دورة إدارة المشاريع الاحترافية PMP
آخر المواضيع الجديدة
النتائج 1 إلى 9 من 9
Mvx ثاني اكسيد التيتانيوم - النانو تكنولوجي
الفصل الاول History of TiO2 The element Titanium was discovered in 1791 by William Gregor, in England. Gregor spent much
  1. #1
    ahmeed19700 Don't Avatar
    تاريخ التسجيل
    Nov 2008
    صفحة الملتقى الرسمية على الفيس بوك .. مجموعة المهندسين العرب .. follow us on twitter...
    الفصل الاول
    History of TiO2
    The element Titanium was discovered in 1791 by William Gregor, in England. Gregor spent much of his time studying mineralogy, which led him to his discovery. This happened when he discovered a sample of a black sandy substance in his neighborhood. He studied this substance and after he was assured that it was a mineral, he called it menachanite. Four years later a man named Martin H. Klaproth, recognized that there was a new chemical element in this mineral, he later named it Titanium after the Titans, which were humongous monsters that ruled the world in Greek mythology. Martin H. Klaproth was not able to make the pure element of titanium however, he was only able to produce TiO2, or Titanium Dioxide.
    Titanium dioxide (TiO2) is a multifaceted compound. It's the stuff that makes toothpaste white and paint opaque. TiO2 is also a potent photocatalyst that can break down almost any organic compound when exposed to sunlight, and a number of companies are seeking to capitalize on TiO2's reactivity by developing a wide range of environmentally beneficial products, including self-cleaning fabrics, auto body finishes, and ceramic tiles. Also in development is a paving stone that uses the catalytic properties of TiO2 to remove nitrogen oxide from the air, breaking it down into more environmentally benign substances that can then be washed away by rainfall. Other experiments with TiO2 involve removing the ripening hormone ethylene from areas where perishable fruits, vegetables, and cut flowers are stored; stripping organic pollutants such as trichloroethylene and methyl -tert-butyl ether from water; and degrading toxins produced by blue-green algae.
    Titanium dioxide is a well-known photo catalyst for water and air treatment as well as for catalytic production of gases. The general scheme for the photo catalytic destruction of organics begins with its excitation by suprabandgap photons, and continues through redox reactions where OH radicals, formed on the photo catalyst surface, play a major role.
    Titanium dioxide is non-toxic and therefore is used in cosmetic products (sunscreens, lipsticks, body powder, soap, pearl essence pigments, tooth pastes) and also in special pharmaceutics. Titanium dioxide is even used in food stuffs, for instance in the wrapping of salami. Small amounts added to cigar tobacco are the cause of the white ash cigar smokers so cherish.
    إذا كان الموضوع مقبولا اريد الردود للمزيد
    وهناك باقي الفصول من هذا الموضوع
    الموضوع يهم المهتمون بالتعقيم والتطهير
    ومهم جدا
    وانا في انتظار الردود
    من مواضيع ahmeed19700 :
  2. #2
    عضو فعال الصورة الرمزية حسام ح
    تاريخ التسجيل
    Dec 2007
    مشكوررررررررررر
    من مواضيع حسام ح :
  3. #3
    نيرفانا Don't Avatar
    تاريخ التسجيل
    Jan 2007
    مشكووور فقط كنت اريد ان اعرف موصلية ثانى اكسيد التيتانيوم الكهربية
    electrical conductivity
    من مواضيع نيرفانا :
  4. #4
    عضو متميز الصورة الرمزية ابو يوسف
    تاريخ التسجيل
    Jul 2009
    يعتبر ثاني أكسيد التيتانيوم أهم ملون (pigment) أبيض معروف في صناعة البلاستيك و الدهانات ، و ترجع أهميته إلى قدرته العالية على عكس الأشعة المرئية مما يعطي بياض و لمعة و قدرة عالية على التغطية . و يتوافر ثاني أكسيد التيتانيوم تجاريا على صورتين بلوريتين ، أناتاس (anatase) و روتايل (rutile) .
    و يفضل الروتايل لقدرته الأعلى على عكس الضوء كما أنه أكثر أستقرارا من الأناتاس. و أغلب ثاني أكسيد التيتانيوم المتاح تجاريا يقسم بناءا على حجم حبيباته و التركيب الكيميائي لسطحه . أغلب الأصناف المتاحة تجاريا تعالج بمواد غير عضوية و أحيانا عضوية . و يضاف عليها عادتا السيليكا و الألومينا و التي تساعد على الإنتشار في الماء و بعض المذيبات العضوية .
    لماذا ثاني أكسيد التيتانيوم بالذات ؟؟
    من المواد المبيضة الشهيرة الليثيبون ، أكسيد الزنك ، كبريتات الزنك ، و حتى كربونات الكالسيوم . و لكن رغم أن ثاني أكسيد التيتانيوم أغلى كثيرا من كل هذه المواد إلا أنه نظرا لبياضه الشديد و تغطيته العالية ، فإنه أفضل هذه المواد خاصتا في الخلطات عالية البياض .
    كيف يصنع ثاني أكسيد التيتانيوم ؟؟
    يصنع ثاني أكسيد التيتانيوم بإحدى طرقتين صناعيتين ، طريقة الكبريتيك و طريقة الكلوريد ، و كلا الطريقتين يمكن أن يستخدموا في صناعة الروتايل و الأناتاس .
    و قد أصبحت طريقة الكلوريد هي الأكثر إنتشارا نظرا لقلة الفاقد منها و جودة المنتج النهائي .
    طريقة الكبريتيك :
    أستخدمت هذه الطريقة للمرة الأولى في 1931 لإنتاج الأناتاس و لاحقا الروتايل و يتم في هذه الطريق إذابة السبيكة الحاوية على معدن التيتانيوم في حمض الكبريتيك المركز مما يعطي محلول حاوي على خليط من التيتانيوم و الحديد و بعض المعادن الأخرى ذائبة على شكل كبريتات .ثم يتم عمل إختذال لهذا الخليط ثم يتم تنقيته و عمل بلورة ينتج عنها فصل محلول كبريتات الحديدوز ، ثم يتم ترسيب ثاني أكسيد التيتانيوم المتبلور ثم يفلتر و يغسل. بعد ذلك يتم تحميصه للتحكم في حجم بلوراته و شكلها ، و يتم بعد ذلك إضافة الإضافات المناسبة للسطح ثم يفلتر و يغسل ثم يجفف . يطحن بعد ذلك ثم يعبأ في شكائر .
    fetio3 + 2 h2so4 à tioso4 + feso4 + 2 h2o
    tioso4 + h2o à tio2 + h2so4
    ‘طريقة الكلوريد :
    أستخدمت هذه الطريقة للمرة الأولى سنة 1950 لإنتاج الروتايل . يتم في هذه الطريقة إجراء تفاعل جاف بين الخام الحاوي على التيتانيوم و غاز الكلورين و الكربون في حرارة عالية و تحت ظروف خاصة لكي ينتج رباعي كلوريد التيتانيوم و بعض كلورات الحديد و المعادن الأخرى ، يتم بعد ذلك فصل رباعي كلوريد التيتانيوم المترسب و تنقيته ثم يتم أكسدته بالأكسجين في حرارة عالية ، و هذه العملية هي التي تحدد حجم البلورات الناتجة و توزيعها و شكلها .
    2 fetio3 + 7 cl2 + 3 c à 2 ticl4 + 2 fecl3 + 3 co2
    ticl4 + o2 à tio2 + 2 cl2
    و اليوم يزيد حجم الإنتاج الناتج من طرقة الكلورين عن حجم الناتج عن طريقة الكبريتيك .
    تنتشر خامة التيتانيوم في العالم بكميات صغيرة و تحتاج إلى معاملات صعبة للإستخراج بسعر تجاري
    من مواضيع ابو يوسف :
  5. #5
    مشرف الهندسة الكيميائية
    مهندس المحبة Don't Avatar
    تاريخ التسجيل
    Dec 2007
    السلام عليكم أخي العزيز
    في البداية أود الترحيب بك بين أخوانك وإن شاء الله نرى المزيد من مواضيعك القيمة وبارك الله فيك ووفقك لعمل الخير دوما .......
    من مواضيع مهندس المحبة :
  6. #6
    ossass73 Don't Avatar
    تاريخ التسجيل
    Jan 2011
    اشكرك بشده على موضوعك الجميل لكن هناك سؤال هل ثانى اكسيد التيتانيم الصين جيد تسوقيا ام هناك انواع اخرى اجود منه وبفس اسعاره
  7. #7
    رناحميد Don't Avatar
    تاريخ التسجيل
    Sep 2009
    مشكور..................
    من مواضيع رناحميد :
  8. #8
    samar elmekkawi Don't Avatar
    تاريخ التسجيل
    Feb 2011
    هل يستعمل الروتايل فقط في صناعة الطلاء أم يستعمل ايضا الناتاس؟
    ولكم جزيل الشكر
    من مواضيع رناحميد :
  9. #9
    سمير حسن الملاح Don't Avatar
    تاريخ التسجيل
    Jul 2011
    من فضلك الاقى اكسيد التيتانيوم فى مصر وشكرا
    من مواضيع رناحميد :
المواضيع المتشابهه
  1. هندسة النانو تكنولوجي
    بواسطة ابو عزام f16 في المنتدى هندسة التقانات الحيوية
    مشاركات: 8
    آخر مشاركة: 08-09-2012, 08:57 PM
  2. النانو تكنولوجي
    بواسطة هانى شرف الدين في المنتدى هندسة الفلزات والمواد
    مشاركات: 70
    آخر مشاركة: 03-08-2012, 03:18 PM
  3. منتدى النانو تكنولوجي
    بواسطة ابو عزام f16 في المنتدى الهندسة الصناعية
    مشاركات: 3
    آخر مشاركة: 13-10-2010, 08:22 AM
  4. علم النانو تكنولوجي
    بواسطة محمد عبد الواسطي في المنتدى الهندسة الكيميائية - عام
    مشاركات: 0
    آخر مشاركة: 26-05-2009, 09:53 PM
ضوابط المشاركة
  • لا تستطيع إضافة مواضيع جديدة
  • لا تستطيع الرد على المواضيع
  • لا تستطيع إرفاق ملفات
  • لا تستطيع تعديل مشاركاتك
عن ملتقى المهندسين العرب
    يُعتبر ملتقى المهندسين العرب من أوائل وأكبر المواقع الهندسية حيث تم تأسيسه منذ عام 2001م ويهدف إلى نشر المعرفة الهندسية وتقديم كل ما له فائدة للمهندسين والمهتمين من خلال أقسامة العلمية والهندسية المتعددة بالإضافة إلى وجود أقسام عامة تستقطب الكثير لمختلف النقاشات الهادفة.
مواقع صديقة
تابعنا على
Twitter Facebook
The owner and operator of the site is not responsible for the availability of, or any content provided.
Topics that are written in the site reflect the opinion of the author.
Search Engine Optimization by vBSEO
