دورة إدارة المشاريع الاحترافية PMP
آخر المواضيع الجديدة
النتائج 1 إلى 6 من 6
Tig Welding
TigWelding Tungsten inert gas (TIG) welding became an overnight success in the 1940s for joining magnesium and aluminium. Using an
  1. #1
    عضو فعال الصورة الرمزية م0بشار الكربولي
    تاريخ التسجيل
    Feb 2010
    صفحة الملتقى الرسمية على الفيس بوك .. مجموعة المهندسين العرب .. follow us on twitter...
    Tig Welding
    TigWelding
    Tungsten inert gas (TIG) welding became an overnight success in the 1940s for joining magnesium and aluminium. Using an inert gas shield instead of a slag to protect the weldpool, the process was a highly attractive replacement for gas and manual metal arc welding. TIG has played a major role in the acceptance of aluminium for high quality welding and structural applications.
    Process characteristics
    In the TIG process the arc is formed between a pointed tungsten electrode and the workpiece in an inert atmosphere of argon or helium. The small intense arc provided by the pointed electrode is ideal for high quality and precision welding. Because the electrode is not consumed during welding, the welder does not have to balance the heat input from the arc as the metal is deposited from the melting electrode. When filler metal is required, it must be added separately to the weldpool.
    Power source
    TIG must be operated with a drooping, constant current power source - either DC or AC. A constant current power source is essential to avoid excessively high currents being drawn when the electrode is short-circuited on to the workpiece surface. This could happen either deliberately during arc starting or inadvertently during welding. If, as in MIG welding, a flat characteristic power source is used, any contact with the workpiece surface would damage the electrode tip or fuse the electrode to the workpiece surface. In DC, because arc heat is distributed approximately one-third at the cathode (negative) and two-thirds at the anode (positive), the electrode is always negative polarity to prevent overheating and melting. However, the alternative power source connection of DC electrode positive polarity has the advantage in that when the cathode is on the workpiece, the surface is cleaned of oxide contamination. For this reason, AC is used when welding materials with a tenacious surface oxide film, such as aluminium.
    Arc starting
    The welding arc can be started by scratching the surface, forming a short-circuit. It is only when the short-circuit is broken that the main welding current will flow. However, there is a risk that the electrode may stick to the surface and cause a tungsten inclusion in the weld. This risk can be minimised using the 'lift arc' technique where the short-circuit is formed at a very low current level. The most common way of starting the TIG arc is to use HF (High Frequency). HF consists of high voltage sparks of several thousand volts which last for a few microseconds. The HF sparks will cause the electrode - workpiece gap to break down or ionise. Once an electron/ion cloud is formed, current can flow from the power source.
    Note: As HF generates abnormally high electromagnetic emission (EM), welders should be aware that its use can cause interference especially in electronic equipment. As EM emission can be airborne, like radio waves, or transmitted along power cables, care must be taken to avoid interference with control systems and instruments in the vicinity of welding.
    HF is also important in stabilising the AC arc; in AC, electrode polarity is reversed at a frequency of about 50 times per second, causing the arc to be extinguished at each polarity change. To ensure that the arc is reignited at each reversal of polarity, HF sparks are generated across the electrode/workpiece gap to coincide with the beginning of each half-cycle.
    Electrodes
    Electrodes for DC welding are normally pure tungsten with 1 to 4% thoria to improve arc ignition. Alternative additives are lanthanum oxide and cerium oxide which are claimed to give superior performance (arc starting and lower electrode consumption). It is important to select the correct electrode diameter and tip angle for the level of welding current. As a rule, the lower the current the smaller the electrode diameter and tip angle. In AC welding, as the electrode will be operating at a much higher temperature, tungsten with a zirconia addition is used to reduce electrode erosion. It should be noted that because of the large amount of heat generated at the electrode, it is difficult to maintain a pointed tip and the end of the electrode assumes a spherical or 'ball' profile.
    Shielding gas
    Shielding gas is selected according to the material being welded. The following guidelines may help:
    • Argon - the most commonly-used shielding gas which can be used for welding a wide range of materials including steels, stainless steel, aluminium and titanium.
    • Argon + 2 to 5% H2 - the addition of hydrogen to argon will make the gas slightly reducing, assisting the production of cleaner-looking welds without surface oxidation. As the arc is hotter and more constricted, it permits higher welding speeds. Disadvantages include risk of hydrogen cracking in carbon steels and weld metal porosity in aluminium alloys.
    • Helium and helium/argon mixtures - adding helium to argon will raise the temperature of the arc. This promotes higher welding speeds and deeper weld penetration. Disadvantages of using helium or a helium/argon mixture is the high cost of gas and difficulty in starting the arc.
    Applications
    TIG is applied in all industrial sectors but is especially suitable for high quality welding. In manual welding, the relatively small arc is ideal for thin sheet material or controlled penetration (in the root run of pipe welds). Because deposition rate can be quite low (using a separate filler rod) MMA or MIG may be preferable for thicker material and for fill passes in thick-wall pipe welds.
    TIG is also widely applied in mechanised systems either autogenously or with filler wire. However, several 'off the shelf' systems are available for orbital welding of pipes, used in the manufacture of chemical plant or boilers. The systems require no manipulative skill, but the operator must be well trained. Because the welder has less control over arc and weldpool behaviour, careful attention must be paid to edge preparation (machined rather than hand-prepared), joint fit-up and control of welding parameters.
    For further information contact
    لاتنسونا من خالص الدعاء .
    من مواضيع م0بشار الكربولي :
  2. #2
    العاني2 Don't Avatar
    تاريخ التسجيل
    Feb 2010
    تحيه طيبه
    ما يهمني هو ماكنة لحام اوتوماتيكيه لغرض لحام خزانات الماء التي توزع الماء على شبكة مياه المدينه مع خالص الشكر
  3. #3
    عضو الصورة الرمزية familymempire
    تاريخ التسجيل
    Oct 2006
    thanks alot for thsee good information
    but i am just agraduated engineer and work in welding field 4 months but i want to know in manual arc welding i mean welding with carbon rods or cabon electrods i want to know
    what does the number of electrode represents such 7080 ?
    when i need to high voltage or reduce it?
    how to choice suitable electrode ?if u have tables plz upload them ?
    من مواضيع familymempire :
  4. #4
    تاريخ التسجيل
    Feb 2010
    الاخ العاني تحية طيبة , ان من مكائن اللحام الاوتماتيكية المتوفرة حاليا هي مكائن لحام mig او mag والمستخدمة في مثل هذا النوع من الامور وهي مكائن لشركة (ESAB)
  5. #5
    عضو متميز الصورة الرمزية مصطفى ريان
    تاريخ التسجيل
    Nov 2008
    انت ممتاز اخ بشار ولى الاخة استكمال لما طرحه مهندس بشار اعطى المزيد من الكتب
    http://www.link512.com/search.php?search=Tig+Welding&button=Search+for+DO Cs
    من مواضيع مصطفى ريان :
  6. #6
    تاريخ التسجيل
    Feb 2010
    مشكور اخ مصطفى على مرورك وشكرا على الاضافة
المواضيع المتشابهه
  1. Welding
    بواسطة كرم الحمداني في المنتدى هندسة التبريد و التكييف
    مشاركات: 6
    آخر مشاركة: 04-04-2013, 09:28 PM
  2. استفسار مهم .. ما الفرق بين welding ispector و welding engineer ؟
    بواسطة انفينتي في المنتدى هندسة الإنتاج
    مشاركات: 8
    آخر مشاركة: 22-09-2011, 06:49 AM
  3. كتب Welding
    بواسطة enmfg في المنتدى هندسة الإنتاج
    مشاركات: 12
    آخر مشاركة: 15-08-2010, 08:57 PM
  4. welding of stainless steel by different welding processes
    بواسطة سامح 2010 في المنتدى هندسة الفلزات والمواد
    مشاركات: 12
    آخر مشاركة: 12-01-2010, 08:17 PM
  5. كتب Welding
    بواسطة enmfg في المنتدى هندسة الفلزات والمواد
    مشاركات: 15
    آخر مشاركة: 10-08-2008, 10:28 PM
ضوابط المشاركة
  • لا تستطيع إضافة مواضيع جديدة
  • لا تستطيع الرد على المواضيع
  • لا تستطيع إرفاق ملفات
  • لا تستطيع تعديل مشاركاتك
عن ملتقى المهندسين العرب
    يُعتبر ملتقى المهندسين العرب من أوائل وأكبر المواقع الهندسية حيث تم تأسيسه منذ عام 2001م ويهدف إلى نشر المعرفة الهندسية وتقديم كل ما له فائدة للمهندسين والمهتمين من خلال أقسامة العلمية والهندسية المتعددة بالإضافة إلى وجود أقسام عامة تستقطب الكثير لمختلف النقاشات الهادفة.
مواقع صديقة
تابعنا على
Twitter Facebook
The owner and operator of the site is not responsible for the availability of, or any content provided.
Topics that are written in the site reflect the opinion of the author.
Search Engine Optimization by vBSEO
