتباس
قديم 27-07-2008, 01:16 AM   رقم المشاركة : [13 (permalink)]
الصورة الرمزية عبدالسلام جحيدر
عبدالسلام جحيدر يستحق التميز
الإمتصاص الذري هي عمليه طبيعيه تعني امتصاص الضوء عند طول موجي معين ( λ ) و ثابت للعنصر الواحد بواسطه ذراته الحرة ، و تزداد كميه الاشعة الممتصه عند هذا الطول الموجي بزيادة عدد ذرات العنصر الموجودة في مسار الاشعة .
و عندما يحترق محلول مادة في اللهب مثلا أو يسخن داخل أنبوبة فان الذرات المنفصلة تصبح حرة في العينة و تتجمع داخل اللهب أو الأنبوبه مكونة سحابة ذريه تتحرك بسرعه ، و هذه السحابه تكون على شكل سائل بخاخ دقيق يندمج مع غاز الوقود المستخدم في اللهب حيث يتأكسد عن طريق الأحتراق .
أما بالنسبه للمذيب المستخدم لإذابه العينهالمراد تحليلها ، فانه يتبخر في مجال قاعده اللهب (Base Region Flame ) . و بالنسبه لجزيئات العينه الصلبه الدقيقه و المجزئه فإنها تنتقل إلى مركز الشمعة ( Cone Inner ) حيث يمتص الطاقة الفوتونات الإشعاعية في المصدر الخارجي الساخن (Lamp ) . و كما نعلم أن كل ذرة مكونه من نواة موجبة الشحنه و محاطه بإلكترونات تدور بسرعه عالية حولب النواه و مرتبه في مدارات معينه ، و لكل منها طاقه وضع محدده ، لذا يختلف التركيب النووي البنائي من عنصر الى آخر .
و في حاله امتصاص الطاقه أو الفوتونات فإنها تحدث عمليه إثارة للإلكترونات ، حيث ينتقل إلكترون أو أكثر إلى مستوى أرقى ( أعلى ) ، بمعنى آخر إلى مستوى ذات طاقة أكثر من مستوى الطاقة الذري الذي كان يشغله في السابق قبل إثارته .
و العلاقه بين كمية الأشعه الممتصه و تركيز العنصر المراد تقديرة يمكن الحصول عليها باستعمال مادة قياسية معروفه التركيز تحتوى على العنصر المراد تقديره على ان تكون الصورة الطبيعية و الكيميائية لهذا العنصر مماثلة لصورته في الماده المجهوله التركيز .
و من قيمة تركيز العنصر في المادة القياسية و كثافه الامتصاص الضوئي يمكن رسم المنحنى القياسي ( Standard Curve ) لهذا العنصر في العينه المجهوله و ذلك بقياس الامتصاص الضوئي للعينة .
طريقه تحليل الزجاج :
وفي حاله استخدام جهاز الامتصاص الذري لتحليل عينات الزجاج ، من الأفضل استخدام جهاز من نوع ( Flameless ) ، وهو عالي الحساسية لمعظم العناصر ، بحيث تقاس بتلك الطريقه عينات زجاج يصل وزنها إلى أصغر من (100µg) أما عن عمليه تذويب عينات الزجاج فإنه يستخدم حمض ( HF ) لهذا الغرض مع العلم أن هذه الطريقه محفوفه نوعاً ما بالمخاطر ، إلا أنها دقيقة .
و النتائج التي نحصل عليها من جهاز الامتصاص الذري ( Atomic Absorption ) ماهي إلا عمليه مقارنه بين الامتصاص الذري لمحاليل عينة الزجاج المراد التعرف على تراكيز مختلفة للمحاليل القياسية بدقة و التي متوقع أن تكون متواجدة في عينة الزجاج
عبدالسلام جحيدر غير متواجد حالياً   رد مع اقتباس
قديم 29-07-2008, 12:10 PM   رقم المشاركة : [14 (permalink)]
الصورة الرمزية tymz
tymz يستحق التميز
شكرا ....للجميع
ارجوا منكم اخواني... اخواتي ...الاعزاء..
ذكر طريقة تحضير العينات خصوصا المنتجات البترولية سواء ( blank-او standardاو sample been teasted)
شكرا مرة اخرى ..ارجو
الساعة الآن 08:56 AM.
