دورة إدارة المشاريع الاحترافية PMP
آخر المواضيع الجديدة
صفحة 1 من 3 123 الأخيرةالأخيرة
النتائج 1 إلى 10 من 27
SP-17(09) ACI Design Handbook
SP-17(09) ACI Design Handbook Title: SP-17(09) ACI Design Handbook Year of Publication: 2009 Number of Pages: 252 This document is:
  1. #1
    عضو متميز الصورة الرمزية majdiotoom
    تاريخ التسجيل
    Oct 2006
    صفحة الملتقى الرسمية على الفيس بوك .. مجموعة المهندسين العرب .. follow us on twitter...
    This document is: Active
    Nonmember Price: $142.50
    ACI Member Price: $86.00
    Order Code: SP1709
    Abstract: This publication provides information for the engineering design and analysis of beams, one-way slabs, footings, pile caps, columns, and seismic design in accordance with ACI 318-05. Information is presented in three sections: Explanatory Material, Design Examples, and Design Aids. The Introduction of each chapter includes explanatory material that provides the engineer with concise background of the subject. The Design Examples illustrate the use of the Design Aids, which are tables and graphs intended to eliminate routine and repetitious calculations.
    Keywords: axial loads; beams (supports); bending moments; biaxial bending; buckling; columns (supports); compression controlled sections; concrete piles; concrete slabs; cracking; deflection; eccentricity; flanges; flexural strength; footings; frames; load factors; loads (forces); long columns; moments of inertia; pile caps; punching shear; reinforced concrete; reinforcement; shear strength; slenderness ratio; special moment frames; spiral reinforcement; splicing; stiffness; strength analysis; strength reduction factors; structural analysis; structural design; T-beams; tension controlled sections; torsion.
    *******s: Chapter 1—Design for flexure, p. 3
    1.1—Introduction
    1.2—Nominal and design flexural strengths (Mn and φMn)
    1.3—Minimum flexural reinforcement
    1.4—Placement of reinforcement in sections
    1.5—Flexure examples
    1.6—Flexure design aids
    Chapter 2—Design for shear, p. 29
    2.1—Introduction
    2.2—Shear strength of beams
    2.3—Designing shear reinforcement for beams
    2.4—Shear strength of two-way slabs
    2.5—Shear strength with torsion and flexure
    2.6—Shear design examples
    2.7—Shear design aids
    Chapter 3—Short column design, p. 59
    3.1—Introduction
    3.2—Column sectional strength
    3.3—Columns subjected to biaxial bending
    3.4—Column examples
    3.5—Column design aids
    Chapter 4—Design of slender columns, p. 167
    4.1—Introduction
    4.2—Slenderness ratio
    4.3—Lateral bracing and designation of frames as non-sway
    4.4—Design of slender columns
    4.5—Slender column examples
    4.6—Slender column design aids
    Chapter 5—Footing design, p. 189
    5.1—Introduction
    5.2—Foundation types
    5.3—Allowable stress design and strength design
    5.4—Structural design
    5.5—Footings subject to eccentric loading
    5.6—Footings examples
    Chapter 6—Seismic design, p. 205
    6.1—Introduction
    6.2—Limitations on materials
    6.3—Flexural members of special moment frames
    6.4—Special moment frame members subjected to bending and axial load
    6.5—Joints of special moment frames
    6.6—Members of intermediate moment frames
    6.7—Members not designed as part of the lateral-force-resisting system
    6.8—Seismic design examples
    6.9—Seismic design aids
    Chapter 7—References, p. 229
    7.1—Referenced standards and reports
    7.2—Cited references
    Appendix A—Reference tables, p. 231
    Appendix B—Analysis tables, p. 237
    Appendix C—Sectional properties, p. 251
    http://www.easy-share.com/1910943169/DESIGN AID ACI CODE.rar
    http://www.4shared.com/file/pczcA7dY/SP-17_09__ACI_Design_Handbook.html
    http://www.megaupload.com/?d=XCVOPS7C
    من مواضيع majdiotoom :
    التعديل الأخير تم بواسطة majdiotoom ; 30-12-2010 الساعة 09:21 PM
  2. #2
    مشرف متميز الصورة الرمزية anass81
    تاريخ التسجيل
    Mar 2007
    جزاك الله خيرا على هذا المرجع القيم
    من مواضيع anass81 :
  3. #3
    العزيزية Don't Avatar
    تاريخ التسجيل
    Dec 2010
    لو سمحتم يا أعضاء المنتدى ألا يوجد أحد ليرد على طلبي
    من مواضيع العزيزية :
  4. #4
    تاريخ التسجيل
    Mar 2007
    اقتباس المشاركة الأصلية كتبت بواسطة العزيزية مشاهدة المشاركة
    تم نقل طلبك الى هذا الموضوع
    طلب مسائل في الكمرات المعدنية
    من مواضيع anass81 :
  5. #5
  6. #6
    عضو الصورة الرمزية Alaa Ali Elesawey
    تاريخ التسجيل
    Jan 2009
    أحسن شرح للكود الأمريكي
    من مواضيع Alaa Ali Elesawey :
  7. #7
  8. #8
    عضو الصورة الرمزية eng_youness2000
    تاريخ التسجيل
    Jan 2010
    فى الكمرات البسيطة الارتكاذ يعطى عزم سالب عند الاطراف فوق الركيزة ويقلب العزم فى المنتصف الى سالب واحيانا فى الثالث الاخير من الكمرة ويعطى لون احمر مع التأكد من عدم وجود ركيزة فى المنتصف وحتى شكل العزم المقلوب عبارة عن كرف مقلوب لاسفل على شكل بيضاوى مش زى العزم العادى ماهو الاحتمالات التى قد اخطأت فيها
    وجزاكم اللة خيرا
    مهندس عمر يمنس
    من مواضيع eng_youness2000 :
  9. #9
  10. #10
    RESEARCHER Don't Avatar
    تاريخ التسجيل
    Mar 2005
    جزاكم الله خيرا
    من مواضيع RESEARCHER :
المواضيع المتشابهه
  1. Aci-sp-17 aci design handbook
    بواسطة رزق حجاوي في المنتدى الهندسة المـدنيـة - عام
    مشاركات: 23
    آخر مشاركة: 30-10-2012, 03:24 AM
  2. Advanced Piping Design (Process Piping Design Handbook - Vol 2)
    بواسطة eng.mohamed_badawi في المنتدى مكتبة الهندسة الميكانيكية والبحرية والميكاترونيكس والتبريد والتكييف Mechanical - Marine - Mechatroni
    مشاركات: 16
    آخر مشاركة: 11-09-2011, 12:17 PM
ضوابط المشاركة
  • لا تستطيع إضافة مواضيع جديدة
  • لا تستطيع الرد على المواضيع
  • لا تستطيع إرفاق ملفات
  • لا تستطيع تعديل مشاركاتك
عن ملتقى المهندسين العرب
    يُعتبر ملتقى المهندسين العرب من أوائل وأكبر المواقع الهندسية حيث تم تأسيسه منذ عام 2001م ويهدف إلى نشر المعرفة الهندسية وتقديم كل ما له فائدة للمهندسين والمهتمين من خلال أقسامة العلمية والهندسية المتعددة بالإضافة إلى وجود أقسام عامة تستقطب الكثير لمختلف النقاشات الهادفة.
مواقع صديقة
تابعنا على
Twitter Facebook
The owner and operator of the site is not responsible for the availability of, or any content provided.
Topics that are written in the site reflect the opinion of the author.
Search Engine Optimization by vBSEO
