العودة   ملتقى المهندسين العرب - أول ملتقى هندسي عربي > الهندسة الميكانيكية > هندسة الميكاترونكس > برنامج الـ Matlab
plot inside loop!!!
قديم 07-02-2010, 09:33 PM
الصورة الرمزية beho86
Unhappy plot inside loop!!!
Hey guys,
I have a question: problem statement is:
Use Euler's method, and assume a cooling constant r = 0.2 , initial temperature of 86 C, and room temperature at 17 C. Choose your time
step h judiciously and integrate to 5 minutes.
You can add some cream which will drop the temperature instantly by 5 C.
(a) Now, add the cream at the beginning. Plot your results. What is the temperature after 5 min?
(b) Add the cream at the end. Plot the results (preferably on the same figure). What is the temperature at the end?
r=0.2;           %Cooling Constant
T=86 ;           % Initial Temperature
t=0   ;
Ts=17;           %Surrounding Temperature
h=0.1  ;         %Step Size
nsteps=300  ;
for i=0:nsteps
   fprintf('%0.2f   %0.3f\n',t,T)
   dT=-r*h*(T-Ts)  ;
   T=T+dT   ;
   t=t+h;
end
plot(t,T)
I need to store the variables into an array, so that I can print it out, not just the last point of the loop.
second: if I want to add cream at the beginning: I need to subtract 5 from the second element.
Third: if I want to add cream at the end: I need to subtract 5 from the last element.
آخر مواضيعي 0 plot inside loop!!!
0 Calculus Concepts and Contexts 2nd Ed solutions
0 Need General Chemistry Student Solutions Manual,by Darrell D. Ebbing
0 Guys, You must check this website 4 Eng.!!
رد مع اقتباس
قديم 07-02-2010, 11:24 PM   رقم المشاركة : [2 (permalink)]
الصورة الرمزية Abdurauf
Abdurauf متميز
t=0 ;
Ts=17;
h=0.1 ; %Step Size
nsteps=300 ;
for i=0:nsteps
fprintf(
dT=-r*h*(T(i+1)-Ts) ;
T(i+2)=T(i+1)+dT ;
t(i+2)=t(i+1)+h;
end
plot(t,T)
t
T
Abdurauf غير موجود حالياً   رد مع اقتباس
قديم 07-02-2010, 11:32 PM   رقم المشاركة : [3 (permalink)]
beho86
Hello Abdurauf,
It worked well, I just made a small change, in the print statement:
r=0.2; T=86 ; t=0 ; Ts=17; h=0.1 ; nsteps=3000 ;
for i=0:nsteps
T(i+2)=T(i+1)+dT ;
t(i+2)=t(i+1)+h;
fprintf('%0.2f %0.3f\n',t(i+1),T(i+1))
end
plot(t,T)
Now, how the program will differs, when I add the cream at the beginning or at the end of the 5 min?!
Beginning, I should subtract 5 from the first cell, and update the rest of the cells.
End, subtract 5 from the last cell only.
Thanks so much for your help
التعديل الأخير تم بواسطة beho86 ; 08-02-2010 الساعة 12:46 AM. سبب آخر: update
beho86 غير موجود حالياً   رد مع اقتباس
قديم 09-02-2010, 10:07 PM   رقم المشاركة : [4 (permalink)]
الصورة الرمزية أسماء الكون
أسماء الكون يستحق التميز
تستطيع مباشرة أن تضع :
t=0:0.1:30
بدون إدخالها في الحلقة التكرارية
أسماء الكون غير موجود حالياً   رد مع اقتباس
inside, loop!!!, plot
المواضيع المتشابهة
ANSYS Example: Axisymmetric Analysis of a Pressure Vesse Eng-Faten الهندسة الميكانيكية - عام 7 14-02-2010 12:32 PM
close loop speed control اسلام محمد البطران الهندسة الكهربائية - عام 0 12-10-2009 10:37 PM
Log Plot أوج الهندسة الهندسة المـدنيـة - عام 2 11-09-2009 04:42 PM
urgent: for loop :( u.student برنامج الـ Matlab 7 23-06-2009 04:01 AM
"Natural" Antennas علي العزام الهندسة الكهربائية - عام 0 14-04-2008 04:00 PM
الساعة الآن 06:17 PM.
