Design a CS-CD MOSFET voltage amplifier with the following specification:
- Small signal gain >30.
- Input resistance Ri > 100kΩ.
- Output resistance Ro < 4 kΩ.
- Verify the computed nodal voltages, currents (for small signal & DC) and gain of the designed amplifier with the results obtained form the related PSPICE program.
* Use N-channel MOSFET 2N4351 (Vt = 1.5V, K'n = 0.05mA/V2, W=30µm and L = 3µm).
* Load resistance RL= 5kΩ.
* Single supply voltage of VCC= 6 V.
* Input voltage (vi) and the internal resistance RS
vi =0.01 sin(ωt) and RS = 500Ω.
* Check for Saturation region.
* What is the maximum allowed input voltage with no distortion or clipping at the output voltage.
(Use transient analysis to verify your hand calculation)
ارجو المساعده لو سمحتو في حل هذا السؤال
