تم افتتاح مركز رفع الملفات للأعضاء من جديد ..  و نعتذر عن عدم إمكانية دمج المركز السابق مع المركز الحالي لرفع الملفات ........ ( إدارة الملتقى )
العودة   ملتقى المهندسين العرب > الملتقى الهندسي > هندسة الطيران
هندسة الطيران ................ بإشراف : جاسر, م/ مصطفي, م المصري
LinkBack أدوات الموضوع التقييم: تقييم الموضوع: 3 تصويتات, المعدل 4.33.
  #16 (permalink)
قديم 04-02-2007, 08:31 PM
محمد زرقة يستحق التميز
Cool كيف تطير الهليكوبتر
GENERAL
This is just the basic informations for the beginners which did not know any things about the helicopter or airplane before and wants to know some principles that why the helicopter can fly but not in deep details. For the people that want to know more than what I have in here, please go to the text book which have many professors wrote them or go to the specific helicopter manuals. The details about the helicopter has so much to put it all in the WEB.
INTRODUCTION
The wings of the airplane create a lift force when they move through the air. As we known,during flight, there are four forces acting on the helicopter or airplane and those are LIFT , DRAG , THRUST ,and WEIGHT .(please go back and see on What makes an airplane fly ? section).In order to make the wings to move through the air , of course, the plane itself has to move. A helicopter works by having its wings move through the air while the body stays still. The helicopter's wings are called Main Rotor Blades. The shape and the angle of the blades move through the air will determine how much Lift force is created. After the helicopter lifted off the ground, the pilot can tilt the blades, causing the helicopter to tip forward or backward or sideward.
NOMENCLATURE AND TECHNICAL TERM
Although we will describe certain terms or parts of helicopter more in the next sections as we go along, but we should familier with all of these terms in order to understand the helicopter better.
Bernoulli'principle :This principle states that as the air velocity increases, the pressure decreases; and as the velocity decreases, the pressure increases .
Airfoil : is technically defined as any surface, such as an airplane aileron, elevator, rudder, wing, main rotor blades, or tail rotor blades designed to obtain reaction from the air through which it moves.
Angle of Attack : is the acute angle measured between the chord of an airfoil and the relative wind.
Angle of Incidence : is the acute angle between the wing's chord line and the longitudinal axis of the airplane. (usually manufacturer had built the aircraft with the wing has some degrees to the horizontal plane or airplane longitudinal axis).
Blades : The blades of the helicopter are airfoils with a very high aspect ratio ( length to chord ). The angle of incidence is adjusted by means of the control from pilots.
The main rotor of the helicopter may have two, three,four , five or six blades, depending upon the design. The main rotor blades are hinged to the rotor head in such a manner that they have limited movement up and down and also they can change the pitch ( angle of incidence ). The controls for the main rotor are called Collective and Cyclic Controls.
The tail rotor is small blades may have two or four blades and mounted on the tail of the helicopter,it rotates in the vertical plane. The tail rotor is controlled by the rudder pedals. Its pitch can be changed as required to turn the helicopter in the direction desired.
Blade Root : The inner end of the blades where the rotors connect to the blade gripos.
Blade Grips : Large attaching points where the rotor blade connects to the hub.
Rotor Hub : Sit on top of the mast , and connects the rotor blades to the control tubes.
Main Rotor Mast : Rotating shaft from the transmission which connects the main rotor blades to helicopter fuselage
رد مع اقتباس
  #17 (permalink)
قديم 04-02-2007, 08:32 PM
Cool كيف تطير الهليكوبتر 2
Pitch Change Horn : to converts control tube movement to blade pitch. Control tube is a push-pull tubes that change the pitch of the rotor blades through the pitch changing horn
Swash Plate Assembly : The swash plate assembly consists of two primary elements through which the rotor mast passes. One element is a disc, linked to the cyclic pitch control. This disc is capable of tilting in any direction but does not rotate as the rotor rotates. This non-rotating disc, often refered to as the Stationary Star is attached by a bearing surface to a second disc, often refered to as the Rotating Star which turns with rotor and linked to the rotor blade pitch horns
Transmission : The transmission system transmits engine power to the main rotor, tail rotor, generator and other accessories. The engine is operated at a relative high speed while the main rotor turns at a much lower speed. This speed reduction is accomplished through reduction gears in the Transmission System
Lift : is produced by a lower pressure created on the upper surface of an airplane's wings compared to the pressure on the wing's lower surfaces,causing the wing to be LIFTED upward. The special shape of the airplane wing (airfoil) is designed so that air flowing over it will have to travel a greater distance and faster resulting in a lower pressure area (see illustration) thus lifting the wing upward. Lift is that force which opposes the force of gravity (or weight).
Lift depends upon (1) shape of the airfoil (2) the angle of attack (3) the area of the surface exposed to the airstream (4) the square of the air speed (5) the air density.
Relative Wind : is the direction of the airflow with respect to an airfoil or to the rotor blades
Pitch Angle : The rotor blade pitch angle is the acute angle between the blade chord line and the rotor plane of rotation.( you may understand as the angle of incidence ) . This pitch angle can be varied by the pilot through the use of cockpit controls ( collective and cyclic pitch control )
اول رايك
رد مع اقتباس
  #18 (permalink)
قديم 04-02-2007, 08:33 PM
Cool كيف تطير الهليكوبتر 3
GENERAL
Helicopter, Lift is obtained by means of one or more power driven horizontal propellers which called Main Rotor. When the main rotor of helicopter turns it produces lift and reaction torque. Reaction torque tends to make helicopter spin. On most helicopters, a small rotor near the tail which called tail rotor compensates for this torque. On twin rotor helicopter the rotors rotate in opposite directions, their reactions cancel each other.
Main Rotor
The lifting force is produced by the main rotor . As they spin in the air and produced the lift. Each blade produces an equal share of the lifting force. The weight of a helicopter is divided evenly between the rotor blades on the main rotor system. If a helicopter weight 4000 lbs and it has two blades, then each blade must be able to support 2000 lbs.In addition to the static weight of helicopter ,each blade must be accept dynamic load as well . For example, if a helicopter pull up in a 1.5 g manouver (1.5 time the gravity force), then the effective weight of helicopter will be 1.5 time of static helicopter weight or 6000 lbs. due to gravitational pull.
Tail Rotor
The tail rotor is very important. If you spin a rotor with an engine, the rotor will rotate,but the engine and helicopter body will tend to rotate in opposite direction to the rotor. This is called Torque reaction. Newton's third law of motion states , " to every action there is an equal and opposite reaction" . The tail rotor is used to compensates for this torque and hold the helicopter straight. On twin-rotors helicopter , the rotors spin in opposite directions, so their reactions cancel each other.
The tail rotor in normally linked to the main rotor via a system of driveshafts and gearboxes , that means if you turn the main rotor , the tail rotor is also turn.Most helicopter have a ratio of 3:1 to 6:1 . That is, if main rotor turn one rotation , the tail rotor will turn 3 revelutions (for 3:1)or 6 revolutions (for 6:1). In most helicopter the engine turns a shaft that connected to an input quill in the transmission gearbox. the main rotor mast out to the top and tail rotor drive shafts out to the tail from the tranmission gear box.
Dissymmetry of Lift
All rotor systems are subject to Dissymmetry of Lift in forward flight . At a hover , the lift is equal across the entire rotor disk . As the helicopter gain air speed , the advanceing blade develops greater lift because of the increased airspeed and the retreating blade will produce less lift , this will cause the helicopter to roll (for example: if rotor speed = 400 km/hr , helicopter move forward=100 km/hr then advancing blade will have speed=500 km/hr but the retreating blade will has moving speed of only 300 kr/hr ) . This has to be compensated for in some way .
Blade Flapping
Dissymmetry of lift is compensated for by Blade flapping. Because of the increased airspeed and lift on the advancing blade will cause the blade to flap up and decreasing the angle of attack . The decreased lift on the retreating blade will cause the blade to flap down and increasing the angle of attack . The combination of decreased angle of attack on the advancing blade and increased angle of attack on the retreating blade through blade flapping action tends to equalize the lift over the two halves of the rotor disc.
Relationship between Swash Plate and Controls
Swash Plate Assembly : The swash plate assembly consists of two primary elements through which the rotor mast passes. One element is a disc, linked to the cyclic pitch control. This disc is capable of tilting in any direction but does not rotate as the rotor rotates. This non-rotating disc, often refered to as the Stationary Star is attached by a bearing surface to a second disc, often refered to as the Rotating Star which turns with rotor and linked to the rotor blade pitch horns.
The Collective Control : When pilot raises the collective control or pull collective control up , the collective control will raises the entire swash plate assembly as a unit . This has effect to the blades by changing the pitch of all blades simultaneously .This causes to increase angle of attack and give more lift.
The Cyclic Control : The cyclic control will push one side of the swashplate assembly up or down. This has the effect to the rotor head system because the cyclic control or cyclic stick controls the angle of the main rotor by angling the rotor head to which all the blades are attached .This cause the helicopter to move left or right, forward or backward.
Anti torque Pedals
The Thrust produced by the auxiliary (tail) rotor is governed by the position of anti torque pedals. These are not rudder pedals, although they are in the same place as rudder pedals on an airplane. They are linked to a pitch change mechanism in the tail rotor gear box to permit the pilot to increase the pitch of the tail rotor blades. The primary purpose of the tail rotor and its controls is to counteract the torque effect of the main rotor.
رد مع اقتباس
  #19 (permalink)
قديم 04-02-2007, 08:36 PM
Cool كيف تطير الهليكوبتر 4
GENERAL
Helicopter, Lift is obtained by means of one or more power driven horizontal propellers which called Rotors. When the rotors of helicopter turns it produces lift and reaction torque, reaction torque which tends to make helicopter spin. on most helicopters a small rotor near the tail which called tail rotor compensates for this torque. On twin rotor helicopter the rotors rotate in opposite directions, their reactions cancel each other. The direction of helicopter is controlled by inclining the axis of the main rotor path in that direction.
Function of Controls
There are three major controls in the helicopter that the pilot must use during flight. They are : ( 1 ) Collective pitch control. ( 2 ) Anti Torque Pedals or Tail Rotor Control. ( 3 ) Cyclic Stick Control.
Collective Control
The collective pitch lever or stick is located by the left side of the pilot's seat and is operated with the left hand. The collective is used to increase main rotor pitch at all points of the rotor blade rotation. It increases or decreases total rotor thrust. The collective lever is connected to the swash plate by a series of bush pull tubes. Raising the collective lever increases the pitch on the main rotor blade, lowering the collective lever decreases the main rotor blade pitch. The amount of movement of th elever determines the amount of blade pitch change. As the angle of attack increase, drag increases and Rotor RPM and Engine RPM tend to decrease . As the angle of attack decreases, drag decreases and the RPM tend to increase.Since it is essential that the RPM remain constant, there must be some means of making a proportionate change in power to compensate for the change in drag. This coordination of power change with blade pitch angle change is controlled through a collective pitch lever- trottle control cam linkage which automatically increases power when the collective pitch lever is raised and decreases power when the lever is lowered.
The picture above is the typical collective lever but the detail of control may varies depend on each munufacturer .The main functions are still the same for all helicopters.
Collective Lever is connected to the rotor system via push pull tubes. It also has droop com pensation devics which sense change in the collective pitch lever and increases or decreases fuel to the engine automatically somewhat in anticipated of a change in power required. This helps to minimize the RPM fluctuations during collective pitch change.
Engine Control (Emergency) is the throttle twist grip. During emergency condition, between flight and flight idle positions. This is useful during any event which would cause engine or rotor RPM to go too high or while landing after a tail rotor failure.
Idle Release Button, when the throttle is rolled from " off " to " idle " the idle release button snaps into a detent which prevents the throttle from being rolled back to " off "
Starter Button : Pushing this button will cause the starter / generator to act as a starter motor ( Starter / Generator is a component that funtion in either mode as a starter or generator ) , turning over the engine.
Landing Light Switch has a three position which are " off " , " forward " and "both " . In forward , only the forward light is activated. In both, the forward and downward lights are activated .
Power Trim Switch ,by holding it in " increase " or " decrease " the pilot can set the RPM that the pilot attempt to maintain
Function of Controls (Continue)
Anti-Torque Pedals or Tail Rotor Control
In accordance with Newton's law of action and reaction, the helicopter fuselage tends to rotate in the direction opposite to the rotor blades . This effect is called torque . Torque must be counteracted and controlled to make flight is possible . Compensation for torque in a single main rotor helicopter is accomplished by means of a variable pitch antitorque rotor (tail rotor) located on the end of the tail boom extension at the rear of fuselage.
Heading Control : In addition to counteracted torque, the tail rotor and its control linkage also permit control of the helicopter heading during flight . Application of more control than is necessary to counteract torque will cause the nose of helicopter to turn in the direction of pedal movement.
In forward flight , the pedals are not used to control the heading of the helicopter (except during portions of crosswind takeoff and approach). They are used to compensate for torque to put the helicopter in longitudinal trim so that coordinated flight can be maintained.
The thrust of the tail rotor is depend upon the pitch angle of the tail rotor blades. The tail rotor may have a positive pitch angle or it may have a negative pitch angle which to push the tail to the right or pull the tail to the left.
With the right pedal pressed or moved forward of the neutral position will cause the tail rotor blades to change the pitch angle and the nose of helicopter will yaw to the right . With the left pedal pressed or moved forward of the neutral position will cause the tail rotor blades to change the pitch angle opposite to the right pedal and the nose of helicopter will yaw to the left.
Cyclic Control
As mention earier , the total lift force is always perpendicular to the tip-path plane of the main rotor. When the tip path plane is tilt away from the horizontal, the lift -thrust force is divide into two components of forces that are, the horizontal acting force, thrust and the upward acting force, lift.
The purpose of the cyclic pitch control is to tilt the tip path plane in the direction that horizontal movement is desired. The thrust component of force then pulls the helicopter in the direction of rotor tilt. The cyclic control changes the direction of this force,thus controlling the attitude and air speed of helicopter.
The rotor disc tilts in the same direction of the cyclic stick was moved. If the cyclic stick is moved forward, the rotor disc tilt forward: if the cyclic is moved aft, the rotor disc tilt aft, and so on. The rotor disc will always tilt in the same direction that the cyclic stick is moved.
The above picture is only typical for cyclic control stick which different manufacturer will have some detail different but the main fuction is the same.
The radio switch is used for pilot to transmit radio by clicking the switch.
The trim switch , pilot use this switch to neutralize stick force . Pilot can use the trim switch to put the stick to the right , left , forward or backward . This runs electric motor which will tension the spring which will tend to hold the stick. The cyclic will stay where it is even the pilot were let it go . This also release tension from pilot.
The cargo release switch is the option switch, some manufacturer may have other function switch.
رد مع اقتباس
  #20 (permalink)
قديم 05-02-2007, 07:44 PM
احمد انور علي يستحق التميز
شكرا علي هذا العمل العظيم
الحاجات دي انا هذكرها
رد مع اقتباس
  #21 (permalink)
قديم 12-02-2007, 07:51 PM
فهد الثاني يستحق التميز
رد مع اقتباس
  #22 (permalink)
قديم 17-02-2007, 03:10 AM
aero2006 يستحق التميز
جزالك الله كل خير على تلك المعلومات القيمة
رد مع اقتباس
  #23 (permalink)
قديم 16-04-2007, 01:30 PM
eng_kamel akrm يستحق التميز
كيف تعمل الطائرة العمودية "الهيليكوبتر
مقارنة بين وسائل النقل المعروفة
لفهم كيف تعمل طائرة الهيليوكبتر ولماذا فكرتها معقدة بعض الشيء، سنقوم بمقارنتها بوسائل النقل المختلفة مثل القطار والسيارة والطائرة. وسوف نعرف في النهاية لماذا تميزت الهيليوكبتر بمرونتها.
لنبدأ بوصف حركة القطار، فالقطار وسيلة نقل سهلة القيادة وذلك لانه يوجد فقط اتجاهين للحركة الاتجاه الامامي او الخلفي، يحتوي القطار على نظام ايقاف "فرامل" لايقاف القطار في الاتجاهين ولكن لا يحتوي على عجلة قيادة حيث ان حركة القطار محكومة بالقضبان الحديدية التي تغير اتجاه القطار تبعاً لتصميمها.
ولأن القطار يتحرك في اتجاهين فإن قائد القطار يمكنه السيطره عليه باستخدام يد واحدة فقط. أما في حالة السيارة فإنه تتحرك للأمام والخلف مع امكانية ان تغير مسارها لليمين واليسار في كلا الاتجاهين.
ولكن الطائرة لا تحتاج ان تتحرك للخلف ولهذا فإن الطائرة تتحرك في خمس اتجاهات في حين ان السيارة تتحرك في اربعة اتجاهات. إن المقدرة على الحركة للأعلى والاسفل يضيف بعد جديد للحركة يجعل الطائرة مختلفة تماماً عن السيارة. وللتحكم في الحركة للأعلى وللاسفل فإن الطائرة تزود بمقوض على شكل عصا الالعاب joystick تتحرك للامام والخلف ولليمين واليسار بدلا من عجلة القيادة الدائرية الثابتة التي تتحرك لليمين واليسار فقط. كما يوجد دواستين للتحكم في حركة ذيل الطائرة والعجلات. لذلك يستطيع قائد الطائرة التحليق بالطائرة والسيطرة عليها باستخدام يداً واحدة وقدمين.
ولكن في طائرة الهيليوكبتر فإنها تستطيع القيام بثلاثة اشياء اضافية لا توجد في الطائرة العادية وهذه هي:
  • <LI class=MsoNormal style="TEXT-ALIGN: justify">الهيليوكبتر تستطيع الرجوع للخلف <LI class=MsoNormal style="TEXT-ALIGN: justify">الهيليوكبتر تستطيع الدوران حول محورها في الجو
  • الهيليوكبتر تستطيع البقاء مكانها محلقة في الجو
أجزاء الهيليوكبتر
تتكون الهيليكبتر من عدة أجزاء وهي موضحة في الشكل التخطيطي التالي:
أجزاء طائرة الهيليكوبتر
سوف نركز على أهم الاجزاء فيها بالشرح والتفصيل.
(1) المروحة الرئيسية
شكل تخطيطي يوضح المروحةا الرئيسية ومروحة الذيل
(2) المروحة المضادة للازدواج
الحركة الانتقالية
لكي تتحرك الهيليكوبتر إلى الأمام فإنها تتحول نوعا ما إلى طائرةعادية، أي أنها تحدث ميلا إلى الأمام في المستوى الذي تدور فيه المروحة. وعندئذ، فإن المروحة الرئيسية تولد قوة شد إلى الإمام،مع استمرارها في المساعدة على توازن الهيليكوبتر .
وواضح أنه إذا مال مستوى الدوران إلى الخلف أو إلى أحد الجانبين فإن الهيليكوبتر تتحرك إلى الخلف أو إلى أحد الجانبين .
كما أنه يمكن تحريك الهيليكوبتر إلى الأمام، بتغيير معدل حركة شفراتالمروحة الرئيسية ويتم هذا التغيير عن طريق رافعة تسمى " جهاز التحكم فيالحركة الدوارة".
مخطط توضيحي لتركيب أجزاء المروحة الرئيسية
صورة للمروحة الرئيسية توضح الأذرع الختلفة التي تتحكم في تغير مستو دوران المروحة بالنسبة للمستوى الأفقي، كما تظهر في الصورة الطبقتين الثابتة والمتحركة
الهبوط
ما الذي يجب على قائد الهيليكوبتر أن يفعله ليهبط بها بعد أن تصل فوقهدفها؟ إن الأمر بسيط. كل ما عليه أن يفعله، هو تقليل قوة الحمل فيالمروحة الرئيسية .
ولكي يفعل ذلك، فإنه يعمل على تغيير معدل حركة شفرات المروحة . ومنالناحية العملية، فإنه يعدل بذلك زاوية اصطدام الشفرات بالهواء . وبهذهالطريقة تقل قوة الحمل، وإذا صارت هذه الأخيرة أقل من وزن الهيليكوبتر،هبطت هذه من تلقاء نفسها . فإن الهيليكوبتر تصعد إذا زادت قوة الحمل علىوزنها، وتهبط إذا زاد وزنها على قوة الحمل وتظل ثابتة في الهواء إذا تساوتقوة الحمل مع وزنها . وتعود فنكرر أن قوة الحمل تتوقف على معدل حركة شفراتالمروحة الرئيسية .
التحليق
يمكن ان يقوم الطيار بتثبيت الهيليوكبتر في الجو وذلك بالتحكم في سرعة دوران المروحة الرئيسية للوصول الى السرعة المطلوبة للحفاظ على توازنها في الجو وهذا يتطلب مهارة كبيرة من القائد.
استخدامات الهيليكوبتر
مزايا الهيليكوبتر وعيوبها
إلى جانب ما للهيليكوبتر من مزايا رائعة فإن لها أيضا بعض العيوب ، فيالوقت الحاضر على الأقل . فهي أولا جهاز دقيق معقد في تشغيله وصعب التوجيه .
وعلاوة على ذلك، فهي جهاز يتطلب محركا أقوى كثيرا مما يلزم لطائرة عادية تماثلها في الوزن والقدرة .
الجنرال
رد مع اقتباس
  #24 (permalink)
قديم 20-04-2007, 06:41 PM
الصورة الرمزية مهندس وليد سمير
مهندس وليد سمير يستحق التميز
شرح متميز من اخ متميز جزاك الله كل الخير
من مواضيعي
لمن يريد دراسه الطيران
رد مع اقتباس
  #25 (permalink)
قديم 21-04-2007, 05:38 PM
ميثم عباس رشيد يستحق التميز
تستالهل الشكر والتقدير
رد مع اقتباس
  #26 (permalink)
قديم 09-05-2007, 02:31 PM
JHONNYGHAIT يستحق التميز
شكرا علي المجهود الكبير الذي بذلته ولاكن اسمح لي بملاحظة التالي:
لم تشير الي المصدر وأثناء ترجمتك الرائعة للمقالة أفرغت بعض الفقرات من مضمونها وهو ليس عيبا لانني اعتقد أنك لست متخصصا في الطائرات العمودية وذلك بقولك ان الطائرة العمودية تستهلك كميات كبيرة من الوقود والزيت.مع جزيل الشكر
وأرجو ان تعذرني علي صراحتي. جزاك الله خير .
رد مع اقتباس
  #27 (permalink)
قديم 07-06-2007, 01:06 AM
الطارق سفيان يستحق التميز
Thumbs up طائرة الا باتشي
تحدثنا في مقال سابق بعنوان كيف تعمل طائرة الهيليوكبتر والامكانيات العديدة لهذه الطائرة وكيف تطير وتحلق في الجو، أما في موضوعنا اليوم فسوف نتحدث عن الطراز الحربي لطائرة الهيليوكبتر والذي يعرف باسم طائرة الأباتشي Apache التي تعد الافضل تطوراً في منظومة الاسلحة الحربية والتي يمكن ان نطلق عليها اسم الدبابة الجوية التي تتحمل الظروف الجوية القاسية سواء بالليل او بالنهار، وذلك لما تحتويه من تقنيات عديدة جعلت منها المقاتلة الاكثر شراسة وخطورة على القوات البرية في المواجهات والمعارك الحربية.
سوف نقوم بشرح مفصل لطائرة الاباتشي مع التركيز بالشرح على نظام الطيران ونظام الاسلحة ونظام المراقبة ونظام الدفاع فيها. وكل نظام من هذه الانظمة عبارة عن تكنولوجيا مستقلة بذاتها ولكنها تعمل مع بعضها البعض لتعطي قدرات هائلة لمقاتلة حربية خطيرة.
المروحة الرئيسية مثبتة في اعلى الطائرة وتتكون من اربع شفرات بطول 6 امتار ويمكن لقائد الطائرة ان يتحكم في محور الدوارن وزاويته من خلال القاعدة الحاملة للمروحة ومن خلال التحكم في سرعة الدوران يمكن للطائرة الارتفاع او الهبوط او الثبات في الجو، كما يمكنه ان يجعل الطائرة تندفع للأمام أو تتحرك للخلف حسب زاوية مستوى الدوران مع سطح الارض. والشكل التالي يوضح القاعدة التي تتحكم في المروحة الرئيسية.
مخطط للأجزاء الرئيسية في طائرة الأباتشي
صورة لطائرة اباتشي وقد تم تفكييك المروحة لتسهل عملية نقلها
وبهذا يمكننا القول ان طائرة الأباتشي هي عبارة عن طائرة هيليكوبتر ولكن مضاف إليها الكثير من الكماليات. والأن سوف ننتقل إلى نظام الاسلحة المتطور الذي نقل هذا الطائرة إلى مراتب متقدمة من الناحية التقنية.
طائرة الأباتشي AH-64A هي إحدى منتجات شركةبوينغ،تعتبر طائرة الهجوم الرئيسية للجيش الأمريكي. فهي عبارة عن سلاح محمولجوا، ذات ردود افعال سريعة، بحيث تستطيع أن تهاجم من مسافات قريبة أو فيالعمق، بحيث تكون قادرة على التدمير، و الإخلال بقوات العدو. تم تصميمالأباتشي بحيث تكون قادرة على العملليلا ونهارا، و بجميع الظروف المناخية. و تستعمل الأباتشي عدة انواع من الأسلحة وهي على النحو التالي:
صواريخ الجحيم HellFire
الهدف الرئيسي لطائرة الأباتشي في المعارك الحربية هو مهاجمة الدبابات والمدرعات، ولتحقيق ذلك فقد تم تزويدها بنظام اطلاق صواريخ متطورة جداً تسمى hellfire أو صواريخ الجحيم التي له القدرة على اختراق المدرعات وتدميرها. وكل صاروخ مزود بنظام كمبيتري خاص به للتحكم فيه وتوجيهه نحو الهدف.
صاروخ من نوع Hellfire اطلق من طائرة اباتشي في أحد التدريبات
نظام توجه صوواريخ hellfire
صممت هذه الصواريخ لتكون موجه بواسطة اشعة الليزر حيث يقوم الطيار المسؤول عن المدفعية باطلاق شعاع ليزر باتجاه الهدف على الارض على شكل نبضات متقطع تعني اشارة مشفرة.
صاروخ Hellfire وتظهر اجنحة التوجيه
وقبل اطلاق الصاروخ فإن الكمبيوتر يعطي هذه الاشارات للصاروخ ويخزنها في ذاكرة كمبيوتر الصاروخ ليتم الاستجابة لها فقط، ويقوم الصاروخ من خلال مجس ضوئي بتتبع الاشارات الضوئية المنعكسة من سقوط نبضات اليزر على الهدف ويعمل كمبيوتر الصاروخ بحساب المسافة بينه وبين الهدف وتحديد المسار الذي سيسلكه للوصول الى الهدف، وذلك من خلال التحكم في الاجنحة المثبتة على جانبي الصاروخ عند الذيل، وذلك حتى يضمن ان يكون اصطدام الصاروخ بالهدف اصطدام عمودي ليكون له تأثير مباشر وقوي.
صاروخ موجه بالليزر ينطلق في اتجاه الهدف
الصواريخ والمدفع الرشاش
بالاضافة الى صواريخ hellfire فإنه في بعض الاحيان يتم تثبيت صاروخين أخرين بدلاً من صاروخين من نوع hellfire ويسمى بصواريخ 2.75inch aerial وهذين الصاروخين يمكن اطلاقهم واحد تلو الأخر او اطلاق مجموعة من الصواريخ مرة واحدة حسب الغرض من ذلك.
على اليمين نشاهد قاذفة الصواريخ وبجانبه حاملة صواريخ Hellfire لطائرة اباتشي من طراز AH-64A
كما يمكن ان يكون رأس كل صاروخ يحتوي على مواد متفجرة وفي بعض الاحيان يكون داخل رأس الصاروخ مواد تعمل على اطلاق دخان كثيف بهدف التمويه والاختفاء، كما يمكن ان يثبت في الصاروخ صواريخ أخرى صغيرة الحجم تنفصل عن الصاروخ الرئيسي عندما تصل إلى هدفها.
وفي حالة قرب الطائرة من الهدف تصبح تلك الصواريخ عديمة الفائدة ولا جدوى من استخدامها فيعتمد الطيار المدفعي على مدفع رشاش اوتوماتيكي عيار 30mm مثبت اسفل الطائرة وفي مقدمتها، ويقوم الطيار المدفعي بتوجيه الرشاش في اتجاه الهدف باستخدام كمبيوتر متطور يتحكم في موقع الرشاش واتجاهة.
المدفع الرشاش اسفل مقدمة الطائرة من طراز اباتشي AH-64A
ويتحكم في الرشاش الاوتوماتيكي ماتور كهربائي خاص يعمل على تحريك سلسلة الرصاص حركة دائرية لتمرير حزام الرصاص الذي يحمل 1200 رصاصة وتسحب كل رصاصة من الحزام بواسطة ميكانيكية خاصة شبيه بالمدفع الرشاش لتضع الرصاصة في المكان المخصص لاطلاقها ويستطيع الرشاش الاوتوماتيكي من اطلاق اطلاق 600 إلى 650 رصاصة في الدقيقة الواحدة.
كابينة القادة وفيها القسم الأمامي للمدفعي والقسم الخلفي لقائد الطائرة ونلاحظ ان القسم الخلفى مرتفع عن القسم الأمامي لكي يتكن قائدة الطائرة من الرؤية بوضوح.
تشبه طريقة قيادة طائرة الاباتشي قيادة الهيليكوبتر والتي تم شرحها في مقال سابق وتعتمد قيادة الاباتشي على اجهزة التحكم التي تعمل على السيطرة والتحكم في محور دوران المروحة الرئيسية والجانبية وكذلك سرعة دورانهما، بواسطة اجزاء ميكانيكية هدروكلوركية مدعمة بنظام توازن رقمي ليعمل بواسطة كمبيوتر ليساعد القائد في الحفاظ على توازن الاباتشي خاصة عند اطلاق القذائف. كما يمكن ان يقوم الكمبيوتر بالتحكم الكامل في الطيران والتحليق.
داخل كابين القيادة في طائرة الاباتشي
طائرة اباتشي من طراز longbow ويظهر الرادار اعلى الطائرة
صورة توضح المجسات المختلفة لطائرة الاباتشي
كما ان الطيار او المدفعي يمكنه توجيه الكاميرا في اي اتجاه بمجرد تحريك رأسه للنظر إلى منطقة او مشهد اخر فتتحرك الكاميرا المثبته على الاباتشي بنفس الاتجاه لتنقل ما يريد المدفعي مشاهدته عبرها.
صورة للخوذة التي يرتديها المدفعي ولاحظ العدسة المثبتة على العين اليمنى
افضل وسيلة لطائرة الاباتشي للحماية هو ان تكون بعيدة عن مرمى النيران، هذا بالاضافة الى امكانية الاباتشي ان تطير بقرب سطح الارض والاختفاء خلف اي جسم على الارض كلما كان ذلك ممكناً، كما انها مصممة للتخفي عن نظام رادار القوات المعادية باستخدام نظام تشويه يعمل على اخفاء وخداع راردار العدو فلا يمكن رصدها عبر الرادار.
وفي النهاية فإن طائرة الاباتشي طائرة خطيرة جدا في المعارك بكل معنى الكلمة فهي طائرة تجمع القوة والشدة وسرعة الحركة.
التعديل الأخير تم بواسطة الطارق سفيان ; 07-06-2007 الساعة 01:09 AM.
رد مع اقتباس
  #28 (permalink)
قديم 17-07-2007, 05:18 PM
salehwafi يستحق التميز
شكرا جزيلا معلومات جيدة
رد مع اقتباس
  #29 (permalink)
قديم 19-07-2007, 02:08 PM
زائر
كاظم عسكر يستحق التميز
افدتني كثيرا
شكرا والف شكر ------ لقد استفدت من هذة المعلومات---- وكنت شغوفا بان اعرفها0
ولي سؤال من فضلك :_
كيف السبيل للحصول على تفاصيل فنية دقيقة حول هذا الموظوع --مثل اطوال الشفرا بالنسبه لحجم الجهاز وقدرة المحرك الحصانية واعلى سرع الدوران وابطأها ------ الى اخره0
اشكرك جدا جدا
رد مع اقتباس
  #30 (permalink)
قديم 19-07-2007, 08:50 PM
مدحت58 يستحق التميز
مشكور يا كامل
مشكور اخ كامل
معلومات مفيدة و ببساطة وضحت الفكرة الرئيسية لعمل هذا النوع من الطائرات
شكرا جزيلا
رد مع اقتباس
مواقع النشر (المفضلة)
الساعة الآن 04:18 AM.
