دورة إدارة المشاريع الاحترافية PMP
آخر المواضيع الجديدة
النتائج 1 إلى 7 من 7
Field Reference Manual: Standard Specifications for Structural Concrete ACI 301-05
السلام عليكم ورحمة الله وبركات ه Field Reference Manual: Standard Specifications for Structural Concrete ACI 301-05 An essential reference document,
  1. #1
    سنا الإسلام Don't Avatar
    تاريخ التسجيل
    Jun 2008
    صفحة الملتقى الرسمية على الفيس بوك .. مجموعة المهندسين العرب .. follow us on twitter...
    An essential reference document, SP-15(05): Field Reference Manual contains ACI 301-05 Specifications for Structural Concrete in its entirety, along with 18 related ACI committee documents, including Chapter 3 through 7 of ACI 318-05 Building Code Requirements for Structural Concrete. Included in SP-15(05) are: ACI 117/117R-90 Standard Specifications for Tolerances for Concrete Construction and Materials and Commentary; ACI 302.1R-04 Guide for Concrete Floor and Slab Construction; ACI 305R-99 Hot Weather Concreting; ACI 306R-88 Cold Weather Concreting; ACI 308R-01 Guide to Curing Concrete; ACI
    SP15(05): Field Reference Manual: Standard Specifications for Structural Concrete ACI 301-05 with Selected ACI References - Table of *******s:
    * ACI 301-05 Specifications for Structural Concrete
    * ACI 116R-00 Cement and Concrete Terminology
    * ACI 117/117R-90 Standard Specifications for Tolerances for Concrete Construction and Materials and Commentary
    * ACI 212.3R-04 Chemical Admixtures for Concrete
    * ACI 213R-03 Guide For Structural Lightweight-Aggregate Concrete
    * ACI 214R-02 Evaluation of Strength Test Results of Concrete
    * ACI 214.4R-03 Guide for Obtaining Cores and Interpreting Compressive Strength Results
    * ACI 224.1R-93 (Reapproved 1998) Causes, Evaluation and Repair of Cracks in Concrete Structures
    * ACI 229R-99 (Reapproved 2005) Controlled Low-Strength Materials
    * ACI 302.1R-04 Guide for Concrete Floor and Slab Construction
    * ACI 303R-04 Guide to Cast-in-Place Architectural Concrete Practice
    * ACI 403R-00 Guide for Measuring, Mixing, Transporting, and Placing Concrete
    * ACI 305R-99 Hot Weather Concreting
    * ACI 306R-88 (Reapproved 2002) Cold Weather Concreting
    * ACI 308R-01 Guide to Curing Concrete
    * ACI 309R-96 Guide for Consolidation of Concrete
    * ACI 318-05 Building Code Requirements for Structural Concrete (Chapters 3-7)
    * ACI 347-04 Guide to Formwork for Concrete
    * ACI 533.1R-02 Design Responsibility for Architectural Precast-Concrete Projects
    347-04 Guide to Formwork for Concrete, and 11 other documents. 660 pp.
    Download links
    http://www.4shared.com/file/11214197...NUALpart1.html
    http://www.4shared.com/file/11214222...NUALpart2.html
    http://www.4shared.com/file/11214249...NUALpart3.html
    http://www.4shared.com/file/11214279...NUALpart4.html
    http://www.4shared.com/file/11214156...NUALpart5.html
    الروابط منقولة
    من مواضيع سنا الإسلام :
    التعديل الأخير تم بواسطة سنا الإسلام ; 16-02-2010 الساعة 04:36 AM
  2. #2
    عضو متميز جداً الصورة الرمزية د.محبس
    تاريخ التسجيل
    Oct 2009
    احب ان اشاركك بهذه المواقع:
    ACI Manual of Concrete Practice
    ACI's Manual of Concrete Practice (MCP) is the most comprehensive concrete reference set available. It contains all of the widely used ACI concrete and masonry code requirements, specifications, guides and reports. Whether you're searching for information about code requirements, deflection, cracking, durability problems, temperature control, nondestructive testing, or hundreds of other topic areas, the MCP can help you find what you need.
    Password ( ACIManual5 )
    Links:
    CODE --> | DOCUMENT
    TOC --> Table of *******s
    http://rapidshare.com/files/285845760/MC5-00TOC.rar
    104-71 --> Preparation of Notation for Concrete
    116R-00 --> Cement and Concrete Terminology
    117-90 --> Standard Specifications for Tolerances for Concrete Construction and Materials
    117R-90 --> Commentary on Standard Specifications for Tolerances for Concrete Construction and Materials
    121R-04 --> Quality Management System for Concrete Construction
    122R-02 --> Guide to Thermal Properties of Concrete and Masonry Systems
    124.2R-94 --> The Mercer Mile Buildings
    126.3R-99 --> Guide to a Recommended Format for Concrete in a Materials Property Database
    http://rapidshare.com/files/285846867/MC5-01.rar
    201.1R-92 --> Guide for Making a Condition Survey of Concrete in Service
    201.2R-01 --> Guide to Durable Concrete
    http://rapidshare.com/files/285848743/MC5-02.rar
    207.1 R-96 --> Mass Concrete
    207.2R-95 --> Effect of Restraint, Volume Change, and Reinforcement on Cracking of Mass Concrete
    207.3R-94 --> Practices for Evaluation of Concrete in Existing Massive Structures for Service Conditions
    207.4R-93 --> Cooling and Insulating Systems for Mass Concrete
    207.5R-99 --> Roller Compacted Mass Concrete
    209R-92 --> Prediction of Creep, Shrinkage, and Temperature Effects in Concrete Structures
    210R-93 --> Erosion of Concrete in Hydraulic Structures
    210.1 R-94 --> Compendium of Case Histories on Repair of Erosion-Damaged Concrete in Hydraulic Structures
    http://rapidshare.com/files/285851390/MC5-03.rar
    211.1-91 --> Standard Practice for Selecting Proportions for Normal, Heavyweight, and Mass Concrete
    211.2-98 --> Standard Practice for Selecting Proportions for Structural Lightweight Concrete
    211.3R-02 --> Guide for Selecting Proportions for No-Slump Concrete
    211.4R-93 --> Guide for Selecting Proportions for High-Strength Concrete with Portland Cement and Fly Ash
    211.5R-01 --> Guide for Submittal of Concrete Proportions
    212.3R-04 --> Chemical Admixtures for Concrete
    212.4R-04 --> Guide for the Use of High-Range Water-Reducing Admixtures (Superplasticizers) in Concrete
    213R-03 --> Guide for Structural Lightweight Aggregate Concrete
    214R-02 --> Evaluation of Strength Test Results of Concrete
    214.4R-03 --> Guide for Obtaining Cores and Interpreting Compressive Strength Results
    http://rapidshare.com/files/285852474/MC5-04.rar
    215R-74 --> Considerations for Design of Concrete Structures Subjected to Fatigue Loading
    http://rapidshare.com/files/285854643/MC5-05.rar
    216R-89 --> Guide for Determining Fire Endurance of Concrete Elements
    216.1-97 --> Standard Method for Determining the Fire Resistance of Concrete and Masonry Construction Assemblies
    221R-96 --> Guide for Use of Normal Weight and Heavyweight Aggregates in Concrete
    221.1R-98 --> State-of-the-Art Report on Alkali-Aggregate Reactivity
    http://rapidshare.com/files/285856096/MC5-06.rar
    222R-01 --> Protection of Metals in Concrete Against Corrosion
    222.1-96 --> Prov Stand Test Meth for Water-Soluble Chloride Avail for Corr of Embedded Steel in Mortar & Cone Using the Soxhlet
    222.2R-01 --> Corrosion of Prestressing Steels
    222.3R-03 --> Design and Construction Practices to Mitigate Corrosion of Reinforcement in Concrete Structures
    223-98 --> Standard Practice for the Use of Shrinkage-Compensating Concrete
    224R-01 --> Control of Cracking in Concrete Structures
    224.1 R-93 --> Causes, Evaluation, and Repair of Cracks in Concrete Structures
    224.2R-92 --> Cracking of Concrete Members in Direct Tension
    224.3R-95 --> Joints in Concrete Construction
    225R-99 --> Guide to the Selection and Use of Hydraulic Cements
    http://rapidshare.com/files/285857271/MC5-07.rar
    228.1 R-03 --> In-Place Methods to Estimate Concrete Strength
    228.2R-98 --> Nondestructive Test Methods for Evaluation of Concrete in Structures
    229R-99 --> Controlled Low-Strength Materials
    http://rapidshare.com/files/285859139/MC5-08.rar
    230.1 R-90 --> State-of-the-Art Report on Soil Cement
    232.1 R-00 --> Use of Raw or Processed Natural Pozzolans in Concrete
    232.2R-03 --> Use of Fly Ash in Concrete
    233R-03 --> Slag Cement in Concrete and Mortar
    http://rapidshare.com/files/285861285/MC5-09.rar
    234R-96 --> Guide for the Use of Silica Fume in Concrete
    http://rapidshare.com/files/285863978/MC5-10.rar
    301-99 --> Specifications for Structural Concrete
    301M-99 --> Specifications for Structural Concrete
    SP-15(99) --> Field Reference Manual
    302.1 R-04 --> Guide for Concrete Floor and Slab Construction
    303R-04 --> Guide to Cast-in-Place Architectural Concrete Practice
    303.1-97 --> Standard Specification for Cast-in-Place Architectural Concrete
    304R-00 --> Guide for Measuring, Mixing, Transporting, and Placing Concrete
    304.1 R-92 --> Guide for the Use of Preplaced Aggregate Concrete for Structural and Mass Concrete Applications
    304.2R-96 --> Placing Concrete by Pumping Methods
    304.3R-96 --> Heavyweight Concrete: Measuring, Mixing, Transporting, and Placing
    304.5R-91 --> Batching, Mixing, and Job Control of Lightweight Concrete
    304.6R-91 --> Guide for the Use of Volumetric-Measuring and Continuous-Mixing Concrete Equipment
    305R-99 --> Hot Weather Concreting
    306R-88 --> Cold Weather Concreting
    306.1-90 --> Standard Specification for Cold Weather Concreting
    307-98 --> Design and Construction of Reinforced Concrete Chimneys
    307R-98 --> Commentary on Design and Construction of Reinforced Concrete Chimneys
    308R-01 --> Guide to Curing Concrete
    308.1-98 --> Standard Specification for Curing Concrete
    http://rapidshare.com/files/285865413/MC5-11.rar
    309R-96 --> Guide for Consolidation of Concrete
    309.1 R-93 --> Behavior of Fresh Concrete During Vibration
    309.2R-98 --> Identification and Control of Visible Effects of Consolidation on Formed Concrete Surfaces
    309.3R-92 --> Guide to Consolidation of Concrete in Congested Areas
    309.5R-00 --> Compaction of Roller-Compacted Concrete
    http://rapidshare.com/files/285867606/MC5-12.rar
    311.1R-99 --> ACI Manual of Concrete Inspection
    311.4R-00 --> Guide for Concrete Inspection
    311.5-04 --> Guide for Concrete Plant Inspection and Testing of Ready-Mixed Concrete
    313-97 --> Standard Practice for Design and Construction of Concrete Silos and Stacking Tubes for Storing Granular Materials
    313R-97 --> Comm on Standard Practice for Design and Construction of Concrete Silos and Stacking Tubes for Storing Granular Matls
    315-99 --> Details and Detailing of Concrete Reinforcement
    SP-66(04) --> ACI Detailing Manual
    318-05/318R-05 --> Building Code Requirements for Structural Concrete and Commentary
    http://rapidshare.com/files/285869233/MC5-13.rar
    318M-02 /318RM-02 Building Code Requirements for Structural Concrete and Commentary (metric)
    SP-71(02) --> ASTM Standards in ACI 318
    http://rapidshare.com/files/291356132/MC5-14.rar
    325.3R-85 --> Guide for Design of Foundations and Shoulders for Concrete Pavements
    325.6R-88 --> Texturing Concrete Pavements
    325.10R-95 --> State-of-the-Art Report on Roller-Compacted Concrete Pavements
    325.11R-01 --> Accelerated Techniques for Concrete Paving
    325.12R-02 --> Guide for Design of Jointed Concrete Pavements for Streets and Local Roads
    http://rapidshare.com/files/296630764/MC5-15.rar
    330R-01 --> Guide for Design and Construction of Concrete Parking Lots
    330.1-03 --> Specification for Unreinforced Concrete Parking Lots
    332R-84 --> Guide to Residential Cast-in-Place Concrete Construction
    334.1 R-92 --> Concrete Shell Structures Practice and Commentary
    336.1-01 --> Specification for the Construction of Drilled Piers
    336.2R-88 --> Suggested Analysis and Design Procedures for Combined Footings and Mats
    336.3R-93 --> Design and Construction of Drilled Piers
    341.2R-97 --> Seismic Analysis and Design of Concrete Bridge Systems
    343R-95 --> Analysis and Design of Reinforced Concrete Bridge Structures
    http://rapidshare.com/files/296633869/MC5-16.rar
    345R-91 --> Guide for Concrete Highway Bridge Deck Construction
    345.1 R-92 --> Routine Maintenance of Concrete Bridges
    345.2R-98 --> Guide for Widening Highway Bridges
    http://rapidshare.com/files/296636898/MC5-17.rar
    346-01 --> Specifications for Cast-in-Place Concrete Pipe
    347-04 --> Guide to Formwork for Concrete
    SP-4(95) --> Formwork for Concrete
    349-01/349R-01 --> Code Requirements for Nuclear Safety Related Concrete Structures and Commentary
    349.1 R-91 --> Reinforced Concrete Design for Thermal Effects on Nuclear Power Plant Structures
    349.2R-97 --> Embedment Design Examples
    349.3R-02 --> Evaluation of Existing Nuclear Safety-Related Concrete Structures
    http://rapidshare.com/files/296637894/MC5-18.rar
    350-01/350R-01 --> Code Requirements for Environmental Engineering Concrete Structures and Commentary
    350.1/350.1 R-01 --> Tightness Testing of Environmental Engineering Concrete Structures and Commentary
    350.2R-04 --> Concrete Structures for Containment of Hazardous Materials
    350.3/350.3R-01 --> Seismic Design Guide for Liquid-Containing Concrete Structures and Commentary
    350.4R-04 --> Design Considerations for Environmental Engineering Concrete Structures
    351.1R-99 --> Grouting between Foundations and Bases for Support of Equipment and Machinery
    351.2R-94 --> Foundations for Static Equipment
    351.3R-04 --> Foundations for Dynamic Equipment
    http://rapidshare.com/files/296639490/MC5-19.rar
    352R-02 --> Recommendations for Design of Beam-Column Joints in Monolithic Reinforced Concrete Structures
    352.1 R-89 --> Recommendations for Design of Slab-Column Connections in Monolithic Reinforced Concrete Structure
    355.2-04/355.2R-04 Evaluating the Performance of Post-Installed Mechanical Anchors in Concrete and Commentary
    357R-84 --> Guide for the Design and Construction of Fixed Offshore Concrete Structures
    357.2R-88 --> State-of-the-Art Report on Barge-Like Concrete Structures
    http://rapidshare.com/files/296640853/MC5-20.rar
    358.1 R-92 --> Analysis and Design of Reinforced and Prestressed-Concrete Guideway Structures
    359-01 --> Code for Concrete Containments
    360R-92 --> Design of Slabs on Grade
    362.1 R-97 --> Guide for the Design of Durable Parking Structures
    362.2R-00 --> Guide for Structural Maintenance of Parking Structures
    http://rapidshare.com/files/302482491/MC5-21.rar
    363R-92 --> State-of-the-Art Report on High-Strength Concrete
    363.2R-98 --> Guide to Quality Control and Testing of High-Strength Concrete
    364.1 R-94 --> Guide for Evaluation of Concrete Structures Prior to Rehabilitation
    365.1 R-00 --> Service-Life Prediction—State-of-the-Art Report
    371R-98 --> Guide for the Analysis, Design, and Construction of Concrete-Pedestal Water Towers
    372R-03 --> Design and Construction of Circular Wire- and Strand-Wrapped Prestressed Concrete Structures
    373R-97 --> Design and Construction of Circular Prestressed Concrete Structures with Circumferential Tendons
    http://rapidshare.com/files/302484578/MC5-22.rar
    408R-03 --> Bond and Development of Straight Reinforcing Bars in Tension
    408.2R-92 --> State-of-the-Art Report: Bond under Cyclic Loads
    408.3-01/408.3R-01 Splice and Development Length of High Relative Rib Area Reinforcing Bars in Tension and Commentary
    421.1R-99 --> Shear Reinforcement for Slabs
    423.3R-96 --> Recommendations for Concrete Members Prestressed with Unbonded Tendons
    423.4R-98 --> Corrosion and Repair of Unbonded Single Strand Tendons
    423.5R-99 --> State-of-the-Art Report on Partially Prestressed Concrete
    423.6-01/423.6R-01 Specification for Unbonded Single Strand Tendons and Commentary
    435R-95 --> Control of Deflection in Concrete Structures
    435.7R-85 --> State-of-the-Art Report on Temperature-Induced Deflections of Reinforced Concrete Members
    435.8R-85 --> Observed Deflections of Reinforced Concrete Slab Systems, and Causes of Large Deflections
    437R-03 --> Strength Evaluation of Existing Concrete Buildings
    439.3R-91 --> Mechanical Connections of Reinforcing Bars
    http://rapidshare.com/files/302487870/MC5-23.rar
    440R-96 --> State-of-the-Art Report on Fiber Reinforced Plastic (FRP) Reinforcement for Concrete Structures
    http://rapidshare.com/files/302492482/MC5-24.rar
    440.1 R-03 --> Guide for the Design and Construction of Concrete Reinforced with FRP Bars
    440.2R-02 --> Guide for the Design and Construction of Externally Bonded FRP Systems for Strengthening Concrete Structures
    440.3R-04 --> Guide Test Methods for Fiber-Reinforced Polymers (FRP) for Reinforcing or Strengthening Concrete Structures
    440.4R-04 --> Prestressing Concrete Structures with FRP Tendons
    441R-96 --> High-Strength Concrete Columns: State of the Art
    445R-99 --> Recent Approaches to Shear Design of Structural Concrete
    446.1 R-91 --> Fracture Mechanics of Concrete: Concepts, Models, and Determination of Material Properties
    446.3R-97 --> Finite Element Analysis of Fracture in Concrete Structures: State-of-the-Art
    446.4R-04 --> State of the Art Report on Dynamic Fracture of Concrete
    http://rapidshare.com/files/302495217/MC5-25.rar
    503R-93 --> Use of Epoxy Compounds with Concrete
    503.1-92 --> Stand Spec for Bonding Hardened Cone, Steel, Wood, Brick, & Other Matls to Hardened Cone w/ a Multi-Comp Epoxy Adhes
    503.2-92 --> Stand Spec for Bonding Plastic Cone to Hardened Cone w/ a Multi-Component Epoxy Adhesive
    503.3-92 --> Stand Spec for Producing a Skid-Resistant Surface on Cone by the Use of a Multi-Component Epoxy System
    503.4-92 --> Standard Specification for Repairing Concrete with Epoxy Mortars
    503.5R-92 --> Guide for the Selection of Polymer Adhesives with Concrete
    503.6R-97 --> Guide for the Application of Epoxy and Latex Adhesives for Bonding Freshly Mixed and Hardened Concretes
    504R-90 --> Guide to Sealing Joints in Concrete Structures
    506R-90 --> Guide to Shotcrete
    506.1 R-98 --> Committee Report on Fiber Reinforced Shotcrete
    http://rapidshare.com/files/302500178/MC5-26.rar
    506.2-95 --> Specification for Shotcrete
    506.3R-91 --> Guide to Certification of Shotcrete Nozzlemen
    506.4R-94 --> Guide for the Evaluation of Shotcrete
    http://rapidshare.com/files/302504336/MC5-27.rar
    523.2R-96 --> Guide for Precast Cellular Concrete Floor, Roof, and Wall Units
    524R-04 --> Guide to Portland Cement-Based Plaster
    530-05/530R-05 --> Building Code Requirements for Masonry Structures and Commentary
    530.1-05/530.1 R-05 Specification for Masonry Structures and Commentary
    533R-93 --> Guide for Precast Concrete Wall Panels
    533.1 R-02 --> Design Responsibility for Architectural Precast-Concrete Projects
    http://rapidshare.com/files/302506267/MC5-28.rar
    543R-00 --> Design, Manufacture, and Installation of Concrete Piles
    544.1 R-96 --> State-of-the-Art Report on Fiber Reinforced Concrete
    544.2R-89 --> Measurement of Properties of Fiber Reinforced Concrete
    544.3R-93 --> Guide for Specifying, Proportioning, Mixing, Placing, and Finishing Steel Fiber Reinforced Concre
    544.4R-88 --> Design Considerations for Steel Fiber Reinforced Concrete
    546R-04 --> Concrete Repair Guide
    546.2R-98 --> Guide to Underwater Repair of Concrete
    548.1 R-97 --> Guide for the Use of Polymers in Concrete
    548.2R-93 --> Guide for Mixing and Placing Sulfur Concrete in Construction
    548.3R-03 --> Polymer Modified Concrete
    548.4-93 --> Standard Specification for Latex-Modified Concrete (LMC) Overlays
    548.5R-94 --> Guide for Polymer Concrete Overlays
    548.7R-04 --> Provisional Test Method for Load Capacity of Polymer Concrete Underground Utility Structures
    http://rapidshare.com/files/302508477/MC5-29.rar
    549.1 R-93 --> Guide for the Design, Construction, and Repair of Ferrocement
    549.2R-04 --> Thin Reinforced Cement Pro ducts: State-of-the-Art
    550R-96 --> Design Recommendations for Precast Concrete Structures
    550.1 R-01 --> Emulating Cast-in-Place Design in Precast Concrete Structures
    551R-92 --> Tilt-Up Concrete Structures
    555R-01 --> Removal and Reuse of Hardened Concrete
    ITG-3-04 --> Report on Bridge Decks Free of Steel Reinforcement
    T1.1-01/T1.1R-01 --> Acceptance Criteria for Moment Frames Based on Structural Testing and Commentary
    T1.2-03/T1.2R-03 --> Special Hybrid Moment Frames Composed of Discretely Jointed Precast and Post-Tensioned Concrete Members and Commentary
    http://rapidshare.com/files/296628119/MC5-30.rar
    ACI Manual of Concrete Practice 2005 - Table of *******s
    ACI Manual of Concrete Practice 2005 - Help
    [Aditional CD-ROM files]
    http://rapidshare.com/files/285845719/MC5-00.rar
    من مواضيع د.محبس :
    التعديل الأخير تم بواسطة د.محبس ; 23-02-2010 الساعة 06:03 AM
  3. #3
    yousry_abuzaid Don't Avatar
    تاريخ التسجيل
    Jul 2010
    الروابط في مشاركة د. محبس معظمها تعطي رساله أن الملفات مخالفه لحقوق النشر
    فهل يتكرم أحد مشكورا باعادة رفعها أو رفع ما هو أحدث منها
    من مواضيع yousry_abuzaid :
    التعديل الأخير تم بواسطة yousry_abuzaid ; 16-08-2010 الساعة 08:25 PM
  4. #4
  5. #5
    عامرمحمد Don't Avatar
    تاريخ التسجيل
    Jun 2007
    اخي الكريم متاج هذا الملف على رابط اخر و شكرا جزيلا مسبقا
    من مواضيع عامرمحمد :
  6. #6
  7. #7
    رورا عمر Don't Avatar
    تاريخ التسجيل
    Dec 2010
    لو سمحت اريد معلومات عن غبار السيليكا وكيفية الحصول عليها واسعارها
    nr900
    nr920
    nr 950
    nr970
    من مواضيع Jamal :
المواضيع المتشابهه
  1. Arab Standard Specifications
    بواسطة احمد خورما في المنتدى مكتبة الهندسة الكهربائية والإلكترونية Electrical & Electronics Engineering
    مشاركات: 0
    آخر مشاركة: 21-11-2011, 01:51 PM
  2. كتاب في التفاصيل الانشائية للبيتون Standard method of detailing structural concrete
    بواسطة anass81 في المنتدى مكتبة الهندسة المدنية والمعمارية والمساحة Architecture & Civil Engineering
    مشاركات: 10
    آخر مشاركة: 23-07-2011, 11:16 PM
  3. standard method of detailing structural concrete
    بواسطة م.تسنيم في المنتدى الهندسة المـدنيـة - عام
    مشاركات: 11
    آخر مشاركة: 20-03-2010, 09:21 AM
  4. Standard Specifications for Highway Bridges, 16th Edition
    بواسطة أهل الحديث في المنتدى الهندسة المـدنيـة - عام
    مشاركات: 5
    آخر مشاركة: 13-08-2007, 07:35 PM
ضوابط المشاركة
  • لا تستطيع إضافة مواضيع جديدة
  • لا تستطيع الرد على المواضيع
  • لا تستطيع إرفاق ملفات
  • لا تستطيع تعديل مشاركاتك
عن ملتقى المهندسين العرب
    يُعتبر ملتقى المهندسين العرب من أوائل وأكبر المواقع الهندسية حيث تم تأسيسه منذ عام 2001م ويهدف إلى نشر المعرفة الهندسية وتقديم كل ما له فائدة للمهندسين والمهتمين من خلال أقسامة العلمية والهندسية المتعددة بالإضافة إلى وجود أقسام عامة تستقطب الكثير لمختلف النقاشات الهادفة.
مواقع صديقة
تابعنا على
Twitter Facebook
The owner and operator of the site is not responsible for the availability of, or any content provided.
Topics that are written in the site reflect the opinion of the author.
Search Engine Optimization by vBSEO
