النتائج 1 إلى 7 من 7
    Received: 41
    Given: 17
    Thumbs up بعض الاختصارات المتعلقه بحساسات بالسيارات
    AFC - Air Flow Control
    ALDL - Assembly Line Diagnostic Link. Former name for GM (only) Data Link Connector, the connector socket into which the scan tool plug is inserted; sometimes used to refer to any pre-OBD II signals
    CAN - Controller Area Network
    CARB - California Air Resources Board
    CFI - Central Fuel Injection (a.k.a. Throttle Body Fuel Injection TBI
    CFI - Continuous Fuel Injection
    CO - Carbon Monoxide
    DLC - Data Link Connector
    Driving Cycle - A specific sequence of start-up, warm-up and driving tasks that tests all OBD II functions
    DTC - Diagnostic Trouble Code
    ECM - Engine Control Module - usually the main on-board computer controlling emissions and engine operation
    EEC - Electronic Engine Control
    EEPROM or E2PROM - Electrically Erasable Programmable Read Only Memory
    EFI - Electronic Fuel Injection
    EGR - Exhaust Gas Recirculation
    EMR - Electronic Module Retard
    EPA - Environmental Protection Agency. Federal agency. Office of Mobile Sources is the branch concerned with auto emissions
    ESC - Electronic Spark Control
    EST - Electronic Spark Timing
    Fuel Trim - Engine computer function that keeps the air/fuel mixture
    as close to the ideal 14.7:1 stoichiometric ratio as possible
    HC - Hydrocarbons
    HEI - High Energy Ignition
    HO2S - Heated Oxygen Sensor
    ISO9141 - International Standards Organization OBD II communication mode, used by Chrysler and most foreign cars. One of three hardware layers defined by OBD II
    ISO14230 - See Keyword Protocol 2000
    J1850PWM - (Pulse Width Modulated) SAE-established OBD II communication standard used by Ford domestic cars and light trucks. One of three hardware layers defined by OBD II
    J1850VPW - (Variable Pulse Width Modulated) SAE-established OBD II communication standard used by GM cars and light trucks. One of three hardware layers defined by OBD II
    J1962 - SAE-established standard for the connector plug layout used for all OBD II scan tools
    J1978 - SAE-established standard for OBD II scan tools
    J1979 - SAE-established standard for diagnostic test modes
    J2012 - SAE-established standard accepted by EPA as the standard test report language for emission tests
    KWP2000 - (Keyword Protocol 2000) SAE-established OBD II communication standard used by some import cars. One of five hardware layers defined by OBD II
    MAF - Mass Air Flow
    MAP - Manifold Absolute Pressure
    MAT - Manifold Air Temperature
    MIL - Malfunction Indicator Light. The "Check Engine Light" on your dash.
    NOx - Oxides of Nitrogen
    O2 - Oxygen
    OBD - On-Board Diagnostics
    OBD II or OBD II - Updated On-Board Diagnostics standard effective in cars sold in the US after 1-1-96
    Parameters - Readings on scan tools representing functions measured by OBD II and proprietary readings
    PCM - Powertrain Control Module, the on-board computer that
    controls engine and drive train
    PCV - Positive Crankcase Ventilation
    Proprietary Readings - Parameters shown by on-board computers which are not required by OBD II, but included by manufacturer to assist in trouble-shooting specific vehicles.
    PTC - Pending Trouble Code
    RPM - Revolutions Per Minute
    SAE - Society of Automotive Engineers, professional organization that set the standards that EPA adopted for OBD and OBD II
    Scan Tool - Computer based read-out equipment to display OBD II parameters
    SES - Service Engine Soon dash light, not referred to as MIL
    SFI - Sequential Fuel Injection
    Stoichiometric (Stoy'-kee-o-metric) Ratio - Theoretical perfect combustion ratio of 1 part gas to 14.7 parts air
    TBI - Throttle Body Injection
    TPI - Tuned Port Injection
    TPS - Throttle Position Sensor
    VAC - Vacuum
    VCM - Vehicle Control Module, the on-board computer that oversees engine management, transmission operation, anti-lock brakes and other functions not directly related to emissions control
    VIN - Vehicle Identification Number
    VSS - Vehicle Speed Sensor
    WOT - Wide Open Throttle
    الصورة الرمزية مهندس حطاب
    تشكر على مجهودك الرااااااااااااااائع
    لا اله الا انت سبحانك اني كنت من الظالمين
    مشرف داعم للملتقى
    الصورة الرمزية العقاب الهرم
    Received: 41
    Given: 17
    شكرا على مرورك اخى
    بشار سيمُـوت ولن تمُت حِمص
    متغيب عن المنتدى
    دعواتكم
    thanks for all your great information
    الصورة الرمزية صلاح الجبوري
    شكرا على هذه المعلومات القيمة وبارك الله فيك اخي
    مشرف داعم للملتقى
    Received: 41
    Given: 17
    اقتباس المشاركة الأصلية كتبت بواسطة fofocom4 مشاهدة المشاركة
    اقتباس المشاركة الأصلية كتبت بواسطة صلاح الجبوري مشاهدة المشاركة
    شكرا على مروركم اخوتى الكرام
    دمتم بالف خير
    متغيب عن المنتدى
    دعواتكم
    عضو متميز جداً
    الصورة الرمزية صلاح الفهد
    طه
    أنعم الله عليك ( بعدما تقول نعم )
    انت رائع والله ... كنت مدفون فين المدة اللي راحت
    لا إله إلا الله محمد رسول الله
    URL="http://www.arab-eng.org/vb"][/URL
