دورة إدارة المشاريع الاحترافية PMP
آخر المواضيع الجديدة
صفحة 1 من 3 123 الأخيرةالأخيرة
النتائج 1 إلى 10 من 28
حصريا برنامج تحويل الملفات الرائع PDF to Word, Excle,
حصريا برنامج تحويل الملفات الرائع PDF to Word, Excle, PowerPoint, HTML, Images and Text Simpo PDF Converter Ultimate 1.1.2.0 Simpo
  1. #1
    عضو متميز جداً الصورة الرمزية engmmt
    تاريخ التسجيل
    Dec 2008
    صفحة الملتقى الرسمية على الفيس بوك .. مجموعة المهندسين العرب .. follow us on twitter...
    حصريا برنامجتحويل الملفات الرائع PDF to Word, Excle, PowerPoint, HTML, Images and Text
    Simpo PDF Converter Ultimate 1.1.2.0 | 4.37 MB
    Simpo PDF Converter Ultimate is a 6-in-1 PDF converter to convert PDF to Word, Excle, PowerPoint, HTML, Images and Text on 32bit/64bit Windows 7/Vista/XP system. It supports batch conversion and you can easily convert PDF to Office in the fastest speed to save your time. With this allsided PDF converter, your PDF files can be converted to other formats with high output quality, images, graphic and tables will be preserved precisely.
    The best PDF converter to solve all problems to convert PDF to Office, HTML, Text and Images.
    • Convert PDF to Word, Excel, PowerPoint, Text, HTML and Images
    • Preserve all *******s like text, tables, graphic objects, hyperlinks and formatting from PDF
    • Convert PDF in faster speed
    • Batch convert up to 200 PDF files at a time
    Features
    • Easy-to-use Interface.
    The interface of Simpo PDF Converter Ultimate is simple and easy to use. You can just import a batch of PDF files with drag and drop function, then click "Convert" to get wanted output file format - Word, Excel, PowerPoint, HTML, Text and Images.
    • Accurately Convert PDF to Word
    Simpo PDF Converter Ultimate can convert PDF to Word accurately. It preserves all *******s including origianl layouts and formatting of text, tables and hyperlinks, even graphic objects like Curve, Shape and Rectangle are also retained precisely from PDF to Word.
    • Easy Convert PDF to Excel
    PDF Converter Ultimate provides 2 methods to convert PDF to Excel - Reserve PDF tables and Reserve whole PDF. Reserve PDF tables means that you can extract origianl text and numbers in PDF tables from PDF to Excel spreadsheet. Reserve whole PDF allows you to preserve whole PDF to Excel, text, numbers, tables and formatting. In addition, PDF Converter Ultimate supports to save PDF to Excel as .xls, .xlsx and .csv format.
    • Convert PDF to PowerPoint
    Demonstrating a PDF file is not easy, but you can convert PDF to PowerPoint, which allows you to present slide show to your audience conveniently. PDF Converter Ultimate converts your PDF file to PowerPoint slide by page, every PDF page is converted to one PowerPoint slide.
    • Convert PDF to HTML Retaining Bookmarks
    PDF Converter Ultimate can preserve hyperlinks and bookmarks from PDF to HTML. With the bookmarks in HTML, you can view the ebooks of your own will any time.
    • Convert PDF to Image
    With PDF Converter Ultimate, it is much easier to extract images from PDF. It also allows you to save extracted images from original PDF file with 5 types - PDF to JPEG, PDF to TIFF, PDF to BMP, PDF to PNG and PDF to GIF. These are the top 5 used images types which can fulfill your need.
    • Convert PDF to Text
    PDF Converter Ultimate can also works as a PDF to Text converter, you can convert PDF to plain text as well. Just choose Text as output file format, all text ******* will be extracted in seconds wit text origianl formating saved precisely.
    • Best and Time-saving PDF Converter
    Simpo PDF Converter Ultimate is the best of many PDF converters. 1) Its output quality is top-grade and conversion speed is the fastest; 2) Convert PDF in two ways - Partial and Batch. Partial means that you can select any specific pages from a multi-page PDF file to convert; Batch is a time-saving way, as you can convert batch of PDF files at a time; 3) Support encrypted PDF files. Directly convert PDF files with printing and copying restrictions and convert open password protected PDF files with entering password first; 4) Support multiple output file formats - Microsoft Office Word 2003/2007/2010(.doc, .docx), Excel 2003/2007/2010(.xls, .xlsx, .csv), PowerPoint 2003/2007/2010(.ppt, .pptx), HTML format(.html), Text format(.txt) and Images format(.jpg, .tiff, .bmp, .png, .giff)
    للتحميل اضغط
    هنااااااااااااااا
    من مواضيع engmmt :
  2. #2
    عضو الصورة الرمزية ابو عمر البغدادي
    تاريخ التسجيل
    Jul 2007
    مشكوووووووووووووووووووووووووووووووور اخي
    من مواضيع ابو عمر البغدادي :
  3. #3
  4. #4
    المسملي999 Don't Avatar
    تاريخ التسجيل
    Jul 2010
    جزيت خيرا
    وزوجت بكرا
    ورزقت من البنين عشرين ومن البنات عشرا
    من مواضيع المسملي999 :
  5. #5
  6. #6
  7. #7
    ahwazy Don't Avatar
    تاريخ التسجيل
    Jun 2010
    شکرا جزیلا
    من مواضيع ahwazy :
  8. #8
  9. #9
  10. #10
    تاريخ التسجيل
    Dec 2008
    مشكووووور
    مشكووووور مشكووووور
    مشكووووور مشكووووور مشكووووور
    مشكووووور مشكووووور مشكووووور مشكووووور
    مشكووووور مشكووووور مشكووووور مشكووووور مشكووووور
    مشكووووور مشكووووور
    مشكووووور
    من مواضيع engmmt :
المواضيع المتشابهه
  1. حصريا برنامجتحويل الملفات الرائع PDF to Word, Excle, PowerPoint, HTML, Images and Text
    بواسطة engmmt في المنتدى ملتقى البرامج العامة و الانترنت
    مشاركات: 23
    آخر مشاركة: 14-04-2011, 02:21 PM
  2. حصريا برنامجتحويل الملفات الرائع PDF to Word, Excle, PowerPoint, HTML, Images and Text
    بواسطة engmmt في المنتدى الهندسة المـدنيـة - عام
    مشاركات: 43
    آخر مشاركة: 18-01-2011, 01:01 AM
  3. حصريا برنامجتحويل الملفات الرائع PDF to Word, Excle, PowerPoint, HTML, Images and Text
    بواسطة engmmt في المنتدى هندسة التبريد و التكييف
    مشاركات: 30
    آخر مشاركة: 16-01-2011, 09:33 PM
ضوابط المشاركة
  • لا تستطيع إضافة مواضيع جديدة
  • لا تستطيع الرد على المواضيع
  • لا تستطيع إرفاق ملفات
  • لا تستطيع تعديل مشاركاتك
عن ملتقى المهندسين العرب
    يُعتبر ملتقى المهندسين العرب من أوائل وأكبر المواقع الهندسية حيث تم تأسيسه منذ عام 2001م ويهدف إلى نشر المعرفة الهندسية وتقديم كل ما له فائدة للمهندسين والمهتمين من خلال أقسامة العلمية والهندسية المتعددة بالإضافة إلى وجود أقسام عامة تستقطب الكثير لمختلف النقاشات الهادفة.
مواقع صديقة
تابعنا على
Twitter Facebook
The owner and operator of the site is not responsible for the availability of, or any content provided.
Topics that are written in the site reflect the opinion of the author.
Search Engine Optimization by vBSEO
