النتائج 1 إلى 7 من 7
    Received: 56
    Given: 23
    Laboratory shear strength of soil: STP740
    Author: Yong RN, Townsend FC | Size: 11.3 MB | Format: PDF | Publisher: ASTM | Year: 1981 | pages: 720 | ISBN: 978-0-8031-0789-2
    INFORMATION
    Describes the development of new test techniques and methods for the evaluation of the laboratory shear strength of soil.
    Table of *******s
    Introduction
    Yong R., Townsend F.
    Summary
    State of the Art: Laboratory Strength Testing of Soils
    Saada A., Townsend F.
    Comparison of Various Methods for Determining K0
    Al-Hussaini M.
    Apparatus and Techniques for Static Triaxial Testing of Ballast
    Alva-Hurtado J., McMahon D., Stewart H.
    Mechanical Behavior and Testing Methods of Unsaturated Soils
    Edil T., Motan S., Toha F.
    Determination of Tensile Strength of Soils by Unconfined-Penetration Test
    Fang H., Fernandez J.
    Torsion Shear Apparatus for Soil Testing
    Lade P.
    A Servo System for Controlled Stress Path Tests
    Law K.
    A New Control System for Soils Testing
    Mitchell R.
    Lateral Stress Measurements in Direct Simple Shear Device
    Dyvik R., Zimmie T., Floess C.
    Tensile Properties of Compacted Soils
    Al-Hussaini M.
    Effect of Organic Material on Soil Shear Strength
    Andersland O., Khattak A., Al-Khafaji A.
    Effect of Shearing Strain-Rate on the Undrained Strength of Clay
    Cheng R.
    Undrained Shear Behavior of a Marine Clay
    Koutsoftas D.
    Shearing Behavior of Compacted Clay after Saturation
    Lovell C., Johnson J.
    Plane-Strain Testing of Sand
    Marachi N., Duncan J., Chan C., Seed H.
    Effect of End Membrane Thickness on the Strength of “Frictionless” Cap and Base Tests
    Norris G.
    Field Density, Gradation, and Triaxial Testing of Large-Size Rockfill for Little Blue Run Dam
    Thiers G., Donovan T.
    State of the Art: Data Reduction and Application for Analytical Modeling
    Ko H., Sture S.
    Normalized Stress-Strain for Undrained Shear Tests
    Drnevich V.
    The Critical-State Pore Pressure Parameter from Consolidated-Undrained Shear Tests
    Mayne P., Swanson P.
    Nonlinear Anisotropic Stress-Strain-Strength Behavior of Soils
    Prevost J.
    A General Time-Related Soil Friction Increase Phenomenon
    Schmertmann J.
    On the Random Aspect of Shear Strength
    Yong R., Tabba M.
    Preconsolidation Pressure Predicted Using su/¯p Ratio
    Anderson T., Lukas R.
    Stress Path Tests with Controlled Rotation of Principal Stress Directions
    Arthur J., Bekenstein S., Germaine J., Ladd C.
    Shear Strength of Cohesionless Soils from Incremental Creep Test Data
    Baladi G., Lentz R., Goitom T., Boker T.
    Comparison of Shear Strength Values Derived from Laboratory Triaxial, Borehole Shear, and Cone Penetration Tests
    Lambrechts J., Rixner J.
    Borehole Shear Test in Geotechnical Investigations
    Lutenegger A., Hallberg G.
    Concepts for a Shear-Normal Gage to Estimate In Situ Soil Strength and Strength Angle
    McNeill R., Green S.
    Residual Shear Strength Determination of Overconsolidated Nespelem Clay
    Miedema D., Byers J., McNearny R.
    The Need for Pore Pressure Information from Shear Tests
    Shields D., Skermer N.
    Behavior of an Overconsolidated Sensitive Clay in Drained K0-Triaxial Tests
    Silvestri V.
    Discussion of “State of the Art: Laboratory Strength Testing of Soils”
    Lacasse S., Vucetic M.
    Christian J.
    Discussion on Laboratory Shear Devices
    Ladd C.
    Limitations of Direct Simple Shear Test Devices
    La Rochelle P.
    Discussion of Soil Testing Practices
    Poulos S.
    Some Aspects of Clay Behavior and Their Consequences on Modeling Techniques
    Tavenas F.
    Development, Testing Requirements, and Fitting Procedure of Elastic-Plastic Models
    Baladi G.
    A Qualitative Stress-Strain (Time) Model for Soft Clays
    Crooks J.
    Links
    http://depositfiles.com/files/jdhum29k9
    http://ifile.it/x8d649w/STP74000001.rar
    من مواضيع cappotchi :
    التعديل الأخير تم بواسطة الأمل الضائع ; 2010-12-20 الساعة 08:31 PM
    ويبقى العراقُ عزيزًا علينا
    كبيرًا بحجْمِ الجِرَاح
    عَنِيدًا كَطَوْدٍ ..
    تَسَاقَطَ منه الفتيتُ المُبَعْثَر
    ويبقى العراقُ
    على دمْعَةٍ من عيونِ المَهَا
    أَهِيمُ بها ..
    أَقُولُ لها:
    دَعِينِي أُمرِّغُ خَدْيَ ..
    في نسمةٍ من نِسيمِ العراق
    أصيحُ من (الثغرِ) حتى بلادِ المغول
    فَلَنْ تُشرقَ الشمسُ من ظُلْمَةِ (الأطلسي)
    وَلَنْ تضحكَ الشمسُ من وَضْعِها في الأفولْ
    ويبقى العراقُ نزيفًا على الخَارِطَةْ
    الصورة الرمزية خلوف العراقي
    Received: 134
    Given: 52
    جزاكم الله خيرا
    اللهم احفظ العراق واهله
    Trust me I 'm Engineer
    ابن ناصريه العراق
    محاضرات رائعه فيديوا صوت وصوره لجميع مناهج الهندسه المدنية على هذه الروابط
    عضو متميز جداً
    الصورة الرمزية cappotchi
    Received: 56
    Given: 23
    ويبقى العراقُ
    أَهِيمُ بها ..
    أَقُولُ لها:
    عضو متميز جداً
    Received: 56
    Given: 23
    اتمني ان تعم الفائدة للحميع ومعا لرقي بمجتمعنا الى رحب الاسلام
    ويبقى العراقُ
    أَهِيمُ بها ..
    أَقُولُ لها:
    جزاكم الله خيرا
    Received: 256
    تمت الاضافة
    جزاكم الله خيرا وبارك الله فيك
    متغيبة عن الملتقى
    merci beauccccccccccccccoup
