مساحة إعلانية  | |
من لديه الكراك ..أستاذ أنس متعودين على أفضالك وخبرتك هذا البرنامج لمستخدمي الايتابس والساب . يحلل الوصلات المعدنية ويرسمها. وجزاك الله خيرا ولكل من يسعى بايجاد الكراك
EC PRAXIS 3J is an entirely new software application, for the analysis and design of steel connections according to EC3. It is a powerful tool which can function either as a stand-alone application or in combination with ETABS or SAP2000 (EC PRAXIS 3J for ETABS or for SAP2000). It covers a wide variety of steel connections while the easy and fully parametric data input, the 3D view of the connection (in Open GL), the detailed results report and the automatically created drawings (in .dxf format) undoubtedly make it one of the most trustworthy and user-friendly programs in the market today. In the newly released v3.0 (fully compatible with MS Windows 2000/XP/Vista) EC PRAXIS 3J is ideal for the design of: Base plate connection Beam to column connection with double angle cleat Beam to column connection with end plate Beam to column connection with fin plate Beam to beam connection with double angle cleat Beam splices with endplates connection Flange and web plates beam splice connection Bracing connection (including hollow profiles) Hollow profile members connection (under development).
Software Screen Shot
Related Software
ms windows 2000 column connection web plates hollow profiles steel connections etabs double angle sap2000 parametric data 3j cleat 3d view splices data input software application flange new software ec praxis drawings
